I seem to be having a strange issue with my RB1200 where I start seeing 25%+ PL mostly in the evenings over the past few days.
I did think I might have somehow caused a switching loop as I have 2 Uplinks to the Rack Switch one on ETH9 and on on ETH10 but even if I disable one of the ports and switch both the subnets to be routed over 1 port I still end up with a lot of packetloss.
The RB handles 1x /27 and 1x /28
There are 2 SSTP tunnels connected permanently but neither push much traffic, sometimes I'll SSTP in from a laptop if im on a public wi-fi but otherwise very little traffic at all on this RB.
Weird thing is it's been happening over the last few days i'd not noticed it previously.
Been looking into this and it seems to be just me that's having the problem other stuff in the same rack on the same switch i'm connected to is fine.
I have some latency/throughput graphs from various locations, including a server in the same rack (Smokeping) the RB is very lightly loaded.
I'm thinking of trying to get one of the connections to the Rack switch moved to alower port as I've seen posts before that suggest ports 9 and 10 on a 1200 can be a bit funny sometimes.
http://imgur.com/a/0VjBe - for various Latency/Throughput graphs for the last few days. (Used Imgur for simplicity)
Edit:
Forgot to mention Software version sorry, it's 5.14
