Should have put in the version I tried this on - 5.14
I have an interface in a IPv4 VRF and the IPv4 routes are show with the correct routing mark and in the correct VRF. However, IPv6 routes on the same interface are not shown as /ipv6 route has no concept of the VRF. If I remove the interface from the VRF then the connected IPv6 route becomes visible:
There is no connected route on pptp-out2:
[admin@door.banana.org.uk] /ip route vrf> /ipv6 route print
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, o - ospf, b - bgp, U - unreachable
# DST-ADDRESS GATEWAY DISTANCE
0 A S ::/0 XXXX:XXX:6:2d6::1 1
1 ADC XXXX:XXX:6:2d6::/64 sit1 0
2 ADC XXXX:XXX:139::/64 ether1.11 0
3 ADC XXXX:XXX:139:1::/64 ether2 0
4 ADC XXXX:XXXX:11:2::/64 ether1.21 0
Now disable the interface in the VRF:
[admin@door.banana.org.uk] /ip route vrf> set numbers=0 disabled=yes
4 ADC XXXX:XXXX:10:1::/64 pptp-out2 0
5 ADC XXXX:XXXX:11:2::/64 ether1.21 0
Re-enable the interface into the VRF:
[admin@door.banana.org.uk] /ip route vrf> set numbers=0 disabled=no
The connected route is no longer visible again:
However the routing works whether the connected IPv6 route is visible or not.
Matt.
