• MikroTik.com
  • RouterBOARD
  • User Meeting
  • Training
  • User Manual
  • Support
  • Downloads
  • Videos
Register |   * Login | HOME
View unanswered posts | View active topics
PCC load balance...what am I doing wrong....eeep!  Page 1 of 1
 [ 3 posts ]  Post new topic Reply to topic
  Print view Previous topic | Next topic
Author Message
schiele
 Post subject: PCC load balance...what am I doing wrong....eeep!
PostPosted: Fri Apr 20, 2012 7:20 am
Offline
I have traffic passing fine out WAN1 but only a trickle going out WAN2 for some reason...anyways first time trying out PCC load balancing so I got tired of not knowing the mangle rules very confidently and how this works, i thought I would post my config for you pro's....if you can see that my config is off for the load balancing please let me know and i will see if any changes help with evening out the load over the two WAN connections, definitely lop sided as it stands.
Cheers,
# jan/02/1970 09:41:09 by RouterOS 5.12
# software id = LQWZ-A0S3
add admin-mac=00:00:00:00:00:00 ageing-time=5m arp=enabled auto-mac=yes \
disabled=no forward-delay=15s l2mtu=1598 max-message-age=20s mtu=1500 \
name=bridge1 priority=0x8000 protocol-mode=rstp transmit-hold-count=6
set 0 arp=enabled auto-negotiation=yes disabled=no full-duplex=yes l2mtu=1600 \
mac-address=00:0C:42:D2:8B:6A mtu=1500 name=ether10 speed=100Mbps
set 1 arp=enabled auto-negotiation=yes disabled=no full-duplex=yes l2mtu=1600 \
mac-address=00:0C:42:D2:8B:6B mtu=1500 name=ether9 speed=100Mbps
set 2 arp=enabled auto-negotiation=yes disabled=no full-duplex=yes l2mtu=1600 \
mac-address=00:0C:42:D2:8B:6D mtu=1500 name=ether7 speed=100Mbps
set 3 arp=enabled auto-negotiation=yes disabled=no full-duplex=yes l2mtu=1600 \
mac-address=00:0C:42:D2:8B:6C mtu=1500 name=ether8 speed=100Mbps
set 4 arp=enabled auto-negotiation=yes disabled=no full-duplex=yes l2mtu=1600 \
mac-address=00:0C:42:D2:8B:6E mtu=1500 name=ether6 speed=100Mbps
set 5 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited \
disabled=no full-duplex=yes l2mtu=1598 mac-address=00:0C:42:D2:8B:6F \
master-port=none mtu=1500 name=ether5 speed=100Mbps
set 6 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited \
disabled=no full-duplex=yes l2mtu=1598 mac-address=00:0C:42:D2:8B:70 \
master-port=none mtu=1500 name=ether4 speed=100Mbps
set 7 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited \
disabled=no full-duplex=yes l2mtu=1598 mac-address=00:0C:42:D2:8B:71 \
master-port=none mtu=1500 name=ether3 speed=100Mbps
set 8 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited \
disabled=no full-duplex=yes l2mtu=1598 mac-address=00:0C:42:D2:8B:72 \
master-port=none mtu=1500 name=WAN2 speed=100Mbps
set 9 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited \
disabled=no full-duplex=yes l2mtu=1598 mac-address=00:0C:42:D2:8B:73 \
master-port=none mtu=1500 name=WAN1 speed=100Mbps
/interface ethernet switch
set 0 mirror-source=none mirror-target=none name=switch1
/ip hotspot profile
set [ find default=yes ] dns-name="" hotspot-address=0.0.0.0 html-directory=\
hotspot http-cookie-lifetime=3d http-proxy=0.0.0.0:0 login-by=\
cookie,http-chap name=default rate-limit="" smtp-server=0.0.0.0 \
split-user-domain=no use-radius=no
add dns-name="" hotspot-address=192.168.2.1 html-directory=hotspot \
http-proxy=0.0.0.0:0 login-by=http-pap name=hsprof1 rate-limit="" \
smtp-server=64.59.128.135 split-user-domain=no use-radius=no
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m name=default \
rate-limit=384k/2066k shared-users=99 status-autorefresh=1m \
transparent-proxy=no
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha1 disabled=no enc-algorithms=3des \
lifetime=30m name=default pfs-group=modp1024
add name=pool1 ranges=192.168.2.20-192.168.2.200
add address-pool=pool1 authoritative=after-2sec-delay bootp-support=static \
disabled=no interface=bridge1 lease-time=1d name=server1
/ip hotspot
add address-pool=pool1 addresses-per-mac=2 disabled=no idle-timeout=5m \
interface=bridge1 keepalive-timeout=none name=hotspot1 profile=hsprof1
/port
set 0 baud-rate=115200 data-bits=8 flow-control=none name=serial0 parity=none \
stop-bits=1
set 1 baud-rate=115200 data-bits=8 flow-control=none name=serial1 parity=none \
stop-bits=1
/ppp profile
set 0 change-tcp-mss=yes name=default only-one=default use-compression=\
default use-encryption=default use-mpls=default use-vj-compression=\
default
set 1 change-tcp-mss=yes name=default-encryption only-one=default \
use-compression=default use-encryption=yes use-mpls=default \
use-vj-compression=default
/queue type
set 0 kind=pfifo name=default pfifo-limit=50
set 1 kind=pfifo name=ethernet-default pfifo-limit=50
set 2 kind=sfq name=wireless-default sfq-allot=1514 sfq-perturb=5
set 3 kind=red name=synchronous-default red-avg-packet=1000 red-burst=20 \
red-limit=60 red-max-threshold=50 red-min-threshold=10
set 4 kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=5
set 5 kind=none name=only-hardware-queue
set 6 kind=mq-pfifo mq-pfifo-limit=50 name=multi-queue-ethernet-default
set 7 kind=pfifo name=default-small pfifo-limit=10
/routing bgp instance
set default as=65530 client-to-client-reflection=yes disabled=no \
ignore-as-path-len=no name=default out-filter="" redistribute-connected=\
no redistribute-ospf=no redistribute-other-bgp=no redistribute-rip=no \
redistribute-static=no router-id=0.0.0.0 routing-table=""
/routing ospf instance
set [ find default=yes ] disabled=no distribute-default=never in-filter=\
ospf-in metric-bgp=auto metric-connected=20 metric-default=1 \
metric-other-ospf=auto metric-rip=20 metric-static=20 name=default \
out-filter=ospf-out redistribute-bgp=no redistribute-connected=no \
redistribute-other-ospf=no redistribute-rip=no redistribute-static=no \
router-id=0.0.0.0
/routing ospf area
set [ find default=yes ] area-id=0.0.0.0 disabled=no instance=default name=\
backbone type=default
/snmp community
set [ find default=yes ] address=70.76.64.215/32 authentication-password="" \
authentication-protocol=MD5 encryption-password="" encryption-protocol=\
DES name=public read-access=yes security=none write-access=no
/system logging action
set 0 memory-lines=100 memory-stop-on-full=no name=memory target=memory
set 1 disk-file-count=2 disk-file-name=log disk-lines-per-file=100 \
disk-stop-on-full=no name=disk target=disk
set 2 name=echo remember=yes target=echo
set 3 bsd-syslog=no name=remote remote-port=514 syslog-facility=daemon \
syslog-severity=auto target=remote
/user group
set read skin=default
set write skin=default
set full skin=default
add bridge=bridge1 disabled=no edge=auto external-fdb=auto horizon=none \
interface=ether3 path-cost=10 point-to-point=auto priority=0x80
interface=ether4 path-cost=10 point-to-point=auto priority=0x80
interface=ether5 path-cost=10 point-to-point=auto priority=0x80
/interface bridge settings
set use-ip-firewall=no use-ip-firewall-for-pppoe=no use-ip-firewall-for-vlan=\
no
set 0 vlan-header=leave-as-is vlan-mode=fallback
set 1 vlan-header=leave-as-is vlan-mode=fallback
set 2 vlan-header=leave-as-is vlan-mode=fallback
set 3 vlan-header=leave-as-is vlan-mode=fallback
set 4 vlan-header=leave-as-is vlan-mode=fallback
set 5 vlan-header=leave-as-is vlan-mode=fallback
/interface l2tp-server server
set authentication=pap,chap,mschap1,mschap2 default-profile=\
default-encryption enabled=no max-mru=1460 max-mtu=1460 mrru=disabled
/interface ovpn-server server
set auth=sha1,md5 certificate=none cipher=blowfish128,aes128 default-profile=\
default enabled=no keepalive-timeout=60 mac-address=FE:98:4A:79:C9:13 \
max-mtu=1500 mode=ip netmask=24 port=1194 require-client-certificate=no
/interface pptp-server server
set authentication=mschap1,mschap2 default-profile=default-encryption \
enabled=no keepalive-timeout=30 max-mru=1460 max-mtu=1460 mrru=disabled
/interface sstp-server server
set authentication=pap,chap,mschap1,mschap2 certificate=none default-profile=\
default enabled=no keepalive-timeout=60 max-mru=1500 max-mtu=1500 mrru=\
disabled port=443 verify-client-certificate=no
/ip accounting
set account-local-traffic=no enabled=no threshold=256
/ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
add address=70.64.252.233/24 disabled=no interface=WAN1 network=70.64.252.0
add address=192.168.2.1/24 disabled=no interface=bridge1 network=192.168.2.0
add address=71.17.11.213/24 disabled=no interface=WAN2 network=71.17.11.0
/ip dhcp-server config
set store-leases-disk=5m
add address=192.168.2.0/24 dhcp-option="" dns-server="" gateway=192.168.2.1 \
ntp-server="" wins-server=""
set allow-remote-requests=yes cache-max-ttl=1w cache-size=5000KiB \
max-udp-packet-size=512 servers=4.2.2.2,8.8.8.8
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s \
tcp-close-wait-timeout=10s tcp-established-timeout=1d \
tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s \
tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no \
tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
add action=passthrough chain=unused-hs-chain comment=\
"place hotspot rules here" disabled=yes
/ip firewall mangle
add action=mark-connection chain=input disabled=no in-interface=WAN1 \
new-connection-mark=WAN1_conn passthrough=yes
add action=mark-connection chain=input disabled=no in-interface=WAN2 \
new-connection-mark=WAN2_conn passthrough=yes
add action=mark-routing chain=output connection-mark=WAN1_conn disabled=no \
new-routing-mark=to_WAN1 passthrough=yes
add action=mark-routing chain=output connection-mark=WAN2_conn disabled=no \
new-routing-mark=to_WAN2 passthrough=yes
add action=accept chain=prerouting disabled=no dst-address=70.64.252.0/24 \
in-interface=bridge1
add action=accept chain=prerouting disabled=no dst-address=71.17.11.0/24 \
add action=mark-connection chain=prerouting disabled=no dst-address-type=\
local in-interface=bridge1 new-connection-mark=WAN1_conn passthrough=yes \
per-connection-classifier=src-address:2/0
local in-interface=bridge1 new-connection-mark=WAN2_conn passthrough=yes \
per-connection-classifier=src-address:2/1
add action=mark-routing chain=prerouting connection-mark=WAN1_conn disabled=\
no in-interface=bridge1 new-routing-mark=to_WAN1 passthrough=yes
add action=mark-routing chain=prerouting connection-mark=WAN2_conn disabled=\
no in-interface=bridge1 new-routing-mark=to_WAN2 passthrough=yes
add action=masquerade chain=srcnat disabled=no out-interface=WAN1
add action=masquerade chain=srcnat disabled=no out-interface=WAN2
add action=masquerade chain=srcnat comment="masquerade hotspot network" \
disabled=no src-address=192.168.2.0/24
add action=dst-nat chain=dstnat disabled=no dst-port=9000 in-interface=WAN1 \
protocol=tcp to-addresses=192.168.2.113 to-ports=9000
add action=dst-nat chain=dstnat disabled=no dst-port=113 in-interface=WAN1 \
protocol=tcp to-addresses=192.168.2.113 to-ports=80
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061 sip-direct-media=yes
set pptp disabled=no
/ip hotspot ip-binding
add address=192.168.2.4 disabled=no mac-address=00:0C:42:08:6D:50 to-address=\
192.168.2.4 type=bypassed
add address=192.168.2.2 disabled=no mac-address=00:0C:42:14:0D:30 server=\
hotspot1 to-address=192.168.2.2 type=bypassed
add address=192.168.2.3 disabled=no mac-address=00:0C:42:08:6D:54 server=\
hotspot1 to-address=192.168.2.3 type=bypassed
add address=192.168.2.5 disabled=no mac-address=00:0C:42:14:0D:2E server=\
hotspot1 to-address=192.168.2.5 type=bypassed
add address=192.168.2.113 comment=DVR disabled=no mac-address=\
00:18:F5:01:72:F2 server=hotspot1 to-address=192.168.2.113 type=bypassed
add address=192.168.2.35 comment="Federal PC worker" disabled=no mac-address=\
00:1C:C4:C9:25:21 server=hotspot1 to-address=192.168.2.35 type=bypassed
add address=192.168.2.194 comment="CRA Federal Worker" disabled=no \
mac-address=00:1C:C4:C9:33:8E server=hotspot1 to-address=192.168.2.194 \
type=bypassed
add address=192.168.2.67 comment="Room 405" disabled=no mac-address=\
00:13:E8:9D:C6:11 server=hotspot1 to-address=192.168.2.67
add address=192.168.2.35 comment="Rm 219" disabled=no mac-address=\
00:1D:60:AA:A6:E0 server=hotspot1
add address=192.168.2.60 disabled=no mac-address=00:25:D3:6F:EC:DD type=\
bypassed
add disabled=no mac-address=0C:60:76:4F:41:34
add disabled=no mac-address=00:1D:D8:B4:7B:90 type=bypassed
add disabled=no mac-address=00:24:2C:1B:86:25 type=bypassed
add disabled=no mac-address=68:A3:C4:08:A4:F2 type=bypassed
add disabled=no mac-address=68:A3:C4:7E:42:8C
add disabled=no mac-address=00:24:E8:B7:1F:F9 type=bypassed
add disabled=no mac-address=AC:81:12:33:37:9A type=bypassed
add address=192.168.2.22 disabled=no mac-address=00:23:12:03:49:74 server=\
hotspot1 to-address=192.168.2.22 type=bypassed
add address=192.168.2.198 disabled=no mac-address=4C:ED:DE:2C:BA:18 server=\
hotspot1 to-address=192.168.2.198 type=bypassed
add address=192.168.2.105 disabled=no mac-address=60:C5:47:08:2A:68 type=\
bypassed
add address=192.168.2.143 disabled=no mac-address=4C:0F:6E:0F:53:EB server=\
hotspot1 to-address=192.168.2.143 type=bypassed
/ip hotspot service-port
/ip hotspot user
add disabled=no name=admin password=******** profile=default
add disabled=no name=generic_user password=generic_password profile=default
/ip hotspot walled-garden
add action=allow disabled=no dst-host=suitesolutions.ca dst-port=""
add action=allow disabled=no dst-host=www.suitesolutions.ca dst-port=""
add action=allow disabled=no dst-host=statcounter.com dst-port=""
add action=allow disabled=no dst-host=http://statcounter.com dst-port=""
add action=allow disabled=no dst-host=http://c.statcounter.com dst-port=""
add action=allow disabled=no dst-host=c.statcounter.com dst-port=""
add action=allow disabled=no dst-host=www.c.statcounter.com dst-port=""
add action=allow disabled=no dst-host=www.statcounter.com dst-port=""
add action=allow disabled=no dst-host=http://www.statcounter.com dst-port=""
/ip neighbor discovery
set ether10 disabled=no
set ether9 disabled=no
set ether7 disabled=no
set ether8 disabled=no
set ether6 disabled=no
set ether5 disabled=no
set ether4 disabled=no
set ether3 disabled=no
set WAN2 disabled=no
set WAN1 disabled=no
set bridge1 disabled=no
/ip proxy
set always-from-cache=no cache-administrator=webmaster cache-hit-dscp=4 \
cache-on-disk=no enabled=no max-cache-size=none max-client-connections=\
600 max-fresh-time=3d max-server-connections=600 parent-proxy=0.0.0.0 \
parent-proxy-port=0 port=8080 serialize-connections=no src-address=\
0.0.0.0
add check-gateway=ping disabled=no distance=1 dst-address=0.0.0.0/0 gateway=\
70.64.252.1 routing-mark=to_WAN1 scope=30 target-scope=10
71.17.11.254 routing-mark=to_WAN2 scope=30 target-scope=10
71.17.11.254 scope=30 target-scope=10
add check-gateway=ping disabled=no distance=2 dst-address=0.0.0.0/0 gateway=\
70.64.252.1 scope=30 target-scope=10
/ip service
set telnet address="" disabled=no port=23
set ftp address="" disabled=yes port=21
set www address="" disabled=yes port=80
set ssh address="" disabled=yes port=22
set www-ssl address="" certificate=none disabled=yes port=443
set api address="" disabled=yes port=8728
set winbox address="" disabled=no port=8291
/ip smb
set allow-guests=yes comment=MikrotikSMB domain=MSHOME enabled=no interfaces=\
all
/ip smb shares
set [ find default=yes ] comment="default share" directory=/pub disabled=no \
max-sessions=10 name=pub
/ip smb users
set [ find default=yes ] disabled=no name=guest password="" read-only=yes
/ip socks
set connection-idle-timeout=2m enabled=no max-connections=200 port=1080
/ip traffic-flow
set active-flow-timeout=30m cache-entries=4k enabled=no \
inactive-flow-timeout=15s interfaces=all
/ip upnp
set allow-disable-external-interface=yes enabled=no show-dummy-rule=yes
/mpls
set dynamic-label-range=16-1048575 propagate-ttl=yes
/mpls interface
set [ find default=yes ] disabled=no interface=all mpls-mtu=1508
/mpls ldp
set distribute-for-default-route=no enabled=no hop-limit=255 loop-detect=no \
lsr-id=0.0.0.0 path-vector-limit=255 transport-address=0.0.0.0 \
use-explicit-null=no
/port firmware
set directory=firmware
/ppp aaa
set accounting=yes interim-update=0s use-radius=no
/queue interface
set ether10 queue=ethernet-default
set ether9 queue=ethernet-default
set ether7 queue=ethernet-default
set ether8 queue=ethernet-default
set ether6 queue=ethernet-default
set ether5 queue=ethernet-default
set ether4 queue=ethernet-default
set ether3 queue=ethernet-default
set WAN2 queue=ethernet-default
set WAN1 queue=ethernet-default
set bridge1 queue=only-hardware-queue
/radius incoming
set accept=no port=3799
/routing bfd interface
set [ find default=yes ] disabled=no interface=all interval=0.2s min-rx=0.2s \
multiplier=5
/routing mme
set bidirectional-timeout=2 gateway-class=none gateway-keepalive=1m \
gateway-selection=no-gateway origination-interval=5s preferred-gateway=\
0.0.0.0 timeout=1m ttl=50
/routing rip
set distribute-default=never garbage-timer=2m metric-bgp=1 metric-connected=1 \
metric-default=1 metric-ospf=1 metric-static=1 redistribute-bgp=no \
redistribute-connected=no redistribute-ospf=no redistribute-static=no \
routing-table=main timeout-timer=3m update-timer=30s
/snmp
set contact="" enabled=no engine-id="" location="" trap-generators="" \
trap-target="" trap-version=1
/system clock
set time-zone-name=manual
/system clock manual
set dst-delta=+00:00 dst-end="jan/01/1970 00:00:00" dst-start=\
"jan/01/1970 00:00:00" time-zone=+00:00
/system console
set [ find port=serial0 ] disabled=no port=serial0 term=vt102
/system identity
set name=gateway
/system logging
set 0 action=memory disabled=no prefix="" topics=info
set 1 action=memory disabled=no prefix="" topics=error
set 2 action=memory disabled=no prefix="" topics=warning
set 3 action=echo disabled=no prefix="" topics=critical
/system note
set note="" show-at-login=yes
/system ntp client
set enabled=no mode=broadcast primary-ntp=0.0.0.0 secondary-ntp=0.0.0.0
/system resource irq
set 0 cpu=auto
set 1 cpu=auto
set 2 cpu=auto
set 3 cpu=auto
set 4 cpu=auto
set 5 cpu=auto
set 6 cpu=auto
set 7 cpu=auto
set 8 cpu=auto
set 9 cpu=auto
set 10 cpu=auto
set 11 cpu=auto
set 12 cpu=auto
set 13 cpu=auto
/system routerboard settings
set baud-rate=115200 boot-delay=2s boot-device=nand-if-fail-then-ethernet \
boot-protocol=bootp cpu-frequency=1GHz<400DDR> enable-jumper-reset=yes \
enter-setup-on=any-key force-backup-booter=no silent-boot=no
/system upgrade mirror
set check-interval=1d enabled=no primary-server=0.0.0.0 secondary-server=\
0.0.0.0 user=""
/system watchdog
set auto-send-supout=no automatic-supout=yes no-ping-delay=5m watch-address=\
none watchdog-timer=yes
/tool bandwidth-server
set allocate-udp-ports-from=2000 authenticate=yes enabled=yes max-sessions=\
100
/tool e-mail
set address=0.0.0.0 from=<> password="" port=25 user=""
/tool graphing
set page-refresh=300 store-every=5min
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=yes
/tool sms
set allowed-number="" channel=0 keep-max-sms=0 receive-enabled=no secret=""
/tool sniffer
set file-limit=1000KiB file-name="" filter-ip-address="" filter-ip-protocol=\
"" filter-mac-address="" filter-mac-protocol="" filter-port="" \
filter-stream=yes interface=all memory-limit=100KiB memory-scroll=yes \
only-headers=no streaming-enabled=no streaming-server=0.0.0.0
/tool traffic-generator
set latency-distribution-scale=10 test-id=0
/user aaa
set accounting=yes default-group=read exclude-groups="" interim-update=0s \
use-radius=no
Top
 Profile
Feklar
 Post subject: Re: PCC load balance...what am I doing wrong....eeep!
PostPosted: Fri Apr 20, 2012 6:19 pm
Offline
Code:
Either make "dst-address-type=local" into "dst-address-type=!local"(not local) or remove that firewall matcher from the rules.
Top
 Profile
schiele
PostPosted: Sat Apr 21, 2012 4:30 pm
Offline
:D
Yep...that was it!!! good eye. thank you Sir. :)
Top
 Profile
Display posts from previous:  Sort by
Post new topic Reply to topic  Page 1 of 1
 [ 3 posts ]
Board index » RouterOS » General
Users browsing this forum: 2fast4youbr, acidsas, Bing [Bot], CelticComms, docmarius, HaPe, whoknew and 37 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
cron
Powered by phpBB® Forum Software © phpBB Group
Karma functions powered by Karma MOD © 2007, 2009 m157y
