Yup, 5.15 is broken. Good results with 6.0b2one of my wireless adapters witch is set as an access point, suddenly blocks client connections and on registration table shows big numbers on "last activity" column. when i disable wireless adapter, and enable it after, everything works perfectly for couple of hours, then again the same problem. I have to mention that everything works OK with previous version.
What do you mean by sure? You have to try stuff for yourself.are you positively sure about the latest beta version?
have you contacted support about this?v 5.15 is SEVERELLY BROKEN !!! It freeze 2.4g interfaces. Clients stay associated, but interface show 0 bytes send and 0 bytes received, and no throughput to assiciated clients. I update several mikrotiks that works perfectly without 5.15 relase and I found this problem. I wish I have a 5.14 or earlier npk files. F**K !
http://forum.mikrotik.com/viewtopic.php?f=7&t=60980Hello Folks!
Do I dare to rollout ROSA5.15 on our production AP's now
All wireless is nv2 point to multipoint networks ?
Is there any who had problems also with wireless nv2 ?
We have no such problems, links are very stable (usaly they are up till next routerboard versions is loaded). We did frequence scan and correct our channel separating on all AP's also splatter effects taken in to calculus and we use directioal antennas with H polarization.http://forum.mikrotik.com/viewtopic.php?f=7&t=60980Hello Folks!
I'm not sure how many others are still seeding it, but this link still works....I wish I have a 5.14 or earlier npk files...
Checking this box will send multicast messages in unicast mode, thus greatly increasing the probability of correct delivery, since unicast packets are acknowledged by the receiver and resent if garbled.new in 5.15
/interface wireless> multicast-helper=
description ?
I downgraded from within the dude on some wireless routers 90Km away, just picked 5.14 and upgrade, guess it also works with winbox. The router restarted and 5.14 was there, no problems.To downgrade from 5.15 to 5.14 - do I have to use netinstall or will winbox do the job for me?
The problem 5.15 APs are remote and hard to get to - thus I hope I can remote downgrade to 5.14
I've got the same problem with R52H.one of my wireless adapters witch is set as an access point, suddenly blocks client connections and on registration table shows big numbers on "last activity" column. when i disable wireless adapter, and enable it after, everything works perfectly for couple of hours, then again the same problem. I have to mention that everything works OK with previous version.
That's GREAT! By the way, what glitches are you having?BTW - currently running v6beta2 on select towers - only a couple of glitches - seems to perform very well - keep up the good work MT!
Just had a glitch actually about an hour ago - AP did the same thing that v5.15 does - shows connections with a crazy time associated and does not pass traffic - reset interface and all is well. Very strange! Also had one of our primaries loose Ethernet ports but not direct RF connections. We are running v6beta2 on one primary Back-haul system that encompasses 12 back-hauls on p-t-p and p-t-mp and also quite a few secondaries and edge towers with APs.That's GREAT! By the way, what glitches are you having?BTW - currently running v6beta2 on select towers - only a couple of glitches - seems to perform very well - keep up the good work MT!
Exactly same problem wireless card AP mode stoppes after some minutes. Had to downgrade all nodes.Another screenshot on another AP.
No data on the ones with big numbers.
Run a scan on the interface and the connections are reset and they work - kick the individual connections and they reconnect but no thru-put.
Rod
seems that the version 6.x is not a new version, but an update 5.xExactly same problem wireless card AP mode stoppes after some minutes. Had to downgrade all nodes.Another screenshot on another AP.
Rod
Any idea about which bug causes this?
here: http://www.mirror.mikrotik-bg.net/?dir=v5/5.14/ ... if it's visible from outside Bulgaria.Please, Link to routeros-mipsbe-5.14.npk because I can't find it anywhere
I also have problems with IPSec, tunnel worked flawlessly for months,IPSec is broken since 5.14
You have to contact the MT support for that answer (if you are eligible to do that directly). Forum here is mostly for venting purposes.So - is there an active Mikrotik staff person looking into the 5.15 AP wlan lockup problem or is this problem so far just noted in this forum?
So why you upgraded a system that have been working for running/working for years?Version 5.15 is broken.
My AP has been running for years. I just upgraded yesterday and the problems started.
Because newer features might yield better performance? For compatibility with newer, possibly not-MT products? Just because a system works doesn't mean it is never necessary to change it.So why you upgraded a system that have been working for running/working for years?Version 5.15 is broken. My AP has been running for years. I just upgraded yesterday and the problems started.
20 days is stable and NOW is not stable5.15 has been pulled from the downloads, it seems... (?)
The bugs were stable. It's actually a good sign that they pulled it; it means they identified a definite problem.20 days is stable and NOW is not stable5.15 has been pulled from the downloads, it seems... (?)
If anyone wants to test the fixed v5.16 before we released, contact support please
In that case, you don't need to update.Currently, we are using v. 5.15 at least 2 weeks until now and found nothing about wireless problems.
yes, me too.The Mikrotik folks worked hard to get this fixed quickly, and I appreciate their efforts.
Changelog does not list anything wireless related, so apparently there isn't nothing for NV2.Dear Mikrotik,
would you please inform us if there are any improvements on nv2 wireless link stability?
