Hi all,
Does anybody tried to make ZTE MF 195 USB modem run with RouterOS. I see the modem is currently not on the supported hardwares' list. Is there any way to make it work?
Connect it, and then send a supout to support@mikrotik.com. They are the only ones that can "make" it work, if it is possible.Hi all,
