I am trying to limit speed on individual ports on a mikrotik 750G that are bridged to the wan port.
Here is the scenario:
port 1 is wan port connected to a bridged modem /w 5 IPs available.
port 2 is connected to a router I would like to limit to 3mbps/512kbps with one of the public ip's
port 3 is connected to a router I would like to limit to 1.5mbps/384kbps with one of the public ip's
Ports 1,2 and 3 are bridged.
I tried to limit it using a simple queue and assigning it to the interface which does not work.
If I setup the interface on NAT, then the queue port speed limit works... however I do not want it to be NATed
Thanks for the help.
- Jon
