jeanbrico
Erase configuration [Resolved]
Wed Jul 25, 2012 3:12 pm
I own a routerboard RB751.
I want to have an "empty" configuration (no interface configured, no IP Address, and so on): as in a virtual machine for example.
On a previous version, after a material reset, a windows permit to launch a script that clear all the config. By now (v5.14), this window don't seems to appear:
- I've put a piece of wood in the reset hole,
- I've powered off the router,
- I've powered on the router,
- I've waited all leds to switch off
- I've put out the piece of wood out of the reset hole.
I've connected to 192.168.88.1 with winbox.exe, but the windows with script don't appear.
Thanks for all.
Best regards.
CyberT
Re: Erase configuration
Wed Jul 25, 2012 3:32 pm
/system reset-configuration
then say yes, after reboot the option will apear
If this helped you then please slam that Karma button :-)
Caci99
Forum Veteran
Forum Veteran
Wed Jul 25, 2012 3:59 pm
or, even faster
/system reset-configuration no-defaults=yes
-Toni-
Don't crash the ambulance, whatever you do
jeanbrico
Wed Jul 25, 2012 10:24 pm
Yes, it works.
Thanks for all.
Users browsing this forum: effndc, RLithgo and 17 guests
