sergioser
DHCP server on bridge and Windows 7 dhcp client
Wed Oct 17, 2012 11:51 am
Hi all!
I have some incomprehensible issue with dhcp server.
I have many user vlans. For equable and dynamic IPs distribution vlans ported to bridge, with IP(gateway for all) on it. dhcp server configured o bridge interface. All working good, except Windows 7 clients - do not get IPs from dhcp. proxy-arp on access switches disabled.
How do you think, problem with dhcp on bridge?
I would appreciate for any help.
Thanks.
cbrown
Trainer
Trainer
Re: DHCP server on bridge and Windows 7 dhcp client
Wed Oct 17, 2012 2:09 pm
No, DHCP should be running on the bridge. Post /export compact
sergioser
Wed Oct 17, 2012 2:52 pm
# oct/17/2012 14:47:19 by RouterOS 5.20
# software id = 61CD-3E5K
add l2mtu=9010 name=bridge1
add l2mtu=9006 mtu=9000 name="bridge(DHCP_BIG_1)"
add l2mtu=9006 mtu=9000 name="bridge(DHCP_BIG_2)"
add disabled=yes name=bridge2
set 0 comment="UPLINK (10g to ETT)" name=ether1
set 1 comment="to Vodoginna (1G fiber)" name=ether2
set 2 comment="to Znamianka (QinQ, vlan1755)" mtu=9000
set 3 name=ether7
set 4 name=ether8
set 5 name=ether9
set 6 comment="for test (vlan3311)" name=ether10
/interface vlan
add interface=ether2 l2mtu=9010 name=vlan1111_InetLvivNAT vlan-id=1111
add interface=ether2 l2mtu=9010 name=USERS vlan-id=2222
add interface=ether2 l2mtu=9010 mtu=9000 name=SERVERS vlan-id=3333
add interface=ether1 l2mtu=9010 name=mngmt vlan-id=911
add interface=ether2 l2mtu=9010 name=vlan3311_Vodoginna vlan-id=3311
add interface=ether1 l2mtu=9010 name=ett vlan-id=1749
add interface=ether3 l2mtu=9010 mtu=9000 name=qnq vlan-id=1755
add interface=qnq l2mtu=9006 name=lvan912_mngmt2 vlan-id=912
add interface=qnq l2mtu=9006 name=vlan10_Korystivka_HP19 vlan-id=10
add interface=qnq l2mtu=9006 name=vlan7_Wifi_Chornoliska_HP27 vlan-id=7
add interface=qnq l2mtu=9006 name=vlan1100_SahZavod_HP19 vlan-id=1100
add interface=qnq l2mtu=9006 name=vlan1220_Kolos_HP19 vlan-id=1220
add interface=qnq l2mtu=9006 name=vlan17_Kononenko_HP17 vlan-id=17
add interface=qnq l2mtu=9006 name=vlan21_A1201_Chornolsska_HP27 vlan-id=21
add interface=qnq l2mtu=9006 name=vlan31_Chornoliska_HP27 vlan-id=31
add interface=qnq l2mtu=9006 name=vlan41_Siemens3_HP4 vlan-id=41
add interface=qnq l2mtu=9006 name=vlan51_Siemens2_HP5 vlan-id=51
add interface=qnq l2mtu=9006 name=vlan61_UZ_DN3_HP18 vlan-id=61
add interface=qnq l2mtu=9006 name=vlan66_Siemens4_HP10 vlan-id=66
add interface=qnq l2mtu=9006 name=vlan67_Siemens1_HP7 vlan-id=67
add interface=qnq l2mtu=9006 name=vlan71_SMP704_HP11 vlan-id=71
add interface=qnq l2mtu=9006 name=vlan72_SMEU3_HP12 vlan-id=72
add interface=qnq l2mtu=9006 name=vlan81_Pasagirska_HP8 vlan-id=81
add interface=qnq l2mtu=9006 name=vlan91_Kirovograd_HP9 vlan-id=91
add interface=qnq l2mtu=9006 name=vlan102_TV_HP26 vlan-id=102
add interface=qnq l2mtu=9006 name=vlan101_Antonov_HP20 vlan-id=101
add interface=qnq l2mtu=9006 name=vlan73_RosUkrTrans_HP13 vlan-id=73
/ip hotspot profile
add hotspot-address=192.168.192.1 name=hsprof1
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m
add name=hs-pool-8 ranges=192.168.192.2-192.168.192.254
add name=BIG_Pool_1 ranges=193.150.56.3-193.150.56.21,193.150.56.23-193.150.56.254,193.150.57.1-193.150.57.49,193.150.57.60-193.150.57.220,193.150.57.222-193.150.57.254
add name=BIG_Pool_2 ranges=193.150.58.2-193.150.58.126
add name=poolVLAN21 ranges=193.150.58.130-193.150.58.254
add name=poolVLAN1015 ranges=192.168.2.3-192.168.2.30
add name=poolVLAN91 ranges=10.10.91.2-10.10.91.254
add name=poolVLAN1100 ranges=10.10.11.2-10.10.11.254
add name=vl71_SMP704_HP-11 ranges=192.168.71.2-192.168.71.100
add name=vl72_SMEU-3_HP-12 ranges=192.168.72.2-192.168.72.100
add name=vl81_Pasagirska ranges=192.168.81.2-192.168.81.150
add name=vl3311_Vodoginna ranges=192.168.55.3-192.168.55.254
add name=v31_Chornoliska ranges=192.168.31.2-192.168.31.150
add name=vl10_Korystivka ranges=192.168.10.2-192.168.10.150
add name=v41_Siemens_3 ranges=192.168.41.2-192.168.41.150
add name=v51_Siemens_2 ranges=192.168.51.2-192.168.51.150
add name=v67_Siemens_1 ranges=192.168.67.2-192.168.67.150
add name=v66_Siemens_4 ranges=192.168.66.2-192.168.66.150
add address-pool=BIG_Pool_1 disabled=no interface="bridge(DHCP_BIG_1)" name=BIG_1
add address-pool=BIG_Pool_2 disabled=no interface="bridge(DHCP_BIG_2)" name=BIG_2
/queue simple
add interface=vlan1100_SahZavod_HP19 max-limit=33M/33M name="\E3\E0\E2\ED\FE\EA"
add interface=vlan17_Kononenko_HP17 max-limit=50M/50M name="\CA\EE\ED\EE\ED\E5\ED\EA\EE 50M"
add interface=vlan101_Antonov_HP20 max-limit=60M/60M name="\C0\ED\F2\EE\ED\EE\E2 60"
add interface=vlan73_RosUkrTrans_HP13 max-limit=100M/100M name=RosUkrTrans_HPport13
/routing bgp instance
set default as=65330 client-to-client-reflection=no
add as=xxxxx client-to-client-reflection=no name=bgpOPTOCOM out-filter=dynamic-in router-id=xx.yyy.zzz.146
/routing ospf instance
set [ find default=yes ] disabled=yes in-filter=dynamic-in out-filter=dynamic-in router-id=aa.bbb.cc.2
add bridge=bridge1 interface=mngmt
add bridge="bridge(DHCP_BIG_1)" disabled=yes interface=vlan1100_SahZavod_HP19
add bridge="bridge(DHCP_BIG_1)" interface=vlan41_Siemens3_HP4
add bridge="bridge(DHCP_BIG_1)" interface=vlan51_Siemens2_HP5
add bridge="bridge(DHCP_BIG_2)" interface=vlan66_Siemens4_HP10
add bridge="bridge(DHCP_BIG_1)" interface=vlan67_Siemens1_HP7
add bridge="bridge(DHCP_BIG_1)" interface=vlan81_Pasagirska_HP8
add bridge="bridge(DHCP_BIG_1)" disabled=yes interface=vlan91_Kirovograd_HP9
add bridge="bridge(DHCP_BIG_2)" interface=vlan7_Wifi_Chornoliska_HP27
add bridge="bridge(DHCP_BIG_1)" interface=vlan10_Korystivka_HP19
add bridge="bridge(DHCP_BIG_1)" interface=vlan31_Chornoliska_HP27
add bridge="bridge(DHCP_BIG_2)" interface=vlan61_UZ_DN3_HP18
add bridge="bridge(DHCP_BIG_1)" disabled=yes interface=vlan1220_Kolos_HP19
/interface l2tp-server server
set authentication=pap,chap default-profile=default enabled=yes
/interface pptp-server server
add address=192.168.192.1/24 interface=USERS
add address=192.168.2.1/24 interface=SERVERS
add address=192.168.1.111/24 interface=USERS
add address=193.150.59.1/27 interface=SERVERS
add address=193.150.56.1/23 interface="bridge(DHCP_BIG_1)"
add address=193.150.58.1/25 interface="bridge(DHCP_BIG_2)"
add address=193.150.58.129/25 interface=vlan21_A1201_Chornolsska_HP27
add address=193.150.59.253/30 interface=vlan101_Antonov_HP20
add address=193.150.59.249/30 interface=vlan102_TV_HP26
add address=192.168.55.1/24 interface=vlan3311_Vodoginna
add address=193.150.59.33/27 interface=vlan3311_Vodoginna
add address=193.150.59.245/30 interface=vlan17_Kononenko_HP17
add address=193.150.59.241/30 interface=vlan1220_Kolos_HP19
add address=xx.yyy.zzz.217/29 interface=vlan61_UZ_DN3_HP18
add address=192.168.61.1/24 interface=vlan61_UZ_DN3_HP18
add address=10.10.100.1/24 interface=mngmt
add address=192.168.91.1/24 comment="Dlya DSLAM Kanatovo i Kirovograd" interface=vlan91_Kirovograd_HP9
add address=10.10.91.1/24 comment="dhcp+nat on vlan91" interface=vlan91_Kirovograd_HP9
add address=10.10.11.1/24 comment="dhcp+nat on vlan1100" interface=vlan1100_SahZavod_HP19
add address=192.168.71.1/24 interface=vlan71_SMP704_HP11
add address=192.168.72.1/24 interface=vlan72_SMEU3_HP12
add address=xx.yyy.zzz.146/30 interface=ett
add address=10.10.200.1/24 interface=lvan912_mngmt2
add address=192.168.81.1/24 interface=vlan81_Pasagirska_HP8
add address=193.150.59.237/30 interface=vlan73_RosUkrTrans_HP13
add address=192.168.31.1/24 interface=vlan31_Chornoliska_HP27
add address=192.168.10.1/24 interface=vlan10_Korystivka_HP19
/ip dhcp-server config
set store-leases-disk=immediately
add address=10.10.11.0/24 comment="dhcp+nat on vlan1100" dns-server=193.150.59.30 gateway=10.10.11.1
add address=10.10.91.0/24 comment="vlan91 dhcp+nat" dns-server=193.150.59.30 gateway=10.10.91.1
add address=192.168.10.0/24 comment=vl10_Korystivka dns-server=193.150.59.30 gateway=192.168.10.1
add address=192.168.31.0/24 comment=vl31_Chornoliska dns-server=193.150.59.30 gateway=192.168.31.1
add address=192.168.41.0/24 comment=vl41_Siemens_3 dns-server=193.150.59.30 gateway=192.168.41.1
add address=192.168.51.0/24 comment=vl51_Siemens_2 dns-server=193.150.59.30 gateway=192.168.51.1
add address=192.168.55.0/24 comment="\C2\EE\E4\EE\E3\B3\ED\ED\E0" dns-server=193.150.59.30 gateway=192.168.55.1
add address=192.168.66.0/24 comment=vl66_Siemens_4 dns-server=193.150.59.30 gateway=192.168.66.1
add address=192.168.67.0/24 comment=vl67_Siemens_1 dns-server=193.150.59.30 gateway=192.168.67.1
add address=192.168.71.0/24 comment=vl71_SMP704_HP-11 dns-server=193.150.59.30 gateway=192.168.71.1
add address=192.168.72.0/24 comment=vl72_SMEU-3_HP-12 dns-server=193.150.59.30 gateway=192.168.72.1
add address=192.168.81.0/24 comment=vl81_Pasagirska dns-server=193.150.59.30 gateway=192.168.81.1
add address=192.168.192.0/24 comment="hotspot network" dns-server=192.168.2.50 gateway=192.168.192.1
add address=193.150.56.0/23 dns-server=193.150.59.30 gateway=193.150.56.1
add address=193.150.58.0/25 dns-server=193.150.59.30 gateway=193.150.58.1
add address=193.150.58.128/25 dns-server=193.150.59.30 gateway=193.150.58.129
set servers=193.150.59.30,8.8.8.8
add action=passthrough chain=unused-hs-chain comment="place hotspot rules here" disabled=yes
/ip firewall mangle
add action=mark-packet chain=forward dst-address=10.10.11.0/24 new-packet-mark=vla1100_users out-interface=vlan1100_SahZavod_HP19 passthrough=no
add action=passthrough chain=unused-hs-chain comment="place hotspot rules here" disabled=yes to-addresses=0.0.0.0
add action=masquerade chain=srcnat comment="Lviv. Vodoginna, office" out-interface=ett src-address=192.168.55.0/24
add action=masquerade chain=srcnat comment="Lviv, Vodoginna, users" disabled=yes src-address=192.168.2.0/24
add action=masquerade chain=srcnat comment="masquerade hotspot network" src-address=192.168.192.0/24
add action=masquerade chain=srcnat comment="vlan91, nat" out-interface=ett src-address=10.10.91.0/24
add action=masquerade chain=srcnat comment="vlan1100, nat" out-interface=ett src-address=10.10.11.0/24
add action=masquerade chain=srcnat disabled=yes src-address=192.168.2.50
add action=netmap chain=dstnat disabled=yes dst-address=193.150.59.30 dst-port=33200 protocol=tcp to-addresses=192.168.11.200 to-ports=80
add action=netmap chain=dstnat dst-address=193.150.59.2 dst-port=30200 protocol=tcp to-addresses=10.10.200.200 to-ports=80
add action=netmap chain=dstnat comment="DSLAM Kanatovo" dst-address=193.150.56.1 dst-port=33252 protocol=tcp to-addresses=192.168.91.252 to-ports=80
add action=netmap chain=dstnat comment="DSLAM Kirovograd" dst-address=193.150.56.1 dst-port=33253 protocol=tcp to-addresses=192.168.91.253 to-ports=80
add action=masquerade chain=srcnat comment=vl71_SMP704_HP-11 out-interface=ett src-address=192.168.71.0/24
add action=masquerade chain=srcnat comment=vl72_SMEU-3_HP-12 out-interface=ett src-address=192.168.72.0/24
add action=masquerade chain=srcnat comment=vl81_Pasagirska out-interface=ett src-address=192.168.81.0/24
add action=masquerade chain=srcnat comment=vl10_Korystivka out-interface=ett src-address=192.168.10.0/24
add action=masquerade chain=srcnat comment=vl31_Chornoliska out-interface=ett src-address=192.168.31.0/24
add action=masquerade chain=srcnat comment=vl41_Siemens_3 out-interface=ett src-address=192.168.41.0/24
add action=masquerade chain=srcnat comment=vl51_Siemens_2 out-interface=ett src-address=192.168.51.0/24
add action=masquerade chain=srcnat comment=vl66_Siemens_4 out-interface=ett src-address=192.168.66.0/24
add action=masquerade chain=srcnat comment=vl67_Siemens_1 out-interface=ett src-address=192.168.67.0/24
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set irc disabled=yes
set h323 disabled=yes
set sip disabled=yes
/ip hotspot ip-binding
add address=192.168.192.110 mac-address=00:26:B9:09:77:2B server=hotspot1 to-address=192.168.192.110 type=bypassed
/ip hotspot user
add name=admin
/ip neighbor discovery
set vlan1111_InetLvivNAT disabled=yes
set USERS disabled=yes
set SERVERS disabled=yes
set mngmt disabled=yes
set vlan10_Korystivka_HP19 disabled=yes
set vlan7_Wifi_Chornoliska_HP27 disabled=yes
set vlan1100_SahZavod_HP19 disabled=yes
set vlan1220_Kolos_HP19 disabled=yes
set vlan17_Kononenko_HP17 disabled=yes
set vlan21_A1201_Chornolsska_HP27 disabled=yes
set vlan31_Chornoliska_HP27 disabled=yes
set vlan41_Siemens3_HP4 disabled=yes
set vlan51_Siemens2_HP5 disabled=yes
set vlan61_UZ_DN3_HP18 disabled=yes
set vlan66_Siemens4_HP10 disabled=yes
set vlan67_Siemens1_HP7 disabled=yes
set vlan71_SMP704_HP11 disabled=yes
set vlan72_SMEU3_HP12 disabled=yes
set vlan81_Pasagirska_HP8 disabled=yes
set vlan91_Kirovograd_HP9 disabled=yes
set vlan3311_Vodoginna disabled=yes
set vlan102_TV_HP26 disabled=yes
set vlan101_Antonov_HP20 disabled=yes
set vlan73_RosUkrTrans_HP13 disabled=yes
set ett disabled=yes
set qnq disabled=yes
set bridge2 disabled=no
set lvan912_mngmt2 disabled=yes
add disabled=yes distance=1 gateway=193.150.59.1
/ip service
set telnet disabled=yes
set www disabled=yes
set ssh port=222
set api disabled=no
/ip traffic-flow target
add address=193.150.59.30:9995 version=5
/ppp aaa
set accounting=no interim-update=5s
/ppp secret
add disabled=yes local-address=193.150.58.1 name=uz password=123456 remote-address=78.154.171.221 service=pptp
add local-address=193.150.56.1 name=uz2 password=123456 remote-address=193.150.57.221 service=pptp
add disabled=yes local-address=193.150.56.1 name=globus password=123456 remote-address=78.154.171.223 service=pptp
/routing bgp network
add network=193.150.56.0/22 synchronize=no
/routing bgp peer
add default-originate=always in-filter=dynamic-in instance=bgpOPTOCOM multihop=yes name=bgpETT out-filter=dynamic-in remote-address=78.154.174.145 remote-as=35320 ttl=default update-source=ett
/routing ospf network
add area=backbone
/system lcd
set contrast=0 enabled=no port=parallel type=24x4
/system lcd page
set time disabled=yes display-time=5s
set resources disabled=yes display-time=5s
set uptime disabled=yes display-time=5s
set packets disabled=yes display-time=5s
set bits disabled=yes display-time=5s
set version disabled=yes display-time=5s
set identity disabled=yes display-time=5s
set lvan912_mngmt2 disabled=yes display-time=5s
set bridge2 disabled=yes display-time=5s
set qnq disabled=yes display-time=5s
set ether1 disabled=yes display-time=5s
set ether2 disabled=yes display-time=5s
set ether3 disabled=yes display-time=5s
set ether7 disabled=yes display-time=5s
set ether8 disabled=yes display-time=5s
set ether9 disabled=yes display-time=5s
set ether10 disabled=yes display-time=5s
set vlan73_RosUkrTrans_HP13 disabled=yes display-time=5s
set vlan1111_InetLvivNAT disabled=yes display-time=5s
set USERS disabled=yes display-time=5s
set SERVERS disabled=yes display-time=5s
set vlan101_Antonov_HP20 disabled=yes display-time=5s
set vlan3311_Vodoginna disabled=yes display-time=5s
set ett disabled=yes display-time=5s
set vlan102_TV_HP26 disabled=yes display-time=5s
set "bridge(DHCP_BIG_2)" disabled=yes display-time=5s
set "bridge(DHCP_BIG_1)" disabled=yes display-time=5s
set vlan91_Kirovograd_HP9 disabled=yes display-time=5s
set vlan81_Pasagirska_HP8 disabled=yes display-time=5s
set vlan72_SMEU3_HP12 disabled=yes display-time=5s
set vlan71_SMP704_HP11 disabled=yes display-time=5s
set vlan67_Siemens1_HP7 disabled=yes display-time=5s
set vlan66_Siemens4_HP10 disabled=yes display-time=5s
set vlan61_UZ_DN3_HP18 disabled=yes display-time=5s
set vlan51_Siemens2_HP5 disabled=yes display-time=5s
set vlan41_Siemens3_HP4 disabled=yes display-time=5s
set vlan31_Chornoliska_HP27 disabled=yes display-time=5s
set vlan21_A1201_Chornolsska_HP27 disabled=yes display-time=5s
set vlan17_Kononenko_HP17 disabled=yes display-time=5s
set vlan1220_Kolos_HP19 disabled=yes display-time=5s
set vlan1100_SahZavod_HP19 disabled=yes display-time=5s
set vlan7_Wifi_Chornoliska_HP27 disabled=yes display-time=5s
set vlan10_Korystivka_HP19 disabled=yes display-time=5s
set bridge1 disabled=yes display-time=5s
set mngmt disabled=yes display-time=5s
set ether6 disabled=yes display-time=5s
set ether5 disabled=yes display-time=5s
set ether4 disabled=yes display-time=5s
set <pptp-uz2> disabled=yes display-time=5s
/tool graphing interface
add
Users browsing this forum: elico and 127 guests
