krasi9220
[SOLVED]PPTP VPN on RB750
Fri Oct 19, 2012 1:25 pm
I have a problem with vpn everything look fine, but when I try to ping the lan there is no ping. I connected to pptp server, but there is no ping.
Help....
P.S. I can see in address list the ip to that computer. I have ping from mikrotik to computer, but from computer to lan after mikrotik there is no ping.
mixig
Re: PPTP VPN on RB750
Fri Oct 19, 2012 1:46 pm
go to your lan interface and in general tab select ARP: proxy-arp, by default is : Enabled
then try pinging that computer again
krasi9220
Fri Oct 19, 2012 1:55 pm
Are you talking about lan interface on my mikrotik?
mixig
Fri Oct 19, 2012 2:25 pm
yep, if your lan is on ether3, go to the interface menu and select that interface and change ARP:Enabled to ARP: Proxy-arp
krasi9220
Fri Oct 19, 2012 2:39 pm
Thanks a lot
Users browsing this forum: Amazon [Bot], Bing [Bot], dervomsee, ejaka2s, Majestic-12 [Bot], viacheslav1988 and 218 guests
