Code: Select all
/ip firewall mangle
add chain=input in-interface=WAN1 action=mark-connection new-connection-mark=WAN1_conn
add chain=input in-interface=WAN2 action=mark-connection new-connection-mark=WAN2_conn
add chain=input in-interface=WAN3 action=mark-connection new-connection-mark=WAN3_conn
add chain=output connection-mark=WAN1_conn action=mark-routing new-routing-mark=to_WAN1
add chain=output connection-mark=WAN2_conn action=mark-routing new-routing-mark=to_WAN2
add chain=output connection-mark=WAN3_conn action=mark-routing new-routing-mark=to_WAN3
add chain=prerouting dst-address=10.1.1.0/30 action=accept in-interface=17216
add chain=prerouting dst-address=10.2.2.0/30 action=accept in-interface=17216
add chain=prerouting dst-address=10.3.3.0/30 action=accept in-interface=17216
add chain=prerouting dst-address=10.1.1.0/30 action=accept in-interface=17217
add chain=prerouting dst-address=10.2.2.0/30 action=accept in-interface=17217
add chain=prerouting dst-address=10.3.3.0/30 action=accept in-interface=17217
add chain=prerouting dst-address=10.1.1.0/30 action=accept in-interface=17218
add chain=prerouting dst-address=10.2.2.0/30 action=accept in-interface=17218
add chain=prerouting dst-address=10.3.3.0/30 action=accept in-interface=17218
add chain=prerouting dst-address=10.1.1.0/30 action=accept in-interface=17219
add chain=prerouting dst-address=10.2.2.0/30 action=accept in-interface=17219
add chain=prerouting dst-address=10.3.3.0/30 action=accept in-interface=17219
add chain=prerouting dst-address=10.1.1.0/30 action=accept in-interface=17220
add chain=prerouting dst-address=10.2.2.0/30 action=accept in-interface=17220
add chain=prerouting dst-address=10.3.3.0/30 action=accept in-interface=17220
add chain=prerouting dst-address=10.1.1.0/30 action=accept in-interface=17221
add chain=prerouting dst-address=10.2.2.0/30 action=accept in-interface=17221
add chain=prerouting dst-address=10.3.3.0/30 action=accept in-interface=17221
add chain=prerouting dst-address=10.1.1.0/30 action=accept in-interface=17222
add chain=prerouting dst-address=10.2.2.0/30 action=accept in-interface=17222
add chain=prerouting dst-address=10.3.3.0/30 action=accept in-interface=17222
add chain=prerouting dst-address=10.1.1.0/30 action=accept in-interface=17223
add chain=prerouting dst-address=10.2.2.0/30 action=accept in-interface=17223
add chain=prerouting dst-address=10.3.3.0/30 action=accept in-interface=17223
add chain=prerouting dst-address=10.1.1.0/30 action=accept in-interface=17224
add chain=prerouting dst-address=10.2.2.0/30 action=accept in-interface=17224
add chain=prerouting dst-address=10.3.3.0/30 action=accept in-interface=17224
add chain=prerouting dst-address=10.1.1.0/30 action=accept in-interface=17225
add chain=prerouting dst-address=10.2.2.0/30 action=accept in-interface=17225
add chain=prerouting dst-address=10.3.3.0/30 action=accept in-interface=17225
add chain=prerouting dst-address-type=!local in-interface=17216 per-connection-classifier=both-addresses-and-ports:3/0 action=mark-connection new-connection-mark=WAN1_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=17216 per-connection-classifier=both-addresses-and-ports:3/1 action=mark-connection new-connection-mark=WAN2_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=17216 per-connection-classifier=both-addresses-and-ports:3/2 action=mark-connection new-connection-mark=WAN3_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=17217 per-connection-classifier=both-addresses-and-ports:3/0 action=mark-connection new-connection-mark=WAN1_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=17217 per-connection-classifier=both-addresses-and-ports:3/1 action=mark-connection new-connection-mark=WAN2_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=17217 per-connection-classifier=both-addresses-and-ports:3/2 action=mark-connection new-connection-mark=WAN3_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=17218 per-connection-classifier=both-addresses-and-ports:3/0 action=mark-connection new-connection-mark=WAN1_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=17218 per-connection-classifier=both-addresses-and-ports:3/1 action=mark-connection new-connection-mark=WAN2_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=17218 per-connection-classifier=both-addresses-and-ports:3/2 action=mark-connection new-connection-mark=WAN3_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=17219 per-connection-classifier=both-addresses-and-ports:3/0 action=mark-connection new-connection-mark=WAN1_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=17219 per-connection-classifier=both-addresses-and-ports:3/1 action=mark-connection new-connection-mark=WAN2_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=17219 per-connection-classifier=both-addresses-and-ports:3/2 action=mark-connection new-connection-mark=WAN3_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=17220 per-connection-classifier=both-addresses-and-ports:3/0 action=mark-connection new-connection-mark=WAN1_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=17220 per-connection-classifier=both-addresses-and-ports:3/1 action=mark-connection new-connection-mark=WAN2_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=17220 per-connection-classifier=both-addresses-and-ports:3/2 action=mark-connection new-connection-mark=WAN3_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=17221 per-connection-classifier=both-addresses-and-ports:3/0 action=mark-connection new-connection-mark=WAN1_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=17221 per-connection-classifier=both-addresses-and-ports:3/1 action=mark-connection new-connection-mark=WAN2_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=17221 per-connection-classifier=both-addresses-and-ports:3/2 action=mark-connection new-connection-mark=WAN3_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=17222 per-connection-classifier=both-addresses-and-ports:3/0 action=mark-connection new-connection-mark=WAN1_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=17222 per-connection-classifier=both-addresses-and-ports:3/1 action=mark-connection new-connection-mark=WAN2_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=17222 per-connection-classifier=both-addresses-and-ports:3/2 action=mark-connection new-connection-mark=WAN3_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=17223 per-connection-classifier=both-addresses-and-ports:3/0 action=mark-connection new-connection-mark=WAN1_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=17223 per-connection-classifier=both-addresses-and-ports:3/1 action=mark-connection new-connection-mark=WAN2_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=17223 per-connection-classifier=both-addresses-and-ports:3/2 action=mark-connection new-connection-mark=WAN3_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=17224 per-connection-classifier=both-addresses-and-ports:3/0 action=mark-connection new-connection-mark=WAN1_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=17224 per-connection-classifier=both-addresses-and-ports:3/1 action=mark-connection new-connection-mark=WAN2_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=17224 per-connection-classifier=both-addresses-and-ports:3/2 action=mark-connection new-connection-mark=WAN3_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=17225 per-connection-classifier=both-addresses-and-ports:3/0 action=mark-connection new-connection-mark=WAN1_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=17225 per-connection-classifier=both-addresses-and-ports:3/1 action=mark-connection new-connection-mark=WAN2_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=17225 per-connection-classifier=both-addresses-and-ports:3/2 action=mark-connection new-connection-mark=WAN3_conn passthrough=yes
add chain=prerouting connection-mark=WAN1_conn in-interface=17216 action=mark-routing new-routing-mark=to_WAN1
add chain=prerouting connection-mark=WAN2_conn in-interface=17216 action=mark-routing new-routing-mark=to_WAN2
add chain=prerouting connection-mark=WAN3_conn in-interface=17216 action=mark-routing new-routing-mark=to_WAN3
add chain=prerouting connection-mark=WAN1_conn in-interface=17217 action=mark-routing new-routing-mark=to_WAN1
add chain=prerouting connection-mark=WAN2_conn in-interface=17217 action=mark-routing new-routing-mark=to_WAN2
add chain=prerouting connection-mark=WAN3_conn in-interface=17217 action=mark-routing new-routing-mark=to_WAN3
add chain=prerouting connection-mark=WAN1_conn in-interface=17218 action=mark-routing new-routing-mark=to_WAN1
add chain=prerouting connection-mark=WAN2_conn in-interface=17218 action=mark-routing new-routing-mark=to_WAN2
add chain=prerouting connection-mark=WAN3_conn in-interface=17218 action=mark-routing new-routing-mark=to_WAN3
add chain=prerouting connection-mark=WAN1_conn in-interface=17219 action=mark-routing new-routing-mark=to_WAN1
add chain=prerouting connection-mark=WAN2_conn in-interface=17219 action=mark-routing new-routing-mark=to_WAN2
add chain=prerouting connection-mark=WAN3_conn in-interface=17219 action=mark-routing new-routing-mark=to_WAN3
add chain=prerouting connection-mark=WAN1_conn in-interface=17220 action=mark-routing new-routing-mark=to_WAN1
add chain=prerouting connection-mark=WAN2_conn in-interface=17220 action=mark-routing new-routing-mark=to_WAN2
add chain=prerouting connection-mark=WAN3_conn in-interface=17220 action=mark-routing new-routing-mark=to_WAN3
add chain=prerouting connection-mark=WAN1_conn in-interface=17221 action=mark-routing new-routing-mark=to_WAN1
add chain=prerouting connection-mark=WAN2_conn in-interface=17221 action=mark-routing new-routing-mark=to_WAN2
add chain=prerouting connection-mark=WAN3_conn in-interface=17221 action=mark-routing new-routing-mark=to_WAN3
add chain=prerouting connection-mark=WAN1_conn in-interface=17222 action=mark-routing new-routing-mark=to_WAN1
add chain=prerouting connection-mark=WAN2_conn in-interface=17222 action=mark-routing new-routing-mark=to_WAN2
add chain=prerouting connection-mark=WAN3_conn in-interface=17222 action=mark-routing new-routing-mark=to_WAN3
add chain=prerouting connection-mark=WAN1_conn in-interface=17223 action=mark-routing new-routing-mark=to_WAN1
add chain=prerouting connection-mark=WAN2_conn in-interface=17223 action=mark-routing new-routing-mark=to_WAN2
add chain=prerouting connection-mark=WAN3_conn in-interface=17223 action=mark-routing new-routing-mark=to_WAN3
add chain=prerouting connection-mark=WAN1_conn in-interface=17224 action=mark-routing new-routing-mark=to_WAN1
add chain=prerouting connection-mark=WAN2_conn in-interface=17224 action=mark-routing new-routing-mark=to_WAN2
add chain=prerouting connection-mark=WAN3_conn in-interface=17224 action=mark-routing new-routing-mark=to_WAN3
add chain=prerouting connection-mark=WAN1_conn in-interface=17225 action=mark-routing new-routing-mark=to_WAN1
add chain=prerouting connection-mark=WAN2_conn in-interface=17225 action=mark-routing new-routing-mark=to_WAN2
add chain=prerouting connection-mark=WAN3_conn in-interface=17225 action=mark-routing new-routing-mark=to_WAN3
add dst-address=0.0.0.0/0 gateway=10.1.1.1 routing-mark=to_WAN1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=10.2.2.1 routing-mark=to_WAN2 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=10.3.3.1 routing-mark=to_WAN3 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=10.1.1.1 distance=1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=10.2.2.1 distance=2 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=10.3.3.1 distance=3 check-gateway=ping
Code: Select all
add chain=srcnat out-interface=WAN1 action=masquerade
add chain=srcnat out-interface=WAN2 action=masquerade
add chain=srcnat out-interface=WAN3 action=masquerade
