Estiaan
Voltage monitor
Wed Jan 09, 2013 10:49 am
Hi
Ive seen a voltage monitor script in the wiki that im trying to implement on my RB800, with no success.
Anybosy else have a working script?
SurferTim
Re: Voltage monitor
Wed Jan 09, 2013 2:04 pm
Which script? What fails? I wrote one of them, and I'm still using it, but not on a RB800.
janisk
Re: Voltage monitor
Wed Jan 09, 2013 2:06 pm
RB800 has CPU-temperature reported, while script uses temperature field to get the value.
SurferTim
Re: Voltage monitor
Wed Jan 09, 2013 2:09 pm
Hi janisk. Why the change to a different field name?
janisk
Re: Voltage monitor
Wed Jan 09, 2013 2:14 pm
different point of measure. There are RouterBOARDS that have both of them present, hence the use of different names. Also, cpu-temperature tends to be higher than ambient temperature measurement.
SurferTim
Re: Voltage monitor
Wed Jan 09, 2013 2:18 pm
My bad. I thought we were talking voltage here. This is the script I wrote:
http://wiki.mikrotik.com/wiki/Monitor_i ... B333/433AH
Estiaan
Re: Voltage monitor
Wed Jan 09, 2013 3:14 pm
That is the exact script I used,
Janisk, how would I change the script to work on the Rb800?
SurferTim
Re: Voltage monitor
Wed Jan 09, 2013 3:19 pm
Does your RB800 send email ok? That would be the first test I would try. You might want to look here for email troubleshooting:
http://wiki.mikrotik.com/wiki/Email_set ... leshooting
janisk
Re: Voltage monitor
Wed Jan 09, 2013 4:37 pm
indeed, voltage is same field over all routers. Temperature measurement was one that came into mind, when script that should work fails. But yes, check your e-mail settings.
btw, in latest RouterOS tls option can be set in settings
ros code
[admin@MikroTik] /tool e-mail> set start-tls=
no  yes
SurferTim
Re: Voltage monitor
Wed Jan 09, 2013 4:42 pm
Thanks, janisk. That is good to know. That way I won't have to use the tls=yes in the email test send.
Users browsing this forum: densenator, GoogleOther [Bot], rextended, settecplus and 116 guests
