We have interface with ARP reply-only, DHCP server which issue static-only addresses. Also we have static ARP records for these addresses. But this combination doesn't work as expected: after restart of Mikrotik no ping to devices, but when we delete static record, change ARP type to enable on interface - it creates new ARP record and works perfectly. Then we do "make static" for this ARP record, change ARP type to reply-only again and it still works, but for about 30 minutes only.
For some interfaces procedure of disable-enable of interface helps. For some interfaces there are no such problems.
We used latest stable version of RouterOS and latest 6.0 RC.
WTF?
