theblop
Port Mirroring on RB450G router
Wed Apr 17, 2013 9:07 pm
I have a simple router/NAT setup on a 450G (routerOS v5.7):
- ether1 (renamed to wan) connected to a cable modem
- ether2-5 in a bridge on the LAN
- NAT/masquerade between wan and LAN and some filtering rules
I want to mirror wan to one of the LAN ports (ether2) to run an IDS (e.g. snort)
so I ran removed ether2 from the bridge and ran
/interface ethernet switch set numbers=0 mirror-source=wan mirror-target=ether2-local :
# NAME TYPE MIRROR-SOURCE MIRROR-TARGET SWITCH-ALL-PORTS
0 switch1 Atheros-8316 wan ether2-local yes
But I don't see any traffic on ether2.
Here is my interface setup:
/interface ethernet switch port print
Flags: I - invalid
# NAME SWITCH VLAN-MODE VLAN-HEADER
0 ether2-local switch1 fallback leave-as-is
1 ether3-local switch1 fallback leave-as-is
2 ether4-local switch1 fallback leave-as-is
3 ether5-local switch1 fallback leave-as-is
4 wan switch1 fallback leave-as-is
5 switch1_cpu switch1 fallback leave-as-is
/interface bridge port print
Flags: X - disabled, I - inactive, D - dynamic
# INTERFACE BRIDGE PRIORITY PATH-COST HORIZON
0 ether3-local bridge 0x80 10 none
1 I ether4-local bridge 0x80 10 none
2 ether5-local bridge 0x80 10 none
I also have filter and NAT rules, but do they still apply to the mirrored port? In any case I don't see anything being blocked in the filter stats monitor.
Any idea what I could be doing wrong?
Thanks!
mrphreak
Re: Port Mirroring on RB450G router
Thu Apr 18, 2013 9:03 am
You might find that the port mirror is a function of the switch chip so you might need to add wan as a master-port for ether2
theblop
Thu Apr 18, 2013 4:15 pm
It doesn't make any difference, still no traffic on ether2:
 /interface ethernet print
Flags: X - disabled, R - running, S - slave
 #    NAME                             MTU MAC-ADDRESS       ARP        MASTER-PORT                         SWITCH
 0 RS ether2-local                    1500 00:0C:42:3E:57:D1 enabled    wan                                 switch1
 1 R  ether3-local                    1500 00:0C:42:3E:57:D2 enabled    none                                switch1
 2    ether4-local                    1500 00:0C:42:3E:57:D3 enabled    none                                switch1
 3 R  ether5-local                    1500 00:0C:42:3E:57:D4 enabled    none                                switch1
 4 R  wan                             1500 00:21:91:DC:BE:CC enabled    none                                switch1
 /interface ethernet switch print
Flags: I - invalid
I tried a switch rule as well, makes no difference:
/interface ethernet switch rule print
 0   switch=switch1 ports=wan copy-to-cpu=no redirect-to-cpu=no mirror=yes
Am I missing something??
Users browsing this forum: Ahrefs [Bot], raiser, simtj and 88 guests
