samir494
routeros 6.2 changelog
Wed Jul 17, 2013 12:31 pm
where can i find routeros 6.2 changelog
normis
Re: routeros 6.2 changelog
Wed Jul 17, 2013 12:32 pm
What's new in 6.2 (2013-Jul-16 13:48):
*) dhcp server - framed routes are now also added to the server routing table;
*) dhcpv6 server - added binding-script option;
*) proxy - allow multiple src-address for ipv4 and ipv6;
*) eoip,gre tunnels could occasionally crash multicore router;
*) fixed bug - sometimes some types of interfaces would stop working;
*) ipsec sometimes could crash kernel on CCR;
*) connection tracking sometimes could crash kernel on CCR;
*) ppp,pptp,l2tp,sstp - added default-route-distance parameter;
*) scep - "/cert scep ra" merged into "/cert scep client" without saving ra config;
*) ipsec - fix phase1 autonegotiation on little endian platforms;
*) pppoe server - allow service with empty service-name to accept all pppoe clients;
*) lcd - current-screen option is replaced with "/lcd show" command
*) lcd - current-interface option is replaced with "/lcd interface display" command
*) graphing - make graphs stable on ppp & ovpn interfaces;
*) www, hotspot - fixed problem when www service stopped responding on high load;
*) winbox, webfig: allow to enter space in the text fields;
*) webfig - fixed configuration of VPLS & routing filters;
*) lcd - added option for enabling or disabling the touch screen;
*) lcd - added options for screen switching;
*) lcd - up to 10 non-physical interfaces can now be added to the lcd;
*) lcd - all interface graph screen can now be customized from /lcd interface page;
*) backup - changed default backup file name to <id>-<YY><MM><DD>-<HHMM>.backup
for file browsers to sort them properly;
*) webfig - it did not work in Opera;
*) webfig - made terminal work again;
*) winbox - added ability to fully set up traffic generator in winbox;
*) trafficgen - allow ranges for ip addrs and udp ports;
*) queue simple - fixed bug - actual queue order sometimes was wrong;
*) queue simple - queue is not invalid when at least one of target interfaces is up;
*) fixed crash when setting master-port on AR8327 switch chips;
*) fixed addresslist - dynamic entries sometimes would still
show up even afther being timed out;
samir494
Wed Jul 17, 2013 1:25 pm
thanks dear
fabiandr
Wed Jul 17, 2013 3:11 pm
Hello Normis,
when you will be available to download the version 6.2?
Regards,
pvidal
Wed Jul 17, 2013 4:23 pm
Normis just posted the Changelog!
pvidal
Wed Jul 17, 2013 4:27 pm
Hi, Normis! do you have the download link?
Thanx!
Numenori
Wed Jul 17, 2013 4:36 pm
v6.2 is here: http://www.mikrotik.com/download/share/ ... be-6.2.npk (MIPS-BE). Change the name to get other build files.
From Normis post in this topic: http://forum.mikrotik.com/viewtopic.php?f=2&t=51835
bax
Wed Jul 17, 2013 4:48 pm
Normis check userman part ... there is people say that have problems with paypal http://forum.mikrotik.com/viewtopic.php?f=10&t=73813
pvidal
Wed Jul 17, 2013 5:44 pm
Thank you!
w0lt
Long time Member
Long time Member
Wed Jul 17, 2013 8:52 pm
There is no support for "Multicast" in the v6.2 package.
aragon
Wed Jul 17, 2013 11:20 pm
No mention of script fixes. Anyone had a chance to test previously working scripts on 6.2 yet?
normis
Thu Jul 18, 2013 9:28 am
all scripts are working, check if you have updated your scripts for the v6 commands and features
normis
clarify please, what is not working
aragon
Thu Jul 18, 2013 9:38 am
Sorry, are you implying there were no scripting bugs with 6.1?
normis
Thu Jul 18, 2013 9:40 am
There are a few issues, but they are not fixed in the above build, that's why they are not in the changelog. Which specific issue are you talking about?
janisk
Thu Jul 18, 2013 10:14 am
for the multicast to work, you need package that has multicast stuff in it.
here are archive with some additional packages:
http://www.mikrotik.com/download/share/ ... es_6.2.zip
aragon
Thu Jul 18, 2013 10:31 am
Ok, thanks for confirmation. My issues are in ticket #2013061866000451. Please could you fix them in 6.3? The scripting API is very important to us. :)
normis
v6.2 is not released, this is only a discussion about it. the issues will be fixed before we release v6.2
honzam
Thu Jul 18, 2013 10:45 am
Do you plan any wireless improvements?
normis
Thu Jul 18, 2013 10:48 am
We always "plan for improvements" :)
Stillhard
Thu Jul 18, 2013 10:59 am
Hi normis, and the rest of MT team :)
I've tried v6.2 (build 2013-Jul-08 AND 2013-Jul-16)
Error in 2013-Jul-16 13:48:
- Error URL redirection in hotspot (if we type ex: http://www.mikrotik.com before login, the browser is not redirected to login page)
In v6.2 (2013-Jul-08) and v6.1, no such problem exist 8)
That's it for now :D
Happy Fasting...
normis
Thu Jul 18, 2013 11:01 am
- Error URL redirection in hotspot.
New build has this issue fixed, always make sure to test new build (Jul 17) before reporting issues ;)
samir494
Thu Jul 18, 2013 11:02 am
MT is always take care for Improvements-- :) :)
that Improvements needs Improvements
honzam
Thu Jul 18, 2013 11:17 am
I thing wireless improvements in 6.2? If yes, then what?
aragon
Thu Jul 18, 2013 11:32 am
Even better, thanks!
Stillhard
Thu Jul 18, 2013 11:50 am
Great, i'll try it later...
lol i just trying to test based on the changelog date :D
normis
Thu Jul 18, 2013 11:54 am
Changelog maybe is not updated yet. Builds take place nearly every day, sometimes - many times per day
Stillhard
Thu Jul 18, 2013 11:57 am
that's why i put the info (build date and time) of my test :D
Thank you MT team :-D
THG
Thu Jul 18, 2013 4:45 pm
Do you intend to address this issue as well. I'm quite sure that it is a bug, because I get different results depending from where I configure DHCPv6 bindings. From the terminal it show IPv6 servers, from Winbox and Webfig it show IPv4 servers.
http://forum.mikrotik.com/viewtopic.php?f=1&t=72495
Cha0s
Thu Jul 18, 2013 6:24 pm
Does this mean that on x86 and mipsbe the problem still exists? :(
telepro
Fri Jul 19, 2013 5:19 am
Regarding scripting errors, please see http://forum.mikrotik.com/viewtopic.php?f=1&t=73772
Although the additional output produced by running scripts in 6.1 may be annoying, the larger problem is that many scripts no longer run successfully in 6.1 as the did in 6.0 and prior revisions. this is definitely not due to changes in the format of commands in 6.1 over previous releases of ROS
For example: "the expansion of local variables now produces a syntax error"
This was a significant (and perhaps an unintended) change such that scripts no longer execute successfully.
janisk
Fri Jul 19, 2013 9:55 am
x86 and mipsle are little endian - as the problem could have been observer only on those platforms, it is fixed now. MIPSbe has never seen the issue.
honzam
Fri Jul 19, 2013 10:59 am
It's Friday - favorite day :)
Publish 6.2 today?
Cha0s
Fri Jul 19, 2013 5:55 pm
Oops! My bad. I thought it was referring to mipsle. :oops:
Great news then! Thanks :D
Any news about running Mikrotik 6.x on XenServer?
It causes a kernel panic
http://forum.mikrotik.com/viewtopic.php?f=2&t=74065
http://forum.mikrotik.com/viewtopic.php ... 77#p374777
nakhla
Sat Jul 20, 2013 5:43 pm
NDIS for 3g modem is supported in this version or not??
Thank you so much :)
Cha0s
Sun Jul 21, 2013 3:03 pm
IPSec still not working properly on 6.2
With only one ipsec peer configured it works. But if I add a second it won't work.
mtmx80
Mon Jul 22, 2013 12:32 pm
I can confirm same: on mipsbe (tested on RB750,RB750G and RB2011) IPSec doesn't works well with multiple IPSec peers. I'm able to use it with 2 peers, but not with more than two. However I'm not sure if number of peers are causing the issue.
Note: by switching Exchange mode from main to aggressive I have managed to connect to my other peers.
tomaskir
Trainer
Trainer
Mon Jul 22, 2013 12:43 pm
Report to support@mikrotik.com so they can fix it.
mrz
Mon Jul 22, 2013 12:49 pm
It really depends on peer config, to tell more write to support with attached supout file.
samir494
Tue Jul 23, 2013 11:07 am
6.2 is still need to LAB test ?
or released today ?
normis
or released today ?
It is not released
markom
Tue Jul 23, 2013 11:13 am
cant wait to test in real environment. One of the most important function for me.
jcem
Tue Jul 23, 2013 12:23 pm
Release 22jul13
Still no PayPal function. RB doesn't accept "return" from Paypal after payment.
Works fine in ROS5.25
RGDS
normis
Tue Jul 23, 2013 1:22 pm
Release 22jul13
RGDS
have you contacted support with supout.rif file and remote access? we can't repeat it, we must see your system
nakhla
Tue Jul 23, 2013 2:18 pm
NDIS connection type for 3g modem is supported in this version or not??
any working driver added for NDIS..
I hope someone can answer my question.
nest
Forum Veteran
Forum Veteran
Tue Jul 23, 2013 2:27 pm
See also http://forum.mikrotik.com/viewtopic.php?f=10&t=73813
Normis - I cannot give you remote access to a 6.1 system as with it not working, we had to go back to 5.25 very quickly, where it works some of the time. We still get a lot of timed out errors but if the customer creates a new account and tries PayPal again, he is sometimes lucky. :P
jcem
Tue Jul 23, 2013 2:45 pm
Release 22jul13
RGDS
Many times Ticket#2013071766000184, Ticket#2013062266000354
napismizpravu
Re: routeros 6.2 netwatch does not work
Fri Jul 26, 2013 5:55 am
netwatch became dysfunctional (does not work)
character encoding comment Unicode UTF-8
He was probably a problem that disappeared from the national characters of the rules in Winbox. Currently written notes are displayed correctly. Terminal no UTF-8
CarulloS
Sun Jul 28, 2013 6:18 am
Thanks for providing the link to the pre-release builds. Is there a pre-release changelog that is updated - even if not kept up to date daily - that kinda shows whats been done since previous build? Can someone provide a link for it if it exists please... thanks
Neovr
Sun Jul 28, 2013 10:28 am
i'm testing 6.2 on x86 esxi 5.1 virtual machine... 3 nic - intel 1000e
max uptime 2-3days
problem - network randomly shutdown...
system normal respond on console, and all network interfaces can see in /interfaces print and all link is up
6.1 have same problem too...
any ideas?
Cha0s
Sun Jul 28, 2013 3:20 pm
max uptime 2-3days
any ideas?
No problem here with v6.x on ESXi 5.1. Works perfect.
Chupaka
Mon Jul 29, 2013 4:59 pm
max uptime 2-3days
any ideas?
the same here: uptime is 43 days, 70 TiB of traffic passed through the router, no problems observed
THG
Tue Jul 30, 2013 11:31 am
max uptime 2-3days
any ideas?
Did you upgrade with the latest patches from VMware?
honzam
Wed Jul 31, 2013 7:59 pm
RB1200 downgrade from 6.2 --> 5.25
Power cycle needed :!:
tomaskir
Trainer
Trainer
Wed Jul 31, 2013 8:40 pm
max uptime 2-3days
any ideas?
I can actually confirm this.
I have 5 VM Routers, only one randomly stops network traffic tho.
Gonna try to recreate VM and reinstall ROS, I will see if that helps or not.
THG
Thu Aug 01, 2013 1:29 am
I had this issue before I upgraded ESXi 5.1 with the latest patches.
DimebagDarrell
Mon Aug 05, 2013 3:15 am
Testing the version 6.2 on RB751U-2HnD:
• After "reset-configuration" does not enter by MAC Address.
• After "reset-configuration" enters through IPv6 only.
• There are the default script for the equipment.
• SNTP Client not updated.
normis
Mon Aug 05, 2013 9:51 am
because reset disables MAC access on Ether1. Did you connect from ports 2-5?
tomaskir
Trainer
Trainer
Mon Aug 12, 2013 4:03 pm
I am currently running 5.1 U1 and I still have this issue.
Would you happen to remember which patch solved it? I looked through the patches, but couldnt see anything relating to this issue.
THG
Mon Aug 12, 2013 6:02 pm
I cannot say what solved my isse because I applied every available patch in the end of may 2013. I'm quite sure that the upgrade from 5.1 to 5.1 U1 did not solved anything in my case, therefore I downloaded and applied everything. Now I se that 5.1 U1b has been released, maybe this upgrade will solve your issue.
ahmedramze
Mon Aug 19, 2013 10:53 pm
Hello ,
I have issue with queue simple and tree ,
we use this script for unlimited download from cache proxy , for TOS marking in mangle ,
/ip firewall mangle
add action=mark-packet chain=postrouting comment=SQUID disabled=no dscp=12 new-packet-mark=squid passthrough=no
/queue tree
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=0 name=FreeSQUID packet-mark=squid parent=global-out priority=8 queue=default
Now there is no Global-Out just Global and it not work at this script.
/queue tree
add name=FreeSQUID packet-mark=Proxy_cache parent=global queue=default
Chupaka
Tue Aug 20, 2013 7:52 pm
if you use Simple Queues for limiting users, you need to create Simple Queue for unlimited traffic
Users browsing this forum: akakua, bobr, Majestic-12 [Bot], rextended and 118 guests
