darkking
gsm error : unable to load unread sms - timeout
Tue Nov 05, 2013 5:19 pm
Hi, I have this problem.
Mikrotik router 951Ui-2HnD with v6.5 OS.
I have a 3,5G USB modem connected to the router's USB port. I have enabled the router to receive SMS.
But after 30 minutes more or less the router is unable to load sms messages that were sent to the phone nr in the USB modem. Therefore I cannot start scripts via SMS. It is a big problem.
Any ideas?
Greetings,
Ahto
tomaskir
Trainer
Trainer
Re: gsm error : unable to load unread sms - timeout
Wed Nov 06, 2013 7:31 pm
Same problem here.
Do you know if this happends in 6.4 as well?
darkking
Sat Nov 09, 2013 10:29 am
Hello.
I was able to fix this problem: got a brand new gsm usb modem and changed it with the old one.
It was running like two days without any fall backs.
But now I have another problem, print from the log:
gsm, error: unable to load unread sms: cannot open port
It means that the service just brokes down, I mean the "Receive Enabled" is not turned in from some random moment (no tick in the /tool/sms Receive Enabled).
I know that it is turned off automatically when to router reboots, but this has not happened.
I will make a script to automatically put the tick in with 10h interval. I don't like it but there is no other better solution to try.
tomaskir
Trainer
Trainer
Tue Nov 12, 2013 2:34 pm
So my problem (6.4 and 6.5):
Multiple modems, tested with channels 0,1.
The receive-sms just breaks down after about 30 minutes, with the timeout error. I tried scripting around it, but after it disables itself, its impossible to turn it back up.
ros code
[admin@SXT] /tool sms set receive-enabled=yes
failure: timeout
So I hoped that something like this would solve it:
ros code
/system routerboard usb power-reset dur=3s
:delay 30s
/tool sms> set receive-enabled=yes
But with that I get
ros code
action timed out - try again, if error continues contact MikroTik support and send
 a supout file (13)
I wrote to support last week, of course, no responce.
I have this on a system that is 40 miles from me, on a mountain where there is no road. This is currently a MAJOR problem for me :?
pablo191f
Sun Sep 14, 2014 11:06 am
Any solution for error "unable to load unread sms: cannot open port" ?
I changed my RB751U-2HnD, v6.17 to RB951G-2HnD, v6.19, FW: 3.18 and I have this issue now. Errors occur once or twice a day. Modem: ZTE MF636.
On rb751u with s/w 6.17 it worked 100% stable (few months without any error)
cicserver
Tue Oct 13, 2015 1:41 pm
same here. (ver 6.32 / 6.29)
/too sms print
action timed out - try again, if error continues contact MikroTik support and send a supout file (13)
genesispro
Tue Aug 23, 2016 1:22 pm
I also have it on a 922UAGS-5HPacD with a HUAWEI ME909u-521 modem.
It is working for a few days and suddenly I get it with no reboot. And the worst thing is that it can't be resolved with a reboot. I have to place the sim to a phone remove all sms and then it is back but it is not a solution.
On my last attempt I even used the latest RC 6.37rc20 (I also had it on the stable version 6.36)
genesispro
Thu Sep 08, 2016 3:20 pm
Still no way to fix this issue?
DrWindowsRU
Mon Dec 10, 2018 3:56 pm
If someone comes in handy: I changed the operator (SIM card) and it all worked ...
ohara
Sun Apr 26, 2020 1:40 pm
This fixed it for me: I had the same issue, which was caused by a power failure. Something locked up messages on my sim card and I could not receive new ones. After the power failure all sms messages disappeared from the inbox, but they were still there and visible when I moved the sim card to another router with a different gsm modem. The following steps kind of unlocked the sim card and I can now receive messages again:
1. open up serial terminal on ROUTER OS
system serial-terminal usb2 channel=0
2. delete all messages with AT command
AT+cmgd=,4
For your reference: https://m2msupport.net/m2msupport/atcmg ... -messages/
tEsrty3
Fri Feb 03, 2023 8:49 pm
For me the issue was fixed by specifying "channel 2" instead of channel 0 in the SMS settings. GSM log is more chatty now and I get zero timeouts. Swapping SIM cards didn't help at all.
The only issue is that after each reboot you must go to SMS settings in Webfig to "activate" the modem, otherwise it won't be receiving anything. It can probably be done in console somehow, perhaps by sending some (any?) AT command to the modem, but I haven't figured that out yet.
Users browsing this forum: Amazon [Bot], infabo, jericho, lif2k3, massinia, raiser, videolab and 120 guests
