Hi guys im new here.
I wanna make dual wan load balance (first w/o fail over) i tryed with few tutorials but this not working i think because i wanna use it in different way.
I have 12km bridge on rockets M5 i wanna make another bridge and load balance my all trafic on this two bridges.
I wanna distribute all trafic for 2 bridges and later maybe fail over if any1 will down.
i tryed this http://aacable.wordpress.com/?s=dual+wan but its dont work :/
/ip firewall mangle
add action=mark-connection chain=input in-interface=WAN1 new-connection-mark=WAN1_conn
add action=mark-connection chain=input in-interface=WAN2 new-connection-mark=WAN2_conn
add action=mark-routing chain=output connection-mark=WAN1_conn new-routing-mark=to_WAN1
add action=mark-routing chain=output connection-mark=WAN2_conn new-routing-mark=to_WAN2
add chain=prerouting dst-address=192.168.1.0/24 in-interface=Local
add chain=prerouting dst-address=192.168.2.0/24 in-interface=Local
add action=mark-connection chain=prerouting dst-address-type=!local in-interface=Local new-connection-mark=WAN1_conn per-connection-classifier=\
both-addresses-and-ports:2/0
add action=mark-connection chain=prerouting dst-address-type=!local in-interface=Local new-connection-mark=WAN2_conn per-connection-classifier=\
both-addresses-and-ports:2/1
add action=mark-routing chain=prerouting connection-mark=WAN1_conn in-interface=Local new-routing-mark=to_WAN1
add action=mark-routing chain=prerouting connection-mark=WAN2_conn in-interface=Local new-routing-mark=to_WAN2
add action=masquerade chain=srcnat out-interface=WAN1
add action=masquerade chain=srcnat out-interface=WAN2
add check-gateway=ping distance=1 gateway=192.168.1.1 routing-mark=to_WAN1
add check-gateway=ping distance=1 gateway=192.168.2.1 routing-mark=to_WAN2
add check-gateway=ping distance=2 gateway=192.168.2.1
second rb working fine after the bridge i just cant load balanced on first rb 750
i hope i wrote everything tnx for help
