Wed Jan 15, 2014 2:09 am
# jan/02/1970 00:10:20 by RouterOS 6.7
# software id = T6W9-7WV2
set [ find default-name=ether5 ] master-port=ether2
set [ find default-name=ether6 ] master-port=ether2
set [ find default-name=ether7 ] master-port=ether2
set [ find default-name=ether8 ] master-port=ether2
set [ find default-name=ether9 ] master-port=ether2
set [ find default-name=ether10 ] master-port=ether2
set [ find default-name=ether11 ] master-port=ether2
set [ find default-name=ether12 ] master-port=ether2
set [ find default-name=ether14 ] master-port=ether2
/interface ethernet switch
set bridge-type=service-vlan-bridge bypass-l2-security-check-filter-for="" \
bypass-vlan-ingress-filter-for="" \
drop-if-invalid-or-src-port-not-member-of-vlan-on-ports="" \
drop-if-no-vlan-assignment-on-ports="" egress-mirror-ratio=1/1 \
egress-mirror0-enable=yes egress-mirror0-format=modified \
egress-mirror0-port=switch1-cpu egress-mirror0-port=switch1-cpu \
egress-mirror1-enable=yes egress-mirror1-format=modified \
egress-sampling-ratio=1/1 fdb-uses=mirror0 forward-invalid-vlan=yes \
ingress-mirror-ratio=1/1 ingress-mirror0-enable=yes \
ingress-mirror0-format=modified ingress-mirror0-port=switch1-cpu \
ingress-mirror1-enable=yes ingress-mirror1-format=modified \
ingress-mirror1-port=switch1-cpu invalid-vlan-lookup-mode=ivl \
ipv4-multicast-lookup-mode=dst-mac-and-vid-always mac-level-isolation=no \
mirror-egress-if-ingress-mirrored=no mirror-tx-on-mirror-port=no \
mirrored-packet-drop-precedence=green mirrored-packet-qos-priority=0 \
override-existing-when-ufdb-full=no unicast-fdb-timeout=5m \
use-cvid-in-one2one-vlan-lookup=yes use-svid-in-one2one-vlan-lookup=no \
vlan-level-isolation=yes vlan-uses=mirror0
/port
set 0 name=serial0
/interface ethernet switch dscp-qos-map
set (unknown) priority=1
set (unknown) drop-precedence=yellow
set (unknown) drop-precedence=red
set (unknown) priority=2
set (unknown) drop-precedence=yellow priority=2
set (unknown) drop-precedence=red priority=2
set (unknown) priority=3
/interface ethernet switch egress-vlan-translation
add customer-vid=11 new-customer-vid=0 port=ether5
add customer-vid=12 new-customer-vid=0 port=ether6
add customer-vid=13 new-customer-vid=0 port=ether7
add customer-vid=14 new-customer-vid=0 port=ether8
add customer-vid=15 new-customer-vid=0 port=ether9
add customer-vid=16 new-customer-vid=0 port=ether10
add customer-vid=17 new-customer-vid=0 port=ether11
add customer-vid=18 new-customer-vid=0 port=ether12
add customer-vid=19 new-customer-vid=0 port=ether13
add customer-vid=20 new-customer-vid=0 port=ether14
/interface ethernet switch ingress-vlan-translation
add customer-vid=0 new-customer-vid=11 port=ether5
add customer-vid=0 new-customer-vid=12 port=ether6
add customer-vid=0 new-customer-vid=13 port=ether7
add customer-vid=0 new-customer-vid=14 port=ether8
add customer-vid=0 new-customer-vid=15 port=ether9
add customer-vid=0 new-customer-vid=16 port=ether10
add customer-vid=0 new-customer-vid=17 port=ether11
add customer-vid=0 new-customer-vid=18 port=ether12
add customer-vid=0 new-customer-vid=19 port=ether13
add customer-vid=0 new-customer-vid=20 port=ether14
set 0 egress-vlan-mode=unmodified isolation-profile=30 \
learn-restricted-unknown-sa=yes per-queue-scheduling="wrr-group1:1,wrr-gro\
up1:2,wrr-group1:4,strict-priority:0,wrr-group0:0,wrr-group0:0,wrr-group0:\
0,wrr-group0:0"
set 1 egress-vlan-mode=unmodified isolation-profile=30 \
0,wrr-group0:0"
set 2 egress-vlan-mode=unmodified isolation-profile=30 \
0,wrr-group0:0"
set 3 egress-vlan-mode=unmodified isolation-profile=30 \
0,wrr-group0:0"
set 4 egress-vlan-mode=unmodified isolation-profile=30 \
0,wrr-group0:0"
set 5 egress-vlan-mode=unmodified isolation-profile=30 \
0,wrr-group0:0"
set 6 egress-vlan-mode=unmodified isolation-profile=30 \
0,wrr-group0:0"
set 7 egress-vlan-mode=unmodified isolation-profile=30 \
0,wrr-group0:0"
set 8 egress-vlan-mode=unmodified isolation-profile=30 \
0,wrr-group0:0"
set 9 egress-vlan-mode=unmodified isolation-profile=30 \
0,wrr-group0:0"
set 10 egress-vlan-mode=unmodified isolation-profile=30 \
0,wrr-group0:0"
set 11 egress-vlan-mode=unmodified isolation-profile=30 \
0,wrr-group0:0"
set 12 egress-vlan-mode=unmodified isolation-profile=30 \
0,wrr-group0:0"
set 13 egress-vlan-mode=unmodified isolation-profile=30 \
0,wrr-group0:0"
set 14 egress-vlan-mode=unmodified isolation-profile=30 \
0,wrr-group0:0"
set 15 egress-vlan-mode=unmodified isolation-profile=30 \
0,wrr-group0:0"
set 16 egress-vlan-mode=unmodified isolation-profile=30 \
0,wrr-group0:0"
set 17 egress-vlan-mode=unmodified isolation-profile=30 \
0,wrr-group0:0"
set 18 egress-vlan-mode=unmodified isolation-profile=30 \
0,wrr-group0:0"
set 19 egress-vlan-mode=unmodified isolation-profile=30 \
0,wrr-group0:0"
set 20 egress-vlan-mode=unmodified isolation-profile=30 \
0,wrr-group0:0"
set 21 egress-vlan-mode=unmodified isolation-profile=30 \
0,wrr-group0:0"
set 22 egress-vlan-mode=unmodified isolation-profile=30 \
0,wrr-group0:0"
set 23 egress-vlan-mode=unmodified isolation-profile=30 \
0,wrr-group0:0"
set 24 egress-vlan-mode=unmodified isolation-profile=30 \
0,wrr-group0:0"
set 25 egress-vlan-mode=unmodified isolation-profile=31 \
0,wrr-group0:0"
/ip service
set "" disabled=no port=22
/lcd interface
set ether1 interface=ether1
set ether2 interface=ether2
set ether3 interface=ether3
set ether4 interface=ether4
set ether5 interface=ether5
set ether6 interface=ether6
set ether7 interface=ether7
set ether8 interface=ether8
set ether9 interface=ether9
set ether10 interface=ether10
set ether11 interface=ether11
set ether12 interface=ether12
set ether13 interface=ether13
set ether14 interface=ether14
set ether15 interface=ether15
set ether16 interface=ether16
set ether17 interface=ether17
set ether18 interface=ether18
set ether19 interface=ether19
set ether20 interface=ether20
set ether21 interface=ether21
set ether22 interface=ether22
set ether23 interface=ether23
set ether24 interface=ether24
set sfp1 interface=sfp1
/lcd interface pages
set 0 interfaces="ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8,ethe\
r9,ether10,ether11,ether12"
set 1 interfaces="ether13,ether14,ether15,ether16,ether17,ether18,ether19,ethe\
r20,ether21,ether22,ether23,ether24"
