gerhard
RB2011UAS-RM PXE setup not working
Sun Mar 23, 2014 2:34 am
I have a Dell PowerEdge 2970 which doesn't want to PXE boot, error is: "No PXE-capable device available".
I can confirm that the server's IP address is 192.168.88.20, netmask 255.255.255.0 and gateway 192.168.88.1. It gets the network config via DHCP, it's not statically configured.
The RB2011-UAS is setup as follows:
[admin@MikroTik] > /ip dhcp-server network export
# mar/23/2014 00:26:33 by RouterOS 6.11
# software id = 0YXJ-NGJP
add address=192.168.88.0/24 boot-file-name=pxelinux.0 comment="default configuration" dns-server=192.168.88.1 \
    gateway=192.168.88.1 next-server=192.168.88.1
[admin@MikroTik] > /ip tftp print
Flags: X - disabled
 #   IP-ADDRESSES         REQ-FILENAME             REAL-FILENAME            ALLOW READ-ONLY ALLOW-ROLLOVER       HITS
 0   192.168.88.0/24      pxelinux.0               usb1/tftp/pxelinux.0     yes   yes       no                      0
 1   192.168.88.0/24      bootmsg.txt              usb1/tftp/bootmsg.txt    yes   yes       no                      0
 2   192.168.88.0/24      memdisk                  usb1/tftp/memdisk        yes   yes       no                      0
 3   192.168.88.0/24      pxelinux.cfg/default     usb1/tftp/pxelinux.cf... yes   yes       no                      0
 4   192.168.88.0/24      mini.iso                 usb1/tftp/mini.iso       yes   yes       no                      0
[admin@MikroTik] > /file print
 # NAME                                      TYPE                                           SIZE CREATION-TIME
 0 usb1/lost+found                           directory                                           mar/22/2014 23:06:53
 1 usb1/tftp                                 directory                                           mar/22/2014 23:15:23
 2 usb1/tftp/bootmsg.txt                     .txt file                                       199 mar/22/2014 23:15:22
 3 usb1/tftp/mini.iso                        .iso file                                   21.5MiB mar/22/2014 23:15:24
 4 usb1/tftp/memdisk                         file                                        25.5KiB mar/22/2014 23:15:23
 5 usb1/tftp/pxelinux.0                      .0 file                                     16.4KiB mar/22/2014 23:15:23
 6 usb1/tftp/pxelinux.cfg                    directory                                           mar/22/2014 23:15:23
 7 usb1/tftp/pxelinux.cfg/default            .cfg/default file                               161 mar/22/2014 23:15:23
 8 usb1                                      disk                                                mar/23/2014 00:28:27
Not sure where the problem is. There's nothing in the logs.
TonyJr
Re: RB2011UAS-RM PXE setup not working
Sun Mar 23, 2014 5:52 pm
You need to specify boot server in dhcp options.
Option 66 is TFTP server address
Option 67 is bootfile
Sent from my BlackBerry 9900 using Tapatalk
gerhard
Sun Mar 23, 2014 8:48 pm
I thought the 66 and 67 options are no longer recommended, and boot-file-name & next-server are meant to be used instead. Anyways, I have added the 2 options as suggested but I'm still getting the same "No PXE-capable device available" error on the server:
[admin@MikroTik] > /ip dhcp-server option print
 # NAME                                CODE VALUE                              RAW-VALUE
 0 TFTP-Server                           66 '192.168.88.1'                     c0a85801
 1 PXE-File                              67 'pxelinux.0'                       7078656c696e75782e30
# mar/23/2014 18:43:41 by RouterOS 6.11
add address=192.168.88.0/24 boot-file-name=pxelinux.0 comment="default configuration" dhcp-option=\
    PXE-File,TFTP-Server dns-server=192.168.88.1 gateway=192.168.88.1 next-server=192.168.88.1
Users browsing this forum: bertus, Bing [Bot], dervomsee, mgual, Mr47, pmcsill, unam83 and 137 guests
