luqasz
badly selected OSPF route. ignored cost
Mon Apr 28, 2014 3:18 pm
hi
i have made a lab with diagram as in
R1
/routing ospf instance
set [ find default=yes ] disabled=no distribute-default=if-installed-as-type-1 !domain-id \
    !domain-tag in-filter=ospf-in metric-bgp=auto metric-connected=20 metric-default=1 \
    metric-other-ospf=auto metric-rip=20 metric-static=20 !mpls-te-area !mpls-te-router-id \
    name=default out-filter=ospf-out redistribute-bgp=no redistribute-connected=no \
    redistribute-other-ospf=no redistribute-rip=no redistribute-static=no router-id=1.1.1.1 \
    !routing-table !use-dn
/routing ospf area
set [ find default=yes ] area-id=0.0.0.0 disabled=no instance=default name=backbone type=\
    default
add area-id=0.0.0.1 disabled=no instance=default name=area1 type=default
/routing ospf interface
add authentication=none authentication-key="" authentication-key-id=1 cost=10 dead-interval=\
    40s disabled=no hello-interval=10s instance-id=0 interface=all network-type=broadcast \
    passive=no priority=1 retransmit-interval=5s transmit-delay=1s use-bfd=yes
    40s disabled=no hello-interval=10s instance-id=0 interface=ether1 network-type=broadcast \
    passive=yes priority=1 retransmit-interval=5s transmit-delay=1s use-bfd=no
/routing ospf network
add area=backbone disabled=no network=10.1.4.0/24
add area=area1 disabled=no network=0.0.0.0/0
add address=10.1.4.2/24 interface=ether2 network=10.1.4.0
add address=10.1.3.2/24 interface=ether3 network=10.1.3.0
R2
set [ find default=yes ] disabled=no distribute-default=never !domain-id !domain-tag \
    redistribute-other-ospf=no redistribute-rip=no redistribute-static=no router-id=2.2.2.2 \
/routing ospf area
    default
add authentication=none authentication-key="" authentication-key-id=1 cost=10 \
    dead-interval=40s disabled=no hello-interval=10s instance-id=0 interface=all \
    network-type=broadcast passive=no priority=1 retransmit-interval=5s transmit-delay=1s \
    use-bfd=yes
add address=10.1.1.3/24 interface=ether4 network=10.1.1.0
add address=10.1.4.3/24 interface=ether2 network=10.1.4.0
R3
    redistribute-other-ospf=no redistribute-rip=no redistribute-static=no router-id=3.3.3.3 \
/routing ospf area
    default
add address=10.1.2.2/24 interface=ether5 network=10.1.2.0
add address=10.1.1.1/24 interface=ether4 network=10.1.1.0
R4
    redistribute-other-ospf=no redistribute-rip=no redistribute-static=no router-id=4.4.4.4 \
/routing ospf area
    default
    use-bfd=yes
add address=10.1.3.4/24 interface=ether3 network=10.1.3.0
add address=10.1.2.4/24 interface=ether5 network=10.1.2.0
R2 should pick default route through R1. Unfortunatelly it does not. It installs default route from ospf with cost=31 via R3. If I tear down link between R3 and R2, R2 installs default route via R1 (which is desired). This route has cost=11. When link between R2 and R3 comes up, R2 installs back "wrong" route via R3.
I have reproduced exactly the same setup in GNS3 with mikrotik in qemu and on cisco IOS. On cisco no such problem was present.
Either there is some option witch I forgot to set, or mikrotik has a bug.
digicomtech
Re: badly selected OSPF route. ignored cost
Mon Apr 28, 2014 5:36 pm
I'm happy to see someone with a lab test showing this problem.
We've got similar problem with ROS OSPF routing.
In our production environment, all OSPF route with the best cost are installed in routing table and that is the correct behavior for OSPF. However, we got a loop on our backbone and when one link goes down and get back after a while, external route distributed through this link is use whenever the cost is !
I don't have much more information but I guess this could be related with time synchronisation.
Do your lab setup have pefect time synchronisation ?
Edit: It looks like a multiarea OSPF problem. It seems to be described in RFC5185 as describe in ths post:
http://forum.mikrotik.com/viewtopic.php ... hilit=ospf
Regards,
luqasz
Mon Apr 28, 2014 8:29 pm
Regards,
I do not think so. Problem described in link is a different one. R2 knows about 2 paths. intra and inter area. R2 does not install intra area path (witch should).
