Ulypka
OVPN bridging
Fri May 16, 2014 11:54 am
Ovpn in the bridge is still not working :(
[Ticket#2014051466000539]
macgaiver
Re: v6.13 released!
Fri May 16, 2014 12:01 pm
OVPN and bridge? How?
You can bridge only interfaces with MAC addresses or PPP interfaces with enabled BCP (Bridge Control Protocol).
So i do not see how that's a bug
Ulypka
Re: v6.13 released!
Fri May 16, 2014 12:05 pm
interface ovpn-server server set mode=ethernet
ppp profile set 0 bridge=bridge1
ROS in <6.8 works
in ROS 6.8 6.9 6.10 6.11 6.12 6.13 not working
sergejs
Re: v6.13 released!
Fri May 16, 2014 12:08 pm
Ulypka, you should have bcp enabled on both sides of PPP (OpenVPN) tunnel.
npero
Re: v6.13 released!
Fri May 16, 2014 12:10 pm
ROS in <6.8 works
Not tested in 6.13 but can confirm in older version bug is you can access to every device in network but not on device where is OpenVPN server like device where is server not in bridge.
Ticket#2014032466000827 open 24.3.2014 for now support not response on this ticket.
Open new ticket Ticket#2014051266000801 12.5.2014. for now noting from MT.
Ulypka
Re: v6.13 released!
Fri May 16, 2014 12:17 pm
confirm bridge with two sides work on MT
and what to do if I connect from windows?
macgaiver
Re: v6.13 released!
Fri May 16, 2014 12:19 pm
Ulypka there is no such feature! It is not a bug! Windows doesn't support any tunnel bridging, it is RouterOS-to-RouterOS feature (and RouterOS-to-Cisco)
npero
Re: v6.13 released!
Fri May 16, 2014 12:22 pm
But in older version works :), also windows to windows work, also in my case only problem is MT device where is server other devices in bridged network work. Problem is happen when MT introduce new PPP package.
Ulypka
Re: v6.13 released!
del.
Ulypka
Re: v6.13 released!
Fri May 16, 2014 12:24 pm
http://forum.mikrotik.com/viewtopic.php ... 96#p426396
just flashing from 6.7 to 6.11
and stops working
npero
Re: v6.13 released!
Fri May 16, 2014 12:25 pm
rextended, I will check for the issue, and try to find out why it is not fixed yet.
And we will try to fix it at 6.14 version.
Check Ticket#2014032466000827 you have explanation how to try.
Ulypka
Re: v6.13 released!
Fri May 16, 2014 12:27 pm
sergejs
As i understand it will not be correct (that would work in version 6.7)?
macgaiver
Re: v6.13 released!
Fri May 16, 2014 12:32 pm
No, it doesn't. you can't get proper MAC-level communications to Windows in any version of RouterOS, maybe you had some setup that had similar behaviour but i'm sure it is not proper bridging. you can simply see this enabling debug logs and see that BCp protocol is not supported by windows client.
Ulypka
Re: OVPN bridging
Fri May 16, 2014 12:54 pm
macgaiver
I have worked with this configuration version 5.11 to 6.7 on any computer
and 6.8 all broke
http://wiki.mikrotik.com/wiki/OpenVPN
Windows
client of a bridged server (tap)
proto tcp-client
remote openvpn.example.com 1194 # Remote OpenVPN Servername or IP address
dev tap
nobind
persist-key
tls-client
ca ca.crt # Root certificate in the same directory as this configuration file.
cert keys/client.crt
key keys/client.key
Ulypka
Re: OVPN bridging
Fri May 16, 2014 1:20 pm
apparently do not even try packages sent
npero
Re: v6.13 released!
Fri May 16, 2014 2:27 pm
Not need full layer 2 support but working like in older version is ok. My configuration is simple MT OpenVPN server in bridge and Windows OpenVPN client for me everything is working only MT device very is server is not accessible. I use OpenVPN because have some location where need to use connection trough proxy server, but now administrators on that network open port for 1723 an gre and everything is switching to PPTP.
But why something is working in older version not working in new version.
And one more thing support not answering on that ticket more that 2 months if support say ok that in new PPP package can be don't ok I can live witout it, but not answering on ticket is not professional because I insist to this feature working.
Ulypka
Re: OVPN bridging
Wed May 21, 2014 7:50 am
support
MarcusW
Re: OVPN bridging
Sat Jun 14, 2014 1:28 am
Same problem here, just tried with 6.15. :( Has someone got any feedback from Mikrotik about this yet?
tscarborough
Re: OVPN bridging
Thu Jun 26, 2014 7:52 pm
I have confirmed this does work in 6.7. I made the mistake of upgrading a ovpn concentrator to 6.15 from 5.26 needless to say all of the connections stopped functioning.
Any update of when or if this will be corrected. I could not even ping the ip of the remote ovpn-out interface after upgrading.
Users browsing this forum: Bing [Bot], Google [Bot], simtj and 181 guests
