sergejs
RouterOS v6.23.1 special release
Tue Dec 09, 2014 9:05 am
6.23.1 version has x86 driver firmware fixes (few old Network Interface Cards might not work properly).
Update is not needed for RouterBOARD users.
x86 all-in-one package,
http://www.mikrotik.com/download/share/ ... 6.23.1.npk
x86 all packages,
http://www.mikrotik.com/download/share/ ... es_x86.zip
DLNoah
Re: RouterOS v6.23.1 special release
Wed Dec 10, 2014 6:13 pm
Is this release specific to an issue/driver introduced in v6.23, or are there previous potentially effected firmware versions?
TechIsCool
Wed Dec 10, 2014 6:56 pm
I would also like to know this since I am fighting a bug I think that makes all my interfaces fail. But I am running this version and its still doing it.
rzirzi
Fri Dec 12, 2014 6:52 pm
I can confirm, that Intel cards works OK under MT6.23.1 at x86, but this fu...g BUG costed me trip about 80km early morning! Who will pay for that and for network inaccessibility??!!
Chupaka
Fri Dec 12, 2014 7:17 pm
I think, a man who decided to upgrade without testing should pay :)
rzirzi
Fri Dec 12, 2014 7:49 pm
Rather the man who decided to publish that BUGGY version as STABLE!!!
boen_robot
Fri Dec 12, 2014 7:55 pm
It was stable in their test environment, so no one intentionally published a "buggy version as stable".
Chupaka
Fri Dec 12, 2014 8:02 pm
they produce RouterBoards, not Intel cards, and that version surely works on RouterBoards ;)
rzirzi
Fri Dec 12, 2014 8:26 pm
Shuold, but do not work properly MANY times - see manry problems with CCR's.
Caci99
Tue Dec 16, 2014 2:12 pm
This is a forum where people post their problems. Very, very, very rarely you would see posts with success stories. It is an irony of life actually, you would notice a device exits when it gives problems :)
Users browsing this forum: eworm, felixka, jaclaz, peri, Qanon, sambol, Unintentional and 65 guests
