hossain2004a
CCTV Port forwarding [SOLVED]
Tue Mar 17, 2015 7:35 am
Hi guys.
I was wondering if someone can help me.
I'm able to open my office router page in home by entering DNS page and right port number.
no problem, I can open my webfig and UM page via remote computer.
The problem is to open DVR or CCTV's page.
If I'm gonna open my CCTV's page over my local network I will enter:
192.168.20.123
and when I enter user and password i can access my CCTVs.
for port forwarding I will forward my 9876 port to my cctv's address and port 80.
so by entering:
mydnsname.net:9876 i will redirect to my cctv. and you should know my DVR is using port: 8000 to transmit data over network.
the problem is here that when i enter user and password it says:
Get data from server failed.
so I forward 8000 port to my cctv's address and port 80. after that:
Not enough buffer size
So can anyone tell me how to forward right ports and is there anything i'm missing?
rajeshrouthu
Re: CCTV Port forwarding
Tue Mar 17, 2015 8:02 am
Bro,
Follow the Steps you need add the same for rstp and mobile dst ports.
chain=dstnat action=dst-nat to-addresses=172.168.100.145 to-ports=80 protocol=tcp dst-address=202.x.x.x in-interface=WAN dst-port=8082 (http)
chain=dstnat action=dst-nat to-addresses=172.168.100.145 to-ports=554 protocol=tcp dst-address=202.x.x.x in-interface=WAN dst-port=554 (Rtsp)
chain=dstnat action=dst-nat to-addresses=172.168.100.145 to-ports=8000 protocol=tcp dst-address=202.x.x.x in-interface=WAN dst-port=8000 (Mobile)
Rajesh R
hossain2004a
Tue Mar 17, 2015 8:13 am
That's great.
Thanks for quick reply Rajesh :D
All you need is to forward 2 ports:
1 of them to you CCTV (xxxx to 80)
another one to the port which is transmitting (8000 to 8000)
rajeshrouthu
Re: CCTV Port forwarding [SOLVED]
Tue Mar 17, 2015 8:33 am
Yes,
RTSP Port Also needed to stream the content.
erikalittaua
Wed Nov 08, 2017 8:56 am
Hi
I have two CCTV devices on two different IP (192.168.0.10 and 192.168.0.20)
I followed Rajesh's sample below:
This works fine but I have another device so I am not sure if I should use the same port?
192.168.0.20 uses 8000 port thats why I can follow the code above
192.168.0.20 uses 7000 port so how do i configure its dst nat?
Users browsing this forum: Aska, GoogleOther [Bot], Javokhir, plastilin, qwertykolea and 203 guests
