Referring to Ticket # 2015042066000634, the problem persists.
My Radius is configured to allow one connection per customer.
I do not believe that is the Radius, because what happens is as follows:
My Radius only authorizes the connection.
The IPS POOL is in Mikrotik
1. Customer initiates PPPoE dial;
2. Mikrotik queries Radius;
3. Radius authorizes the client;
4. Mikrotik authenticates the client.
THE PROBLEM:
1. Randomly some authenticate clients, but do not sail;
2. Active PPP connections in the address field, appears in the IP that the client received;
3. PPP interface, the same client, the Remote Address field is empty;
4. PPP interface, this same customer is om the only status with D (dinamic) but nowhere with R (Running);
5. In IP Address, the same client is in red, with the status D (Dynamic) and I (Invalid);
6. Interfaces, the same customer is with Status D (Dynamic) and without the R (Running) and also not as a slave of the physical interface;
7. IP Route, is not created proper route (/ 32) to the client.
RESULT: The PPPoE session is established, the client receives IP, but the RouterOS for some reason creates totally bugged connection.
CUSTOMER IS NO CONNECTION.
After some time, the RouterOS "adjusts" the connection, creates the route and the customer browsing normally.
