If the distance is not so far for the link - up to km then try to set the distance to indoors.v6.35rc2 ping time ap to station 8ms, device shows distance with value 1 km
Upgrade v6.35rc3 ap to station 150ms, device shows distance with value 5 km, using the same conditions!
You guys should try other Winbox version, maybe 3.0 or 3.1.I can confirm that too.Maybe the question is missed... There is no 'default authenticate' option tickbox anymore......Is the default authenticate option gone? Is client now always to connect to units mentioned in the 'Connect List'?
hping3 --udp --data 512 --rand-source -i u10 <mikrotick ip>
Yesterday I install 6.35rc3 on CCS-1036 Mikrotik Hardware and run following command to test network performance using firewall rules.. i added single rules in firewall to track connection
Above command created around ~500k connection in connection table almost max out. CPU was 50%-60% and after 15 min kernel crash and Mikrotik rebooted.Code: Select allhping3 --udp --data 512 --rand-source -i u10 <mikrotick ip>
I have opened ticket to support but they are saying it because of connection table full. But I am saying no matter connection table full or kernel should not get panic and crash
Does anyone able to produce this issue?
Hi guys,Version 6.35rc5 has been released.
I was thinking the same thing!What's the use of Background Scan if it disconnect radio before ticking it?
Like InoX and Cha0s wrote, it also doesn't work on my SXT's.Background scan does not work via Webfig.
When I try it from Webfig it disconnects clients but when I try the same thing from winbox then it works.
Latest rep package on 951g.
Is this an answer to my question re the missing 'default auth' box?Version 6.35rc4 has been released.
Changes since previous version:
*) dude - (changes discussed here: http://forum.mikrotik.com/viewtopic.php?f=8&t=104395)
*) certificate - allow manual crl url addition;
*) ipsec - fix console peer aes enc algorithm display;
*) ipsec - fix fast ph2 SA addition;
*) led - fix crash on assigned interface removal;
*) lte - support Alt38XX modem;
*) tile-crypto - fix minor memory leak;
*) wireless-rep - allow to connect to AP after scan;
*) wireless-rep - fix signal leds;
*) wireless-rep - request interface name for setup-repeater;
*) wireless-rep - adjust roaming scan times;
*) wireless-rep - do not allow empty ssid for AP modes.
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as suspected or after crash.
So, will this help improve PtP throughput performance for 802.11n or AC?
And what about voltage monitor in 493g?Version 6.35rc6 has been released.
*) dude - (changes discussed here: http://forum.mikrotik.com/viewtopic.php?f=8&t=104395);
*) ipsec - always re-key ph1 because it was possible that ph1 without DPD would expire;
*) log - try not to loose disk messages and warn if lost any;
*) switch - make "sa-learning=yes" by default when adding Ingress VLAN Translation rules;
*) system - log time changes;
*) trafflow - fix potential deadlock.
Mmmm.... Interesting!!! Hotspot 2.0 with HTTPS-Redirection and another new features in the last 6.35rc7
[img]https://www.dropbox.com/s/15zj0l5au84gk ... 9.png?dl=0[/img]
Yes! not tested in other... but i am very happy with these new features and supports!Included in new wireless repeater package?
NoIncluded in new wireless repeater package?
Why I can't find any over 802.11u? The Question is when Mikrotik will release this Protocol in their AP's configurations!Yes! not tested in other... but i am very happy with these new features and supports!Included in new wireless repeater package?
Very interesting to typing the commands into new terminal, but I'don't understand how works this type of hotspot; how control the users payments, access limits etc, etc??????Yes! not tested in other... but i am very happy with these new features and supports!Included in new wireless repeater package?
we're can only guess, i think.Why I can't find any over 802.11u? The Question is when Mikrotik will release this Protocol in their AP's configurations!
This fixes the issues with LNS function to carry PPPoE sessions over L2TP tunnels.6.35rc9 has been released.
*) l2tp - added support for proxy authentication when receiving forwarded PPPoE sesssions;
*) l2tp - added support for Hidden AVP, it is needed for proxy authentication;
Hello MikroTik support team,Version 6.35rc5 has been released.
*) ssh - fixed connection stalling.
I can't find this, in 2,4 ghz device and not in 5,8 ghz (6.35rc10)6.35rc9 has been released.
*) ipsec - fix larval SA refresh for display;
*) wireless-rep - added 802.11g/n only band;
*) wireless-rep,capsman - added rate config support;
*) wireless-rep,capsman - added more configuration settings;
*) ssh - simplify login process;
*) ups - fix entering hibernate mode when below battery capacity limit;
*) ups - fix waiting for AC power restore in hibernate mode;
*) lte - fix allowed bands for RBSXTLTE3-7;
*) lte - support for zte mf820s2.
802.11b or 802.11g is working on 2.4GHz not 5GHz look the wikipedia https://en.wikipedia.org/wiki/IEEE_802.11
Yes same here[
it is on the download page:is any decription/changelog for 635rc11, yet ?
What's new in 6.35rc11 (2016-Feb-17 09:09):
*) winbox - added factory-firmware field to system/routerboard;
*) l2tp - ipsec peer & policy sometimes was not removed after l2tp interface disable;
*) pptp - fixed kernel crash when receiving fragmented packet with fragmented header;
*) www - fixed www crash;
*) winbox - fixed email address saving;
*) queue - added bucket-size setting to queues (derived from max-limit);
*) queue - improve "/queue interface" menu;
! No band g/n Option !!!it is on the download page:is any decription/changelog for 635rc11, yet ?
For others with wireless band issues -Code: Select allWhat's new in 6.35rc11 (2016-Feb-17 09:09): *) winbox - added factory-firmware field to system/routerboard; *) l2tp - ipsec peer & policy sometimes was not removed after l2tp interface disable; *) pptp - fixed kernel crash when receiving fragmented packet with fragmented header; *) www - fixed www crash; *) winbox - fixed email address saving;
1) make sure that you are running wireless-rep package;
2) check CLI - features comes to Winbox later that CLI.
BartoszP - Upgrade in this device happens within RAM memory
Kidding or not, misinformation or not, your suggested method has not worked for me.He is not kidding. Upgrade happens in RAM, and it does not matter how much storage you have. Upload goes directly into RAMDRIVE. Please stop spreading misinformation about uploading only one package, this just breaks things
http://forum.mikrotik.com/viewtopic.php ... 43#p519443Most likely you just rebooted device which erased RAM memory and after reboot you had enough space for upgrade.
Yeah, what about it?Again - Warning: If device has a directory named "flash"...
What means CLI??? I don't understand what is CLI????BartoszP - Upgrade in this device happens within RAM memory;
PeterDoBrasil - For now it is available only through CLI.
CLI means "Command line Interface", when you connect with SSH for exampleWhat means CLI??? I don't understand what is CLI????BartoszP - Upgrade in this device happens within RAM memory;
Hey Normis, Is this an Hotspot Bug ????CLI means "Command line Interface", when you connect with SSH for exampleWhat means CLI??? I don't understand what is CLI????BartoszP - Upgrade in this device happens within RAM memory;
A. Restart helped ... inmemory upgrade have made my RB741 @ rc11 ... why not to put "inmemory upgrade in progress" instead of "too low space" ?... You have seen a picture where was clearly visible that BartoszP pressed "download" or "download and install" button in system-packages after checking for update. The response was that there is not enough space for it............
Firstly, it is your decision to make new devices with just 32MB of RAM although I (and others) are telling you that it is too small amount of memory. And besides that, you decided to provide almost any flash memory. OK, I know, 16MB in this case, but not usable to store the packages to be installed, as the running ros is already installed there.
Yes, nice feature indeed.Yeah, pppoe-client fastpath support!!!
Now I can reach 306Mbps download speed (http://www.speedtest.net), and CPU is 34%-40% (on 6.34.2 was 85%), tested on RB951G / Movistar / Spain.
Thanks MikroTik, great job!!
There is no signature displayed in tapatalk. I am not aware about it.It means one point for spammer and zero for jarda, better luck next time.
I don't know if the signature was there before you replied or if it was added later, but it's quite obvious with it. User's first post, does not make much sense, but they made sure they added the signature with link to some commercial activity.
Are you really expecting fastpath when firewall rules are implemented?About this nice feature "*) pppoe-client - implemented fastpath support;"
Is the RB3011 RouterOS specific version really supporting fastpath ?
Why this question:
- It not appears listed as supported in the WIKI page on fatspath.
- My testing after applying the firewall rules and having the counter growing...does not seem to provide any CPU saving on RB3011.
Please, Mikrotik, may you clarify this: today, an RB3011 dowloading one TCP stream at 300 Mbits over PPP and having NAT and a basic configuration of firewall rules needs 80% of one CPU to handle this trafic with spikes up to 90% at 1400 mhz frequency...
This device is starting to remember me the buggy RB850x2: lower performance than anticipated, strange problems (software bridge problems,...), features not working (partition not working,...), hardware revisions (I hope this not again, please)...
It would be "funny" to have to go back to an RB2011: starting to become tired to be patient with MIkrotik...RB3011 is not a 100$ device.
No, but please, be smart too....before trying to teach please learn to read....and use fair-play...please, perhaps,...Are you really expecting fastpath when firewall rules are implemented?About this nice feature "*) pppoe-client - implemented fastpath support;"
Why this question:
Try fasttrack in this case.
Why this question:
What can provide fastrack if trafic over a pure software based not optimized ppoe client implementation?
This combination of both works like a charm in two tested mono-CPU devices....shared by other contributors in this same topic and configuration.
can you share config for wireless-rep ?Wow! This new wireless-rep is fantastic! All my UDP packets are consistent, I have not lost a single packet! Amazing work guys!
What happened with rc13?Version 6.35rc14 has been released.
yes! +1 for that!can you share config for wireless-rep ?Wow! This new wireless-rep is fantastic! All my UDP packets are consistent, I have not lost a single packet! Amazing work guys!
can someone post how to config wireless-rep step by step? i've been searching over here and google but can't find the answer
thx before
Mikrotik crew believe in fengshui that said number 13 is bad so that's why they skip rc13 lolWhat happened with rc13?Version 6.35rc14 has been released.
Iám running v.14 on 4 devices, sxt, Rb2011,BaseBox, without any Problems!Version 6.35rc14 has been released.
*) pppoe - added rfc4679 support;
*) pppoe-server - added pado-delay option;
*) ppp - close connection if peer wants to re-authenticate;
*) winbox - added missing modp8192 to /ipsec peer dh-group;
*) winbox - limit ospf key to 16 symbols;
*) snmp - fix cpu load reporting to 1min average and change oid to 1.3.6.1.4.1.2021.11.10.0;
*) mpls - do not reset VPLS on TE tunnel re-optimize;
*) lcd - add flip-screen option;
*) lcd - security screen did not show ip addresses on ccr;
*) interface queue - fixed "no-queue" on upgrade;
*) fastpath - fixed rare kernel failure;
*) lte - fixed bandlux modem dialing;
*) wireless-rep - fixed qos frame-priroty when nv2 protocol used in station-wds mode;
*) wireless - improved 1-chain 802.11ac station campability with other vendor multichain APs.
Same here, since 6.35rc14. PPtP not working either. "Encryption method not supported" even without encryption. Opened a support ticket with supout (Ticket#2016030266000632).HAP ac on Version 6.35rc15 l2tp/ipsec is not working on windows 7. On 6.34.2 everything is working fine with same settings
Even with latest RC this is still an issue.Same here, since 6.35rc14. PPtP not working either. "Encryption method not supported" even without encryption. Opened a support ticket with supout (Ticket#2016030266000632).HAP ac on Version 6.35rc15 l2tp/ipsec is not working on windows 7. On 6.34.2 everything is working fine with same settings
I see that message from support is sent to you and we have not received reply.Even with latest RC this is still an issue.Same here, since 6.35rc14. PPtP not working either. "Encryption method not supported" even without encryption. Opened a support ticket with supout (Ticket#2016030266000632).HAP ac on Version 6.35rc15 l2tp/ipsec is not working on windows 7. On 6.34.2 everything is working fine with same settings
This problem is fixed in the latest RouterOS v6.35rc19On RC16 if capsman is enable it make the cap to loop boot kernel error
rc16 ==> rc19??This problem is fixed in the latest RouterOS v6.35rc19On RC16 if capsman is enable it make the cap to loop boot kernel error
[raffaello@RJ-AT-MK03 - CAP2] >
[raffaello@RJ-AT-MK03 - CAP2] > /tool fetch address=$ip src-path="$[/system identity get name]_$datetimestring.backup" user=$user password=$pass port=$port upload=ye
s mode=ftp dst-path=($dir."$[/system identity get name]_$datetimestring.backup")
[raffaello@RJ-AT-MK03 - CAP2] > :log info "Sending Backup Mikrotik to FTP Server............."
status: finished
downloaded: 38KiBg
total: 38KiB-z pause]
duration: 0s
[raffaello@RJ-AT-MK03 - CAP2] > dress=$ip src-path="$[/system identity get name]_$datetimestring.rsc" user=$user password=$pass port=$port upload=yes mode=ftp dst-path=($di
r."$[/system identity get name]_$datetimestring.rsc")
:global thisdate [/system clock get date]
:global datetimestring ([:pick $thisdate 0 3] ."-" . [:pick $thisdate 4 6] ."-" . [:pick $thisdate 7 11])
#IP DO SERVIDOR FTP
:global ip "1.1.1.1"
#SUBDIRETORIO NO SERVIDOR REMOTO FTP
:global dir "/RJ-AT-MK02/"
# PORTA DO FTP
:global port "21"
#USUARIO
:global user "backup"
#SENHA
:global pass "B@ckUp"
log info "Starting Automatic Backup Script Configure By Raffaello"
/system backup save name="$[/system identity get name]_$datetimestring"
export file="$[/system identity get name]_$datetimestring"
:log info "Please wait...!!!"
:delay 5s
/tool fetch address=$ip src-path="$[/system identity get name]_$datetimestring.backup" user=$user password=$pass port=$port upload=yes mode=ftp dst-path=($dir."$[/system identity get name]_$datetimestring.backup")
/tool fetch address=$ip src-path="$[/system identity get name]_$datetimestring.rsc" user=$user password=$pass port=$port upload=yes mode=ftp dst-path=($dir."$[/system identity get name]_$datetimestring.rsc")
:delay 1
:log info "Finished Backup Script...!!!!"
:delay 5s
:log info "Deleting backup just created after has sent"
/file remove "$[/system identity get name]_$datetimestring.backup"
/file remove "$[/system identity get name]_$datetimestring.rsc"
What's the point? RC are for testing purposes and it's legit that they introduce bugs/problems and they have the right to build, test, publish, skip any release they want. You should only be happy that we have been given the opportunity to test while they develope so we can help them (and ourselves) having better stable releases.Too many failures in between?
Hi raffavSince the maybe(v34)
this code for sent backup via ftp dont work any more the script broke between the \tool fetch
if i copy the code and past on the terminal
i get the error point
status: finished
downloaded: 38KiBg
duration: 0s
Code: Select all:global thisdate [/system clock get date] :global datetimestring ([:pick $thisdate 0 3] ."-" . [:pick $thisdate 4 6] ."-" . [:pick $thisdate 7 11]) #IP DO SERVIDOR FTP :global ip "1.1.1.1" #SUBDIRETORIO NO SERVIDOR REMOTO FTP :global dir "/RJ-AT-MK02/" # PORTA DO FTP :global port "21" #USUARIO :global user "backup" #SENHA :global pass "B@ckUp" log info "Starting Automatic Backup Script Configure By Raffaello" /system backup save name="$[/system identity get name]_$datetimestring" export file="$[/system identity get name]_$datetimestring" :log info "Please wait...!!!" :delay 5s :log info "Sending Backup Mikrotik to FTP Server............." /tool fetch address=$ip src-path="$[/system identity get name]_$datetimestring.backup" user=$user password=$pass port=$port upload=yes mode=ftp dst-path=($dir."$[/system identity get name]_$datetimestring.backup") /tool fetch address=$ip src-path="$[/system identity get name]_$datetimestring.rsc" user=$user password=$pass port=$port upload=yes mode=ftp dst-path=($dir."$[/system identity get name]_$datetimestring.rsc") :delay 1 :log info "Finished Backup Script...!!!!" :delay 5s :log info "Deleting backup just created after has sent" /file remove "$[/system identity get name]_$datetimestring.backup" /file remove "$[/system identity get name]_$datetimestring.rsc"
# automated Um backup to External FTP
#File name:Um-FTP-Backup
# Get time
:local routeros [ /system package get number=0 value-name=version ]
:local thistime [/system clock get time]
:set thistime ([:pick $thistime 0 2].[:pick $thistime 3 5].[:pick $thistime 6 8])
# Get Date
:local thisdate [/system clock get date];
:local month
:set month [:pick $thisdate 0 3]
:if ($month="jan") do { :set month "01"}
:if ($month="feb") do { :set month "02"}
:if ($month="mar") do { :set month "03"}
:if ($month="apr") do { :set month "04"}
:if ($month="may") do { :set month "05"}
:if ($month="jun") do { :set month "06"}
:if ($month="jul") do { :set month "07"}
:if ($month="aug") do { :set month "08"}
:if ($month="sep") do { :set month "09"}
:if ($month="oct") do { :set month "10"}
:if ($month="nov") do { :set month "11"}
:if ($month="dec") do { :set month "12"}
:set thisdate ([:pick $thisdate 7 11]."_".$month."_".[:pick $thisdate 4 6])
# This line to generate the file name for System backup - file name will be User_Manager- ServerName? - Date? - Time?
:local FName ("/User_Manager_".[/system identity get name]."_".$thisdate."_".$thistime."_".$routeros.".umb")
:local FExport ("/BackUp_".[/system identity get name]."_".$thisdate."_".$thistime."_".$routeros.".rsc")
:local FBackup ("/BackUp_".[/system identity get name]."_".$thisdate."_".$thistime."_".$routeros.".backup")
:delay 5s;
/system backup save name=$FBackup;
:delay 5s;
/export file=$FExport
:delay 5s;
/tool user-manager database save name=$FName
:delay 5s;
:log info "Backup File's is Create - $FBackup";
:log info "Export File's is Create - $FExport";
:log info "UM Database Backup File is Create - $FName";
:delay 5s;
:log info "System Backup & Export File's is now been send to FTP Server";
# Upload the System Backup to External FTP - change address to your ftp server + user + pass+upload_path
/tool fetch address="192.168.0.105" user="mikrotik" password="mikrotik" mode=ftp src-path="$FExport" dst-path="/$FExport" upload=yes
:delay 5s;
/tool fetch address="192.168.0.105" user="mikrotik" password="mikrotik" mode=ftp src-path="$FBackup" dst-path="/$FBackup" upload=yes
:delay 5s
/tool fetch address="192.168.0.105" user=mikrotik password=mikrotik mode=ftp src-path="$FName" dst-path="/$FName" upload=yes
:log info message="FTP Sending Backup & Export File's is Finish";
:delay 5s;
:foreach i in=[/file find] do={:if ([:typeof [:find [/file get $i name] "BackUp_"]]!="nil") do={/file remove $i}}
:log info message="SystemBackup & Export File's - Removed";
:foreach i in=[/file find] do={:if ([:typeof [:find [/file get $i name] "User_Manager_"]]!="nil") do={/file remove $i}}
:log info message="User-Manager Database Backup File's - Removed";
status: finished
downloaded: 38KiBg
duration: 0s
I have been using this scrip from V5 and I have had no problem with it.
It looks like the tool fetch does not like your src-path and dst-path parameters.
Code: Select all# automated Um backup to External FTP #File name:Um-FTP-Backup # Get time :local routeros [ /system package get number=0 value-name=version ] :local thistime [/system clock get time] :set thistime ([:pick $thistime 0 2].[:pick $thistime 3 5].[:pick $thistime 6 8]) # Get Date :local thisdate [/system clock get date]; :local month :set month [:pick $thisdate 0 3] :if ($month="jan") do { :set month "01"} :if ($month="feb") do { :set month "02"} :if ($month="mar") do { :set month "03"} :if ($month="apr") do { :set month "04"} :if ($month="may") do { :set month "05"} :if ($month="jun") do { :set month "06"} :if ($month="jul") do { :set month "07"} :if ($month="aug") do { :set month "08"} :if ($month="sep") do { :set month "09"} :if ($month="oct") do { :set month "10"} :if ($month="nov") do { :set month "11"} :if ($month="dec") do { :set month "12"} :set thisdate ([:pick $thisdate 7 11]."_".$month."_".[:pick $thisdate 4 6]) # This line to generate the file name for System backup - file name will be User_Manager- ServerName? - Date? - Time? :local FName ("/User_Manager_".[/system identity get name]."_".$thisdate."_".$thistime."_".$routeros.".umb") # This line to generate the file name for System backup - file name will be User_Manager- ServerName? - Date? - Time :local FExport ("/BackUp_".[/system identity get name]."_".$thisdate."_".$thistime."_".$routeros.".rsc") # This line to generate the file name for System backup - file name will be User_Manager- ServerName? - Date? - Time? :local FBackup ("/BackUp_".[/system identity get name]."_".$thisdate."_".$thistime."_".$routeros.".backup") :delay 5s; /system backup save name=$FBackup; :delay 5s; /export file=$FExport :delay 5s; /tool user-manager database save name=$FName :delay 5s; :log info "Backup File's is Create - $FBackup"; :log info "Export File's is Create - $FExport"; :log info "UM Database Backup File is Create - $FName"; :delay 5s; :log info "System Backup & Export File's is now been send to FTP Server"; # Upload the System Backup to External FTP - change address to your ftp server + user + pass+upload_path /tool fetch address="192.168.0.105" user="mikrotik" password="mikrotik" mode=ftp src-path="$FExport" dst-path="/$FExport" upload=yes :delay 5s; # Upload the System Backup to External FTP - change address to your ftp server + user + pass+upload_path /tool fetch address="192.168.0.105" user="mikrotik" password="mikrotik" mode=ftp src-path="$FBackup" dst-path="/$FBackup" upload=yes :delay 5s # Upload the System Backup to External FTP - change address to your ftp server + user + pass+upload_path /tool fetch address="192.168.0.105" user=mikrotik password=mikrotik mode=ftp src-path="$FName" dst-path="/$FName" upload=yes :log info message="FTP Sending Backup & Export File's is Finish"; :delay 5s; :foreach i in=[/file find] do={:if ([:typeof [:find [/file get $i name] "BackUp_"]]!="nil") do={/file remove $i}} :log info message="SystemBackup & Export File's - Removed"; :foreach i in=[/file find] do={:if ([:typeof [:find [/file get $i name] "User_Manager_"]]!="nil") do={/file remove $i}} :log info message="User-Manager Database Backup File's - Removed";
What does the below change mean?
"snmp - fix cpu load reporting to 1min average and change oid to 1.3.6.1.4.1.2021.11.10.0;"
1). Does it mean it is replacing the old Total CPU Load OID 1.3.6.1.4.1.2021.11.52.0?
2). And that earlier it was reporting realtime CPU Load and now this new OID will report 1 min average CPU load?
Kindly please clarify.
Thanks.
Yes yes yes... To much stupid people in the forum only doing bad critics!What's the point? RC are for testing purposes and it's legit that they introduce bugs/problems and they have the right to build, test, publish, skip any release they want. You should only be happy that we have been given the opportunity to test while they develope so we can help them (and ourselves) having better stable releases.Too many failures in between?
With RouterOS configurations can be very complex and it's not possible to test every corner case.
Do you have details on this PPP fix? I've had a mysterious random disconnect issue with windows VPNs since 6.30 or so.6.35rc19 has been released!
What's new in 6.35rc19 (2016-Mar-04 11:46):
*) ppp - fixed ppp crash (make it work with Windows clients);
Nice feature !!6.35rc19 has been released!
*) winbox - added /interface wireless setup-repeater;
It is radio to max-limit (0,1 is 10%)
HTB (Hierarchical Token Bucket) is finally getting custom size buckets
https://en.wikipedia.org/wiki/Token_bucket
basically this option can eliminate any need for bursts options, and allow much more neat hierarchical structures.
I do not understand how it will work if bucket size is 0 .
Simple burst behavior can be achieved by use values more that 1. For example if you set bucket-size=4 max-limit=10M - first 40Mb will cross the queue with virtually unlimited speed.
I plan to use this analogy when explainig it in future: bucket size determines amount of delivered water ( traffic) per take, you cannot control the amount of water in the bucket (it always come full), but you can control number of buckets per second, bigger buckets = smaller number of buckets per second = more burstness of the traffic (and i would imagine less load on CPU)
This i know... but has another advantage over WDS in performance or something connecting 2 RB in repeater mode?Connection to non-Mikrotik and still use one radio for station and AP modes simultaneously.
On my rb433uah after update to rc21 rb was rebooting after 5-10 seconds after system boot normallyIf you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as suspected or after crash.
If router goes into reboot loop, then if device has serial port send output of it within text file to support.
If router is rebooting and it does not have serial port, then Netinstall it to older version (With "Keep old configuration" enabled on Netinstall), generate supout file and send it to us.
Please provide support output file to support@mikrotik.com after you are able to recover the board by disabling the wireless card. That will help us to identify the problem and fix it.i think that the kernel boot loop is related to wifi-rep on the 433 or related to wireless card
because at home i use a 433uah as capsman and there was no cap enable on it and also get the kernel boot
i fallback to wifi-cm2 and the problem is gone, with cap enable
i my case the wifi card is a xr2 on both device
I forgot to note in my post that I was using wireless-rep package.Running rc21 just now on rb962 (hAP ac). I started with a blank config and ended up in a boot loop:
I had to clear the config. After clearing, I tried again and the same thing happened.
- Changed wlan1 (2 GHz) to station pseudobridge
- Scanned
- Chose a network
- Clicked connect
- Appeared to start connecting and then the router rebooted and got stuck in a boot loop.
Cleared again, and used it to successfully connect to a different network.
Without console access, how can I get a kernel panic message and/or kernel dump? What would you like to see?
v6.35rc21
after upgrade sxt Light lost access to device, device reboots every 60 seconds, after downgrade to v.6.35rc19 no more problems, I think there is any thing with ether port configuration causing this problem. The unice option to access the device is reset with reset button, and then downgrade to v6.35rc19
v6.35rc21
Version 6.35rc25 has been released.
*) tile - fixed rare situation when some cores decide not to take part in packet processing till next reboot;
*) fastpath - fixed crash when packet arrives on disabled interface;
*) capsman - fixed capsman extension channel names;
*) console - fixed print follow in "/ip dns cache" menu
*) ethernet - add option to see S-GPON-ONU module, GPON side SN in "/int eth mon sfp#"
*) ethernet - do not allow to set self as master port;
*) health - always report fan speed (even if it is 0);
*) l2tp - introduced per tunnel allow-fast-path option;
*) webfig - fixed firewall rule sorting did not work in other chains except all;
*) winbox - allow to set multiple dh-groups;
*) winbox - do not show fan statuses in passive cooling CCR1009;
*) winbox - fixed unset options in /routing ospf interface menu;
*) wireless-rep - fix crash on non-HT clients;
*) l2tp - implemented l2tp and lns fastpath/fasttrack support;
*) pppoe-client - implemented fastpath support.
Have you switch from wireless-fp to wireless-rep on both CAP (access point) and CAPsMAN (controller)? The wireless-fp implements CAPsMAN v1 while wireless-rep implements CAPsMAN v2 and these are not compatible with each other.- with wireless-fp: client receives IPv6 router advertisement, everything works
- with wireless-rep: client doesn´t receive any IPv6 traffic, no RA at all
Yes I did and realized that I made a mistake.Have you switch from wireless-fp to wireless-rep on both CAP (access point) and CAPsMAN (controller)? The wireless-fp implements CAPsMAN v1 while wireless-rep implements CAPsMAN v2 and these are not compatible with each other.- with wireless-fp: client receives IPv6 router advertisement, everything works
mistry7 - Did it actually upgrade? Or did it boot up with rc21?
Have you tried from a fresh boot (i.e., empty ramdisk)?I´ve tried to upgrade my "hap lite" (smips) from rc21 with wireless-rep to rc25 via winbox: System -> Packages.
This doesn´t work with the following error:
ERROR: not enough disk space, 7.7MiB is required and only 7.1 MiB is free.
Stupid question: Is this specific to smips where packages are smaller and just system one would probably fit in free space (I don't have any smips device myself, so I can't say for sure), or is there a way (without netinstall), how to do it for mipsbe too? I wanted to get rid of combined package on my mAP Lite and free space was only around 5MB, while system package is almost 7MB...., install system package only, ...
Same here, upgrading a hEX Lite board from RC19. Upgrade fails. Opened support ticket (#2016031066001081).When i Download and Install 6.35 RC25
My CRS reboot with Kernel Failure
I now use 6.35 RC21
it creates autosupot
I'd really appreciate a working config that I can dig through to understand.Yes it can. Change wlan1 to station pseudobridge, connect it to a Wi-Fi network by using the scan function. (Remember to setup a security profile if needed for Wi-Fi encryption.) Then setup firewall to src NAT that interface. Create a Virtual AP on the same interface. Ensure both wlan1 and the Virtual AP are joined to a bridge interface. Turn on DHCP server. Should be close to finished. I can send you a working config later if you get stuck.
ignore, it was a isolated case !!!ATTENTION
RC26
Maybe constant reboot on CHR
verifying if is a isolated case or on all CHR
testing on another CHR
when CAPMAN is enable on any wifi pack CM2 or REP12:08:22 system,error,critical router was rebooted without proper shutdown
Recall that we're discussing a RBmAPL-2nD single-Ethernet single-WAN router, where I wanted to use an existing WLAN as my WAN, and NAT-route it to a LAN consisting of an access point (using the same WiFi radio) with a different SSID and the Ethernet. I hoped that RouterOS v6.35 might at last allow me to do that in a single box. It's working now, thanks to yottabit's vital hints. His one hint that confused me a bit was "ensure that wlan1 and the Virtual AP are joined to a bridge interface". I think he meant that ether1 and the Virtual AP should be joined to a bridge interface. If anybody wants the config, I'll post it.I'd really appreciate a working config that I can dig through to understand.Yes it can. Change wlan1 to station pseudobridge, connect it to a Wi-Fi network by using the scan function. (Remember to setup a security profile if needed for Wi-Fi encryption.) Then setup firewall to src NAT that interface. Create a Virtual AP on the same interface. Ensure both wlan1 and the Virtual AP are joined to a bridge interface. Turn on DHCP server. Should be close to finished. I can send you a working config later if you get stuck.
My other problem is finding a sequence of steps to get from the factory-default RBmAPL-n2D WISP AP configuration to one where the (only) Ethernet interface is on the LAN without losing Winbox connectability. (I can always use the magic button to restore the factory-default configuration, but then I'm right back where I started.) Once I'm controlling the router firmly through its Ethernet interface, I should be able to reconfigure the wlan interface without losing control.
Thank you, Iám using v6.35rc26; no more problems!We have implemented fix which should help with wireless-rep reboot loop. Please test it if you can use rc version on your environment. Fix will be available in RouterOS v6.35rc25.
If the goal is a more stable release, then the more rc's the better. Other companies do the same, the builds are just not publically available; just designated beta testers have access to them.Mikrotik will launch how much rc's to come to final version ???? 30? 40? 50?
This was only a question! My prefered update option always is the rc's because there are a lot of good new things!If the goal is a more stable release, then the more rc's the better. Other companies do the same, the builds are just not publically available; just designated beta testers have access to them.Mikrotik will launch how much rc's to come to final version ???? 30? 40? 50?
If you need stability, use the bugfix version.
http://www.cisco.com/c/en/us/products/i ... index.htmlIs there any chance to implementation of
http://forum.mikrotik.com/viewtopic.php ... 50#p235456
Umetered Content for PPPoE . 'Unmetered Content' services aren't counted against your monthly download/upload inclusion
http://forum.mikrotik.com/viewtopic.php?t=59745
Mikrotik staff ?
Please contact support@mikrotik.com and attach a support output file which is made when you have the ping loss.I use 6.35rc26 wireless-rep (AP mode), my laptop (WIN7 INTEL wireless 5300AGN) had a lot of PING loss, when I changed to WIRELESS-CM2, everything is normal.
Rc26
My hex increases the use of mem whitout reason until it hangs. Need to reboot to work again and do the same again.
12 hours more or less until it uses all the memory and need reboot.
No config changes before update. Only from rc 19 to rc 26
Update to include image.
Please provide more detailed info on the problem. What RouterOS version and wireless package you had were this all was working fine?In rc26, and it has been in CAPsMAN configuration, from the DHCP Server, which is activated in the other RB, has been confirmed a phenomenon in which the IP address is not passed.
Moreover, instead of immediately occur, but after the elapse of a few hours if you are using.
It has not been output, especially something like anxious to log.
If you have enabled local forwarding, it seems this phenomenon is likely to occur.
Hello, uldis.Please provide more detailed info on the problem. What RouterOS version and wireless package you had were this all was working fine?In rc26, and it has been in CAPsMAN configuration, from the DHCP Server, which is activated in the other RB, has been confirmed a phenomenon in which the IP address is not passed.
What setup you have on the CAPsMAN and the CAP?
Please send the support output files and also information how to reproduce this problem to support@mikrotik.com
English pleaseДоброго дня Всем.
1. Очень серьёзная проблема, не могу от версии что обновился на 6.35rc19 ни дальше обновиться ни откатится назад. Пытался через НЕТИНСТАЛЛ 6.35.3 - не получилось. Не видит НЕТИНСТАЛЛ Микротик в состоянии BOOT
2. Около 2-х месяцев проблема с 2-йными сессиями в Микротик, во вложении скриншот. Авторизация у нас PPPoE через РАДИУС. Порой 2-х сессий так много, приходится по 2-3 раза в день перезагружать Микротик.
Sorry I downgrade to 6.34.3 and now all is ok.Please make a support output file after the reboot and then another file when you see that the board has taken a lot of memory - this will help us to identify what causes the memory usage.
Send both files to support@mikrotik.com
Rc26
This issue with memory started for me on rc25. I have RB750GL.
I have 1 PPPoE outgoing, 2 L2TP outg., 1 PPTP incoming running almost all the time.incahex, amokkatmt - Do you have some kind of tunnels on your devices? For example, L2TP and/or PPPoE?
Also have this issue on CCR1036-12G-4S.Good day everyone.
1. Very serious problem, I can not from the version that was updated on 6.35rc19 no further update or rollback. Tried through NETINSTALL 6.35.3 - it did not work. He does not see NETINSTALL Mikrotik able BOOT
2. About 2 months is a problem with 2-ynymi sessions in Mikrotik, screenshot as an attachment. Authorization we PPPoE via RADIUS. Sometimes 2 sessions so much, we have 2-3 times a day to restart the Mikrotik.
Our real 800 pppoe clients turned into 2400 pppoe sessions with "kernel failure" random reboots and fail to up/down grade RouterOS. But netinstall worked for me. CCR just "kernel failure" and rebooting instead of flashing ROS. Same with restoring backups - "kernel failure". I have 3 supouts, 2 auto, and 1 created manually when uptime was 5 minutes. Where should I send this?
I have a pppoe client for the wan connection.incahex, amokkatmt - Do you have some kind of tunnels on your devices? For example, L2TP and/or PPPoE?
Thanks Mikrotik support and developers.Version 6.35rc29 has been released.
*) RB3011 - fixed time keeping
With what wireless package you see this problem?I have wireless problems since 6.35rc28, didnt changed any config about that
Has anybody else these problems?
Thanks for respone but i have to apologyWith what wireless package you see this problem?I have wireless problems since 6.35rc28, didnt changed any config about that
What configuration you have on the wireless and what wireless encryption you have enabled?
What is your wireless client hardware?
Now this is a nice addition. I assume it also initiates connection tracking for reverse path...*) firewall - added experimental "action=route" in mangle prerouting - that forces packets to specific gateway by ignoring routing decisions (CLI only);
Probably not related with the problem on mAP Lite.Happened here too with rc29 in x86 but stopped after a day. Normal behavior?
NTP SERVERS: 150.214.94.5 - 176.31.53.99
Can reproduce this with 6.35rc31 on Basebox2. Switched back to WIRELESS-CM2 as well.I use 6.35rc26 wireless-rep (AP mode), my laptop (WIN7 INTEL wireless 5300AGN) had a lot of PING loss, when I changed to WIRELESS-CM2, everything is normal.
Excellent! I confirm this works, you can therefore close Ticket#2016030366000916.*) snmp - fix getbulk result ordering with multiple request OIDs;
I hoped that this might fix Ticket#2016031766000471 but unfortunately this just made it worse to the point that AT+CPIN? commands on the Huawei ME909s time out all the time, rendering the modem unusable as it is stuck in an initialization sequence loop. If I usb power-reset the modem, I get a response to AT+CPIN? once, but then the communication hangs at AT+CMEE=1 . I'll send in a supout.rif as well.Version 6.35rc33 has been released.
*) lte - changed AT parsing because supported Huawei modems use unsolicit events instead of polling
I have the same issue on Metal 2SHPn, running regular AP without CAPsMAN, all traffic simple stops, i cant even acces AP i get connection refused, turning on off wireless on my HTC phone fixes it, i was thinking its my phone issue..will get logs next time from router when it happens.I too am having wireless client issues since running 6.35rc33. Using a hAP AC in CAPsMAN mode and my clients keep loosing their connection to the network, connection stays up, but not traffic locally or to internet possible anymore. Reconnect of the wireless link immediately solves it. Running 6.35rc22 before this all worked perfectly well.
It looks like the connection before the CAPsMAN and CAP was lost and CAP initiated a new connection to the CAPsMAN.Hello
can any one have any clue what about this error
Thanks for the tip. The country setting is really the problem. In the configuration I set it to Switzerland. So, strangely it selects 5740MHz as center channel, which is not allowed. If I set country to Germany it selects something like 5180, then it works fine. So, there might be a frequency table problem in the country settings.heydude, what country setting you have specified in the CAPsMAN configuration as it selected 5740mhz as a center channel?
what is the usage of this new action ?) winbox - added support for route action in mangle rules;
[juanvi@xxx] /caps-man> configuration set channel.band=
2ghz-b 2ghz-b/g 2ghz-b/g/n 2ghz-onlyg 2ghz-onlyn 5ghz-a 5ghz-a/n 5ghz-a/n/ac 5ghz-onlyac 5ghz-onlyn
Problem with disconnecting wifi under capsmana with Intel cards introduced in rc33 is still persist in rc34. It occurs less frequently. I noticed it only once whole yesterday evening.Version 6.35rc34 has been released.
*) capsman - added 802.11g/n band;
*) chr - added support for VLAN on Hyper-V;
*) hotspot - fix possible deadlock;
*) hotspot - improved html page resistance against attacks;
*) l2tp & pppoe - fixed user traffic accounting when fastpath was used;
*) pppoe - fixed crash when removing <l2tp> pppoe service;
*) winbox - added init-delay option to routerboard settings;
*) winbox - added sfp-mac for GPON interfaces;
*) winbox - added support for route action in mangle rules;
Using cm2juanvi - Do you use wireless-rep package?
Any news about mAP Lite clock drift?You must have at least 635rc34 and wireless-rep package on CAP device and also on CAPsMAN:
Running 6.35rc34 with cm2 package I've found the gn mode under capsman provisioning but is missing under config: by strods » 22 Mar 2016, 10:28
[juanvi@xxx] > caps-man provisioning set hw-supported-modes=
a a-turbo ac an b g g-turbo gn
Still the same - disconnecting laptop with intel card.Version 6.35rc35 has been released.
*) chr - fixed kernel crash when virtual ethernet was not connected to anything in Hyper-V;
*) chr - implemented kernel crash saving to autosupout.rif (will utilize additional 24Mb of RAM);
*) romon - fix romon discovery after of romon ID change;
*) userman - fixed www crash;
*) wireless - fix crash on nstreme-dual interface stats update;
Unfortunately, this still breaks compatibility with Huawei ME909s (Ticket#2016032166000454)Version 6.35rc37 has been released.
*) lte - supported modems now use unsolicit events for network monitoring;
After upgrading, the option has dissapeared from routerboard settings.Version 6.35rc40 has been released.
It does not resolve the behavior to flapping at the RB3011 interface.Version 6.35rc41 has been released.
*) bonding - fixed mac-address disappearance after reboot in specific setups;
*) chr - fixed reboots with license and queues;
*) quickset - fixed invalid date adjusted the signal threshold for the signal chart and refresh rate;
http://download2.mikrotik.com/routeros/ ... e-6.19.zip ?Where can I find previous version of rc files? Need 6.35rc19.
..[CUT]..
[Ticket #2016032466000172]
Also confirmed here.It does not resolve the behavior to flapping at the RB3011 interface.Version 6.35rc41 has been released.
..[CUT]..
Version 6.35rc42 ..port flapping on 3011 persist (ports 6-10), device unusable
I'm quite new to 3011 so I went back to 6.34.3, flapping resolved but I've encountered some strange 'loop' alert on bridges witch have VLANs (temp "bad fixed" moving VLANs onto real interfaces instead of bridge ones)Also confirmed here.Version 6.35rc42 ..port flapping on 3011 persist (ports 6-10), device unusable
Downgraded back to 6.35rc29 and the problem was resolved.
actually...http://download2.mikrotik.com/routeros/ ... e-6.19.zip ?Where can I find previous version of rc files? Need 6.35rc19.
http://download2.mikrotik.com/routeros/6.35rc19/all_packages-mipsbe-6.35rc19.zip
yeah, right. i just picked MIPSBE because probability and propagation between gear.actually...http://download2.mikrotik.com/routeros/ ... e-6.19.zip ?Where can I find previous version of rc files? Need 6.35rc19.
change the "mipsbe" to the platform you need.Code: Select allhttp://download2.mikrotik.com/routeros/6.35rc19/all_packages-mipsbe-6.35rc19.zip
Requests for CAPsMAN bug fixes and new features, based on my experience with the current RC version:
1. {Nice to have} Add "CCQ", P Throughput" and "Signal to Noise", "Encryption" and "Group Encryption" and "WMM Enabled" fields to CAPsMAN Registration Table.
2. {Feature} Add "Frequency Mode", "WMM Support", "Multicast Buffering", "Keepalive frames", "Adaptive Noise Immunity" and "AMPDU Priorities" to CAPsMAN Config Settings.
3. {BUG} Make "Multicast Helper=full" in CAPsMAN slave interfaces work (now the interfaces stay in default setting).
4. {BUG} Make "Country=no_country_set" work on CAPsMAN 5GHz 802.11ac interfaces (it works on 2.4GHz, but on 5GHz ones it results in "no supported band" error message, regardless of the band and frequency settings).
5. {Feature} Add a scan/freq usage feature in CAPsMAN, with an aption to run in the background. Right now, if one wants to scan, they have to detach the physical interface from the Manager, do the scan and re-attach it. [In the future, use this info to auto-adjust CAP channels and power levels.]
6. {Annoying} Stop CAPsMAN from creating virtual interfaces on CAPs with name "wlanXXX" where XXX is a number which is incremented every time the interface is disabled and re-enabled.
7. {Nice to have} Let the user rename the virtual interfaces on the CAPs, like he/she can do with physical interfaces.
+1Requests for CAPsMAN bug fixes and new features, based on my experience with the current RC version:
