strods
v6.34.4 [current] is released!
Tue Mar 29, 2016 10:10 am
What's new in 6.34.4 (2016-Mar-24 13:13):
*) bonding - fixed crash on bonding slave release;
*) bonding - fixed mac-address disappearance after reboot in specific setups;
*) chr - fixed reboots with license and queues;
*) console - allow unknown scan-list names on wireless configuration to fix import;
*) ethernet - fixed Netmetal, QRT, DynaDish, SXT ac linking at 10/100Mbps (introduced in 6.34.x);
*) fastpath - fixed rare kernel failure;
*) ipsec - take into account ip protocol in kernel policy matcher;
*) mac-winbox - try to aggregate packets & resend all pending packets on timeout;
*) ppp - do not crash when received multiple CBCP packets;
*) ppp - fixed crash when ppp interface gets disconnected and user gets authenticated at the same time (most probable with slow RADIUS server);
*) quickset - fixed wan interface selection on devices with SFP interfaces;
*) quickset - use 5GHz interface instead of 2GHz interface on SXT Lite5 ac;
*) rb3011 - fixed high cpu load breaks ethernet stats;
*) rb3011 - fixed link down messages;
*) romon - fixed romon discovery after romon ID change;
*) timezone - fixed reboot by watchdog when selecting timezones from the end of list;
*) userman - fixed www crash;
*) winbox - allow to show revoked & authority flags at the same time;
*) winbox - correctly recognise if there is need to report fan information under system health;
*) winbox - do not use area v2 names instead of ospf v3 area names;
*) winbox - make mac-winbox work with RB850;
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as suspected or after crash.
nz_monkey
Re: v6.34.4 [current] is released!
Tue Mar 29, 2016 10:17 am
Thanks Mikrotik.
Another fine release.
ufm
Tue Mar 29, 2016 1:47 pm
Thnx for bugfixes.
nxs02
Tue Mar 29, 2016 4:22 pm
nice...
keep the good work...
paoloaga
Tue Mar 29, 2016 4:26 pm
Is the clock skew problem on RB3011 fixed in this release or is it only on 6.35rc ?
Thanks MT for the great job, things improved a lot since you branched between stable & development releases!
noyo
Tue Mar 29, 2016 11:34 pm
What's new in firmware v3.32 ?
StefanM
Wed Mar 30, 2016 12:17 am
So what happen earlier yesterday is after upgrading one of my test mikrotiks to v6.34.4 and we did some testings for ipv6 and after rebooting router my wireless interface disappeared, did couple of reboots and it was not there, the package was enabled and everything looked fine but after rebooting a router wireless interface disappeared, so i had to downgrade to 34.3
I don't have support file, neither am able to send it right now, so just describing what happen. Hope it helps.
nxs02
Wed Mar 30, 2016 3:00 am
firmware release notes is in http://wiki.mikrotik.com/wiki/RouterBOOT_changelog
but they not update it yet...
hapi
Wed Mar 30, 2016 10:22 am
IPv6 local link address may be deleted. Is not it a mistake?
satcom
Wed Mar 30, 2016 8:17 pm
After upgrade RB850Gx2 i can´t login from winbox v3.4 with my ip,only with mac id???
What is new:
noyo
Wed Mar 30, 2016 8:20 pm
I know this page.
isolnet
Wed Mar 30, 2016 9:32 pm
I think bug in CPU Frequency
Splash
Thu Mar 31, 2016 10:32 am
After upgrading from version 6.34.3 to 6.34.4 within a few hours the device (RB493G) stops responding over an SSTP VPN connection. The connection reports up on the CPE, but down on the VPN concentrator (CCR). The device is monitored over the SSTP connection using PING and SNMP.
  • System resources look fine.
  • Running a /export hangs
  • Reboot takes a long time to action
  • Saving a Supout.rif file takes a long time.
  • Disabling/Renabling the SSTP interface fails.
Downgrading back to 6.34.2 resolves the problem.
honzam
Fri Apr 01, 2016 12:06 pm
Changelog is now to v3.31:
nxs02
Fri Apr 01, 2016 3:12 pm
yes finally... :) :)
keep up the good work guys...
kometchtech
Fri Apr 01, 2016 4:24 pm
+1
mainTAP
Mon Apr 04, 2016 4:54 pm
Dear Team,
Unfortunately after upgrading RB951G-2HnD to 6.34.4 my IPsec/L2TP from Android clients is not working.
Downgrading back to 6.32.4 solves the issue, but even upgrading to the latest 6.35rc45 is not working.
The connection just time-outs and does not give any particular error.
It seems that the router_os struggles to create dynamic policies for the SAs.
Thank you.
mrz
Mon Apr 04, 2016 6:42 pm
Works fine with any ROS version on our routers. Enable ipsec debug logs and see where exactly is the problem.
saaremaa
Thu Apr 07, 2016 8:48 am
On 6.34.4 not work DHCPv6 client. I can't get IPV6 prefix and IPv6 from DHCPv6 server (Mikrotik Router OS 6.32.4).
Tonda
Thu Apr 07, 2016 11:09 am
I have noticed port flapping of CRS212-1G-10S-1S+ in 6.34.4 (see http://forum.mikrotik.com/viewtopic.php?f=3&t=107000)
bax
Fri Apr 08, 2016 3:22 pm
It looks that web proxy not mark cashed files with cashe hits DSCP TOS 4 ? can somebody also check
Siona
Fri Apr 08, 2016 5:36 pm
What about voltage monitor in rb493g? It still seems not work.
ddejager
Sat Apr 09, 2016 2:54 am
I was running 6.34.1. I upgraded to 6.34.4 on Tuesday. Since then the CPU has jumped up by about 10 percent. Profile shows that the additional CPU is all going to "unassigned". Device is CRS125-24G-1S-2HnD.
nickjail
Sun Apr 10, 2016 9:55 am
Hi!
Got problem with sector writes after enabling IP cloud. This problem was in 6.34.3 and now it exist in latest 6.34.4
Without IP cloud there is ablout ~1500-2000 sectors per day
After enabling IP cloud about ~10000 sectors per day :shock:
tryed to reboot, reset configuration. But after enabling IP cloud big amout of sectors starts writing.
africantech
Sun Apr 10, 2016 2:26 pm
v6.34.4
When I try to download from within winbox, it gives an error:
ERROR: missing wireless-6.34.4-mipsbe.npk
Current Version: 6.33.3
Winbox: 3.4
Neilson
Tue Apr 12, 2016 1:00 pm
v6.34.4
Winbox: 3.4
Please ensure you delete any downloaded npk files from the files folder, go to the packages window System > Packages and click on wireless and select uninstall.
In 6.34 Mikrotik removed the wireless package from the system so FP is the base one and CM2 is the "to be base" (and default on some newer models - SMIPS)
If you are using the all in one package to supply your wifi package then it should upgrade automatically, if you are using individual packages you will need to manually remove the wireless package or it will fail to download.
This was mentioned on the earlier 6.34 release notes.
Regards
Alexander
sensor
Wed Apr 13, 2016 11:00 am
Ccr1009. After update 6.34.2 to 6.34.4. I have problem: L2tp stop working. Router one time have stop working and i reset him. And portforwarding don't work for me, any new open port don't opened.
ddejager
Wed Apr 13, 2016 5:44 pm
Please delete this post. Sorry.
k750
Fri Apr 15, 2016 12:03 am
It is planned for the Version 7 release
modrzyk
Fri Apr 15, 2016 9:12 am
How to fix update error?
status: ERROR: missing wireless-6.32.4-mipsbe.npk on MikroTik RB951G-2HnD current-version: 6.32.3
Neilson
Fri Apr 15, 2016 11:45 am
Please see above at: http://forum.mikrotik.com/viewtopic.php ... 76#p532594
If this is not working for you please let us know what error you are seeing or whats happening to you that is preventing you completing the upgrade and we can try help you out.
Regards
Alexander
Users browsing this forum: Amazon [Bot], jvanhambelgium, Renfrew and 28 guests
