yap99
Re: v6.35.1 [current] is released!
Thu Apr 28, 2016 7:36 pm
PCC load balancing does not work after upgrade
routes does not work
:? :( :( : urgent help I have the same problem with load balancing, I have a rb850
mrtester
Fri Apr 29, 2016 12:14 am
Guys, after I did delete all my routes and firewall rules and added them back it all started to work again. I do not know.. maybe I just did mess up something myself but, just did "/ip route export" and "/ip firewall mangle export" and did remove all routes and mangle rules afterwards. Imported commands from export output and it started to work again.
CaVaStra
Fri Apr 29, 2016 1:44 am
we can confirm observance that pcq load-balancing stopped working after upgrading to v6.35.1 because of main-routes becoming inactive.
also snmp health monitoring fails since the upgrade.
we are running capsman so we need the fixes in there...
reverting to v6.35 resolves the pcq balancing issue and health monitoring but introduces again loss of caps interfaces
reverting back to v6.35 resolves the problem
same here: I'm running 3 hap ac here (1 is capsman+cap the other two are cap) and since upgrading to 6.35.1 I see the cap (on the box with capsman running) missing in capsman. rebooting not solving anything, disable/enable caps not working. the wlan interfaces do show and scanning does work. however when turning them on (as local wlan) the default microtik ssid also does not come alive and no logging
did reverting back solve the caps missing issue ?
wa4zlw
Fri Apr 29, 2016 1:48 am
wa4zlw, this 2016-Apr-25 09:29 is a timestamp for the listed features, when they were added to the specific version.
I'd like more specific info on each item with a date/timestamp
leon
gius64
Fri Apr 29, 2016 3:43 am
6.35.1 finally solved fcs errors on AirFiber24 links for me! :D
PastuhMedvedey
Fri Apr 29, 2016 9:27 am
After repeatedly performing the commands :
interface l2tp-server server set enabled=yes
or
interface pptp-server server set enabled=yes
(more than 10 times in a row), pptp and l2tp server stops working,
the connection of customers to them is impossible!
Please fix this error.
Ivoshiee
Fri Apr 29, 2016 2:04 pm
On a RB433 I have multiple default gateways set and the default gateways with routing mark set went out of use by the v6.35.1 (all these routes were turned blue in winbox) and I was cut off from the network on that box. I've managed to find an older firmware on my laptop and recovered that given functionality. Should I expect that to be fixed or what to think about it?
karwos
Sat Apr 30, 2016 4:27 pm
Please FINALLY FIX SFP DDM INFORMATION READING
On CRS125, there is nothing shown in SFP tab...
HOWEVER i've successfully readen DDM data (and RX/TX power was updated few times a seconds too) today on CRS125.
How it's fixed?
Run CRS125 without SFP module.
Tick system restart, while restarting PLUG SFP module in.
DDM data is there.
If you will reboot CRS now, DDM will not come back anymore
hamipopo
Sun May 01, 2016 8:32 am
PPP User (pptp vpn) could not disconnect from routeros from 6.35
basd
Sun May 01, 2016 2:18 pm
After the upgrade, i lost my vrrp interfaces ...
But this is fix in the next RC.
But i have problem with my site tot site now , they don't pass ant TCP trafic. UDP and ICMP are working fine.
But TCP not
krisjanis
Mon May 02, 2016 10:46 am
How it's fixed?
DDM data is there.
What vendor - model transceiver you use in that CRS125? Possibly it is having some trouble reporting info back to host.
igb
Mon May 02, 2016 11:24 am
The voltage displayed for an RB2011UiAS is not plausible. 1143.7V?
[igb@rb2011-1] /system identity> /system routerboard print
       routerboard: yes
             model: 2011UiAS
     serial-number: 444702957500
     firmware-type: ar9344
  factory-firmware: 3.09
  current-firmware: 3.18
  upgrade-firmware: 3.33
[igb@rb2011-1] /system identity> /system health print
  voltage: 1143.7V
Edit to add: fixed by firmware update, so the problem is 6.35.1 (and perhaps earlier, I don't know when this problem started) plus firmware 3.18 (ditto).
[igb@rb2011-1] > /system health print
      voltage: 24.1V
  temperature: 27C
[igb@rb2011-1] > /system routerboard print
       routerboard: yes
             model: 2011UiAS
  current-firmware: 3.33
[igb@rb2011-1] >
xrayd78
Mon May 02, 2016 6:28 pm
we have bis problem with tile CCR-1036-12G-4S.
Last version 6.35.1 is installed, but after 2 days later mikortik pasword is empty. You can login without password! :-(
Ip> Pool is blank.
I try make supout.rif, but can´t find among Files!
Reboot can help, but aftter 2-3 days have the same problem!
What can I do?
DSpazman
Mon May 02, 2016 7:46 pm
I had a bug upgrading to this.
I use policy based routing, and had 3 route tables and main.
All my routes in my other route tables besides main went down when I upgraded. They would not show as active.
I had to completely remove them all, and add them all back in with different table names in order to get it all working again.
Even just changing the table names would fix the route, but then when I changed it back to the old table name, it made the route not active again.
As a side note I used interface names for all my routes And there were about 1500 static routes on the router (around 300 per routing table and in the main table.
karwos
Mon May 02, 2016 10:20 pm
How it's fixed?
DDM data is there.
They are AscentOptics modules, you can get datasheet from there:
http://www.ascentoptics.com/en/dow.asp?Pid=93
Cha0s
Mon May 02, 2016 10:34 pm
       routerboard: yes
             model: 2011UiAS
  voltage: 1143.7V
      voltage: 24.1V
  temperature: 27C
       routerboard: yes
             model: 2011UiAS
[igb@rb2011-1] >
The bug started on 6.34.1
http://forum.mikrotik.com/viewtopic.php ... 87#p519887
In my case an RB2011UiAS shows the proper voltage/temperature where an RB2011UAS does not
http://forum.mikrotik.com/viewtopic.php?f=21&t=107686
Both with latest firmware (3.33) and RouterOS v6.35.1.
napismizpravu
Re: v6.35.1 - RB433UAH top speed port 506,26Mb/s
Tue May 03, 2016 1:04 am
RB433UAH (6.35.1) ethernet port graf statistic Top Speed 506,26 Mb/s
inserting images prohibited :(
irghost
Tue May 03, 2016 1:37 pm
where is update? 6.35.2 to fix these bugs
locodog
Tue May 03, 2016 7:54 pm
I'm using CCR1036-12G-4S 6.35.1 as PPPoE concentrator, about 100 PPPoE servers and all of them except one are on EoIP tunnels. That one server is running on ether5 interface with exactly same profile and settings as others. User connected to PPPoE server on ether5 interface will disconnect on exactly 5 minutes (it's for testing purposes and I'm only user there, so it's not that big of a problem), there is always 4-5mbps running so it isn't idle. As soon I connect to PPPoE over EoIP (same CPE) it works without problems. This didn't happen on 6.32.2 and error I get is "terminating... link inactive". Can anyone try to reproduce it?
edit: After inserting ether5 under bridge interface (eth5 is only interface in bridge) connection doesn't terminate after 5 minutes. So I guess that it is a bug.
prawira
Trainer
Trainer
Wed May 04, 2016 5:47 am
i have some of oid functions broken on CRS...
but the same functions still work fine on RB750UP and RB2011.
[admin@Cendana] > sys reso pr
                   uptime: 18h25m32s
                  version: 6.35.1 (stable)
               build-time: Apr/25/2016 09:29:50
              free-memory: 86.5MiB
             total-memory: 128.0MiB
                      cpu: MIPS 74Kc V4.12
                cpu-count: 1
            cpu-frequency: 600MHz
                 cpu-load: 28%
           free-hdd-space: 104.0MiB
          total-hdd-space: 128.0MiB
  write-sect-since-reboot: 177879
         write-sect-total: 100957409
               bad-blocks: 0.8%
        architecture-name: mipsbe
               board-name: CRS125-24G-1S-2HnD
                 platform: MikroTik
[admin@Cendana] > sys heal pr
      voltage: 24.5V
  temperature: 39C
[admin@Cendana] > sys heal pr oid
             active-fan: .1.3.6.1.4.1.14988.1.1.3.9.0
                voltage: .1.3.6.1.4.1.14988.1.1.3.8.0
            temperature: .1.3.6.1.4.1.14988.1.1.3.10.0
  processor-temperature: .1.3.6.1.4.1.14988.1.1.3.11.0
                current: .1.3.6.1.4.1.14988.1.1.3.13.0
      power-consumption: .1.3.6.1.4.1.14988.1.1.3.12.0
             psu1-state: .1.3.6.1.4.1.14988.1.1.3.15.0
             psu2-state: .1.3.6.1.4.1.14988.1.1.3.16.0
while the snmpwalk only show :
.1.3.6.1.4.1.14988.1.1.3.14.0
i wanna to attach the picture / screen shoot from my computer but i do now know how to do it.
P
prawira
Trainer
Trainer
Wed May 04, 2016 6:54 am
'safe mode' under winbox also does not work.
i do connect into my CRS via wireless, open winbox, click safe mode, and disable wlan1
after long wait (more than 15 minutes), the interface wlan1 still disable and i have to connect with wire to enable it again.
P
jarda
Wed May 04, 2016 9:06 am
It is not necessary to double the posts. You already rised this topic few days ago. http://forum.mikrotik.com/viewtopic.php ... 34#p535534
prawira
Trainer
Trainer
Wed May 04, 2016 10:48 am
dear jarda,
the previous post was made when i use 6.35; not 6.35.1
while everyone talk about .6.35.1, is it wrong if i remind the mikrotik developer to have a look into unworking "safe mode" for winbox ?
P
jarda
Wed May 04, 2016 1:12 pm
Ok. But it seems that the lack of safe mode functionality is not linked specifically to the latest version introduced here but it is general bug.
littlebill
Wed May 04, 2016 9:44 pm
i have a issue with wireless 2.4 which appears to also be in 32.4 none of my 40mhz capable device are going into 40mhz, they are stuck at 20mhz? 5gz dual band ac radio does not have this problem? anyone else seeing this?
rdanyk
Thu May 05, 2016 12:35 pm
The same issue! :(
krisjanis
Thu May 05, 2016 2:13 pm
I don't have exactly those modules for testing, but I checked with various other vendor ones and no problems with any of them.
As I mentioned possibly modules them selves are acting up sometimes. System can stop attempting to read ddmi if there are to many failed attempts.
karwos
Thu May 05, 2016 2:22 pm
These modules DDM works perfectly in other manufacturer equipment (i.e. DASAN networking).
I can send you one module for tests, or make some tests/debug if needed (i can attach logic analyzer to TWI line and give you sniff if needed ;) )
aforster
Thu May 05, 2016 2:57 pm
Yesterday I made the upgrade on my new router CRS125-24G-1S-2HnD, which I got 1 week ago and came running an old sw version, 6.6.
After the upgrade, the wifi clients keeps disconnecting all the time, even when signal is strong. On the logs, I see tons of for all wifi clients:
00:56:CD:XX:XX:XX@wlan1: disconnected, extensive data loss
I tried to downgrade, but for some reason, after the reboot, it came back with the same 6.35.1. I ried also searching the forum for problems like this, but none indicated what could be happening, and since the problem started after the upgrade...
Thanks for any help.
normis
Thu May 05, 2016 3:21 pm
1. the mentioned log means your signal was not great after all, it means weak signal due to low signal or noise
2. downgrade is done with a special command "/system package downgrade", simple reboot doesn't make downgrade like for upgrades
aforster
Thu May 05, 2016 3:34 pm
Normis, thank you for your response. Regarding your comments, the wifi signal was working perfectly before the upgrade. Is there any other report of problems with this newer version?
yes, the downgrade attempt was done using that command.. but for some reason, after the rebook, it came back with the same version. Just tried again:
[admin@ho-rt-01] > /system package downgrade
Router will be rebooted. Continue? [y/N]:
y
system will reboot shortly
[admin@ho-rt-01] >
And it still came back like:
MikroTik RouterOS 6.35.1 (c) 1999-2016
Any idea?
Best regards.
gotsprings
Thu May 05, 2016 4:24 pm
Seeing the time zone problem in the logs on 3011s and hEX. CCR1009 does not have the issue.
Marino
Thu May 05, 2016 5:51 pm
Did you upload the old firmware version first to the files area?
y
[admin@ho-rt-01] >
Any idea?
Best regards.
aforster
Thu May 05, 2016 6:21 pm
Now I feel stupid.. haha
No, I didn't know I should (since I had not deleted anything, I thought it was there already and documentation I found didn't say anything about that).
But that gave me the direction already. Thank you :-)
strods
Fri May 06, 2016 10:20 am
Users browsing this forum: efka and 29 guests
