That functionality is not available in netfilter I think, so it would have to be implemented entirely in the management layer.
(you maintain some time object but in reality it is modified in all rules that refer to it)
That is probably more work to implement. The "time" match has this functionality:
time
This matches if the packet arrival time/date is within a given range.
All options are optional, but are ANDed when specified. All times are
interpreted as UTC by default.
--datestart YYYY[-MM[-DD[Thh[:mm[:ss]]]]]
--datestop YYYY[-MM[-DD[Thh[:mm[:ss]]]]]
Only match during the given time, which must be in ISO 8601 "T"
notation. The possible time range is 1970-01-01T00:00:00 to
2038-01-19T04:17:07.
If --datestart or --datestop are not specified, it will default
to 1970-01-01 and 2038-01-19, respectively.
--timestart hh:mm[:ss]
--timestop hh:mm[:ss]
Only match during the given daytime. The possible time range is
00:00:00 to 23:59:59. Leading zeroes are allowed (e.g. "06:03")
and correctly interpreted as base-10.
[!] --monthdays day[,day...]
Only match on the given days of the month. Possible values are 1
to 31. Note that specifying 31 will of course not match on
months which do not have a 31st day; the same goes for 28- or
29-day February.
[!] --weekdays day[,day...]
Only match on the given weekdays. Possible values are Mon, Tue,
Wed, Thu, Fri, Sat, Sun, or values from 1 to 7, respectively.
You may also use two-character variants (Mo, Tu, etc.).
--contiguous
When --timestop is smaller than --timestart value, match this as
a single time period instead distinct intervals. See EXAMPLES.
--kerneltz
Use the kernel timezone instead of UTC to determine whether a
packet meets the time regulations.
As you can see, datestart and datestop fields could easily be added to give oneshot temporary rules
in addition to the daily/weekly rules that already are available.
