Cascuda
Re: v6.38 [current] is released!
Tue Jan 03, 2017 11:57 pm
After upgrade in the log appear: system, info, critical - memory overclocked. All device which is contain 128 MB memory.
Devices affected in my network:
1x RB2011UiAS
2x CRS109-8G-1S-2HnD
2x CRS125-24G-1S
Devices not affected in my network:
2x RB3011UiAS
Thanks & Regards,
David
I've update the "RB2011UiAS" router from 6.37.2 to 6.38 and have same mistake when open the terminal of winbox. Any solution?
I return to a version safe 6.36.4 "Bugfix only"...
Njumaen
Wed Jan 04, 2017 12:16 am
Is this intended? Why? What's the point I am missing?
You forgot to read the release notes!!
Important note!!!
To avoid STP/RSTP compatibility issues with older RouterOS versions upgrade RouterOS on all routers in Layer2 networks with VLAN and STP/RSTP configurations.
Sure I did not forgot this!
The issues came *with* upgrading the RB3011. No upgrade - no issue... Still confused...
rgbiernat
Wed Jan 04, 2017 8:57 am
Just upgraded my shiny new HEX (RB750GR3) from v6.37.3 to latest stable v6.38. Unfortunately it did not come back. Instead it keeps beeping every 10sec.
I am not using any fancy stuff just natting between an telco edge router and my internal network. A reset did not work. Will try a Netinstall in a few minutes.
DuduZZZ
Trainer
Trainer
Wed Jan 04, 2017 9:21 am
1x RB2011UiAS
2x CRS125-24G-1S
2x RB3011UiAS
Thanks & Regards,
David
strods from MikroTik Support wrote:
Tue Jan 03, 2017 11:23 am
Do not worry about these overclocked messages - they are still work on progress. If you have not overclocked device manually, then there is no need to worry about that.
We are still improving this feature.
Cascuda
Wed Jan 04, 2017 9:36 am
Thanks DuduZZZ, I read the comment of Mikrotik Support but I prefere usage a version safe where don't show any error.
becs
Wed Jan 04, 2017 10:00 am
Can you elaborate on the RSTP incompatibility? We've been using 6.30/6.34/6.36 for some time now between different devices without a problem, including inter-operating with another vendor (A few HP/Aruba 48 port switches). Does this change affect the inter-operability with other vendors?
Thanks.
Previously RSTP in RouterOS bridges worked more like a per-VLAN RSTP and caused troubles with standard RSTP with VLANs.
Since most enterprise level switches understand RPVST, likely, there were not any compatibility problems with older RouterOS versions.
becs
Wed Jan 04, 2017 10:21 am
Njumaen - please generate supout files on your RB3011 and CRS125 and send them to support@mikrotik.com
nacer - please generate supout files on your CCR1009 and CRS125 send and them to support@mikrotik.com
Njumaen
Wed Jan 04, 2017 10:33 am
And there is another issue
RB3011 (my router) on 6.38 download max. 3.25 Mbps
installed 3.63.4 results in max. 110 Mbps as to be explected
tripple checked - same result.
no queues
upload max both approx 8Mbps..
So for my part I'll stick on the bugfix only on the RB3011...
Update 1: digging deeper...
Usually my Mac is connected to the CRS125 that is connected to the RB3011 by a bonding Interface.
Connecting the Mac to the RB3011 and performing the same test this is what I get
Perfect!!! Cannot expect a better download!
Update 2: deeper...
Pinging RB3011 from Mac connected to CRS125
Disabled the bonding interface
Conncection lost... as expected
Connected both by a single cable...
Connection. One ping.. Connection lost! Red October??? "only ONE ping!!!"
Ahhh... Port on CRS125 has a flapping "learning" at bridge port status
Setting STP protocol mode of bridge to "none"
Connection! Lots of pings...
Speedof.me is nearly perfect!!! I 118 MBps down.. I skip the picture...
(Remember: RB3011 on 6.36.4 - CRS125 on 6.38)
Update 3: nothing gonna stop me now...
Upgrade RB3011 to 6.38
STP protocol mode of bridge is already set to "none"
no ping problem
Speedof.me is horrible again! Max 2.8MBps down :( I skip the picture.
works for me:
RB3011 on 6.36.4
CRS125 on 6.38
STP protocol mode of both bridges set to "none"
@Mikrotik - it is so awesome how easily one can switch the routeros releases! \o/
csi
Wed Jan 04, 2017 11:32 am
I had situation with 6.38 on my CRS
I have CRS-1009 router and CRS-125-24G switch. Both of them was ROS 6.37. I upgraded both to 6.38.
I am using Port based VLAN tagging described in http://wiki.mikrotik.com/wiki/Manual:Interface/VLAN / example #1 on my CRS-125-24
After 6.38 and all IP traffic stopped on my switch. When I disabled Vlan taggings IP traffic started on my management LAN.
I downgraded to 6.37 and Vlan problem disappeared.
İs this the problem you mentioned "To avoid STP/RSTP compatibility issues with older RouterOS versions upgrade RouterOS on all routers in Layer2 networks with VLAN and STP/RSTP configurations."
Thank you.
I had the same issue, tagged VLANs between CRS and Routerboard. I have configured the CRS as described in the Wiki, but it does not work with 6.38. What I have done is to build a bridge on the RB and put the ether-interface which is connected to the CRS in that bridge. At the end there is one bridge with one interface. Or if you have more connections to CRS devices you should implement different bridges per ether interfaces. Then the connections in the VLANs works as expected. Second a build also a one bridge for one interface on the CRS and then it works as described within the wiki.
Build the bridge per tagged VLAN does not work in this case. It need to be the ether interfaces on both sites. Hopefully that helps you.
Cheers
csi
majestic
Wed Jan 04, 2017 11:38 am
Hi there,
I also have several of these routers (RB750Gr3's) and as much as I really would love to upgrade to this version, I am a little worried of potentially bricking them thus leaving me without connectivity. Could you please let me know if the netinstall managed to rescue your device or not and also has anyone else with this same version suffered the same problem or is this just one rare occasion?
Really would appreciate you or others to confirm if there is a serious problem with this upgrade on RB750Gr3.
Thanks in advance.
onnoossendrijver
Wed Jan 04, 2017 12:25 pm
Thanks in advance.
I experienced no problems when upgrading my RB750Gr3 from version 6.37.3 to version 6.38
vitaliyy
Wed Jan 04, 2017 12:28 pm
Updating to 6.38 fastrack is broken, maximum download and upload speed is 150 Mbits, after downgraded to 6.37.3 all ok, speed about 800-850 Mbits
majestic
Wed Jan 04, 2017 12:39 pm
Thanks in advance.
Thanks very much for letting me know.
Note
Wed Jan 04, 2017 1:57 pm
i get in logs a critical system error "memory overclocked"
majestic
Wed Jan 04, 2017 2:00 pm
Mikrotik has confirmed to ignore it if you haven't manually overlocked it. Its a feature they are improving on.
uldis
Wed Jan 04, 2017 2:39 pm
What device you are testing the fasttrack?
Please report to support@mikotik.com with a support output file attached.
Boter
Wed Jan 04, 2017 2:41 pm
For now everything runs smoothly and as expected. I still dont use it for wifi p2p or p2mp links, because of wifi "problems", on other devices as I said - works great
Mazutti
Wed Jan 04, 2017 3:01 pm
Hi there,
Thanks in advance.
Had no problems upgrading my RB750Gr3 to 6.38, only difference from the described, is that I upgraded from 6.38rc52.
majestic
Wed Jan 04, 2017 3:03 pm
Hi there,
Thanks in advance.
Awesome, thank you for the confirmation and as soon as I get home, I will update mine.
Thanks again everyone who's put my mind at ease.
nje431
Wed Jan 04, 2017 3:26 pm
Q
Thanks.
Thanks for the explanation. Currently we use straight up RSTP, but I can see a day coming when we could benefit from using MSTP. Any plans to add that option?
mrz
Wed Jan 04, 2017 3:30 pm
First of all happy new year and nice work on overall ipsec improvements.
But the password length is still capped to 31 characters, which creates incompatibility to previous versions with long xauth passwords
i wrote this here:
http://forum.mikrotik.com/viewtopic.php ... 86#p573186
please try to fix it :)
It is fixed, I have no problems using 33character passwords and longer. Contact support with supout file if you still cannot use longer passwords.
vitaliyy
Wed Jan 04, 2017 3:34 pm
model: RouterBOARD 962UiGS-5HacT2HnT
support output file contains pre-shared key in clear text format I will not send it
v 6.7.3
CPU load 85-90%
and after update
v 6.8
and CPU load 100%
uldis
Wed Jan 04, 2017 3:37 pm
vitaliyy, please provide the export file to support@mikrotik.com from both versions (you can replace the pre-shared keys in those files).
At least on my spare hAP AC router I got 500/700Mbps (download/upload), I hit ISP bandwidth limit.
majestic
Wed Jan 04, 2017 7:48 pm
Hi Guys,
I have just received another RB750Gr3 in the post today and I decided to update the firmware and rOS as the first things I do before configuring it. After doing the upgrade(s) I started to adjust the packages which are installed by default as there are a few which isn't so useful to me like wireless and hotspot as it doesn't have wireless in this model.
I then just found that there is a very small graphical bug with the icon that is used for disabled packages.
I am enclosing a screenshot below which shows the disabled missing graphic.
https://www.dropbox.com/s/8xhlamew8y1yi ... 0.png?dl=0
If you look at my existing router (same one but previous rOS version, you will see its much neater graphic.
https://www.dropbox.com/s/u107oxfziubmd ... 4.png?dl=0
Im sure its just an oversight that the main image seems to have a bad graphic.
HTH
ErfanDL
Wed Jan 04, 2017 8:29 pm
I upgrade my hap lite to 6.38 and upgrade firmware to 3.36 whats chanelog in new firmware version 3.36 for hap lite?
Sent from my C6833 using Tapatalk
dadoremix
Wed Jan 04, 2017 9:26 pm
Every update new problems
When was 5.x no problems with updates
6.1x was last stable, future realese fix on fix
I have also hex r3 with vlan bridge and problems
5ghz sxt ap lvl4 update to 6,38 and die
Maybe config conflict?
But he is in bridge and no other config
Bad bad and bad
Sent from my iPhone using Tapatalk Pro
storp
Wed Jan 04, 2017 11:52 pm
After updating RB2011 I got issues with flapping sfp-port. All worked fine before on 6.37.3 and now I reverted back to bugfix only and all is fine again.
LexaKnyazev
Thu Jan 05, 2017 12:13 am
ROS: v6.38
RB: CRS125-24G-1S-2HnD and 2011UiAS (both 3.33)
WebFig doesn't allow to set "Profile" property for L2TP-Client or PPTP-Client interfaces. WinBox (3.7) works as expected.
Steps to reproduce:
  1. Open WebFig
  2. Interfaces -> Add New -> PPTP Client
  3. Fill in "Connect To" and "User" fields
  4. Select "default-encryption" in "Profile"
  5. Click "Apply"
  6. Profile switches to "default".
Abdock
Re: The Dude, v6.38 [current] release.
Thu Jan 05, 2017 7:20 am
Most of our 1100Ax2 are freezing and have to be power cycled.
moep
Thu Jan 05, 2017 3:22 pm
It was not fixed for my situation, when the main site was 6.38 and the clients were still 6.37.3.
It was "fixed" by upgrading every router to 6.38 which was not planned this day.
This still means that IPsec with xAuth and a password longer than 31 Chars is treated differently in ROS 6.37.3 than in 6.38 which leads to problems when "old" clients try to connect.
i wrote this here:
mrz
Thu Jan 05, 2017 3:34 pm
Thanks, we will look into this problem
R1CH
Thu Jan 05, 2017 3:54 pm
Fasttrack is working fine for me on a RB951G-2HnD in a simple home NAT setup. Maybe something else in your config is causing it.
zinkpad
Thu Jan 05, 2017 6:13 pm
Hi all,
I updated my RB951G-2HnD to 6.38 version and I have an issue with my laptop (ThinkPad T420s), it's connects fine to my WLAN but it's disconnected after 5min. aprox.
Watching the log I can see a lot of entries like this:
Jan/05/2017 16:20:40 xx:xx:xx:xx:xx:xx@wlan1: connected
Jan/05/2017 16:20:55 xx:xx:xx:xx:xx:xx@wlan1: reassociating
Jan/05/2017 16:20:55 xx:xx:xx:xx:xx:xx@wlan1: disconnected, ok
Jan/05/2017 16:20:55 xx:xx:xx:xx:xx:xx@wlan1: connected
Jan/05/2017 16:21:05 xx:xx:xx:xx:xx:xx@wlan1: reassociating
Jan/05/2017 16:21:05 xx:xx:xx:xx:xx:xx@wlan1: disconnected, ok
Jan/05/2017 16:21:05 xx:xx:xx:xx:xx:xx@wlan1: connected
I rebooted the router and the issue it's not gone, finally I downgraded it to 6.37.3 and it's working fine again.
(the laptop has been in the same place all the time).
Regards.
AlexN
Thu Jan 05, 2017 10:07 pm
Changes with RSTP is a complete disaster!!! IMHO such changes are not the subject for release branch! RPVST was great approach with high level of flexibility. Now if we just update all our routers in L2 segment it won't work at all (fortunately tested on the table) and I'm talking about network that comes across few cities not a few offices!
And tell me what should I do with this situation now?
Upgrade to future versions is not possible without almost complete redo of L2 logic of whole network. With RPVST it was also possible to assign different bridges as root for vlans that have same parent interface and yes you may need it in some situations. Now this doesn't work.
Please, revert this changes back!!! Put it to some beta ROS version first, give it good tests with feedbacks and provide same functionality with minimum reconfiguration required. Otherwise it turns for us into hell, really. Especially if similar "surprises" will come in future releases in the branch that considered as production branch.
MartijnVdS
Thu Jan 05, 2017 10:53 pm
It's been in an RC version for months. It's now in the "current" release channel. If you need the old functionality, there's the "bugfix only" channel.
killersoft
Fri Jan 06, 2017 12:49 am
Installed 6.38 to a 50+ device mix of MT routers/crs devices(~50%) and AP's(~50%) from v6.37.1.
Had 3x devices die from a 6.37.1 ->6.38 upgrade ( 1xRBwAP2nD & 2xRB912UAG-2HPnD), had to net-install to fix.
*** Had ALL 5x RB2011UiAS 2x CRS125-24G-1S give a WARNING in the log about OVERCLOCKED RAM at boot.
I am in process of rolling back all 50+ MT devices to 6.37.3..
Mazutti
Fri Jan 06, 2017 4:01 am
On RB750Gr3, where I have two PPPoE links to ISP, if I disable the secondary one, I can´t reenable it (tried through winbox, winbox "new terminal" and ssh).
Log shows the initializing/connecting messages, but nothing else, and the interface won´t go up / get ip address. Log shows this entries just once every time I put the PPPoE client down/up.
Anyway, can´t reboot or put the main PPPoE client down now, but I will do ASAP and report back.
cheeze
Fri Jan 06, 2017 4:44 am
To all who have upgraded to 6.38 I just wanted to give some info on what I have found.
I have found that I needed to rediscover all of my devices for 6.38 as I lost all SNMP graphing/oids that were CPU, temperatures, and voltages. However it was quickly fixed with a full rediscovery of the device.
I just wanted to give everyone a heads up that have upgraded.
zipvault
Fri Jan 06, 2017 4:49 am
Miracle
Fri Jan 06, 2017 6:01 am
I got a nightmare after upgrade ccr1009 & crs125 to 6.38.
All vlan via switchip error.
They should be test carefully more before release this to stable version
moep
Fri Jan 06, 2017 7:59 am
I found several other bugs:
RB2011 with NTP-Package is losing the correct time while displaying "synchronized" after a while, it does not matter if I enter another routerboard or official NTP-Servers. (Standard System-SNTP not tested, as I need the NTP-Server portion)
IPsec xAuth with Mode Config (ROS as Client): sometimes after a SA-Rekey the devices are losing their IP-Adresses and are not getting them back until ich do a manual peer "kill connections" which is obviously not the way to go. Until is do this, they have no IP-Address on the Interface making the tunnel anymore and display an invalid policy while at the same time having another identical dynamic policy which is not working because of the missing IP-Address.
kiler129
Fri Jan 06, 2017 9:14 am
What's the upgrade scenario for CAPsMAN controller and devices?
Currently CAP<->Controller communication is done on VLAN, so if I go and upgrade controller I will loose communication with CAPs. If I upgrade CAP it will no longer connect to controller.
Am I missing something?
DuduZZZ
Trainer
Trainer
Fri Jan 06, 2017 10:27 am
Please read the topic above.
73/dx
pe1chl
Fri Jan 06, 2017 10:38 am
On my 2011 it works OK. Primary NTP server on the LAN, secondary on the internet.
moep
Fri Jan 06, 2017 10:40 am
are you using the separate NTP Package or integrated SNTP-Client?
pe1chl
Fri Jan 06, 2017 11:04 am
The NTP package of course, that is what you are talking about.
From my own local server I have also added the router as a reference and I see this:
     remote           refid      st t when poll reach   delay   offset  jitter
x127.127.8.0     .DCFa.           0 l   73   64  356    0.000   -1.904 2049498
+127.127.28.0    .GPS.            0 l    8   16  377    0.000   13.589   0.187
*127.127.28.1    .PPS.            0 l    7   16  377    0.000   -0.002   0.002
 192.168.1.1     192.168.1.3      2 u   34   64  377    0.213   -1.042   0.033
So it is synchronized.
moep
Fri Jan 06, 2017 11:19 am
thats odd that it is working in your environment
but it was already odd that the 2011 was the only device in the network with this problem.
a periodic "restart" of ntp (disable+delay+enable) solves the problem at the moment for about 5 minutes as the clock deviates again
devices that are using this ntp-server are still getting bad packets with "server-not-synchronized"
zcache
Fri Jan 06, 2017 12:05 pm
Hi all,
After upgrade to 6.38, I feel my routerbox temperature too high than before. As I often check before upgraded the temperature about 50-51 but now it is 60-62, anybody have same with me?
My box is: RB850Gx2, already downgrade cpu speed to 400MHz but not effective.
willianwrm
Fri Jan 06, 2017 12:30 pm
Today I found a severe bug with 6.38:
It will not (or at least incompletely) learn MAC-Addresses on a bridge connected to the master-port of a switch.
I did notice this bug too: because of not learning MAC-Addresses on the bridge all packets are being broadcasted! My VPN is getting all the ether-master packets.
In the bridge there is only one MAC learned from ether2, but there are a lot of MAC in ARP Table:
The good news are:
What's new in 6.39rc7 (2017-Jan-05 12:24):
*) bridge - fixed MAC address learning from switch master-port;
MartijnVdS
Fri Jan 06, 2017 2:19 pm
Hi all,
From the changelog:
*) rb850Gx2 - fixed pcb temperature monitor if temperature was above 60C;
pe1chl
Fri Jan 06, 2017 3:08 pm
Maybe your clock crystal is too far off to keep synchronized.
moep
Fri Jan 06, 2017 3:21 pm
i did another reboot of the device
now the time stays correct and the other router syncs with this NTP server
i hope it stays that way :)
pe1chl
Fri Jan 06, 2017 4:35 pm
unfortunately the MikroTik NTP does not implement the management interface so it is difficult to see what is going on inside.
(of course, if it would be implemented, it would require subnet permission settings like in the SNMP service, or else it
would be abused for DDOS)
mrz
Fri Jan 06, 2017 4:46 pm
Thanks problem confirmed, will try to fix in next v6.39rc version
kujo
Fri Jan 06, 2017 6:32 pm
Who then tested the limit of connections? it seems that the filter rule is not working with him! CHR 6.38
/ip firewall filter add connection-state=new chain=forward connection-nat-state=dst-nat dst-port=443 connection-limit=100,32
Sorry! Work well!! Need add not! To connection-limit
sup5
Fri Jan 06, 2017 8:05 pm
Important note!!!
Is there a detailed description how (PV)(R)STP was handled prior ROS 6.38 versus it is being handled with ROS 6.38?
There should be a global setting to restore the old behaviour.
There are large networks which don't use the switch-chip-feature at all and cannot be upgraded at once.
kevini
Fri Jan 06, 2017 9:25 pm
I have the same issue with the Fasttrack on 6.38. With 6.37.3 I had my full 250mbit internet speed without any issues. With 6.38 it dropped to 30Mbit the packets are going through the FP but not at the rates expected.
I have 2 x Hex Gr2's and I use EOIP with IPsec between them. This cannot use the FP but with 6.38 this seems to make all the packets slow. When I disable the EOIP tunnel the speed comes back immediately.
I upgraded to 6.39rc and it works fine again with the EOIP tunnel. So it is either fixed or not merged from 6.38 yet.
Any suggestions? I'm going to upgrade to GR3's in the future to have everything on the FP but since my Comcast upload limits the speed for now it was not needed.
mariuslazar
Fri Jan 06, 2017 9:55 pm
Software 6.38 cpu usage for fasttrack connections very high. For example ( 951g-2hnd at 750mhz) bandwidth 300 Mbps 6.37.3 cpu usage 30-40, 6.38 cpu usage 80-85.
My 951G dropped from 305 Mb/s with ~50% CPU (6.37.3) to 210 Mb/s with 100% CPU (6.38). I had to downgrade to keep the speed up.
If I check the profiler I can see the "networking" is taking ~30%. On 6.37.3 it was about 1% on full speed.
AlexN
Sat Jan 07, 2017 12:19 am
Totally agree. MikroTik team, please, implement this feature. This would be really helpful.
kubisek78
Sat Jan 07, 2017 10:12 am
Another:
I have RB450G (router1/ovpn server) and 2011UAS (router2/client1) and RB751G (router3/client2). LAN networks of all routers are bridged over OVPN at the server side (and client1+client2 are bridged over EoIP beacause they are in same WAN).
I have found (after upgrading to 6.38 on all RBs) when any client is connected to the OVPN server, the download speed at the router1/server drops to approx 1Mbps (normally DSL 20/2).
When all ovpn clients are disconnected, the spped goes back to 20/2.
I also have found when any of the ovpn clients is connected, there is a lot of upload traffic through DSL pppoe interface. When I "cut" all clients, traffic dissapear and download speed rise to 20 Mb.
Reverting back to 6.37.3 - works perfectly.
ryan0803
Sat Jan 07, 2017 12:48 pm
Thank you.
i have the same problem
i downgrade to 6.37.1 all problem just vanish
pe1chl
Sat Jan 07, 2017 12:56 pm
Please can 6.37.x be made the bugfix release?
There has to be a convenient way to update routers to this version that proves to be quite stable,
and avoid the current problems with 6.38 without having to go back to 6.36.4
darkprocess
Sat Jan 07, 2017 3:40 pm
There is some performance issues on 6.38
On my RB3011
ROS 6.37.3
Download 900Mb/s
Upload 200Mb/s
CPU 14% during speedtest
ROS 6.37.3
Download 260Mb/s
Upload 200Mb/s
CPU 67% during speedtest
I'm back to 6.37.3
heviejob
Sat Jan 07, 2017 8:48 pm
I had the same issue between rb750GL and rb850Gx2. After update to 6.83 on both PPPoE connections over VLANS stopped working. I fiddled for about an hour trying to get the VLANs to work and had to roll back to restore service. I think the changelog needs to be more detailed when such far-reaching changes are done.
GuntherDW
Sun Jan 08, 2017 7:13 am
I have a RB750Gr3, almost new, received it around xmas. Updated from 6.37.3, got the 100/20 from my VDSL2 connection over PPPoE, with FP for around ~2-10% CPU usage.
It still says it's going over FP, but takes up to 40%.
This was a minute after I closed Torch to check for bandwith usage.
I did the same test 5 minutes after that and the CPU usage went back down to its previous 2-10%.
The wiki does state that "Torch/packet sniffer/.." type stuff will break the FP stuff, but it seems a bit more delayed now?
Long story short at first I was afraid that I was suffering from the same issue, but it turned out alright.
This is on a somewhat simple NAT home setup though. Modem into the RB to the internal network. Haven't really done anything with VLAN's or VPN's yet.
qiet72
Sun Jan 08, 2017 2:32 pm
Same problem here, except downgrading to 6.37.3 also makes the vlan problem disappear. This was tested on a hAP ac. Other MikroTik and X86 devices do not seem to have this problem though.
The STP/RSTP compatibility issue does not seem to affect me though as I have 6.37.3 on hAP ac, 6.38 on X86 PC and hAP lite (smips) all connected to the same layer 2 network.
Qiet72
Thank you.
liamalxd
Sun Jan 08, 2017 4:39 pm
I think this started in 6.37.3, but it's still broken in 6.38. On my CCR 1009-8G-1S-1S+ the fan speed is not reported correctly in fan1-speed in /system health:
> system health print
fan-mode: auto
use-fan: main
active-fan: main
cpu-overtemp-check: yes
cpu-overtemp-threshold: 70C
cpu-overtemp-startup-delay: 1m
voltage: 24V
current: 825mA
temperature: 31C
cpu-temperature: 55C
power-consumption: 19.9W
psu1-state: ok
psu2-state: ok
fan1-speed: 0RPM
This used to report correctly and seems to start working if you set the use-fan to auxiliary and then back to main again, but breaks again upon a reboot.
pe1chl
Sun Jan 08, 2017 8:11 pm
The fan speed is reported as zero when it is below some threshold (but still running).
When it spins up due to higher outside temp it is displayed. Probably a bug, yes.
colinardo
Sun Jan 08, 2017 9:13 pm
Hi.
I discovered the following problem with the current 6.38 Release on a RB951G-2HnD with the auto certificate feature of CAPsMan:
If you request certificate with a CAP on the same device as the CAPsMAN, the device is unable to issue the private key for the certificate. The certificate for CAP is created ('I' can be seen in certificate list) but without private key ('K' is missing in certificate list), thus it cannot be used by CAP. Also if you manually create the certificate on the router itself with private key, it's not accepted, log says certificate is not valid anymore, but it actually is ... really weird!
Version 6.37.3 in contrast is working fine.
Best regards
@colinardo
manulu
Mon Jan 09, 2017 5:23 am
I have a problem once i've upgrade to
dude-install-6.38.exe
dude-6.38.npk
RB2011UiAS-2HnD
Windows 7 32
the error
no dude package
emikrotik
Mon Jan 09, 2017 8:30 am
Strange Bug:
After upgrading my CCR1009-8G-1S-1S+ from 6.37.3 to 6.38 the exported config mixed up the interface IDs:
set [ find default-name=ether5 ] l2mtu=1520 name=ether1-kbd
set [ find default-name=ether6 ] l2mtu=1520 name=ether2
set [ find default-name=ether7 ] l2mtu=1520 name=ether3
set [ find default-name=ether8 ] l2mtu=1520 name=ether4-inl
set [ find default-name=ether1 ] name=ether5-wan-lacp1-1
set [ find default-name=ether2 ] name=ether6-wan-lacp1-2
set [ find default-name=ether3 ] name=ether7-wan
set [ find default-name=ether4 ] name=ether8-wan
This was definitely NOT the actively running config since i did not rename the interfaces that crappy ;)
Just to make sure that the export was wrong tried to load this config into the zeroed device but it failed.
after a manual correction to:
set [ find default-name=ether1 ] l2mtu=1520 name=ether1-kbd
set [ find default-name=ether2 ] l2mtu=1520
set [ find default-name=ether3 ] l2mtu=1520
set [ find default-name=ether4 ] l2mtu=1520 name=ether4-inl
set [ find default-name=ether5 ] name=ether5-wan-lacp1-1
set [ find default-name=ether6 ] name=ether6-wan-lacp1-2
set [ find default-name=ether7 ] name=ether7-wan
set [ find default-name=ether8 ] name=ether8-wan
everything worked fine.
Is there any explanation for this effect?
Cheers,
Christoph
Have also experienced this issue 3 times on 2 routers.
LIV2
Mon Jan 09, 2017 9:23 am
On both my CRS125 and my mAP 2n installing 6.38 results in a unit that won't boot, for both I had to revert to an earlier version using netboot. is this a known issue?
uldis
Mon Jan 09, 2017 9:33 am
Hi.
Best regards
@colinardo
Thank you for the report, we will try to fix this problem in the v6.39.
uldis
Mon Jan 09, 2017 9:38 am
On my RB3011
ROS 6.37.3
Download 900Mb/s
Upload 200Mb/s
ROS 6.37.3
Download 260Mb/s
Upload 200Mb/s
I'm back to 6.37.3
Please report to support@mikrotik.com with a support output file so we could check the configuration and try to reproduce your problem.
uldis
Mon Jan 09, 2017 9:40 am
kevini
Tue Jan 10, 2017 12:30 am
I submitted my info, I had the standard network diagram etc request which I don't have time to provide. Hopefully with all the people reporting the performance issues they resolve it soon.
zcache
Tue Jan 10, 2017 2:30 am
Hi all,
From the changelog:
Yes, but I wonder why the temperature rise up too high, 10 degree from previous version. Although the box working same function.
[admin@MikroTik] > system health print
          voltage: 12V
      temperature: 49C
  cpu-temperature: 60C
[admin@MikroTik] >
kiler129
Tue Jan 10, 2017 3:13 am
From the change log I would assume your board temperature was like 60*C, but ROS was showing lower one (which was fixed in 6.38).
zcache
Tue Jan 10, 2017 5:14 am
Ohh!! I got it, that it mean the box has kidding me so long time... haha :lol: :lol:
moep
Tue Jan 10, 2017 8:01 am
I might have found some other IPsec related bugs:
1. sometimes the new "PH states" are not correct, traffic is flowing but there is "no PH2" or "ready to send" which often only reverts after phase1 rekey or new phase2
2. if the initiator is reconnecting too fast e.g. after PPPoE 24 hour reconnect and the old SAs are not flushed on responder, the initiator thinks he is connected and has SAs but the responder has an invalid policy and no traffic can flow.
EDIT
If a peer reconnects after PPoE 24h disconnect within DPD timeout and with a another IP address than before, there will be the situation described in 2.,
I tested this by setting delay before attempting to reconnect to a value greater than the DPD timeout which "solved" the problem. Bit this is clearly not the expected behaviour.
UPDATE
even my workaround did not solve the problem
UPDATE2:
now again a second reboot after the upgrade seems to solve this problem for now (testet with a script doing disable+enable)
as usual, please fix :)
thank you in advance
Psiho
Tue Jan 10, 2017 10:43 am
Hello! DHCP server in 6.38 and higher version include bug with synthetic NIC (Hyper-V) on my RB-951G. When virtual NIC trying to get offer from dhcp following message in log is appear:
- dhcp,warning,info,debug dhcp1 offering lease Virtual_NIC_IP for Virtual_NIC_MAC without success
As result i lost connect to Hyper-V HOST also. 6.39RC9 - same problem. Return to 6.37 and all become OK again.
majestic
Tue Jan 10, 2017 12:03 pm
Agree. It would be nice if after every new release that a new repo say called old current/stable or something was created and used to store the previous version as it's very frustrating to have to use net install to switch back to the exact version we were running before.
Also net install has to be done onsite which is not very convenient. If it was more easier to return back to our old version rather then bugfix branch, I'm sure more people would be helping to try and debug issues.
notToNew
Tue Jan 10, 2017 12:22 pm
No, please NOT!!! 6.36.4 is the only version which works with some older WIFI-Devices, like INTEL 2200.
This version should be supported until the new wireless-package is fixed.
pe1chl
Tue Jan 10, 2017 1:13 pm
I have suggested that in the 6.39rc thread already but I suspect it cannot be done in an existing release (e.g. by serving a different file from the update server)
so for the current release the marking of 6.37 as bugfix release is probably the only way.
Some people apparently require 6.36.4 but they can just stay at their existing install or use netinstall on new devices.
The currently most occuring situation is "updated to 6.38 then want to go back until new issues are fixed" and for that making 6.37.3 the bugfix release, if only
temporarily, would be easiest.
uldis
Tue Jan 10, 2017 1:23 pm
We need more detailed report - provide us export file or support output file so we could try to reproduce this problem.
Psiho
Tue Jan 10, 2017 2:07 pm
To reproduce this problem you just need to try obtain IP by guest OS's NIC (Hyper-V) from DHCP server in 6.38 and higher version ROS. As for me - i must again do upgrade-downgrade cycle on Router in production. This may take a while - 1 day at least. What will take a less time?
DuduZZZ
Trainer
Trainer
Tue Jan 10, 2017 2:28 pm
I think you don't understand. Uldis request a supout.rif file. More information: http://www.mikrotik.com/support
Psiho
Tue Jan 10, 2017 2:40 pm
Ok, will try to do this tonight
janisk
Tue Jan 10, 2017 3:26 pm
your hyper-v client is a dhcp-client receiving the address from the DHCP server? Or vice versa - server that gives out addresses to mipsbe (or various) devices?
Psiho
Tue Jan 10, 2017 4:06 pm
Yes. Mikrotik - DHCP server. Guest OS on HOST and HOST himself - clients
In addition - when described error is occurred, the affected clients remaining in "offering" state in DHCP server - Leases table with cycled 30s timeout. Seems like synthethic NIC dont answer on offer from DHCP, while real ones work as usual. In ROS 6.37 all work fine with both NIC.
gilester
Tue Jan 10, 2017 4:34 pm
We have observed exactly this with a UniFi UAP-LR and a Soekris Engineering Net4801 board. We have reverted to 6.37.3 to restore correct DHCP behaviour.
Giles.
darkmanlv
Wed Jan 11, 2017 2:42 am
fastpath problem on 6.38 with hap ac, download speed dropped to 200 mbps from 500-800 mbps, cpu load is 100%
on 6.37.3 all ok
darkmanlv
Wed Jan 11, 2017 2:48 am
i have the same problem with hap lite, old toshiba notebook with intel 2200bg doesn`t work if upgrade to 6.37.xx or 6.38, works perfectly on 6.36.4
IanEKB
Wed Jan 11, 2017 9:01 am
Good day!
Error with updating status (reachable) in static routes. System displays "unreachable" for static route, but it is reachable.
Traffic did not go through a second ISP because of this. Changing Distance values did not help.
Fix: change checking gateway type to ARP from PING (WinBox displays reachable now). I turn option back to ping, but status reachable was saved.
Reload whether the status if ISP gateway is not available and will be available again? I not tested it.
Info: SFP-interface (SFP module: WDM SFP-G-03SC-B).
I do not know whether there was a problem in early versions.
P.S.: I am sorry for bad english.
notToNew
Wed Jan 11, 2017 9:31 am
I have >60 IP-Cams, which only work on 6.36.4. I hope no one asks me to replace them all just because of this ;-)
majestic
Wed Jan 11, 2017 9:54 am
Adding an extra repo wouldn't effect anything, wouldn't touch the existing versions available, it only would give users an alternative to install, I.e old stable.
notToNew
Wed Jan 11, 2017 10:05 am
I agree! But the quoted question was not to add an extra version, it was about to replace the current bugfix-version. I support adding a new one!!
majestic
Wed Jan 11, 2017 10:07 am
My bad, wasn't intended. Should proof read what I type more :) sorry about that.
MoDest
Wed Jan 11, 2017 10:26 am
It's good idea to add "creation time" column to firewall address list. I hope you do it and for firewall filters and NAT. With this will be easier to find outdated rules in big firewalls with many rules.
normis
Wed Jan 11, 2017 10:32 am
You could use the note feature for that. Enter reason why each rule is made.
pe1chl
Wed Jan 11, 2017 10:42 am
In some cases it could be nice to have a "countdown timer" with a rule like with address list members,
to temporarily open some thing without risk to forget to remove it later, but I do not consider it important
enough to make it into a feature request. The comment feature already is a very nice advantage of
RouterOS over competing products and even operating systems.
JuanRamiro
Wed Jan 11, 2017 10:51 am
After upgrading to 6.38, my pppoe connection to WAN speed test makes cpu go to 100%. FastTrack counters seem OK --> FastTrack seems to be configured properly.
Because of the cpu, the router no longer gets 300 mbps at 45% of CPU. Now I get up to 200 mbps at 100%.
notToNew
Wed Jan 11, 2017 10:57 am
my whish is to get an "time"-object which I can add to any firewall-rules. The tiime-object should have an beginning and an end-datetime.
If added, the rule is only enabled within this time! This has several advantages: 1. Having the "countdown timer" you mentioned 2. Allowing me to enable several
"mainenance"-rules(with several vlans i have over 50 of them) by just extending the end-datetime of this "timeobject" named "Maintenance-AllowExternalAccess "....
pe1chl
Wed Jan 11, 2017 11:24 am
Well that is already available, but it appears that it allows only cyclic definitions and no date fields. That can probably be fixed rather easily.
notToNew
Wed Jan 11, 2017 11:36 am
Somehow... it should be available as an own "object", just like the adress-list. If so, I can add several named "time-objects" and add them to te corresponding rules.
pe1chl
Wed Jan 11, 2017 11:43 am
That functionality is not available in netfilter I think, so it would have to be implemented entirely in the management layer.
(you maintain some time object but in reality it is modified in all rules that refer to it)
That is probably more work to implement. The "time" match has this functionality:
   time
       This matches if the packet arrival time/date is within a  given  range.
       All  options  are optional, but are ANDed when specified. All times are
       interpreted as UTC by default.
       --datestart YYYY[-MM[-DD[Thh[:mm[:ss]]]]]
       --datestop YYYY[-MM[-DD[Thh[:mm[:ss]]]]]
              Only match during the given time, which must be in ISO 8601  "T"
              notation.   The  possible  time  range is 1970-01-01T00:00:00 to
              2038-01-19T04:17:07.
              If --datestart or --datestop are not specified, it will  default
              to 1970-01-01 and 2038-01-19, respectively.
       --timestart hh:mm[:ss]
       --timestop hh:mm[:ss]
              Only  match during the given daytime. The possible time range is
              00:00:00 to 23:59:59. Leading zeroes are allowed (e.g.  "06:03")
              and correctly interpreted as base-10.
       [!] --monthdays day[,day...]
              Only match on the given days of the month. Possible values are 1
              to 31. Note that specifying 31  will  of  course  not  match  on
              months  which  do  not have a 31st day; the same goes for 28- or
              29-day February.
       [!] --weekdays day[,day...]
              Only match on the given weekdays. Possible values are Mon,  Tue,
              Wed,  Thu,  Fri,  Sat, Sun, or values from 1 to 7, respectively.
              You may also use two-character variants (Mo, Tu, etc.).
       --contiguous
              When --timestop is smaller than --timestart value, match this as
              a single time period instead distinct intervals.  See EXAMPLES.
       --kerneltz
              Use  the  kernel  timezone instead of UTC to determine whether a
              packet meets the time regulations.
As you can see, datestart and datestop fields could easily be added to give oneshot temporary rules
in addition to the daily/weekly rules that already are available.
notToNew
Wed Jan 11, 2017 3:04 pm
I know this from shorewall, It is really a nice feature and a nice addition to Mikrotik and I'd appreciate also this smaller solution.
My suggestion from above is just the more "global" version of this.
cristanboj
Wed Jan 11, 2017 3:45 pm
hi guys,
does anyone of you encountered problems in PCC after upgrading their Mikrotik OS?
PCC currently is not working anymore after upgrading . please help.
easyspot
Wed Jan 11, 2017 4:09 pm
GrooveA-52HPn:
Wifi working but scan, freq usage, align, snooper not working. Downgrade to 6.32.4 all working.
Solved: need to press start lol
macgaiver
Wed Jan 11, 2017 6:32 pm
hi guys,
Just a guess - did you enable fasttrack?
driven
Thu Jan 12, 2017 12:27 am
Confirm - at 6.38 (and possibly earlier, updated from 6.37) fasttrack is broken, dynamic rules are in "passtrough", as well as on devices that do not support this feature. Downgrade to 6.37 recovers it.
moep
Thu Jan 12, 2017 7:44 am
EDIT
UPDATE
UPDATE2:
UPDATE3
second reboot does not solve this for long. after two days the problem is back. responder shows invalid dynamic policy while initiator thinks that he is connected.
UPDATE4
it seems that a double reconnect with a delay makes it possible to "solve" it.
on first (re)connect the bad invalid policy is created on responder and not automatically flushed in time. on second (re)connect the bad policy is removed and a new valid one is created allowing traffic to flow.
sbeauchamp
Thu Jan 12, 2017 3:32 pm
does this fix the out of order packets on the CCR models when using the encryption hardware acceleration?
pe1chl
Thu Jan 12, 2017 4:14 pm
No.
zennik
Fri Jan 13, 2017 1:17 am
I've noticed with all of my HAP and 2011 Routers I tested on the bench, 6.38 gets really pissy with IPsec after it's running for a few hours. With each one, after about 2-3 hours it just stops passing IPSec traffic, and I can't go into IP/IPSec in Winbox or CLI, and I can't do a config export unless I disable the security package and reboot.
Winbox just gives me no info on those tabs, and in CLI as soon as I go to do a 'print' under any category in IPsec, it just hangs.
pe1chl
Fri Jan 13, 2017 10:30 am
[quote="zennik"][/quote]
Not here. Post your config and/or send a supout.rif file to support.
berny
Fri Jan 13, 2017 11:32 pm
Not sure if bug...
I upgraded to 6.38, I already reset the config to default
When I download or run speed test, the speed (tx/rx) appears also on wlan1 interface, but my pc is connected only via ethernet5
JohnTRIVOLTA
Fri Jan 13, 2017 11:55 pm
I upgraded hEX/v3 - mmips/ to 6.38, firmware to 3.35 . This release broke my speed to 250Mbit/s max for tcp or udp per direction/rx or tx/, both speed 130-150 per direction, whats happenеd ?Only now the load of cpu have equal threads load 20-30%, previously only one thread work on 100% load but speed up 1300Mbit/s!
normis
Mon Jan 16, 2017 5:33 pm
Users browsing this forum: cyrq, dervomsee and 58 guests
