prawira
Trainer
Trainer
Re: The Dude, v6.38 [current] release.
Tue Jan 24, 2017 5:13 am
Hallo everyone.
I got the new fresh installation with hotspot and userman yesterday using rb951ui-2hnd. The unit installed with ros 6.38
The things that surprise me is, i can not add 2nd profile on userman with error already exist. The profile name surely different but it always said already exist. I did try both from web and cmd but both ways gave me the same error message.
When i downhrade to 6.37, the problem solved.
What's going on with 6.38 ?
Paul
jefersonw
Wed Jan 25, 2017 2:02 pm
I've always used The Dude4.0beta3 quick access and read-only with hidden password by clicking on the device, tools / Winbox, it works perfectly ..
In Dude version 6.38.1 (with RouterBOARD 750G r3 hEX) this was removed, but I created the tool normally this way:
"%homedrive%%homepath%\desktop\winbox.exe" [Device.FirstAddress] [Device.UserName] [Device.Password]
Also works !, but if winbox.exe is not in the path indicated (this may occur) an error appears in the Dude client and shows the secret password registered!
Note: if I create the same tool in Dude4.0beta3 and inform an incorrect path to winbox.exe it will not work but also does not show the error message with the secret_password, that's good.
Please, could check and correct this, not to report the error with the visible password if the winbox.exe path is inconsistent ..
(Post # 25 also mentions this)
Thank you very much
prawira
Trainer
Trainer
Wed Jan 25, 2017 5:34 pm
Changes in v6.38.1:
prawira - I haven't seen problems with RouterOS v5 devices. Check in Devices => RouterOS => Device, to see if your Dude server is connected to this device.
as mentioned, the problem only happen on ROS v5 and v4 with high latency (>500ms). no problem with low latency devices.
Paul
jefersonw
Wed Jan 25, 2017 6:46 pm
Thank you very much
Checking and testing I still found another bug that shows the password !, in version v4 and v6, when we click on the device / tools / "Web", it shows the command line with the password:
Mikrotik_RouterOS_Device
Http://192.168.141.2/cfg?user=user&pass ... &backpage=
I removed this standard tool!
Command: "[DeviceType.Url]"
... and created a new tool
Command: "http: // [Device.FirstAddress]"
So if there is an error does not show the password! ,,, But for the winbox.exe tool I'm waiting for help, thanks.
eivind
Fri Jan 27, 2017 2:51 pm
DFS-mode selections gone, and wireless set to fixed radar detect on. For good, or just a miss?
5815 to 5850 MHz dissappeared a long time ago from "norway 5.8 p-p". Why did it disappear, and is there a chance to get them back? It's still legal for use in norway.
BobcatGuy
Wed Feb 01, 2017 10:35 am
Having problems with connectivity to the Mikroti AP.
One Mikrotik is doing DHCP, routing,... the other is AP.
When upgraded both of them, I cannot connect to the AP (which is connected via cable in the main Mikrotik router). I can't event ping the AP.
If I set STP to none on main router (now is rstp), I can ping and connect to the AP. On both of machines there are few VLAN intefraces. Why is this happening after the upgrade?
No one else having this problems?
Funny thing, I had this same problem with a cAP2N. After upgrade cannot access it from the wired side, It showed connected Ethernet, and it even passed traffic for two other Virtual AP's onto VLANs. But I could not access it from the wired side on any method.
I connected to the AP through wireless, and I could connect with the "tikAPP" on the android phone. Could change settings etc. Ironically my phone got an IP address from a distant DHCP server that was connected in such... cAP2n >wired< RB493 >wired< CRS125 The CRS 125 did the DHCP.
I could not access anything other than this cAP while being connected. While sitting reading your post I thought, I'll try this and I changed the Bridge on the 493 that included the Ethernet port 2 that connected to the cAP from rstp to NONE and then all of the sudden I could access the cAP2n with no problems. The Bridge on the cAP2n is set to rstp still. Switching back the bridge on the 493 to rstp from none breaks connectivity.
fyi - power cycle on the cAP2n prior to any of this did not fix the issue, nor did a reboot when connected from the wireless side.
Any ideas as to why it was working fine before the upgrade and then not afterwards?
tomekmak
Sun Feb 05, 2017 1:37 pm
Im missing Winbox Tool.
We have multiple PC with dude client - every1 has different path to dude client.
Adding path do winbox.exe in system path doesn't fix the problem.
This is very bad. Please fix it.
ploquets
Thu Feb 09, 2017 2:46 pm
Hello!
Is it possible to create an user without possibility to use the sensitive information stored on devices?
Because on Dude 4.0beta3, we deliver the web for seeing network maps and from the web, they couldn't use the password, for example, to access Winbox as admin.
And, now, sorry for this, but the web from the older version was better,multiple times better than this version.
I want to be able to deliver access for TheDude Desktop but without the sensitive information, so they could not use [Device.Password] for example, if logged in with user that doesn't have sensitive checked on System, Users
PaulsMT
Wed Feb 22, 2017 11:58 am
New current version have been released.
Changes in v6.38.3:
*) Fixed - winbox/webfig ping probe used retry interval in retry count field.
*) Fixed - wireless registration table didn't show values in all fields.
*) Fixed - Device tree notification system were not working properly.
*) Fixed - Client started from shortcut with added arguments tried to use 2210/2211 ports
amt
Long time Member
Long time Member
Wed Feb 22, 2017 12:56 pm
is possible to enter username and password also ? did you find any solution ?
Campano
Wed Feb 22, 2017 1:12 pm
Hello @PaulsMT a few seconds later I update my CHR to 6.38.3 and now dude shows interfaces and traffic on my Ubiquiti devices! :D Tks for the improvements!
and now I tried to upload MIBS files, but cant upload any file on dude's directory.
Tested: drang and drop on dude and winbox, through ftp is same trouble
please help me.
and greetings from Chile
Campano
Thu Feb 23, 2017 3:11 pm
my mistake
http://wiki.mikrotik.com/wiki/Manual:The_Dude_v6/Files
from a new directory on dude folder, mibs and images work properly
mobdoc
Thu Feb 23, 2017 5:47 pm
I have just upgraded to 6.38.3 and have noticed a change in behaviour regarding devices that have parents that are down. My scenario is this:
I have an AP connected to a CPE. The AP has designated the CPE as its parent.
Previously if the CPE (and therefore the AP) were down the CPE would show in red and the AP in grey. If I then ACK the CPE it would turn blue and the AP would remain grey. Since the upgrade all my CPE devices that were previously red or blue remain that way but the AP devices that were grey now show as red. i.e. the parent setting seems to be being ignored.
Any ideas?
Steve
apes
Sun Feb 26, 2017 7:33 pm
We really need custom fonts, when is it possible to provide support for us?
And how to recreate snmp profile 'no-snmp' after deleting? If create profile has version 'none', community field is not empty - it is filled 'public'. Hosts continue to be polled by snmp.
maxkrok
Tue Feb 28, 2017 9:16 am
I support the request as well with multifile syslog storing on rb750gr3 with after reboot keeping logs facility.. please help!!!!
sithara99
Wed Mar 01, 2017 12:42 pm
I'm currently using the dude 6.38.1 client version and suddenly I noticed the Dude import and export buttons are not appearing on the interface.I searched a solution on the web and could find out anyone has reported such an issue.can someone explain how to resolve this issue?
docmarius
Wed Mar 01, 2017 8:13 pm
You could use '/dude export-db backup-file=blabla.tgz' in CLI and then copy the file.
jassi
Wed Mar 01, 2017 10:03 pm
Is it possible in dude to access the charts/graphs using web url like http://ipaddress/dude/chartfileforlinks.
I want to display usage graphs url to my clients like i giving in cacti.
bclewl1ns
Thu Mar 02, 2017 9:47 pm
I posted this in another string but i figured that i should try here since there is posts about backups
So i am running Dude 6.38.3 I spend 12 hours building out our entire network to wake up the next morning and having it all Gone. So I rebuilt it again. about 200 Devices running on a CCR1016. after I got the network completely done I went to back it up so that if i lost the data again i could restore. I started the backup 16 hours ago. 16 Hours ago. again for dramatic effect 16 HOURS AGO.
currently it is stating this:
/dude print
enabled: yes
data-directory: SSD
status: disabling before export: waiting for config changes to flush (3910678 bytes in queue)
After 16 Hours it has yet to backup a 45 Meg file. WTH. I am more then pleased that the DUDE was resurrected. However, I do not understand why a simple backup takes this long. It should take minute. I have backup my entire cloud platform 1.5 TBs twice during this simple database backup.
Can someone please give me and idea what the problem is.
I am running a CCR1016-12s-1S+ with an SSD dedicated for just the DUDE.
Disk Details
# NAME LABEL TYPE DISK FREE SIZE
0 SSD SSD ext3 SD 58.9GiB 59.5GiB
gramels
Sat Mar 04, 2017 10:21 pm
I used to use theDude to upgrade my Mikrotik devices.
Now I fail to do so. I can upload package file using winbox, but they do not show up in the upgrade menu.
What might I do wrong? Where do the files need to go to, which folder on thedude server using winbox?
thx for help
bclewl1ns
Sun Mar 05, 2017 12:41 am
you need to put them into your dude/files directory then the system will see them. I have no idea why they have made this part of the system so difficult
dougshack
Tue Mar 07, 2017 1:42 am
I'm running DUDE Version 3.6 on a singe Windows 7 machine for years to monitor a Windows environment. I see no software package for the newer releases of The Dude to run 'stand alone' on a typical Windows machine.
Did I miss something???
soonwai
Tue Mar 07, 2017 4:07 am
I'm afraid so. The current version of Dude server runs only on CHR, ROS x86 and selected routerboards. Windows server was removed. See here: viewtopic.php?t=102772
dougshack
Tue Mar 07, 2017 1:22 pm
I need to move my current Dude software (on a Win 7 CPU/ version 3.6) to another Windows CPU. Where would I download the last version of The Dude that would run 'standalone' on windows CPU?
docmarius
Tue Mar 07, 2017 6:13 pm
The last stand-alone version was 4.0beta3, build date 2012-06-13.
Unfortunately I can not provide you with a download link, as it seem not to be available in the download archive.
A google search for 'dude-install-4.0beta3.zip' may help.
jarda
Wed Mar 22, 2017 9:19 am
New error on 6.38.5:
The status of records on routeros page, dhcp lease tab is displayed reversely. Enabled is grey, disabled is black...
jebz
Sun Apr 02, 2017 2:11 am
You can install Virtualbox on your windows 7 machine and run ROS CHR with Dude. Dude in CHR is very good.
patrick80180
Tue Apr 25, 2017 5:27 am
Excuse me.
Anyone can tell me,
When will 'custom fonts' function be available?
Thanks very much.
patrick
Users browsing this forum: Johann1525, nescafe2002 and 65 guests
