PaulsMT
Re: The Dude, v6.39rc test builds.
Wed Jan 18, 2017 8:16 am
joanllopart - Seems like there is a small bug with SNMP and UBNT devices, can you please test with just releases 6.37.4 version ? If you get the same results, then its not related and we would need remote access (support@mikrotik.com)
Chupaka - Only [CTRL]+[V] will not show > sign, you will see it in the next newline. Does it really not working ? Just tested, seems to be working fine
sparker
Wed Jan 18, 2017 8:39 am
Is support snmp-traps is planned?
Chupaka
Wed Jan 18, 2017 5:04 pm
oh, I see it. can't it be fixed to show real-time situation? not an important thing but just a cosmetic fix
lgualla
Wed Jan 18, 2017 5:10 pm
My dude map on 6.39rc13 doesn't show interfaces in SNMP > Interfaces with devices like Cisco 3750-X
Also, in link's labels, doesn't show RX TX information with devices like IBM RackSwitch G7028, HP Proliant servers, 3COM 2948 plus, Ubiquiti Nanobridge M5. (But in the SNMP > Interface list they are correctly shown with traffic rates and all).
(Spanglish)
FFAMax
Thu Jan 19, 2017 12:12 am
Guys, i use function for obtain time info
oid_raw("1.3.6.1.4.1.318.1.1.1.2.2.3.0")/100/60
but in 39.rc13 this does not work, just return "0".
If i detete /100/60 then working fine: "00:48:00.00"
So how i can now divide?
dpilibosian
Thu Jan 19, 2017 9:17 pm
joanllopart - I'm not sure about Cacti, but in RouterOS - graph is made from 5 min average data rate. What is polling interval in your Dude graph ?
We imported from 4.0beta3 where graphs has been working fine. I noticed issues with graphs maybe at 6.38. Now graphs ara wrong, specially when they are over 1Gbps, and doesn't get SNMP info from devices like Ubiquiti EdgeSwitch (different models). If you look at my previous post graphs, you'll see how Dude's graphs fail when we have more traffic.
Polling interval 1 minute
Polling timeout 10 seconds
We relay on dude to graph most of our network links, it's quite important they work as expected.
I have reported a similar issue under my previous account from my last job
http://forum.mikrotik.com/viewtopic.php ... 14#p519591
The issue got better once we backed our dude database with a flash array instead of spinning disks and seems to be better in recent builds, it is not entirely gone, a cursory glance shows some graph drops that don't correspond to any other drops upstream or downstream from the link as I would expect if it was real packet loss. I'm getting these issues from a variety of devices, none of the ubnt. I've even had it happen on MTik devices. I will gladly give any and all info required to help solve this issue but it is something that needs to be solved.
jchmelik
Thu Jan 19, 2017 9:41 pm
When will Dude natively support IPv6?
bajodel
Long time Member
Long time Member
Fri Jan 20, 2017 9:32 am
in my setup, starting from 6.38x, the email notification server PORT setting is ignored (If I put 587, it uses 25 instead). I can't test rc now, could someone please check/confirm ? thanks
macsrwe
Sat Jan 21, 2017 1:43 am
In 6.39rc13, opening Link / General always shows "Interface" field in blue as if it has been changed and not saved. Hitting Apply turns it black, then immediately blue again. A really minor bug (I hope). Originally, I thought it was causing link coloring to fail, but upon further examination, I believe coloration appears to be working properly.
FFAMax
Sat Jan 21, 2017 4:45 am
When editing link speed on map in 6.39 rc13 unable to use shorts like 20M (20 Mbit). Should use 20000000.
Please fix it.
asik
Mon Jan 23, 2017 9:37 am
Changes in v6.39rc13:
*) Fixed - winbox/webfig ping probe used retry interval in retry count field.
asik,cdemers - In the next release candidate version (rc14) will be included some fixes for parrent/child notifications.
tested, it looks promising. I inform about malfunction.
Here another problem.
When I open the chart, the dude hangs for a long time, because of the large amount of data to view in chart (from few months).
It is posibility to setup last zooming value as default instead of "all"? like is when i open label beetwen links i have last zooming setup.
FFAMax
Mon Jan 23, 2017 9:40 am
+1
I think should be "default zoom value" i settings for links
joanllopart
Mon Jan 23, 2017 10:58 am
Installed 6.37.4 and SNMP polling from Ubiquiti's EdgeSwitch works again.
We don't know if the other issue (graphs on Mikrotiks' links with traffic over 1Gbps) is fixed in 67.37.4, we have to wait some hours ...
joanllopart
Mon Jan 23, 2017 11:11 am
Graph isues are with any kind of device link, not just Ubnt. We are somehow used to those spikes. The problem we have with last versions is that it fails to graph properly when traffic is over 1Gbps. An example with two graphs on same interface, secod graph is the one that shows real traffic:
Graphed by Dude, SNMP polling on CCR1072:
Graphed by CCR1072:
asik
Mon Jan 23, 2017 11:28 am
it's posiblle to view created chart's in the dude via web like graphing in routerOS?
bajodel
Long time Member
Long time Member
Tue Jan 24, 2017 7:39 pm
Am I the only one ?
(x86 dude)
gammy69er
Tue Jan 24, 2017 11:27 pm
Bug Report.
Unsure if this affects other element types at this stage, but Copy/Paste on Network Elements goes onto new map - but holds Network Map ID information, rather than changing the information to the new map
Adjusting XML net map ID Corrects adjusts, but creates 2 times the work - almost faster to just make each manually.
Here is a copy of some of the XML - Highlighted in Red is the Offending variable, Green is the Correct Variable - which relates to the current map
<?xml version="1.0" ?>
<dude version="6.39rc17">
<Network>
<sys-id>XXXXXXXX</sys-id>
<sys-name>PPTP-XXX</sys-name>
<subnets>x.x.x.x/32</subnets>
<netMapID>11778236</netMapID>
<netMapElementID>XXXXXXXX</netMapElementID>
</Network>
<Note>
<sys-name>Name:XXXXXXXXX</sys-name>
<objID>XXXXXXXX</objID>
<timeAdded>Jan/24/2017 20:48:32</timeAdded>
</Note>
<NetworkMapElement>
<sys-name>[Network.Name]\0d\0a[Network.SubnetsColumn]</sys-name>
<mapID>11789731</mapID>
<itemType>network</itemType>
<itemID>XXXXXXXX</itemID>
<itemX>72</itemX>
<itemY>227</itemY>
<itemUseLabel>yes</itemUseLabel>
<itemUseShape>yes</itemUseShape>
<itemUpColor>FFFF53</itemUpColor>
<itemShape>cloud</itemShape>
<itemFont>0B00000000000000000000000000000000000000000000010000000042697473747265616D20566572612053616E7300000000000000000000000000</itemFont>
</NetworkMapElement>
Just to note - these elements were copied in 6.38rc41, but this is also still produced in 6.39rc17 when copying these elements.
The Problem is the Network Map ID dictates the "Map" Listing under the Networks List
Sorry for the redaction - not too sure about our sensitivity at this stage (better to be safe than sorry). as you can see here though, all the Map Names are the same - but the note indicates that they are in different areas, and I have checked - they are.
Any statements on this would be awesome, and a fix would be epic :)
macsrwe
Wed Jan 25, 2017 4:32 am
Since putting up 6.39rc13, a large portion of my network got stuck in this state:
wrong challenge (not requested)(4)
whatever that means. I can't see link status or do bandwidth tests to those devices until I call each one up by hand and do a manual Reconnect. They're still green and all, but Dude can't talk to them.
PaulsMT
Wed Jan 25, 2017 10:13 am
Changes in v6.39rc17:
*) Fixed - wireless registration table didn't show values in all fields.
*) Fixed - Device tree notification system were not working properly.
*) Fixed - Client started from shortcut with added arguments tried to use 2210/2211 ports
joanllopart - at the moment I can only suggest you to use RouterOS as mastering type in cases where the link speed is above 1Gbps.
bajodel - thanks, problem is reproduced.
gammy69er - moving devices between maps is in our to-do list.
macsrwe - If you can repeat the problem in rc17, please write to support@mikrotik.com
FFAMax
Wed Jan 25, 2017 10:17 am
Hello, Pauls!
But what about my issue http://forum.mikrotik.com/viewtopic.php ... 13#p578559?
PaulsMT
Wed Jan 25, 2017 10:43 am
Quick tests didn't show problems. Make sure that you are dividing only integers.
FFAMax
Wed Jan 25, 2017 11:13 am
If i rightly understand, in my case TimeTicks (oid 1.3.6.1.4.1.318.1.1.1.2.2.3)
This worked before but now broken.
joanllopart
Wed Jan 25, 2017 1:47 pm
Selecting mastering type = RouterOS does not lists any interfaces in the drop-list. And yes, there is a valid user/password set.
asik
Wed Jan 25, 2017 7:14 pm
not working as expected, in this device tree structure at the end of a large tree:
......3 parent____
...........................|2 child______
.................................................|__________________________
.......................................................|1a child..........|1b child..........|1c child
when (3) parent stoped working i have got notifications in the order received:
when DOWN:
1a child
1b child
3 parent
when UP:
3 parent
1a child
in this configuration:
http://forum.mikrotik.com/viewtopic.php ... 71#p577808
UPDATE:
I have different notyfication behavior every time when i do a controlled failure.
jstump
Thu Jan 26, 2017 7:42 pm
Can we please add the ability to type something like 20M under link speed (like btest, etc) instead of having to type 20000000? Those of us with a lot of 10G and 1G links would really appreciate it!
macsrwe
Fri Jan 27, 2017 10:54 am
Reset all the "wrong challenge" units yesterday by manually Reconnecting. Upgraded to rc17 last night. Tonight, I see I have two CPEs again stuck in the "wrong challenge (not requested)(4)" state. I'll send in an error report.
It also would be nice to know what that error message is supposed to mean.
Micropower
Thu Feb 02, 2017 2:51 am
Running 6.38.1 on a 20 ROS device Network. Since the Dude is Evolving, Is it Recommend to Run Dude 39.x.rc ( Latest ) on just the ROS+Dude-Hex Server
or will the older versions of ROS on Network cause issues? Best to use an entry in " IP Firewall Address List" for Discovery Blacklist ?
milhorini
Fri Feb 03, 2017 5:31 pm
Hi...
I need list device with stats down via cli, is possible?????
me9
Wed Feb 08, 2017 12:11 am
Hi.
arxdust
Fri Feb 10, 2017 5:37 pm
Please add centralized storage backups of all devices under management RouterOS on dude server. For example: create backups by schedule, restore backups. As well as a choice save to internal or external storage.
macsrwe
Re: v6.39rc [release candidate] is released
Sun Feb 12, 2017 1:52 am
There's been this display bug that's been in Dude since the old version of years ago: that is that the background image entirely disappears at some resolutions.
It used to be that at resolution 200%, the background turned to white. Every other resolution (including 100% and 400%) showed the background image just fine.
I just rebooted my Dude server to 6.39rc27, and the behavior now is even weirder. At the far northwest end of my map, all resolutions work fine. Move a little further SE and only the 400% resolution background is white. Further still, and both the 200% and 400% resolutions show the problem. Even further, and only the 200% resolution shows the problem. At the far southeast end, again both the 200% and 400% resolutions show the problem. It is entirely position-dependent, and entirely repeatable.
Am I the only one experiencing this?
vosgessystemes
Wed Feb 15, 2017 10:47 am
We really need two link between two routerOS on our network map... Please :)
Br,
Julien
jarda
Re: RE: Re: The Dude, v6.39rc test builds.
Wed Feb 15, 2017 7:45 pm
Br,
Julien
Even two are not enough sometimes. Using dummy device in between is a nightmare.
ryz
Wed Feb 15, 2017 7:58 pm
heaven
Thu Feb 16, 2017 8:09 am
Somebody faced with problem in nat rules? When I try to add new scrnat rule, src,dst,any port was not activied. Maybe somebody speak about that but I not find it. Sorry for flood.
Chupaka
Thu Feb 16, 2017 2:24 pm
upgrade your WinBox, this was fixed in v3.9
raffav
Tue Feb 21, 2017 4:19 pm
i don't know if is a Dude Problem or ROS Problem or Winbox
but i can not change value using the "dude on winbox"
ie on dude/probe if i change a port number and save it return to the default value
asik
Thu Feb 23, 2017 9:11 pm
- problem with dissapearing background image on main map still exist. It appeared on upgrade from 6.39rc25 to 6.39rc35
- problem with notifications still exist on larger setup in 6.39rc25 (400+ devices, but i see improve in functioning)
update: some image used for map apperance missing too and was automatically removed from dude/files/images
aTan
Wed Mar 01, 2017 4:40 pm
I still can't auto upgrade the Dude client under Windows 10. It does the same under Administrator account and under non-Administrator account. Tries to download some dlls and then nothing. Surprisingly it successfully auto upgrades under Linux and Wine. No problems at all. After downloading dlls the Dude client restarts and a new version is running. Maybe there is something with UAC. The Dude client doesn't ask for Administrator rights during upgrade. So it can be the source of the problem.
UPDATE: Tried on several PCs. One PC with disabled UAC upgrades the Dude client without any problem.
ploquets
Fri Mar 03, 2017 8:53 pm
What if you execute Dude as administrator from any account ? Maybe it will grant permissions to be updated.
mysz0n
Tue Mar 07, 2017 3:06 pm
Just updated my 3011 to 6.39.rc.45
I don't see speed on links and graphs
https://drive.google.com/file/d/0Bz1c8I ... sp=sharing
aTan
Thu Mar 09, 2017 10:08 am
It works when it is run as Administrator. But it is not correct behavior. It should prompt for elevation (UAC) before update.
apes
Thu Mar 09, 2017 5:54 pm
We really need custom fonts, when is it possible to provide support for us?
And how to recreate snmp profile 'no-snmp' after deleting? If create profile has version 'none', community field is not empty - it is filled 'public'. Hosts continue to be polled by snmp.
nkourtzis
Thu Mar 23, 2017 10:37 am
I agree! Furthermore, having to run Dude as admin every time, prevents it from running at login and also, in multi-user PCs, it makes it use a common server list instead of a personal one for the user.
macsrwe
Sun Mar 26, 2017 11:35 pm
Just an update that this problem persists in the latest version. Still awaiting any response from support.
mysz0n
Sun Mar 26, 2017 11:41 pm
Try to Vacuum database. I got the same issue I did the vacuum and it helped me
macsrwe
Mon Mar 27, 2017 4:55 am
Apparently, I cannot vacuum the database. I'm running on a hEX, which has limited "RAMdisk" storage. A number of references claim that vacuum uses the same store as the Dude DB, but either that isn't true or it has gotten broken since -- I have tons of space on that drive, but when I run vacuum, I watch the free space indicator in the Files window go from 42% to 0% and then the vacuum aborts. I've filed a support request.
dash
Thu Mar 30, 2017 1:17 pm
- DELETED -
posted under the wrong topic
mysz0n
Thu Mar 30, 2017 1:20 pm
I am facing issues with the 6.39rc58 on an RB952 (6.39rc58 port1) which is POE powered from an RB3011 (6.38.5, LAN port 10). After updating the RB952 with the rc58 frimware POE does not turn it on again. I had to use the standard 24v power supply to get it up and running before i was able to downgrade to the 6.38.5 package. In 6.38.5 POE works with no issue...
Does it have anything to do with the dude package?
pietroscherer
Trainer
Trainer
Tue Apr 04, 2017 12:24 am
Does anyone having a problem with "find tool" (Ctrl + F)?
At 6.38.5 is not possible to search using IP Address (nothing is found), only by device names.
In partial change logs, nothing about this was said yet.
OnixJonix
Request...
Fri Apr 07, 2017 7:20 am
1. (Winbox) In CapsMan REGISTRATION TABLE add column with client IP and Active Host Name like in dhcp server lease section!!
2. (Winbox) In DHCP Lease section when pressed right mouse button on client add Torch and Ping option!!
ittcoin
Mon Apr 10, 2017 5:55 pm
Dear all, I've a problem with dude tools security. When create a tool, for example for winbox and has a problem with the file, winbox.exe, for any reason, in the alert message you can see in plain text the password of the device, that is a big security problem :-S. Any suggestion for solve it? The error windows is: "Execute failed (command: C:\winbox.exe 192.168.0.1. admin "thepasswordinplaintext". The system...." Thanks.
Chupaka
Tue Apr 11, 2017 6:04 pm
it's not a big problem. just copy your device to Clipboard and paste to Notepad - here's the password even without calling WinBox :)
sterling
Wed Apr 12, 2017 3:25 am
Sorry to ask, but have need to upgrade a bunch of core CCR1072 units and CRS units.
When do you think v6.39 final will be available?
It's been since Dec 30 on 6.38 when I upgraded everything and then right after they had a lot of STP/RSTP stuff happen...
aTan
Wed Apr 12, 2017 10:21 am
Unbelievable. :shock:
mysz0n
Wed Apr 12, 2017 12:04 pm
After updrade to 6.39rc68 (hex r3) I lost all the files on the usb drive, and in the FILE a nwe folder appeared disk2, I also have disk1 (both empty).
Guess where i kept the backup ...
On Friday I added 100+ test devices to check the stability on hex r3 ...
Thx mikrotik ..
mrbartez
Thu Apr 13, 2017 12:57 pm
Hello everyone - that's my first post although adventure with mikrotik started many years ago :-)
I have a problem with 64-bit counters. In changelog v6.36: Fixed - diff64 function broken.
I installed dude on mmips (RB750Gr3) - but for this platform dude is available from 6.37.5 version - maybe fix is not implemented for this platform?
I need simple function: diff64(oid_raw("1.3.6.1.2.1.31.1.1.1.10.436400128")) - oid_raw return correct value but diff64 from oid_raw value return "0". On 4.0beta3 its ok
Additionally there is some problem with reading 64 bit count. If interface speed is more than 1Gb build-in function e.g. Interface.InBitRate looks like reading 32-bit count because value which show is not correct - much lower. I set on link snmp-type and speed (10g ethernet) but there is no difference. On label visible max speed is 4.29Gbps. I tried a few different version - the same problem.
nje431
Thu Apr 13, 2017 3:12 pm
It's actually broken on 4.0beta3 as well. While it will take a 64 bit counter as an input, it is a 32 bit signed output. I haven't tried it since it was pronounced fixed.
macsrwe
Sun Apr 16, 2017 11:20 pm
There are two aspects to this: 1. It's too easy to for any user without advanced credentials to get any password through this or a similar (CSV) hack; and 2. There's no supported provision for a user having advanced credentials to recover a password. My point here is that I pray that MikroTik does not close loophole one without providing feature two first.
Sent from my iPhone using Tapatalk
macsrwe
Mon Apr 17, 2017 3:38 am
Not only has this problem not been addressed, but yesterday the Windows 10 machine that runs our Dude client did an automatic OS update and an automatic reboot, and failed to restart the client. When I got back to it, there was a (truncated) error message saying something to the effect of the server had refused connection frim the client(!) because of the wrong challenge. I stopped and restarted the client, and it came up, but whatever this wrong challenge thing is, it really needs to get fixed.
xeroin
Mon Apr 24, 2017 12:06 pm
Good day,can anyone have experienced the problem: use 6.39 Dude,the map added about 1000 of switches that are polled via SNMP when you open the card device is a large delay of about 8-10 seconds,while the server is not overloaded and CPU usage does not exceed 20%,this problem is present? on Dude 4 this problem was not observed
eriitguy
Sat Apr 29, 2017 5:21 pm
Hello!
Please add a possibility to add multiple "To" in Email notification. Something like: user@domain.com, user2@domain.com
And it seems that Dude and Winbox shows different Server address:
Dude
Server Dns Name: smtp.gmail.com
Winbox
Server: 0.0.0.0
Thank you!
dineshplp
Thu May 04, 2017 8:23 am
Upgraded to 6.39.1 and lost the history graphs and nothing in the outage. Running it on CHR. Anyone else facing this issue.
dineshplp
Thu May 04, 2017 8:54 am
rebooted the CHR and now everything is back.
mezzovide
Thu May 04, 2017 9:57 am
Hi, i have a problem with the dude 6.39rc80 and TP-Link TL-SG105E. When i create a new device for TL-SG105E ping probe return ok(corrupted), and i already checked with normal ping command it returns normal when pinged.
LouisVisagie
Thu May 04, 2017 9:58 am
Any plans to enable drag & drop of devices into a subnet map?
ilunne
Sat Jun 10, 2017 4:39 am
no more updates?
dirtonth
Trainer
Trainer
Fri Jun 16, 2017 10:12 pm
I was running both The Dude 6.39 and The Dude 6.40rc21 and I am getting:
std failure: not allowed (9)
This affects only RoS Devices, for The Dude trying to log in using winbox. It seems sometimes it works, other times it does not !
any ideas as to why this happening ?
105547111
Sat Jul 01, 2017 10:09 pm
I'd like to see link downs being able to be monitored and logged on RoS devices. Right now there is none :(
aTan
Fri Jul 28, 2017 10:51 am
No changes in 6.40?
JimmyNyholm
Sat Jul 29, 2017 1:51 pm
Graphed by CCR1072:
Are you sure you using 64bit counters. that looks very much like wrapping numbers!?
autostoper76
Fri Jul 20, 2018 5:03 pm
when will the new versions?
There is no improvement for a long time
6.39 === the latest version
https://wiki.mikrotik.com/wiki/Manual:T ... _changelog
Users browsing this forum: I7A3Ui, lastlegittroll, massinia, raffav and 48 guests
