normis
Re: RouterOS v6.27 released
Fri Feb 13, 2015 1:06 pm
Maybe Winbox is slow to give updates beause your router is 100% CPU loaded? What is the cause of CPU load ?
isaiservices
Fri Feb 13, 2015 1:10 pm
does RouterOS work on SATA 6gb/s?
Just love how some questions just gets ignored.........
paka
Fri Feb 13, 2015 1:13 pm
100 % CPU load is since we have upgraded from v6.6 to v6.22.
The cause for that is bug :)
see here http://forum.mikrotik.com/viewtopic.php?t=91468
in v6.22 we had not problem with system time
kristaps
Fri Feb 13, 2015 1:30 pm
Yes it works with 6gb/s ports
in motherboard GA-Z77MX-D3H with kingston V300 ssd
normis
Fri Feb 13, 2015 1:54 pm
You say v6.22 but image shows v6.25, but this topic is actually about v6.27 ...
mars
Fri Feb 13, 2015 1:57 pm
we find that with the new ros versions after a day or two the ccq drops and the data across the links starts getting less till the router is rebooted then it is back to normal for the next two days
mostly we see this on the newer rbs
anybody else have this problem
und3ath
Fri Feb 13, 2015 2:14 pm
What about Nstreme? When will it be fixed? (not polled for too long disconnections)
THG
Fri Feb 13, 2015 2:30 pm
Is there any reasons not to fix this issue? As you can see in the picture, TCP traffic through the Ethernet interface shows over 80 percent more than the VLAN interface. UDP shows the correct speed on both interfaces and the issue appears only in the X86 version of RouterOS.
Sob
Re: Re:
Fri Feb 13, 2015 3:21 pm
I'm pretty sure that 6to4 works, i use it a lot, maybe it is configuration error? ...
It depends on what kind of 6to4 you use. If it's connection to tunnel broker (6to4 interface has remote-address set), then it works. But if it's the automatic kind (no remote-address for 6to4 interface, address derived from IPv4 in 2002::/16 range and default route with gateway ::192.88.99.1%<6to4_interface_name>), then it does not. This is complete config. Since then, they fixed the first problem ("hop limit exceeded" for 2002::/16) in 6.24. But the second one ("no route to host" for everything else) persists. Last reply ("we will look into it") from support is from 16th December, so I'm getting a little worried if the issue got lost in queue or something.
bronx
Fri Feb 13, 2015 3:45 pm
Hi Normis,
system clock error in RouterOS v6.25 by x86!
It is synchronized with NTP-Servers unproblematic
But it works delayed in time (look on seconds).
we can't upgrade our live system to v6.27 to test it.
we have tested v6.25 in RouterOS v6.25 by mipsbe, it works
for your reply thank you in advance
Regards,
paka
please explain more, what is wrong with seconds ?
can you post some image, or other details about this ?
Normis, but the same packet loss occurs when one pppoe reach keepalive-timeout or only if removed from shell/gui by administrator?
In order to understand if in this case is better to restart pppoe-client on the CPE.
The limit of 1000 pppoe it's valid on CCR1036 ?
Thank you
normis
Fri Feb 13, 2015 4:15 pm
There is no limit, just on large numbers it takes a lot of resources, what happens then, depends on your CPU and number of clients
bronx
Fri Feb 13, 2015 4:18 pm
But keep-alive reached/CPE disconnect pppoe/Administrator remove ppppoe from server take the same CPU resources ?
ufm
what about Ticket#2014122166000217
We already responded that this is not a bug that is easily fixable. This is one of fundamental flaws of the whole system, reason comes from kernel. If you have thousands of interfaces that are being listed, removing entries is very CPU intensive. We cannot fix it in RouterOS v6
Nowhere in documentation or promotional materials not described this serious limitation.
Several times I asked - when the wait though, would be the beta v7? No answer.
Yes, we are small company from small country.
I really try not to swear.
But I very much hope that there will some big company вы.бет вас за такое поведение при помощи своих юристов - по полной программе.
normis
Fri Feb 13, 2015 4:34 pm
In our test, the effect is very mild, not like Ufm describes, so I guess this is a question to him. We are still doing everything we can to repeat this problem, but so far, we are not successful.
Kalpar
Re: Re:
Fri Feb 13, 2015 4:35 pm
Oh. This was unexpectedly fast release.
It is true. Mikrotik Support is there any known serious problem in 6.26?
since there were no other big issues, we wanted to fix the health very badly :D
zero bugs left
Hello Normis,
Any chance that Support TicketID: 2014030666000236 will get fixed?
Router always looks in the main table when it has to send ICMP TTL exceeded in transit (type 11)
It is detailed at:
http://forum.mikrotik.com/viewtopic.php ... 00#p414018
and
http://forum.mikrotik.com/viewtopic.php ... 00#p413242
Thanks.
noyo
Fri Feb 13, 2015 4:44 pm
is bug?
Polish shortcuts:
English shortcuts
normis
Fri Feb 13, 2015 4:45 pm
You have localized Windows version? Yes, RouterOS only understands settings in english.
noyo
Fri Feb 13, 2015 4:49 pm
Debian 7 + wine + winbox :)
That's what he sets RouterOS Polish?
galaxynet
Long time Member
Long time Member
Fri Feb 13, 2015 8:22 pm
routerboard-6.27-mipsbe.npk - seems that this package is missing....
Both in the zip file for download on the 'download' page and via packages 'update' under ROS.....
Thom
paoloaga
Fri Feb 13, 2015 9:13 pm
There is no "routerboard" package in ROS v6, it is included into system.
galaxynet
Long time Member
Long time Member
Fri Feb 13, 2015 9:16 pm
routerboard-6.27-mipsbe.npk - package missing is what ROS tells me from the Winbox /system packages download.
It is not I who is telling 'you' its missing, it's ROS telling me it's missing.
BartoszP
Fri Feb 13, 2015 10:15 pm
RB133C3 - Sytem/Packages/Check shows 6.27 available but version 6.xx bricks RB133C3.
Should be therefore 6.xx be reported to this router as upgrade ?
plentyofbug
Fri Feb 13, 2015 10:17 pm
No, routeros doesn't work on any new x86 system, especially Intel C202 or many many similar new chipsets, including Intel® i217LM + Intel® i210AT ethernet controllers family and so on...
Basdno
Sat Feb 14, 2015 12:58 am
Maybe that is because you ask them in the totaly wrong thread?!
This is a thread about the latest release of RouterOS, and bugs/questions regarding that particular subject. Meaning the guys who come into this thread doesnt necesserily pay attention to off subject topics when they screen through the thread in look for answers.
Asking about what hardware to use would probably be best put in an OWN thread under f.ex. GENERAL or maybe even Hardware talk section, then you would probably have gotten straight to people interested and capable of replying fast to you.
I am not saying you cant get an answer here(clearly you did already anyway), just pointing out that it does matter WHERE you post your questions about different topics. And whining you arent getting any attention when in the wrong thread isnt the best way to go about it. ;)
This is not meant as criticism, only a well meant general advice!
Wish u all the best! :)
Cheers
jarda
Sat Feb 14, 2015 3:09 pm
Having three mipsbe routers connected to internet:
A: running SSTP server accepting SSTP conections from B and C
B: running SSTP server and client, connecting to A and accepting connections from C
C: running SSTP client and connecting to A and B
A had 6.25, B had 6.18, C had 6.25 and everything worked fine.
Decided to update A from 6.25 to 6.27. Result: Connection from B was fine. C was not able to establish connection.
Decided to update C from 6.25 to 6.27. Result: C is not able to establish connections both to A and B. The disk1 that was working in 6.25 was renamed to disk3 and new disk1 appeared – this should not happen!
And what is more: not running SSTP clients show incoming packets and data in interface overview. How to? Torch is blank…
Reverting both A and C to 6.25 and waiting a correction. After downgrade both A and C to 6.25 everything works correctly like before.
Supout was sent to support, ticket nr. [Ticket#2015021466000104]
galaxynet
Long time Member
Long time Member
Sat Feb 14, 2015 4:07 pm
Well I was able to resolve my own issue. I was upgrading units from 5.26 to 6.27 and got this as an error:
"routerboard-6.27-mipsbe.npk - package missing " That is what package update is telling me when I tried downloading the latest update.
The solution was to upgrade to an earlier version of 6. In my case I used 6.17, once I upgraded to 6.17, the update/upgrade to 6.27 went fine.
Still - this should be fixed in 6.27. It should not be necessary to do intermediate upgrades from a mature ROS version to a newer 'mature' version. Just my two cents worth.
Paoloaga - just thowing out, ROS 6.27 doesn't have "routerboard-6.27-mipsbe.npk" is not an answer. I knew it didn't have it, I was looking for a solution to the upgrade issue.
ibm
Sat Feb 14, 2015 10:25 pm
I have a kernel failure and so a forced reboot on the routerboard pinged when I ping with a frame size of 1470 and more a pppoe client or a pppoe server address, the pppoe client and server interfaces run on a bridge in each rb in which I have an eoip tunnel that allow the L2 communications between the 2 devices. Both have 6.27 with latest firmware.
redbullsteve
Mon Feb 16, 2015 7:01 am
Upgraded a few CCR1036-12G-4S to 6.27 and have seen BPG become very unstable, connected to 4 peers, session connects fine then randomly drops all peer sessions and reset between 4 hours and 10 mins.
Not sure what the cause is, nothing errors or looks incorrect, downgraded to 6.26 and BGP is stable again.
Could either be an issue with OSPF or BGP, very hard to tell.
normis
Mon Feb 16, 2015 8:47 am
this is not the right command. "/system packages update check-for-updates" is the right command
normis
Mon Feb 16, 2015 8:48 am
You are right, that auto-upgrades shouldn't be shown to incompatible routers, but old RouterOS doesn't know about limitations of new RouterOS, and we can't simply tell old RouterOS some new instructions.
As you know, Download page states "RB111, RB112, RB133C, RB150 devices are not supported in v6, please use v5.", but yes, I agree, we need to think of some way to disable auto-upgrades for these devices.
zyzelis
Mon Feb 16, 2015 8:58 am
I have running CCR1036-12G-4S 3 days. bgp uptime equal to routers uptime. So You should check configs
nz_monkey
Mon Feb 16, 2015 10:12 am
We have the same router running 6.27 with 4 peers running OSPF, BGP, BFD, MPLS, VPLS, L3VPN with 9000+ byte MTU and holding around 60,000 routes via BGP.
It has been stable for 3 days now. Maybe your instability is something specific to your configuration. You may want to email support@mikrotik.com with more details so they can help you.
yozz
Mon Feb 16, 2015 11:17 am
script not work in 6.27
:foreach i in=[/ip firewall address-list find ] do={
:if ( [/ip firewall address-list get $i comment] = "OpenBL" ) do={
/ip firewall address-list remove $i
/import file-name=disk2/openbl.rsc;
:log info "Removal old openbl and add new";
/tool fetch url="http://joshaven.com/dshield.rsc" mode=http dst-path=disk2/dshield.rsc;
:log info "Downloaded dshield.rsc from Joshaven.com";
skibi82
Mon Feb 16, 2015 1:01 pm
And again, the same can not be imported and name of the certificate.
As I will now want it to be 100 certificates then i have totally fuck
Fairy where I have a certificate?
Maybe cert_42 can cert_23 wtf?
I have all displayed in the CLI and then look for
Great Improvement
DjM
Re: Re:
Mon Feb 16, 2015 2:03 pm
Normis, MikroTik support team,
what is the reason of no-reply or no-answer to my question related to SMS bug, please?
@normis:
What about setting variable in script via SMS - multiple year bug?
http://forum.mikrotik.com/viewtopic.php?f=9&t=58934
Multiple support tickets created for this bug.
Thank you
strods
Re: Re:
Mon Feb 16, 2015 2:44 pm
DjM - Please try to do the following:
1) Delete your variable from "/system script environment";
2) Remove ":global myvar" definition from script and leave only log and beep functions.
It works for me like that.
Please let us know how it goes.
DjM
Re: Re:
Mon Feb 16, 2015 5:06 pm
Hello strods,
great, it is working. :-)
I can't believe that it takes years to get the hint that the variable shouldn't be declared as ":local" or ":global" in the script source, but it is great that it is working and we finally have found the solution :-) All related tickets can be closed, if they are still open.
Thank you for the hint.
ubikt23
Tue Feb 17, 2015 12:46 am
What's new in 6.27 (2015-Feb-11 13:24):
*) ipsec - fixed crash that happened in specific situation;
In what specific situation?
I try to setup an IPSec IPv4-over-IPv6 VPN between Mikrotik and Juniper ScreenOS.
The Mikrotik Device crashes when trying to establish Phase 2.
me pasa lo mismo despues de actualizar el dhcp dejo de funcionar
deanMKD1
Tue Feb 17, 2015 3:36 pm
@ubikt23 English please. We dont understand Spanish :D
ndnet
Tue Feb 17, 2015 7:41 pm
How can I configure Mikrotik hotspot to allow IP Phones to make calls without authentication and computer connected to the other IP Phone Ethernet port to be authenticated?
I am a new user of Mikrotik and i love using it. Please any help will be appreciated.
This is the challenge am having using IP Phones in the office with Mikrotik 1100 as my server.
Thanks in advance.
pbr3000
Tue Feb 17, 2015 8:24 pm
Thanks in advance.
Maybe you should create a new topic because this one is specific for v6.27 and issues related to it. A good place to look is the wiki page. ;-)
TonyJeppesen
Tue Feb 17, 2015 10:00 pm
EoIP tunnels stopped working after 6.27 release... Any Ideas or other known issues with this upgrade like this. Simple EoIP just two routers connected to each other with public IPs any help would be greatly appreciated.
Chupaka
Wed Feb 18, 2015 12:28 am
[offtop]
A week after 6.27 release, and no new RC builds... Seems like v7 is coming :) Or some Latvian holidays?..
P.S. To make this post completely off the topic: Normis, please hide that floating header on the forum, it just disturbs and nothing else...
[/offtop]
LaZyLion
Wed Feb 18, 2015 12:51 am
RouterOS auto upgrade script is broken, there is no more "current-version" and "latest-version" properties in "/system package update".
I would like to re-iterate this issue.
In 6.26 we get:
[user@myrouter] /system package update> :put [get current-version ]
6.26
But in 6.27 we get:
[user@thisrouter] /system package update> :put [get current-version ]
input does not match any value of value-name
Same thing happens with "latest-version".
Using the question mark (?) we should be able to get a list of properties.
In 6.26 it works:
[user@myrouter] /system package update> :put [get value-name=?
ValueName ::= current-version | latest-version | status
But in 6.27, no properties are shown.
[user@thisrouter] /system package update> :put [get value-name=?
ValueName ::=
strods
Wed Feb 18, 2015 11:10 am
LaZyLion - Since 6.27 "/system package update check-for-updates" is dynamic and gives output to console. That has caused changes.
You can use command like this:
:put ([/system package update check-for-updates once as-value ] -> "current-version")
ibm
Wed Feb 18, 2015 11:15 am
+1
normis
Wed Feb 18, 2015 11:25 am
+1
easy to access "View Active Topics" without scrolling to top
ibm
Wed Feb 18, 2015 11:30 am
+1
Yes, but the solution is simply to let it have always the same height (the smallest would be good).
magchiel
Wed Feb 18, 2015 2:23 pm
RB1100AHx2 switch functionality seems affected after upgrading from ROS6.25/RB3.18 to ROS6.27/RB3.22 resulting in periodic dropouts of the network as well as a flapping port to my 10MBit VoIP device.
Switch configuration is:
set [ find default-name=ether6 ] arp=proxy-arp
set [ find default-name=ether7 ] master-port=ether6
set [ find default-name=ether8 ] master-port=ether6
set [ find default-name=ether9 ] master-port=ether6
set [ find default-name=ether10 ] master-port=ether6
set [ find default-name=ether11 ] comment=WAN
set 5 default-vlan-id=1 vlan-header=always-strip vlan-mode=secure
set 6 default-vlan-id=1 vlan-header=always-strip vlan-mode=secure
set 7 default-vlan-id=1 vlan-header=always-strip vlan-mode=secure
set 8 default-vlan-id=1 vlan-header=always-strip vlan-mode=secure
set 9 vlan-header=add-if-missing vlan-mode=secure
set 10 vlan-header=add-if-missing vlan-mode=secure
add independent-learning=yes ports=ether6,ether7,ether8,ether9,ether10,switch1-cpu switch=\
    switch1 vlan-id=1
add independent-learning=yes ports=ether10,switch1-cpu switch=switch1 vlan-id=100
ether 1-5 are unused.
ether 6-9 are access ports.
ether10 is trunk port for VLAN1 and VLAN100 to an HP switch.
In addition, ether6 (master port) had a VLAN configured on the CPU-side configured as
/interface vlan
add interface=ether6 l2mtu=1594 name=vlan100 vlan-id=100
This has been running fine for over a year on various releases of RouterOS, however after the update of both ROS and RB traffic was erratic and the log was filled with a flapping ethernet port (up/down).
Placing a dedicated switch on the non-switched ether2 port to all the ports solves the issue. Aside from necessary reconfigurations to keep the network running, i.e. move the VLAN interface from ether6 to ether2 along with addresses, DHCP (both for VLAN1 and VLAN100) and hotspot services (running VLAN100), no further changes to the network have been made.
Any ideas?
strods
Wed Feb 18, 2015 2:28 pm
magchiel - Please generate supout file on your device and send it to support@mikrotik.com.
magchiel
Wed Feb 18, 2015 3:11 pm
done.
PashaT
Wed Feb 18, 2015 5:21 pm
RB951g-2Hnd
Interfaces - Blink not working.
rextended
Wed Feb 18, 2015 7:55 pm
The only valid system for RB133C3 are RouterOS 2.9.51...
rextended
Wed Feb 18, 2015 8:09 pm
All my network work with EoIP, no one single problem on 6.27,
the error are surely your configuration, paste it on the forum.
rextended
Wed Feb 18, 2015 8:23 pm
After some days of use 6.27 on ALL my 200 network devices
(i have also near 4000 CPE all upgraded up to to 6.20, and 4 Gateway for PPPoE all forced to 6.7 for the unresolved bug also described on my signature)
All 200 devices with 3.22 BIOS except 2 RB1200 at 3.10, because for RB1200 (AMCC460) the latest released bios are 3.10
1) No single nstreme or nv2 problem on 5GHz (I not use 802.11 or 2.4GHz)
2) No single BGP, VRRP or EoIP problem
3) No single pppoe problem on transit from CPE (6.20) to Gateway (I'm forced to 6.7 on pppoe servers)
4) No system healt problem on any device
5) No strange shutdown or other problems.
6) No misaligned clock on x86, mipsbe, tilera or powerpc device (i not longer use obsolete mipsle)
7) The only problem are the OID for system voltage, on some random boards (7 from 200, various models), after upgrade, I stop get only the voltage value (obviously the function are supported on that devices!)
iso.org.dod.internet.private.enterprises.mikrotik.mikrotikExperimentalModule.mtXRouterOs.mtxrHealth.8.0
( 1.3.6.1.4.1.14988.1.1.3.8.0 )
Simply reboot the device, do not get the solution.
The solution (my solution...): open the device with clean winbox (no load previous session), click on system/healt, open new terminal, write "/system healt;print", press enter, and write "print oid", press enter and after that, reboot the device, and the system healt voltage oid are get again by snmp.
mike910815
Wed Feb 18, 2015 8:51 pm
I had a problem on my 2009 vintage RB433 after installing v6.27. I had the MTU on all Ethernet ports set to 1522 as advertised here http://wiki.mikrotik.com/wiki/Manual:Ma ... uterBoards
Everything was working fine before the upgrade reboot (I think I was running 6.22), but after the reboot ports 2 and 3 were dead. I had to set the MTU down to 1518 to get them to work and it will not accept a setting of 1522 anymore. An MTU value of 1522 still works on the first port.
For anyone with an RB433 I suggest setting your MTU to 1518 or less before performing the upgrade to 6.27. I'm not sure if this will apply to any other hardware.
ibm
Wed Feb 18, 2015 9:37 pm
The bug is also present with non standard eoip and pppoe server configuration?
rextended
Wed Feb 18, 2015 10:50 pm
The bug are present on all possible variant of config, I write "default settings" to underline the easy way for reproduce the bug.
For make it all worst, if you use default-encryption on pppoe server over EoIP tunnel, the kernel crash at the first logged user.
If you read my previous post on the previous version topic, you can read me proposing that kernel crash bug propably since 6.8, and I open also the ticket, but nothing is changed till now.
alibalalo
Wed Feb 18, 2015 10:59 pm
Trouble seeing where health sxt for not offering voltage and temperature this problem only in sxt
ibm
Thu Feb 19, 2015 12:01 am
Are you sure about this?
A few days ago I tested a configuration with 3 rb951 with 6.27 and ospf running, on the first rb I create an eoip tunnel to the third and I created also a pppoe server on a bridge in wich there is also the eoip tunnel. Then i created an eoip tunnel in the third rb to first and I put a pppoe client on a bridge in which there is also the eoip tunnel. I had encryption activated on pppoe and I had no problem for the time of test (about 1 hour).
PPPoE MTU is 1500, EOIP MTU is 1512 and interfaces MTU are 1554 (I reserved 4 byte for future vlans on the eoip).
marcodefreitas
Thu Feb 19, 2015 3:26 am
Did you tried VPLS/MPLS in this setup?
hossain2004a
Thu Feb 19, 2015 8:21 am
There is a little problem annoying me each time I upgrade and:
after each upgrade all of my counter will reset.
jarda
Thu Feb 19, 2015 9:11 am
Counters are reset by reboot.
strods
Thu Feb 19, 2015 9:47 am
rextended - I have created configuration which you did describe. Will see if we manage to reproduce your issue.
alibalalo - Which model of SXT are you using? Not all devices has something to show under Health menu.
ibm
Thu Feb 19, 2015 10:27 am
This is a screen on the rb1 (the pppoe server), as
you can see there is also the encryption running.
paka
Thu Feb 19, 2015 11:14 am
I've upgraded to v6.27, regardless system time does not work
For problem with 100 % CPU found - dude usage over 72%
but i can't understand why dude usage? - dude is not activated, see package state by attachment
strods
Thu Feb 19, 2015 11:29 am
paka - Do not simply disable Dude package. Please remove it and check your CPU usage then. If load drops, then check clock again.
rextended
Thu Feb 19, 2015 11:30 am
Not, I not use VPLS or MPLS on any point of my net.
rextended
Thu Feb 19, 2015 11:40 am
The couter are not stored inside RB and is perfectly normal to lost all,
is not a bug.
rextended
Thu Feb 19, 2015 11:42 am
Your test are invalid, you put the pppoe-server on the bridge, not the pppoe-server on eoip directly.
I never mentioned bridges.
ibm
Thu Feb 19, 2015 11:46 am
Mmh, ok.
Using bridge is not for you a good workaround?
rextended
Thu Feb 19, 2015 12:02 pm
If you take in charge the bug,
I can make again the test config and post it on the forum.
(On the past RB1100AHx2 + RB951Ui-2HnD, but also happen on new CCR... is not hardware related...)
Those are the links for all post about this two bug:
http://forum.mikrotik.com/viewtopic.php ... x2#p411334
http://forum.mikrotik.com/viewtopic.php ... x2#p411343
http://forum.mikrotik.com/viewtopic.php ... x2#p417272
http://forum.mikrotik.com/viewtopic.php ... x2#p421337
http://forum.mikrotik.com/viewtopic.php ... x2#p440221
The various links also contain some ticket # already opened.
rextended
Thu Feb 19, 2015 12:14 pm
Mmh, ok.
You probably find the solution for circumventing the problem (must be tested with real traffic first),
but the problem still present.
I also stop using "default-encription", but the memory leak when pass traffic, hang the board after some time is used....
ibm
Thu Feb 19, 2015 12:22 pm
Mmh, ok.
I forgot to mention that with all default MTU when I tried to ping the pppoe server from the pppoe client routerboard with a MTU size bigger than 1454 the rb1 rebooted due a kernel panic.
So the problem could be related to MTU.
strods
Thu Feb 19, 2015 12:25 pm
rextended - Could you please generate new supout file after your device has crashed and send it to our support mail? I will check it out and try to rerpoduce.
For a few hours my setup is running now and no issues. Links to previous posts include few ticket numbers but they are from old versions and more related to other issues. Supout file from latest version with crash report would be very helpful.
rextended
Thu Feb 19, 2015 12:30 pm
Mmh, ok.
I do not know what is happen, but all start with RouterOS 6.8, when mikrotik has rewrited ppp:
*) kernel drivers for ppp, pppoe, pptp, l2tp are now lock-less on transmit %26 receive;
but it deplete free memory until kernel crash, if pppoe-server are (DIRECTLY) over EoIP
*) all ppp packets (except discovery packets) now can be handled by multiple cores;
i not know is it related
*) MPPE driver now can handle up to 256 out-of-order packets;
but crash the kernel if MPPE encryption are used in combination with MRRU on pppoe-server over EoIP, when pass traffic on pppoe link.
rextended
Thu Feb 19, 2015 12:31 pm
Ok, wait please, I make it again:
I use one CCR-1036-12G-4S and one RB951Ui-2HnD
Both just netinstalled only with routeros-6.27, without keep old configuration, and update the bios with 3.22 on both.
Only one ethernet cable put between the two ether2 of the devices.
strods
Thu Feb 19, 2015 1:06 pm
rextended - Seems like I managed to reproduce. Wil see what programmers can do about it. Thank you.
rextended
Thu Feb 19, 2015 1:19 pm
VERY VERY VERY THANKS!!!!!!!!
Config on CCR 1:
[admin@MikroTik] > export
# jan/02/1970 00:37:15 by RouterOS 6.27
# software id = ****-****
/interface eoip
add !keepalive mac-address=02:4B:D6:06:ED:9B name=eoip-tunnel1 remote-address=10.0.0.2 tunnel-id=0
/port
set 0 name=serial0
set 1 name=serial1
/interface pppoe-server server
add disabled=no interface=eoip-tunnel1 max-mru=1480 max-mtu=1480 mrru=1600 service-name=service1
add address=10.0.0.1/24 interface=ether2 network=10.0.0.0
/ppp secret
add local-address=10.1.0.1 name=test password=test remote-address=10.1.0.2
/system routerboard settings
set cpu-frequency=1200MHz memory-frequency=1066DDR
[admin@MikroTik] >
config on RB951 and lines with errors:
jan/02/1970 00:01:12 system,error,critical System rebooted because of kernel failu
re
jan/02/1970 00:01:12 system,error,critical Out of memory condition was detected
jan/02/1970 00:01:12 system,error,critical router was rebooted without proper shut
down
# jan/02/1970 00:05:13 by RouterOS 6.27
/interface wireless
set [ find default-name=wlan1 ] l2mtu=2290
/interface eoip
add !keepalive mac-address=02:81:70:72:C2:07 name=eoip-tunnel1 remote-address=10.0.0.1 tunnel-id=0
/interface pppoe-client
add add-default-route=yes disabled=no interface=eoip-tunnel1 mrru=1600 name=pppoe-out1 password=test user=test
add address=10.0.0.2/24 interface=ether2 network=10.0.0.0
set cpu-frequency=500MHz
[admin@MikroTik] >
After more than 100M of traffic are passed, RB951 go out of memory and kernel crash.
For make crash CCR, you must do that various time, because CCR has more memory than RB951
For other users: OBVIOUSLY this configuration is ONLY for test purpose, not how pppoe must be used between two devices.
The config is simulating this:
pppoe-server->EoIP server->various network devices->EoIP client->bridge->wlan->cpe wlan->pppoe client
rextended
Thu Feb 19, 2015 1:36 pm
Mmh, ok.
I do the same test again, using default bridge between pppoe-server and EoIP, and one between eoip and pppoe-client
this not solve temporarly the problem :(
ibm
Thu Feb 19, 2015 2:30 pm
How is it possible?
These are my export:
RB1 Server:
add mtu=1554 name=bridge_pppoe
add mtu=1554 name=bridge_wan
add mtu=1500 name=lo
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n disabled=no frequency=2422 l2mtu=2290 mode=station-bridge ssid="MikroTik test" tx-power=14 tx-power-mode=all-rates-fixed
set [ find default-name=ether2 ] mtu=1554
/interface eoip
add !keepalive mac-address=02:F5:3B:21:71:7E mtu=1512 name=eoip-tunnel1 remote-address=10.1.0.6 tunnel-id=0
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" mode=dynamic-keys wpa2-pre-shared-key=test
/ppp profile
set 0 dns-server=10.1.0.1 local-address=10.128.0.1 use-compression=no use-mpls=no use-vj-compression=no
set 1 dns-server=10.1.0.1 local-address=10.128.0.1 use-compression=no use-mpls=no use-vj-compression=no
/routing ospf instance
set [ find default=yes ] redistribute-static=as-type-1 router-id=10.101.0.1
add bridge=bridge_wan interface=wlan1
add bridge=bridge_wan interface=ether1
add bridge=bridge_pppoe interface=eoip-tunnel1
add authentication=chap,mschap2 disabled=no interface=bridge_pppoe max-mru=1500 max-mtu=1500 service-name=service1
add address=10.1.0.1/30 interface=ether2 network=10.1.0.0
add address=10.101.0.1/32 interface=lo network=10.101.0.1
/ip dhcp-client
add dhcp-options=hostname,clientid interface=bridge_wan
add default-route-distance=0 dhcp-options=hostname,clientid disabled=no interface=wlan1
add action=masquerade chain=srcnat out-interface=bridge_wan
add disabled=yes distance=1 dst-address=192.168.0.190/32 gateway=bridge_wan
/ppp secret
add name=test password=test profile=default-encryption remote-address=10.1.0.200 service=pppoe
/routing ospf interface
add authentication=md5 authentication-key=test interface=ether2 network-type=broadcast
/routing ospf network
add area=backbone network=10.1.0.0/30
add area=backbone network=10.1.0.4/30
/system clock
set time-zone-name=Europe/Rome
/system ntp client
set enabled=yes primary-ntp=192.168.0.1
RB3 Client:
add mtu=1554 name=bridge1
/interface wireless
/interface eoip
add !keepalive mac-address=FE:8A:BC:D5:5E:9B mtu=1512 name=eoip1 remote-address=10.1.0.1 tunnel-id=0
add name=dhcp_pool1 ranges=192.168.1.2-192.168.1.254
add address-pool=dhcp_pool1 disabled=no interface=ether4 lease-time=3d name=dhcp1
add disabled=no interface=bridge1 max-mru=1500 max-mtu=1500 mrru=1600 name=pppoe-out1 password=test profile=default-encryption user=test
set [ find default=yes ] redistribute-connected=as-type-1 redistribute-static=as-type-1 router-id=10.101.0.6
add bridge=bridge1 interface=eoip1
add address=10.1.0.6/30 interface=ether2 network=10.1.0.4
add address=10.101.0.6/32 interface=lo network=10.101.0.6
add address=192.168.1.1/24 interface=ether4 network=192.168.1.0
add address=192.168.1.0/24 gateway=192.168.1.1
set servers=8.8.8.8
add action=masquerade chain=srcnat out-interface=pppoe-out1 src-address=192.168.1.0/24
add distance=1 gateway=pppoe-out1
/system clock
rextended
Thu Feb 19, 2015 2:42 pm
I do not know, but I use all DEFAULT settings, not mtu=1554
rextended
Thu Feb 19, 2015 2:57 pm
RB951g-2Hnd
on 6.27 (3.22) it's working like 6.23 (3.18):
works on all connected ethernet ports,
not work on unconnected ethernets.
all connected ethernets blink at the same time, not only the selected.
mcdebugger
Thu Feb 19, 2015 7:32 pm
Any news on CAPsMAN? See nothing in changelogs for recent versions, do U have some development on the topic?
alibalalo
Thu Feb 19, 2015 9:48 pm
Use the device sxt 5ndr2 lite
In the previous version RouterOS v5 was working well
rextended
Fri Feb 20, 2015 12:43 am
What version exactly?
I downgrade one SXT Lite5 (SXT 5nD r2) serial-number: 46AD048A8FE9 BIOS 3.18
from 6.20 to 5.26 but I not see in both case any info on healt...
I not remember any "Lite" model with temperature or voltage sensor...
SXT 2nD r2 (SXT Lite 2):
[admin@xxx] > sys
[admin@xxx] /system> rou
[admin@xxx] /system routerboard> pri
       routerboard: yes
             model: SXT 2nD r2
     serial-number: 467E0240D765
  current-firmware: 3.18
  upgrade-firmware: 3.18
[admin@xxx] /system routerboard> ..
[admin@xxx] /system> he
[admin@xxx] /system health> pri
RB911-5Hn (RB911 Lite5)
[admin@xxx] > sys
       routerboard: yes
             model: 911-5Hn
     serial-number: 4E6704A1B74B
SXT 5HnD:
       routerboard: yes
             model: SXT 5HnD
     serial-number: 2DCA012AF8C3
  current-firmware: 3.17
  upgrade-firmware: 3.17
[admin@xxx] /system> health
      voltage: 18.1V
  temperature: 30C
SXT G-2HnD:
       routerboard: yes
             model: SXT G-2HnD
     serial-number: 41F902558F90
      voltage: 23.8V
  temperature: 36C
SXT 5HPnD:
[admin@xxx] > sys
       routerboard: yes
             model: SXT 5HPnD
     serial-number: 45EF023C9C2B
      voltage: 23.6V
  temperature: 34C
SXT G-5HPnD r2 (SXT SA):
[admin@xxx] > sys
       routerboard: yes
             model: SXT G-5HPnD r2
     serial-number: 46BC02124E94
  current-firmware: 3.22
  upgrade-firmware: 3.22
[admin@xxx] /system routerboard> .. he
      voltage: 26.7V
  temperature: 18C
rextended
Fri Feb 20, 2015 10:54 am
After some day of running 6.27,
RANDOMLY
stop working on some boards.
STILL WORKING ON API, WINBOX AND TERMINAL, ONLY THIS SPECIFIC SNMP OID STOP WORKING
On 6.24 I never have one problem (Yes, I jump directly from 6.24 to 6.27 on all core machines)
I do not understand why the simple or twice reboot do not solve nothing, buit if I do:
after that the OID mtxrHlVoltage work again.
Is the only OID stop working (the OK are for each RB model than support it!),
iso.org.dod.internet.private.enterprises.mikrotik.mikrotikExperimentalModule.mtXRouterOs.mtxrHealth.mtxrHlVoltage.0: KO on some random boards
iso.org.dod.internet.private.enterprises.mikrotik.mikrotikExperimentalModule.mtXRouterOs.mtxrHealth.mtxrHlActiveFan.0: OK on all boards
iso.org.dod.internet.private.enterprises.mikrotik.mikrotikExperimentalModule.mtXRouterOs.mtxrHealth.mtxrHlTemperature.0: OK on all boards
iso.org.dod.internet.private.enterprises.mikrotik.mikrotikExperimentalModule.mtXRouterOs.mtxrHealth.mtxrHlProcessorTemperature.0: OK on all boards
iso.org.dod.internet.private.enterprises.mikrotik.mikrotikExperimentalModule.mtXRouterOs.mtxrHealth.mtxrHlCurrent.0: OK on all boards
iso.org.dod.internet.private.enterprises.mikrotik.mikrotikExperimentalModule.mtXRouterOs.mtxrHealth.mtxrHlPower.0: OK on all boards
iso.org.dod.internet.private.enterprises.mikrotik.mikrotikExperimentalModule.mtXRouterOs.mtxrHealth.mtxrHlProcessorFrequency.0: OK on all boards
strods
Fri Feb 20, 2015 10:58 am
alibalalo - This model does not have any Health info as already been said in this topic. I double checked also on version 5.26. There are still nothing on Health. Thought maybe there could have been, for example, temperature=0, but still Health window is empty.
rextended
Fri Feb 20, 2015 1:44 pm
I also update MIKROTIK-MIB, but after fix some problem, the bug is still present.
paka
Fri Feb 20, 2015 2:38 pm
Thank you very much! it is working :D
w0lt
Long time Member
Long time Member
Fri Feb 20, 2015 3:53 pm
Can someone confirm, whether or not, if the EoIP "auto-mtu" function is working correctly in v6.27?
It doesn't seem to be working for me, and wanted to know if anyone else is having this issue?
Works ok for "GRE" tunnels.. :-)
I use the EoIP tunnel over the internet, and have different MTU's when using a cable modem on one end, and a DSL (PPPoE) on the other end. and as I said, the "auto-mtu" function seems to compensate very nicely using GRE, but not EoIP. If this needs to be corrected, I would really like to see that in 6.28 if possible.
Thanks, 8)
-tp
rextended
Fri Feb 20, 2015 4:40 pm
Thanks, 8)
-tp
I use auto discovery on bridge, EoIP and GRE (from 6.2? to 6.27) and actually I do not have noticed any problem.
More detail, please?
jwcn
Fri Feb 20, 2015 6:24 pm
Still having 100% CPU issues on RB2011's. SNMP disabled, no polling with the Dude. Ticket Ticket#2015020266000038 from three weeks ago still unanswered. Please help. Management process culprit for the CPU spike. Spike to 100% and stops passing data. RB2011 is doing nothing except acting as a switch. Ports 1-5 switched 6-10 bridged to port 1.
rextended
Fri Feb 20, 2015 6:28 pm
Too few details.
Packages and version of that package installed?
jwcn
Fri Feb 20, 2015 6:39 pm
[img]
[/img]
vortex
Fri Feb 20, 2015 7:14 pm
The banner wastes an unbelievable amount of space on mobile, leaving about half the screen for the actual posts in landscape, and completely obscuring the editing area also in landscape, so that composing posts in such mode is impossible.
I also did not find how to quote, that is why this post was added by itself to the bottom of the thread.
jarda
Fri Feb 20, 2015 7:25 pm
[img]
[/img]
Where do you see 100 % cpu on your picture? How profiler looks like?
pturkey
Fri Feb 20, 2015 7:58 pm
I just upgraded to 6.27 on my RB711-5HnD and upgraded the routerboard to 3.22.
It looked good at the start so I ran a speed test at http://www.speedtest.net/.
The router disconnected, then I ran a wireless scan it shows no ap's at all.
Rebooting makes it reconnect but it disconnects as soon as I try a speed test.
Downgrading back to 6.23 make everything work again.
0 R name="wlan1" mtu=1500 mac-address=XX:XX:XX:XX:XX:XX arp=enabled interface-type=Atheros AR92xx mode=station-pseudobridge ssid="" frequency=5300
band=5ghz-a/n channel-width=20/40mhz-ht-below scan-list=default wireless-protocol=any wds-mode=disabled wds-default-bridge=none wds-ignore-ssid=no
bridge-mode=enabled default-authentication=yes default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=no
security-profile=default compression=no
jwcn
Fri Feb 20, 2015 8:53 pm
[img]
[/img]
Its been rebooted now so it doesn't show 100%. When it is at 100% I can't pull up anything but profiler shows management as the process.
docmarius
Fri Feb 20, 2015 9:31 pm
It seems that SPF status is broken on CRS-125, with no info shown except 'module present' (S-31DLC20D).
Module works correctly nevertheless.
jarda
Fri Feb 20, 2015 10:08 pm
Don't you have istalled dude package, do you?
infernoltu
Fri Feb 20, 2015 11:53 pm
Hello.
I read all posts here, but did not found that someone face same issue too.
I have a wide range of CCR1016 routers and routerOS based virtual routers.
The issue what i faced now is:
my cload core CCR1016-12G was able to be upgraded to newest 6.27 version with out any problems.
The upgrade was done from v6.24 to v6.27 on CCR1016
But now on virtual machines the upgrade fail.
My virtual routerOS are running v6.24 and v6.21.1.
When i go to system>packages>check for updates>download and upgrade, it tries to get latest v6.27 version, but during download it says it failed to download
isdn package.
Well this package i do not need, so i uninstalled it from mine virtual routers.
Then i repeat upgraded, download is successfull, it reboots for upgrade to be installed.
In console it writes it does the update.
No errors are given out by command line GUI.
But once router loads, and i log in to it, i see my old version v6.21.1 or v6.24
So it does not upgrade, and does not give any error.
jwcn
Sat Feb 21, 2015 3:25 am
No.
yvhitxcel
Sat Feb 21, 2015 10:23 am
ccr1036 12G-4s v6.27 hotspot not working.i didn't look the login web. my email 2338953@qq.com
rextended
Sat Feb 21, 2015 12:03 pm
Hello.
isdn package.
How much time you use same SoftwareID?
You use Software ID downloaded from Internet?
rextended
Sat Feb 21, 2015 12:07 pm
Do not simply leave email, this is not one direct support service, open new thread and post your config.
If someone want help you, you get help.
All users must benefit from helping you.
infernoltu
Sat Feb 21, 2015 2:08 pm
Physical cloadcores run each of them with lic preinstalled.
Virtual mikrotiks, they are clones of each other.
I am using them already for couple years, and did not experienced any problems till now.
So this means if i try to get software upgrade with same ID, it will fail?
Hello.
isdn package.
jarda
Sat Feb 21, 2015 3:03 pm
Hello.
isdn package.
Did you pay for license for each individual copy?
infernoltu
Sat Feb 21, 2015 4:39 pm
Problem solved.
Its not licensing or smth like that.
Its smth wrong with system>packages updater.
I upgraded manually from 6.21.1 to 6.26 and to 6.27 successfully.
Hello.
isdn package.
yvhitxcel
Sun Feb 22, 2015 5:45 am
interface,warning 3_WIFI: bridge port received packet with own address as source address, probably loop
why i got a lot of the warming message?how to fix
my ccr1036-12g-4s and a lot of other hardware buy only one week,,how to got Technical Support?
Spirch
Sun Feb 22, 2015 6:09 am
I have a RB951G-2HnD with v6.13 and firmware v3.14
is there any reason for me to update to 6.27 if I currently have no issue?
this is a simple home router setup
jarda
Sun Feb 22, 2015 8:11 am
If you are happy with your setup, don't touch it.
rextended
Re:
Sun Feb 22, 2015 1:17 pm
+100
docmarius
Sun Feb 22, 2015 2:16 pm
There is a saying: Better is good's worst enemy.
vortex
Sun Feb 22, 2015 5:16 pm
Upgrading from 5.26 to 6.25 or 6.27 enabled ppp, wireless, and hotspot (these last two very bad).
deanMKD1
Mon Feb 23, 2015 2:48 am
@vortex what is very bad with wireless and hotspot?
vortex
Mon Feb 23, 2015 3:19 am
That I had them disabled and the upgrade silently activated them, and I don't know if that results in a wide open network.
sergejs
Mon Feb 23, 2015 9:41 am
A loop [or bridge loop] occurs in computer networks when there is more than one Layer 2 (OSI model) path between two endpoints (e.g. multiple connections between two network hosts). Examine your network topology and find duplicate connection and remove it from your network.
uldis
Mon Feb 23, 2015 10:08 am
Please provide us more information about your setup. The AP or this Client router stopped working?
Also send the support output files to support@mikrotik.com
simaskkk
Mon Feb 23, 2015 12:23 pm
Queue Tree queues does not work in 6.27 (all counters stays on 0) (at least for GRE tunnel interfaces) :)
Very poor performance for single TCP flow over GRE tunnel.
zyzelis
Mon Feb 23, 2015 1:38 pm
If queue type is "default" Try to change default queue type to another eg from pfifo to RED. and write here if it helps.
strods
Mon Feb 23, 2015 1:53 pm
simaskkk - Does problem persist if you disable/enable queues? Do you have scripts/schedulers or something else which might change queue settings while they are working?
simaskkk
Mon Feb 23, 2015 4:15 pm
I will do some testing to figure out where the problem is and will open the case soon.
krisjanis
Mon Feb 23, 2015 4:35 pm
It's possible that system didn't manage to get correct info or get anything at all from eeprom/ddmi on transceiver. In cases like that after several attempts system will give up and leave those fields empty. Replugging the module, reboot or power cycle might help.
docmarius
Mon Feb 23, 2015 11:12 pm
Tnx krisjanis,
Replugging the module did solve the issue - all info is in its place :-)
strods
Tue Feb 24, 2015 8:23 am
rextended - We finally managed to fix crash when PPPoE was being configured over EoIP. Fix should be included in 6.28rc5 and later versions of RouterOS.
rextended
Tue Feb 24, 2015 10:41 am
YES! YES! YES!
Thanks!
sparrow
Tue Feb 24, 2015 1:24 pm
What's new in 6.7 (2013-Nov-29 13:37):
*) fixed l2mtu changing on CCRs - could cause port flapping;
Changing l2mtu on any interface of my ccr 1036-12G-4S cause port flapping, shutting down all interface, someone had same problem?
This behaviour still persist on 6.27!
becs
Tue Feb 24, 2015 3:03 pm
Although similar, this behaviour (one all interface reload after L2MTU changes) is not related to the problem in v6.7.
Users are now warned in wiki about such behaviour.
Warning: L2MTU configuration changes on Cloud Core Routers evoke all interface reload (link down - link up) due to necessary internal processes.
It is recommended to configure L2MTU with caution by keeping in mind that it can cause short interruption with connected devices.
wotoni
Tue Feb 24, 2015 5:27 pm
Hey, can we please have the .torrent files back for ALL RouterOS. I don't believe that I am the only one that uses the .torrent to download RouterOS. I myself support multiple different hardware flavors and to download each file separately can be a pain.
Thanks!
bax
Tue Feb 24, 2015 7:27 pm
Well last night i was try to upgrade my x86 ROS to v6.27 ...
Userman is give error like "radius server not responding" so i must fast downgrade to v6.26.
On other routerboard devices it looks that all is fine.
Can someone try to upgrade device with userman ?
micromaxi
Tue Feb 24, 2015 7:34 pm
Funny i just noticed on the download package from this site that the 6.27 software has been updated (release date is now 23-02-2015 where it was 11-02-2015) however i just cant find any changes in the changelog. And why hasnt the version number not been altered ?
Normis ?
uldis
Tue Feb 24, 2015 8:08 pm
Normis ?
The release date changed because we added "smips" RouterOS version for the hAP lite boards in the website. There are no other changes.
hossain2004a
Tue Feb 24, 2015 9:14 pm
It's been month, I've upgrade router with userman package, but no luck. Still have that error "not responding...." searched the forums and found no solution.
But it works fine except sometimes :D
finalcutroot
Tue Feb 24, 2015 9:39 pm
This is the third time
when i open winbox and goto the Interfaces
the router crash
i use simple script/scheduler to turn off interfaces on specific time
hapi
Tue Feb 24, 2015 11:01 pm
the router crash
same problem on two x86 routers. Local access is ok but print anything go to crash or not print. Router is not function. Same is fresh install 6.27 is same problem on same router.
Ljubo
Wed Feb 25, 2015 11:12 am
An error, which I don't know the meaning of, occasionally appears in the log.
I would be greateful if you could tell me if this error occurs due to a configuration fault or if someone is trying to connect but I am unable to see the IP from which it is coming from.
This started happening after upgrade 6.27, but before the update I didn't see the error.
jarda
Wed Feb 25, 2015 12:19 pm
To this ticket. I received today info from Mikrotik support that I should have all involved ros devices at the same level (6.27). But the ticket was also about the SSTP not working between two 6.27 devices. So the advice was false.
I found the solution myself: it is the PFS option that is not documented. Correct settings allows communication between both 6.27 as between different versions (for example 6.27-6.18 or 6.27-6.25 in my case).
Mikrotik should take care about the documentation if changing/adding anything!
siavashblade
Wed Feb 25, 2015 1:07 pm
hi guys I have a problem with this can you help me?
I didn't know how to make topic nor did I fine an appropriate place to post it so if you can help me or direct me to the best location I would appreciate it. thanks
first of all after I enable DDNS, in the status section it tells me that:
"DDNS server received request from ip ...(the public ip adress)... but your local ip was 192.168.1.6 (which is my gateway ip). DDNS service might not work."
and I can't ping the DNS name it gives me 100% timeout then I've added this command:"/ip firewall filter add action=accept chain=input disabled=no dst-port=8291 protocol=tcp place-before=0"
but this didnt help either! :|
what should I do?
I have ip cameras in my work place and I want to watch them from home via this feature.
can you help me?
mars
Wed Feb 25, 2015 2:44 pm
anybody having a problem with simple queues and mangle rules in ros 6.27
the mangle rules are not marking the traffic properly so simple queues are not working
in ros 6.26 it works with no problems
deanMKD1
Thu Feb 26, 2015 1:35 am
what should I do?
can you help me?
You dont need to add filters in firewall to gain access to your cameras.! In what LAN port is connected your camera? Are you sure that port is properly forwarded?
Farhadgh
Thu Feb 26, 2015 2:36 am
Hello normis. I wanted to inform you of this bug in case of you didn't read that:
http://forum.mikrotik.com/viewtopic.php?f=1&t=94415
It's making me a lot of effort.
ofca
Thu Feb 26, 2015 4:42 am
so when all_packages torrent/zip will be back?
siavashblade
Thu Feb 26, 2015 7:37 am
what should I do?
can you help me?
all cameras plus computers and server are attached to a switch and one cable from switch is attached to ether 2 of my mikrotik and one cable from the dsl modem is attached to the ether1 of my mikrotik.
my internet is working on mikrotik gateway and I can ping 8.8.8.8 from winbox plus I've enabled ip cloud and it gave me the dns but I cant use it, it gave me 100% timeout. so I dont know what to do!
VagnerBecker
Thu Feb 26, 2015 3:22 pm
I'm having trouble with IPv6, the interface I try to add an ip starting from a pool is in red and does not work until you restart the equipment, is an example
ipv6 pool add prefix=2001:db8::/56 prefix-length=64 name=pool1
ipv6 address add interface=ether1 address=::1/64 from-pool=pool1
karina
Thu Feb 26, 2015 3:29 pm
MikroTik 951G-2HnD.
RouterOS v6.23
RouterOS v6.27
Awesome improvement MikroTik! :D
For me it works faster...
305mbit to 345mbit...
Are you sure your speedtest.net server gives full speed?
I can confirm that I also had a speed hit on V 6.27. BAck to 6.19 all good again. I also noticed a degrading of voip quality. This was on a 1100AH. Personally for me with the config I use 6.19 is still the most stable. It is possibe the upgrade is not taking properly somewhere and a fresh install would be fine but I have not tested this
deanMKD1
Thu Feb 26, 2015 3:57 pm
what should I do?
can you help me?
Dude open a new thread, and will found the solution for your problem. This is not right thread for this problem.
LaZyLion
Fri Feb 27, 2015 11:43 pm
Great, that gives me the current version, which I can also get using
 :put [/system resource get version ]
But when I attempt to get the latest-version, it just returns a blank.
:put ([/system package update check-for-updates once as-value ] -> "latest-version")
Status isn't very helpful either:
:put ([/system package update check-for-updates once as-value ] -> "status")
resolving upgrade.mikrotik.com
Obviously the command needs time to go online and get the information,
so how do I get it to wait?
Any suggestions on how to get the latest-version without doing
/tool fetch url="something.mikrotik.com/something"
Basdno
Sat Feb 28, 2015 3:02 pm
what should I do?
can you help me?
This is clearly the wrong topic for this, a new topic under GENERAL f.ex. would probably have been a lot better place for this!
BUT:
The problem is clearly stated in the error message in Mikrotik winbox, and translated it says your Mikrotik router that recieved the dns adress is BEHIND a Firewalled/NATted gateway. Meaning it is not possible to directly connect to that mikrotik-router from the internett.
This again means if you want to use that DNS adress via the internett, I think you will have to make a NAT RULE(s) in your GATEWAY-ROUTER(Probably your DSL modem or something) that sends all requests the gateway recieves from the internet for that dns-adress to be forwarded directly to your Mikrotik router.
This feature works best and easiest if your Mikrotik router IS the Gateway, since it then has direct contact with the internet.
Hope that helps you understand the problem and how to solve it a little better. :)
Cheers
rextended
Sat Feb 28, 2015 3:24 pm
MikroTik 951G-2HnD.
RouterOS v6.23
RouterOS v6.27
For me 6.27 work faster than 6.24 and previous version used (USED, not only TESTED) on all my network infrastructure
(except for CPE for the huge amount of time to update it all, actually all the CPE are 6.20)
BUT...
the strange thing on pictures:
no one notice the differencies on minutes between the two images?
reboot the machine to start new RouterOS, and start and complete the test again after only 3 minutes???
Or I have misunderstand the images?
I save the picture for not be removed or altered:
P.S.
FOR ALL USERS:
I suggest to STOP TO USE SPEEDTEST FOR DO THE TEST (if you not are the owner of the other side...)
Use two other machine to do the test properly. On this way you can also test different packet size and tipology of traffic.
You have never the warranty than the service, on the other side, are overcharged from other users...
I do not think than the various "speedtest" servers have unlimited & warranted bandwidth for you and the all the other users.
jarda
Sat Feb 28, 2015 9:13 pm
Where are the seconds? I see 3 minutes difference...
Awax
Sun Mar 01, 2015 10:55 am
Hi, ceased to work at my RB750G service port PPTP, for resumption of work it is necessary to add the rule:
chain=input action=accept protocol=tcp in-interface=WAN dst-port=1723 log=no log-prefix=""
worked without it earlier
Second question or wish, as you wish. You can write "torrent client" as it is realized in other routers, for installation by a separate package? I would think it very much increased appeal of your product.
galaxynet
Long time Member
Long time Member
Sun Mar 01, 2015 12:49 pm
For anyone with the same issues. I have contacted support. I expect to hear from them soon. Below is an excerpt of what was sent.
I have a RB912UAG-5HPnD w/a Mikrotik 802.ac card with ROS 6.27 installed with the wireless-fp package active.
I have attached the autosupout.rif file.
1) After a ping watchdog timeout, the unit will try to reboot, it never makes it. I can only assume from the log that it is a kernel panic that causes the lockup during the reboot process, i.e., shows rebooting because of ping watchdop timeout, logs a few other items then kernel panic during the boot process and stops there.
2) After 3 bandwidth test runs I can no longer access this board from winbox or any other method, telnet/mac-telnet, ssh, it must be powered off/on in order to regain control. It will however pass data through during this time.
3) In the log there are references to kernel panic and script errors. After this last reboot, all files are gone. It will not create a backup file from the file menu in winbox.
I have another board exactly the same except it does not have your 802.11ac card in it. It does however have the wireless-fp package installed and active.
I included the script error message from the log here: 08:57:15 script, error script error: error - contact MikroTik support and send a supout file (2)
dada
Sun Mar 01, 2015 1:35 pm
do you lose connection to the board through WLAN or through ethernet?
Maggiore81
Trainer
Trainer
Sun Mar 01, 2015 11:22 pm
One bug discovered from6.25.
in the routes list, I have set a route, with "check gateway" option enabled, so if the router is unreachable, it disables the route.
With 6.25 works, with 6.27 doesnt work. Even if the router is unreachable, the route is still up.
rextended
Re:
Mon Mar 02, 2015 12:59 pm
Ok, misspelled and fixed, thanks
JackANSI
Mon Mar 02, 2015 9:37 pm
P.S.
FOR ALL USERS:
So you're saying that he couldn't possibly have two devices and just swapped the devices?
Even with one device, 3 minutes for something as simple as a firmware upgrade is quite feasible. Do speed test, click upgrade & reboot, do speed test. Very easy to do in 3 minutes (could also be as much as 3 minutes, 59 seconds since we don't have seconds to refer to).
Two, 3-minute-spaced speedtest.net readings are a little more realistic than a lab/bench test in my opinion. A lab test will only be more consistent over a long time period (i.e. months or years or comparing old generation hardware to new gen without re-benchmarking the old).
I couldn't even push 30% throughput of what the MikroTik benchmarks says my device could do. I put the old Cisco equipment back in place with upgraded interface modules and it handles the load like a champ. The MikroTik boxes are just wireless AP/hotspot for visitors now.
rextended
Re: RouterOS v6.27 released
Mon Mar 02, 2015 10:42 pm
Yes is possible, but the test must be done also crossing version and routeboards, or the test are incomplete...
jarda
Mon Mar 02, 2015 11:52 pm
3 minutes are perfectly enough for running test, upgrade and test again. I don't see any problem with it.
galaxynet
Long time Member
Long time Member
Tue Mar 03, 2015 5:57 am
Support -
Just as a follow-up to my ticket, I reverted to just the wireless package (disabled the wireless-fp package) no issues with running bandwidth tests or having the RB get rebooted by the ping watchdog. So it is definitely something with either the .AC card and/or the wireless-fp package.
Thanks.
Thom
sparrow
Tue Mar 03, 2015 11:08 am
Hi guys, is it normal that over a pppoe-client tunnel using mppe128 encoding I have a lot of rx errors?This on every fw I use
If I disable encoding (mschap1 and mschap2) all goes well without tx/rx errors...I see this behaviour on all client that use MPPE encoding.
strods
Tue Mar 03, 2015 11:35 am
LaZyLion - We fixed print function for "/system package update" in latest 6.28rcX versions. Now something like this might work for you:
delay 5
:put [/system package update get latest-version ]
First function will force RouterOS to check for a latest version. Delay can be reduced but must be longer than time needed to find out latest version. Last function will give latest available version of RouterOS.
PastuhMedvedey
Thu Mar 05, 2015 3:18 pm
1. Perform the upgrade RB SXT 5HPnD to version 6.27
2. When you try to create a file - Supout.rif CPU usage becomes 100 percent.
3. After creating the file - Supout.rif CPU usage is 100 percent.
finalcutroot
Sun Mar 08, 2015 2:21 am
this script on (rb750 , os 6.27 , winbox Winbox 3.0rc5) with hotspot cause crash after a while
the crash occur when you go to interface menu
/system scheduler
add interval=1d name=Start on-event=Start policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive start-date=dec/07/2014 start-time=07:00:00
add interval=1d name=Stop on-event=Stop policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive start-date=dec/07/2014 start-time=16:00:00
/system script
add name=Start policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive source="interface ethernet enable ether3-slave-local"
add name=Stop policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive source="interface ethernet disable ether3-slave-local"
LaZyLion
Sun Mar 08, 2015 9:14 am
Strods
delay 5
Your suggestion works in 6.26; that's what I've been using. But in 6.27:
[admin@my-router] > /system package update check-for-updates once
  current-version: 6.27
           status: resolving upgrade.mikrotik.com
[admin@my-router] > :put [/system package update get latest-version ]
I guess I will wait for 6.28 unless there is another way.
Maybe I can wireshark where routeros pulls the data from then use /tool fetch to get it myself via script. Hmmmm...
conecting
Sun Mar 08, 2015 9:55 pm
deleted becouse it can not be repeated
jarda
Sun Mar 08, 2015 10:12 pm
I see no problem with upnp at 6.27. It works fine with automatic port redirection.
conecting
Sun Mar 08, 2015 10:41 pm
conecting
Sun Mar 08, 2015 10:50 pm
rkau045
Mon Mar 09, 2015 1:29 am
I fail to see the problem here. The rules are processed in order from top to bottom.
Sent from my LG-D800 using Tapatalk
Kadafi
Wed Mar 11, 2015 9:06 am
Upgraded CCR-1016 6.12 -> 6.27 (clean configuration) = Dead brick, reboot loop. :?
sergejs
Wed Mar 11, 2015 10:04 am
Please attach Null Modem cable to your router and provide us with console output that you get from router.
Kadafi
Wed Mar 11, 2015 10:13 am
Console was non-functional, we tried several cables com@9600/8/1 and com@115200/8/1
Restored with netboot. Clean install 6.27 is ok.
ruudux
Wed Mar 11, 2015 10:53 pm
I ran the upgrade from routeros 5.24 to 6.27. After the reboot, i am only able to login using telnet/ssh but cann't login anymore using the webfig. Allready changed the password, deleted browser cache. Any idea's? Error message after filling in the login form: internal server error. In the log i do not see a login entree using http (ssh is showed normally)
finalcutroot
Sat Mar 14, 2015 11:00 pm
There is abug drive me crazy
when i add static ip address for int eth1 its gone after tow or three day
and when i add static ip address then goto quick set up , just click apply the added static rout also gone
win9x
Sun Mar 15, 2015 2:01 am
whats better
upgrading directly from 6.24 to 6.27
or upgrade virsion next version :?
6.25 then 6.26 -- 6.27
poizzon
Mon Mar 16, 2015 12:19 am
[poi@HotSpotAs] > sys resource print
uptime: 1h48m46s
version: 6.27
build-time: Feb/11/2015 13:24:13
free-memory: 3784.0KiB
total-memory: 32.0MiB
cpu: MIPS 24Kc V7.4
cpu-count: 1
cpu-frequency: 300MHz
cpu-load: 19%
free-hdd-space: 43.6MiB
total-hdd-space: 64.0MiB
write-sect-since-reboot: 21992
write-sect-total: 62832584
bad-blocks: 0.8%
architecture-name: mipsbe
board-name: RB450
platform: MikroTik
[poi@HotSpotAs] >
[poi@HotSpotAs] >
[poi@HotSpotAs] >
[poi@HotSpotAs] > tool profile
action timed out - try again, if error continues contact MikroTik support and send a supout file (13)
[poi@HotSpotAs] >
normis
Mon Mar 16, 2015 9:05 am
poizzon, did you do what this log line asked?
ATROX
Mon Mar 16, 2015 9:41 am
I use about 15 IPsec tunnels
Sometimes IPsec is down. Reboot, kill connetctions and flush SAs do not help. Rarely identify problems. Developers - Check the IPsec please!
Router OS v6.27
CCR1036-12G-4S and RB951G-2HnD
noyo
Mon Mar 16, 2015 5:36 pm
Why 6.28rc13 has been removed?
pbr3000
Mon Mar 16, 2015 6:34 pm
+1. Good question... :?
honzam
Mon Mar 16, 2015 7:22 pm
Good question, but bad topic:
http://forum.mikrotik.com/viewtopic.php?f=21&t=94352
poizzon
Mon Mar 16, 2015 11:49 pm
nop, i can't connet...
after disconnecting access point's and reeboting, i can connect, cleared user manager logs, it seems working for now.
JanezFord
Tue Mar 17, 2015 11:43 am
I get lots of this messages on my setup ... I use capsmanv2 with multiple APs configured to provide same said over a building ... this warning pops up when client goes from one AP to another ... sometimes RSTP disables the port long enough to make CAP drop connection due to timeout and loose all of its clients which is annoying.
JF.
hzdrus
Tue Mar 17, 2015 3:17 pm
We found EoIP on 6.27 to be very buggy on CCRs and RB750.
Frames passing through bridge would randomly get corrupted. Removing and adding interface to the bridge may temporarily fix the problem.
jarda
Tue Mar 17, 2015 3:48 pm
Just to let you know. This problem was confirmed by mikrotik to be an error finally.
After my further investigation, it is not linked to PFS nor to ros versions mismatch nor to SSTP only, as it also happens to L2TP. The basic of the problem lies in the dynamically assigned IP to the client device that suddenly becomes ivalid without any obvious reason at the clients ip address list.
For those who suffer by this problem like me, you can switch off the sstp/l2tp client, remove the invalid addresses from address lists, reboot the client and switch on the sstp/l2tp client. Then it should behave good at least for some time...
I have got a message that it was passed to programmers for correction. Hope it will be included in 6.28.
hossain2004a
Tue Mar 17, 2015 7:56 pm
I'd like to know when will you correct the bug in UM?
which is after you add new langauge and open new windows (e.g. session list) you can not close the new window.
already supports tell me they are working on it.
gabrielpike
Thu Mar 19, 2015 3:10 pm
I am not really complaining about 6.27 but after upgrading my core routers I did notice a spike in CPU usage. My reason for updating was to fix the outdated NTP issue. Both routers were running 6.7. In winbox under tools->profile the routers show a higher CPU for both routing and firewall. Again not a complaint just an observation.
SQx
Thu Mar 19, 2015 7:45 pm
On RB751u-2HnD with v6.27 not work Health Status and Ethernet 5 error with auto-negotiate, no cable but led is on, (temporary solution - clear option auto-negotiate).
brauser
Trainer
Trainer
Thu Mar 19, 2015 11:41 pm
+1 for this.
and please, dont repeat this again =]
cheers
strods
Fri Mar 20, 2015 8:26 am
hossain2004a - Fix for testing is available starting since RouterOS 6.28rc14 version. It will be included in next full release of RouterOS 6.28.
strods
Fri Mar 20, 2015 8:40 am
SQx - We are not being able to reproduce your issue. Could you please send supout file from your device to support@mikrotik.com? Seems like it depends on your configuration. As for a System/Health problem - there is nothing to show in Health for this device. It should be empty.
SQx
Fri Mar 20, 2015 11:36 am
strods, please see [Ticket#2015032066000252]
strods
Fri Mar 20, 2015 1:50 pm
SQx - reply to this ticket is already sent to you
SQx
Fri Mar 20, 2015 1:51 pm
strods, added new supout.rif, autosupout.rif
diode
Sat Mar 21, 2015 2:00 pm
hi,
I have a problem starting nstream to be unusable with ac hardware. I have swapped a RB912 with a netbox5 on a place were nstream was working really good (uptimes of clients ofthen 10-20 days before getting a not polled for too long), now it disconnects ALL clients simultainously every hour or so (not polled for too long).
wireless-fp package
a/n mode
please make nstream working stable again, for most of my sites it gives AT LEAST double tcp performace at the client side than NV2. I'm worried now about using the newest hardware as this is even less usable with nstreme than old hardware.
I can't simply downgrade all my clients to just 50% of the bandwidth just for using another protocol.
thanks
ps.: btw I have around 450 mikrotiks in use here, and I'm doing wisp since 2000
uldis
Mon Mar 23, 2015 10:53 am
hi,
wireless-fp package
a/n mode
thanks
Please contact support@mikrotik.com so we could check the configuration of the board and setup environment. Then we could try to reproduce this problem in the lab with the AC boards.
sergejs
Mon Mar 23, 2015 12:33 pm
What ports do you have on bridge?
It seems that there is a loop in your network, that is caused by bridged interfaces.
mangust
Mon Mar 23, 2015 8:31 pm
20:32:31 ipsec,error failed to get valid proposal.
20:32:31 ipsec,error failed to pre-process ph1 packet (side: 1, status 1).
20:32:31 ipsec,error phase1 negotiation failed.
20:32:41 ipsec,error failed to get valid proposal.
20:32:41 ipsec,error failed to pre-process ph1 packet (side: 1, status 1).
20:32:41 ipsec,error phase1 negotiation failed.
20:32:51 ipsec,error failed to get valid proposal.
20:32:51 ipsec,error failed to pre-process ph1 packet (side: 1, status 1).
20:32:51 ipsec,error phase1 negotiation failed.
20:33:01 ipsec,error failed to get valid proposal.
20:33:01 ipsec,error failed to pre-process ph1 packet (side: 1, status 1).
20:33:01 ipsec,error phase1 negotiation failed.
20:33:05 ipsec,error phase1 negotiation failed due to time up X.X.X.X[500]<=>Z.Z.Z.Z[500] 5654bdb3a0805b43:00000000000000
20:33:05 ipsec,error failed to get valid proposal.
20:33:05 ipsec,error failed to pre-process ph1 packet (side: 1, status 1).
20:33:05 ipsec,error phase1 negotiation failed.
I have exactly the same issue with IPSEC tunnel between 6.25 & 6.27.
IS it me , or i shoud try to downgrade to 6.25 ?
DjM
Tue Mar 24, 2015 9:02 am
Do you have any SNAT on the network path from SSTP client to SSTP server which is configured out of SSTP client?
SSTP client ---> some router with SNAT ---> SSTP server
I have the same issue and instead of disable/remove/reboot I have found another workaround:
1) disable SSTP client interface
2) remove invalid IP address (if there is still any)
3) wait around 30s when the connection is removed from IP conntrack or manually remove it
4) enable the SSTP client interface and it is working
Please let me know if this workaround working also for you.
tgyula
Wed Mar 25, 2015 7:28 pm
Thanks!
Not only are you! Mikrotik: please come back torrent download!
mars
Fri Mar 27, 2015 5:58 pm
Thanks!
+10000.....
alobci
Mon Apr 06, 2015 12:04 am
I cannot access to user manager on mikrotik after i turn off the router bord i turn it on then its not working maybe its damage what can i do ?
steen
Mon Apr 06, 2015 9:23 am
Hello Folks!
Trying to upgrade CCR1016 from 6.24 to 6.27 failed due to kernel panic, and it reverted back to 6.24 again and support was generated. I put up a support case to MT with support file.
Anyone who have seen this and or know how to mitigate it ?
TomosRider
Tue Apr 07, 2015 10:03 am
Steen, did you try Netinstall or just copying .npk files?
For me, 6.27 is a good release. I have it running on couple of routerboards and on those never had kernel panics, sudden reboots or resets. Everything that i have set on earlier releases (5.x) working like a charm. Big plus from me!
rextended
Tue Apr 07, 2015 2:58 pm
Please put a disclaimer inside 6.27/6.28:
"ac" models wlan work only with "wireless-fp" package enabled.
using "wireless" package on ac models cause wlan to not be recognized from the system.
RB922UAGS-5HPacD S.N.:5F820473960B
steen
Tue Apr 07, 2015 9:14 pm
I did copying the .npk file as always, I have no way to do netinstall from remote location where I am some 500km from the device. :-)
TomosRider
Wed Apr 08, 2015 10:26 am
I had cases where i copy .npk files and then after reboot, device simply wont upgrade.Copy again in files dir and then copy to packages directorium...worked for me once. First mark old npk's for uninstall, ofc
Chupaka
Wed Apr 08, 2015 12:20 pm
And the reason is in Log, isn't it? :)
TomosRider
Wed Apr 08, 2015 11:47 pm
Well, yes, but im always on hurry so i skipped checking log.. :)
locodog
Sun Apr 12, 2015 4:10 am
There seems to be a problem with RB1100AHx when running hotspot and PPPoE at the same time. Users are unable to reach certain websites. On every other version and model of RB with same settings everything works good. Also, when RB1100AHx is running hotspot OR PPPoE, works good, but when it has both there is problem.
StubArea51
Trainer
Trainer
Sun Apr 12, 2015 8:45 am
Hello Folks!
If you can netinstall the router I would do that. If not, you might try upgrading to 6.25 and then go to 6.27.
ennnot
Tue Apr 14, 2015 12:02 pm
Hi!
I'm using MRTG (RB450G) with 6.27. The are some L2TP-servers. Edit comment for L2TP-interface cause a restart of L2TP-server. Is it normal process?
TomosRider
Tue Apr 14, 2015 12:42 pm
Simple...no.
killersoft
Sat Apr 18, 2015 3:47 pm
Just wondering if anyone else is suffering a failure of the "Reset Counters" in the Interface/Traffic TAB.
By where as an example in the Tx/Rx Bytes( and in my instance this interface connections to my cable modem ) and in my case shows 32Gb TX and 31Gb Rx respectively. But when I click on "Reset Counters" this does not clear to 0 as I would expect it to..
I am running a RB750G with 6.27 and v3.22 Firmware... Anyone else noticing this ?
0ldman
Sun Apr 19, 2015 3:22 am
I've got the same network loop error. There is no loop. The network has been in operation in this config for nearly 4 years, then 2PM this afternoon it just stopped.
0ldman
Mon Apr 20, 2015 5:21 pm
I figured it out. DDoS attack was spoofing MAC addresses in the network causing the equipment to falsely detect a loop.
Habib89
Fri Apr 24, 2015 1:59 am
hi
after updating to 6.27 the internet connection become very slow and some websites doesn't even open after 10 or 20 minutes,
it was working fine in 6.14 version.
is there any solution?
Chupaka
Tue Apr 28, 2015 4:08 pm
it depends on your setup, I think :)
sattlink
Mon Jun 08, 2015 6:17 am
please help me, someone can tell me where I find the download version 6.27 parael npk ccr1036-12G -4S
jebz
Mon Jun 08, 2015 1:58 pm
Try -
http://download2.mikrotik.com/routeros/ ... e-6.27.npk
tapsin
Mon Jul 27, 2015 11:04 am
Royalsaleh1
Mon Sep 21, 2015 10:09 pm
loop probably problems i need help thanks
Royalsaleh1
Mon Sep 21, 2015 10:23 pm
hello !
I have a problem
router rb 1100
internet in
broadband
out
hotspot
output ip 10.10.10.10
i have bridge
i have ip back
10.0.0.1 on bridge client dhcp
log : ether 6 loop probably
Users browsing this forum: eworm, khimin, MateuszP, Sit75 and 80 guests
