done.magchiel - Please generate supout file on your device and send it to support@mikrotik.com.
The only valid system for RB133C3 are RouterOS 2.9.51...RB133C3 - Sytem/Packages/Check shows 6.27 available but version 6.xx bricks RB133C3.
Should be therefore 6.xx be reported to this router as upgrade ?
All my network work with EoIP, no one single problem on 6.27,EoIP tunnels stopped working after 6.27 release... Any Ideas or other known issues with this upgrade like this. Simple EoIP just two routers connected to each other with public IPs any help would be greatly appreciated.
The bug is also present with non standard eoip and pppoe server configuration?After some days of use 6.27 on ALL my 200 network devices
(i have also near 4000 CPE all upgraded up to to 6.20, and 4 Gateway for PPPoE all forced to 6.7 for the unresolved bug also described on my signature)
The bug are present on all possible variant of config, I write "default settings" to underline the easy way for reproduce the bug.The bug is also present with non standard eoip and pppoe server configuration?After some days of use 6.27 on ALL my 200 network devices
Are you sure about this?The bug are present on all possible variant of config, I write "default settings" to underline the easy way for reproduce the bug.The bug is also present with non standard eoip and pppoe server configuration?After some days of use 6.27 on ALL my 200 network devices
For make it all worst, if you use default-encryption on pppoe server over EoIP tunnel, the kernel crash at the first logged user.
If you read my previous post on the previous version topic, you can read me proposing that kernel crash bug propably since 6.8, and I open also the ticket, but nothing is changed till now.
Did you tried VPLS/MPLS in this setup?The bug are present on all possible variant of config, I write "default settings" to underline the easy way for reproduce the bug.
This is a screen on the rb1 (the pppoe server), asAre you sure about this?
A few days ago I tested a configuration with 3 rb951 with 6.27 and ospf running, on the first rb I create an eoip tunnel to the third and I created also a pppoe server on a bridge in wich there is also the eoip tunnel. Then i created an eoip tunnel in the third rb to first and I put a pppoe client on a bridge in which there is also the eoip tunnel. I had encryption activated on pppoe and I had no problem for the time of test (about 1 hour).
PPPoE MTU is 1500, EOIP MTU is 1512 and interfaces MTU are 1554 (I reserved 4 byte for future vlans on the eoip).
you can see there is also the encryption running.
I've upgraded to v6.27, regardless system time does not workYou say v6.22 but image shows v6.25, but this topic is actually about v6.27 ...Maybe Winbox is slow to give updates beause your router is 100% CPU loaded? What is the cause of CPU load ?
100 % CPU load is since we have upgraded from v6.6 to v6.22.
The cause for that is bug
see here http://forum.mikrotik.com/viewtopic.php?t=91468
in v6.22 we had not problem with system time
Not, I not use VPLS or MPLS on any point of my net.Did you tried VPLS/MPLS in this setup?The bug are present on all possible variant of config, I write "default settings" to underline the easy way for reproduce the bug.
The couter are not stored inside RB and is perfectly normal to lost all,There is a little problem annoying me each time I upgrade and:
after each upgrade all of my counter will reset.
Your test are invalid, you put the pppoe-server on the bridge, not the pppoe-server on eoip directly.This is a screen on the rb1 (the pppoe server), asAre you sure about this?
PPPoE MTU is 1500, EOIP MTU is 1512 and interfaces MTU are 1554 (I reserved 4 byte for future vlans on the eoip).you can see there is also the encryption running.
Mmh, ok.Your test are invalid, you put the pppoe-server on the bridge, not the pppoe-server on eoip directly.This is a screen on the rb1 (the pppoe server), asAre you sure about this?
I never mentioned bridges.
If you take in charge the bug,rextended - I have created configuration which you did describe. Will see if we manage to reproduce your issue.
alibalalo - Which model of SXT are you using? Not all devices has something to show under Health menu.
You probably find the solution for circumventing the problem (must be tested with real traffic first),Mmh, ok.
Using bridge is not for you a good workaround?
I forgot to mention that with all default MTU when I tried to ping the pppoe server from the pppoe client routerboard with a MTU size bigger than 1454 the rb1 rebooted due a kernel panic.You probably find the solution for circumventing the problem (must be tested with real traffic first),Mmh, ok.
but the problem still present.
I also stop using "default-encription", but the memory leak when pass traffic, hang the board after some time is used....
I do not know what is happen, but all start with RouterOS 6.8, when mikrotik has rewrited ppp:I forgot to mention that with all default MTU when I tried to ping the pppoe server from the pppoe client routerboard with a MTU size bigger than 1454 the rb1 rebooted due a kernel panic.You probably find the solution for circumventing the problem (must be tested with real traffic first),Mmh, ok.
So the problem could be related to MTU.
Ok, wait please, I make it again:rextended - Could you please generate new supout file after your device has crashed and send it to our support mail? I will check it out and try to rerpoduce.
For a few hours my setup is running now and no issues. Links to previous posts include few ticket numbers but they are from old versions and more related to other issues. Supout file from latest version with crash report would be very helpful.
VERY VERY VERY THANKS!!!!!!!!rextended - Seems like I managed to reproduce. Wil see what programmers can do about it. Thank you.
[admin@MikroTik] > export
# jan/02/1970 00:37:15 by RouterOS 6.27
# software id = ****-****
/interface eoip
add !keepalive mac-address=02:4B:D6:06:ED:9B name=eoip-tunnel1 remote-address=10.0.0.2 tunnel-id=0
/port
set 0 name=serial0
set 1 name=serial1
/interface pppoe-server server
add disabled=no interface=eoip-tunnel1 max-mru=1480 max-mtu=1480 mrru=1600 service-name=service1
add address=10.0.0.1/24 interface=ether2 network=10.0.0.0
/ppp secret
add local-address=10.1.0.1 name=test password=test remote-address=10.1.0.2
/system routerboard settings
set cpu-frequency=1200MHz memory-frequency=1066DDR
[admin@MikroTik] >
jan/02/1970 00:01:12 system,error,critical System rebooted because of kernel failu
re
jan/02/1970 00:01:12 system,error,critical Out of memory condition was detected
jan/02/1970 00:01:12 system,error,critical router was rebooted without proper shut
down
# jan/02/1970 00:05:13 by RouterOS 6.27
/interface wireless
set [ find default-name=wlan1 ] l2mtu=2290
/interface eoip
add !keepalive mac-address=02:81:70:72:C2:07 name=eoip-tunnel1 remote-address=10.0.0.1 tunnel-id=0
/interface pppoe-client
add add-default-route=yes disabled=no interface=eoip-tunnel1 mrru=1600 name=pppoe-out1 password=test user=test
add address=10.0.0.2/24 interface=ether2 network=10.0.0.0
set cpu-frequency=500MHz
[admin@MikroTik] >
I do the same test again, using default bridge between pppoe-server and EoIP, and one between eoip and pppoe-clientI forgot to mention that with all default MTU when I tried to ping the pppoe server from the pppoe client routerboard with a MTU size bigger than 1454 the rb1 rebooted due a kernel panic.You probably find the solution for circumventing the problem (must be tested with real traffic first),Mmh, ok.
How is it possible?I do the same test again, using default bridge between pppoe-server and EoIP, and one between eoip and pppoe-client
this not solve temporarly the problem
add mtu=1554 name=bridge_pppoe
add mtu=1554 name=bridge_wan
add mtu=1500 name=lo
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n disabled=no frequency=2422 l2mtu=2290 mode=station-bridge ssid="MikroTik test" tx-power=14 tx-power-mode=all-rates-fixed
set [ find default-name=ether2 ] mtu=1554
/interface eoip
add !keepalive mac-address=02:F5:3B:21:71:7E mtu=1512 name=eoip-tunnel1 remote-address=10.1.0.6 tunnel-id=0
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" mode=dynamic-keys wpa2-pre-shared-key=test
/ppp profile
set 0 dns-server=10.1.0.1 local-address=10.128.0.1 use-compression=no use-mpls=no use-vj-compression=no
set 1 dns-server=10.1.0.1 local-address=10.128.0.1 use-compression=no use-mpls=no use-vj-compression=no
/routing ospf instance
set [ find default=yes ] redistribute-static=as-type-1 router-id=10.101.0.1
add bridge=bridge_wan interface=wlan1
add bridge=bridge_wan interface=ether1
add bridge=bridge_pppoe interface=eoip-tunnel1
add authentication=chap,mschap2 disabled=no interface=bridge_pppoe max-mru=1500 max-mtu=1500 service-name=service1
add address=10.1.0.1/30 interface=ether2 network=10.1.0.0
add address=10.101.0.1/32 interface=lo network=10.101.0.1
/ip dhcp-client
add dhcp-options=hostname,clientid interface=bridge_wan
add default-route-distance=0 dhcp-options=hostname,clientid disabled=no interface=wlan1
add action=masquerade chain=srcnat out-interface=bridge_wan
add disabled=yes distance=1 dst-address=192.168.0.190/32 gateway=bridge_wan
/ppp secret
add name=test password=test profile=default-encryption remote-address=10.1.0.200 service=pppoe
/routing ospf interface
add authentication=md5 authentication-key=test interface=ether2 network-type=broadcast
/routing ospf network
add area=backbone network=10.1.0.0/30
add area=backbone network=10.1.0.4/30
/system clock
set time-zone-name=Europe/Rome
/system ntp client
set enabled=yes primary-ntp=192.168.0.1
add mtu=1554 name=bridge1
/interface wireless
/interface eoip
add !keepalive mac-address=FE:8A:BC:D5:5E:9B mtu=1512 name=eoip1 remote-address=10.1.0.1 tunnel-id=0
add name=dhcp_pool1 ranges=192.168.1.2-192.168.1.254
add address-pool=dhcp_pool1 disabled=no interface=ether4 lease-time=3d name=dhcp1
add disabled=no interface=bridge1 max-mru=1500 max-mtu=1500 mrru=1600 name=pppoe-out1 password=test profile=default-encryption user=test
set [ find default=yes ] redistribute-connected=as-type-1 redistribute-static=as-type-1 router-id=10.101.0.6
add bridge=bridge1 interface=eoip1
add address=10.1.0.6/30 interface=ether2 network=10.1.0.4
add address=10.101.0.6/32 interface=lo network=10.101.0.6
add address=192.168.1.1/24 interface=ether4 network=192.168.1.0
add address=192.168.1.0/24 gateway=192.168.1.1
set servers=8.8.8.8
add action=masquerade chain=srcnat out-interface=pppoe-out1 src-address=192.168.1.0/24
add distance=1 gateway=pppoe-out1
/system clock
I do not know, but I use all DEFAULT settings, not mtu=1554Code: Select all/interface bridge add mtu=1554 name=bridge_pppoe
on 6.27 (3.22) it's working like 6.23 (3.18):RB951g-2Hnd
Interfaces - Blink not working.
What version exactly?Use the device sxt 5ndr2 lite
In the previous version RouterOS v5 was working well
[admin@xxx] > sys
[admin@xxx] /system> rou
[admin@xxx] /system routerboard> pri
routerboard: yes
model: SXT 2nD r2
serial-number: 467E0240D765
current-firmware: 3.18
upgrade-firmware: 3.18
[admin@xxx] /system routerboard> ..
[admin@xxx] /system> he
[admin@xxx] /system health> pri
[admin@xxx] > sys
routerboard: yes
model: 911-5Hn
serial-number: 4E6704A1B74B
routerboard: yes
model: SXT 5HnD
serial-number: 2DCA012AF8C3
current-firmware: 3.17
upgrade-firmware: 3.17
[admin@xxx] /system> health
voltage: 18.1V
temperature: 30C
routerboard: yes
model: SXT G-2HnD
serial-number: 41F902558F90
voltage: 23.8V
temperature: 36C
[admin@xxx] > sys
routerboard: yes
model: SXT 5HPnD
serial-number: 45EF023C9C2B
voltage: 23.6V
temperature: 34C
[admin@xxx] > sys
routerboard: yes
model: SXT G-5HPnD r2
serial-number: 46BC02124E94
current-firmware: 3.22
upgrade-firmware: 3.22
[admin@xxx] /system routerboard> .. he
voltage: 26.7V
temperature: 18C
after that the OID mtxrHlVoltage work again.The solution (my solution...): open the device with clean winbox (no load previous session), click on system/healt, open new terminal, write "/system healt;print", press enter, and write "print oid", press enter and after that, reboot the device, and the system healt voltage oid are get again by snmp
Thank you very much! it is workingpaka - Do not simply disable Dude package. Please remove it and check your CPU usage then. If load drops, then check clock again.
I use auto discovery on bridge, EoIP and GRE (from 6.2? to 6.27) and actually I do not have noticed any problem.Can someone confirm, whether or not, if the EoIP "auto-mtu" function is working correctly in v6.27?
It doesn't seem to be working for me, and wanted to know if anyone else is having this issue?
Works ok for "GRE" tunnels..
I use the EoIP tunnel over the internet, and have different MTU's when using a cable modem on one end, and a DSL (PPPoE) on the other end. and as I said, the "auto-mtu" function seems to compensate very nicely using GRE, but not EoIP. If this needs to be corrected, I would really like to see that in 6.28 if possible.
Thanks,
-tp
Too few details.Still having 100% CPU issues on RB2011's. SNMP disabled, no polling with the Dude. Ticket Ticket#2015020266000038 from three weeks ago still unanswered. Please help. Management process culprit for the CPU spike. Spike to 100% and stops passing data. RB2011 is doing nothing except acting as a switch. Ports 1-5 switched 6-10 bridged to port 1.
Where do you see 100 % cpu on your picture? How profiler looks like?[img][/img]
Its been rebooted now so it doesn't show 100%. When it is at 100% I can't pull up anything but profiler shows management as the process.Where do you see 100 % cpu on your picture? How profiler looks like?[img][/img]
Don't you have istalled dude package, do you?Its been rebooted now so it doesn't show 100%. When it is at 100% I can't pull up anything but profiler shows management as the process.
No.Don't you have istalled dude package, do you?Its been rebooted now so it doesn't show 100%. When it is at 100% I can't pull up anything but profiler shows management as the process.
How much time you use same SoftwareID?Hello.
I read all posts here, but did not found that someone face same issue too.
I have a wide range of CCR1016 routers and routerOS based virtual routers.
The issue what i faced now is:
my cload core CCR1016-12G was able to be upgraded to newest 6.27 version with out any problems.
The upgrade was done from v6.24 to v6.27 on CCR1016
But now on virtual machines the upgrade fail.
My virtual routerOS are running v6.24 and v6.21.1.
When i go to system>packages>check for updates>download and upgrade, it tries to get latest v6.27 version, but during download it says it failed to download
isdn package.
Well this package i do not need, so i uninstalled it from mine virtual routers.
Then i repeat upgraded, download is successfull, it reboots for upgrade to be installed.
In console it writes it does the update.
No errors are given out by command line GUI.
But once router loads, and i log in to it, i see my old version v6.21.1 or v6.24
So it does not upgrade, and does not give any error.
Do not simply leave email, this is not one direct support service, open new thread and post your config.ccr1036 12G-4s v6.27 hotspot not working.i didn't look the login web. my email 2338953@qq.com
isdn package.
You use Software ID downloaded from Internet?
Did you pay for license for each individual copy?Physical cloadcores run each of them with lic preinstalled.
Virtual mikrotiks, they are clones of each other.
I am using them already for couple years, and did not experienced any problems till now.
So this means if i try to get software upgrade with same ID, it will fail?
isdn package.
isdn package.
interface,warning 3_WIFI: bridge port received packet with own address as source address, probably loopDo not simply leave email, this is not one direct support service, open new thread and post your config.ccr1036 12G-4s v6.27 hotspot not working.i didn't look the login web. my email 2338953@qq.com
If someone want help you, you get help.
All users must benefit from helping you.
+100If you are happy with your setup, don't touch it.
why i got a lot of the warming message?how to fix
my ccr1036-12g-4s and a lot of other hardware buy only one week,,how to got Technical Support?
Please provide us more information about your setup. The AP or this Client router stopped working?I just upgraded to 6.27 on my RB711-5HnD and upgraded the routerboard to 3.22.
It looked good at the start so I ran a speed test at http://www.speedtest.net/.
The router disconnected, then I ran a wireless scan it shows no ap's at all.
Rebooting makes it reconnect but it disconnects as soon as I try a speed test.
Downgrading back to 6.23 make everything work again.
0 R name="wlan1" mtu=1500 mac-address=XX:XX:XX:XX:XX:XX arp=enabled interface-type=Atheros AR92xx mode=station-pseudobridge ssid="" frequency=5300
band=5ghz-a/n channel-width=20/40mhz-ht-below scan-list=default wireless-protocol=any wds-mode=disabled wds-default-bridge=none wds-ignore-ssid=no
bridge-mode=enabled default-authentication=yes default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=no
security-profile=default compression=no
If queue type is "default" Try to change default queue type to another eg from pfifo to RED. and write here if it helps.Queue Tree queues does not work in 6.27 (all counters stays on 0) (at least for GRE tunnel interfaces)
Very poor performance for single TCP flow over GRE tunnel.
simaskkk - Does problem persist if you disable/enable queues? Do you have scripts/schedulers or something else which might change queue settings while they are working?
It's possible that system didn't manage to get correct info or get anything at all from eeprom/ddmi on transceiver. In cases like that after several attempts system will give up and leave those fields empty. Replugging the module, reboot or power cycle might help.It seems that SPF status is broken on CRS-125, with no info shown except 'module present' (S-31DLC20D).
Module works correctly nevertheless.
YES! YES! YES!rextended - We finally managed to fix crash when PPPoE was being configured over EoIP. Fix should be included in 6.28rc5 and later versions of RouterOS.
Changing l2mtu on any interface of my ccr 1036-12G-4S cause port flapping, shutting down all interface, someone had same problem?What's new in 6.7 (2013-Nov-29 13:37):
*) fixed l2mtu changing on CCRs - could cause port flapping;
Although similar, this behaviour (one all interface reload after L2MTU changes) is not related to the problem in v6.7.Changing l2mtu on any interface of my ccr 1036-12G-4S cause port flapping, shutting down all interface, someone had same problem?What's new in 6.7 (2013-Nov-29 13:37):
This behaviour still persist on 6.27!
The release date changed because we added "smips" RouterOS version for the hAP lite boards in the website. There are no other changes.Funny i just noticed on the download package from this site that the 6.27 software has been updated (release date is now 23-02-2015 where it was 11-02-2015) however i just cant find any changes in the changelog. And why hasnt the version number not been altered ?
Normis ?
Well last night i was try to upgrade my x86 ROS to v6.27 ...
Userman is give error like "radius server not responding" so i must fast downgrade to v6.26.
On other routerboard devices it looks that all is fine.
Can someone try to upgrade device with userman ?
same problem on two x86 routers. Local access is ok but print anything go to crash or not print. Router is not function. Same is fresh install 6.27 is same problem on same router.This is the third time
when i open winbox and goto the Interfaces
the router crash
i use simple script/scheduler to turn off interfaces on specific time
Having three mipsbe routers connected to internet:
A: running SSTP server accepting SSTP conections from B and C
B: running SSTP server and client, connecting to A and accepting connections from C
C: running SSTP client and connecting to A and B
A had 6.25, B had 6.18, C had 6.25 and everything worked fine.
Decided to update A from 6.25 to 6.27. Result: Connection from B was fine. C was not able to establish connection.
Decided to update C from 6.25 to 6.27. Result: C is not able to establish connections both to A and B. The disk1 that was working in 6.25 was renamed to disk3 and new disk1 appeared – this should not happen!
And what is more: not running SSTP clients show incoming packets and data in interface overview. How to? Torch is blank…
Reverting both A and C to 6.25 and waiting a correction. After downgrade both A and C to 6.25 everything works correctly like before.
Supout was sent to support, ticket nr. [Ticket#2015021466000104]
You dont need to add filters in firewall to gain access to your cameras.! In what LAN port is connected your camera? Are you sure that port is properly forwarded?hi guys I have a problem with this can you help me?
I didn't know how to make topic nor did I fine an appropriate place to post it so if you can help me or direct me to the best location I would appreciate it. thanks
first of all after I enable DDNS, in the status section it tells me that:
"DDNS server received request from ip ...(the public ip adress)... but your local ip was 192.168.1.6 (which is my gateway ip). DDNS service might not work."
and I can't ping the DNS name it gives me 100% timeout then I've added this command:"/ip firewall filter add action=accept chain=input disabled=no dst-port=8291 protocol=tcp place-before=0"
but this didnt help either!
what should I do?
I have ip cameras in my work place and I want to watch them from home via this feature.
can you help me?
all cameras plus computers and server are attached to a switch and one cable from switch is attached to ether 2 of my mikrotik and one cable from the dsl modem is attached to the ether1 of my mikrotik.You dont need to add filters in firewall to gain access to your cameras.! In what LAN port is connected your camera? Are you sure that port is properly forwarded?hi guys I have a problem with this can you help me?
what should I do?
can you help me?
For me it works faster...MikroTik 951G-2HnD.
RouterOS v6.23
RouterOS v6.27
Awesome improvement MikroTik!
305mbit to 345mbit...
Are you sure your speedtest.net server gives full speed?
Dude open a new thread, and will found the solution for your problem. This is not right thread for this problem.all cameras plus computers and server are attached to a switch and one cable from switch is attached to ether 2 of my mikrotik and one cable from the dsl modem is attached to the ether1 of my mikrotik.You dont need to add filters in firewall to gain access to your cameras.! In what LAN port is connected your camera? Are you sure that port is properly forwarded?hi guys I have a problem with this can you help me?
what should I do?
can you help me?
my internet is working on mikrotik gateway and I can ping 8.8.8.8 from winbox plus I've enabled ip cloud and it gave me the dns but I cant use it, it gave me 100% timeout. so I dont know what to do!
LaZyLion - Since 6.27 "/system package update check-for-updates" is dynamic and gives output to console. That has caused changes.
You can use command like this:
:put ([/system package update check-for-updates once as-value ] -> "current-version")
:put [/system resource get version ]
:put ([/system package update check-for-updates once as-value ] -> "latest-version")
:put ([/system package update check-for-updates once as-value ] -> "status")
resolving upgrade.mikrotik.com
/tool fetch url="something.mikrotik.com/something"
what should I do?
can you help me?
For me 6.27 work faster than 6.24 and previous version used (USED, not only TESTED) on all my network infrastructureFor me it works faster...MikroTik 951G-2HnD.
RouterOS v6.23
RouterOS v6.27
I can confirm that I also had a speed hit on V 6.27. BAck to 6.19 all good again. I also noticed a degrading of voip quality. This was on a 1100AH. Personally for me with the config I use 6.19 is still the most stable. It is possibe the upgrade is not taking properly somewhere and a fresh install would be fine but I have not tested this
Hi,For anyone with the same issues. I have contacted support. I expect to hear from them soon. Below is an excerpt of what was sent.
I have a RB912UAG-5HPnD w/a Mikrotik 802.ac card with ROS 6.27 installed with the wireless-fp package active.
Ok, misspelled and fixed, thanksWhere are the seconds? I see 3 minutes difference...
So you're saying that he couldn't possibly have two devices and just swapped the devices?
the strange thing on pictures:
no one notice the differencies on minutes between the two images?
reboot the machine to start new RouterOS, and start and complete the test again after only 3 minutes???
Or I have misunderstand the images?
I save the picture for not be removed or altered: P.S.
FOR ALL USERS:
I suggest to STOP TO USE SPEEDTEST FOR DO THE TEST (if you not are the owner of the other side...)
Use two other machine to do the test properly. On this way you can also test different packet size and tipology of traffic.
You have never the warranty than the service, on the other side, are overcharged from other users...
I do not think than the various "speedtest" servers have unlimited & warranted bandwidth for you and the all the other users.
Yes is possible, but the test must be done also crossing version and routeboards, or the test are incomplete...So you're saying that he couldn't possibly have two devices and just swapped the devices?
LaZyLion - We fixed print function for "/system package update" in latest 6.28rcX versions. Now something like this might work for you:
delay 5
:put [/system package update get latest-version ]
First function will force RouterOS to check for a latest version. Delay can be reduced but must be longer than time needed to find out latest version. Last function will give latest available version of RouterOS.
[admin@my-router] > /system package update check-for-updates once
current-version: 6.27
status: resolving upgrade.mikrotik.com
[admin@my-router] > :put [/system package update get latest-version ]
input does not match any value of value-name
[poi@HotSpotAs] > sys resource print
uptime: 1h48m46s
version: 6.27
build-time: Feb/11/2015 13:24:13
free-memory: 3784.0KiB
total-memory: 32.0MiB
cpu: MIPS 24Kc V7.4
cpu-count: 1
cpu-frequency: 300MHz
cpu-load: 19%
free-hdd-space: 43.6MiB
total-hdd-space: 64.0MiB
write-sect-since-reboot: 21992
write-sect-total: 62832584
bad-blocks: 0.8%
architecture-name: mipsbe
board-name: RB450
platform: MikroTik
[poi@HotSpotAs] >
[poi@HotSpotAs] >
[poi@HotSpotAs] >
[poi@HotSpotAs] > tool profile
action timed out - try again, if error continues contact MikroTik support and send a supout file (13)
[poi@HotSpotAs] >
+1. Good question...Why 6.28rc13 has been removed?
Good question, but bad topic:+1. Good question...Why 6.28rc13 has been removed?
nop, i can't connet...poizzon, did you do what this log line asked?
I get lots of this messages on my setup ... I use capsmanv2 with multiple APs configured to provide same said over a building ... this warning pops up when client goes from one AP to another ... sometimes RSTP disables the port long enough to make CAP drop connection due to timeout and loose all of its clients which is annoying.interface,warning 3_WIFI: bridge port received packet with own address as source address, probably loop
Just to let you know. This problem was confirmed by mikrotik to be an error finally.Having three mipsbe routers connected to internet:
To this ticket. I received today info from Mikrotik support that I should have all involved ros devices at the same level (6.27). But the ticket was also about the SSTP not working between two 6.27 devices. So the advice was false.
I found the solution myself: it is the PFS option that is not documented. Correct settings allows communication between both 6.27 as between different versions (for example 6.27-6.18 or 6.27-6.25 in my case).
Mikrotik should take care about the documentation if changing/adding anything!
+1 for this.so when all_packages torrent/zip will be back?
Please contact support@mikrotik.com so we could check the configuration of the board and setup environment. Then we could try to reproduce this problem in the lab with the AC boards.hi,
I have a problem starting nstream to be unusable with ac hardware. I have swapped a RB912 with a netbox5 on a place were nstream was working really good (uptimes of clients ofthen 10-20 days before getting a not polled for too long), now it disconnects ALL clients simultainously every hour or so (not polled for too long).
wireless-fp package
a/n mode
please make nstream working stable again, for most of my sites it gives AT LEAST double tcp performace at the client side than NV2. I'm worried now about using the newest hardware as this is even less usable with nstreme than old hardware.
I can't simply downgrade all my clients to just 50% of the bandwidth just for using another protocol.
thanks
ps.: btw I have around 450 mikrotiks in use here, and I'm doing wisp since 2000
What ports do you have on bridge?interface,warning 3_WIFI: bridge port received packet with own address as source address, probably loop
An error, which I don't know the meaning of, occasionally appears in the log.
I would be greateful if you could tell me if this error occurs due to a configuration fault or if someone is trying to connect but I am unable to see the IP from which it is coming from.
This started happening after upgrade 6.27, but before the update I didn't see the error.
20:32:31 ipsec,error failed to get valid proposal.
20:32:31 ipsec,error failed to pre-process ph1 packet (side: 1, status 1).
20:32:31 ipsec,error phase1 negotiation failed.
20:32:41 ipsec,error failed to get valid proposal.
20:32:41 ipsec,error failed to pre-process ph1 packet (side: 1, status 1).
20:32:41 ipsec,error phase1 negotiation failed.
20:32:51 ipsec,error failed to get valid proposal.
20:32:51 ipsec,error failed to pre-process ph1 packet (side: 1, status 1).
20:32:51 ipsec,error phase1 negotiation failed.
20:33:01 ipsec,error failed to get valid proposal.
20:33:01 ipsec,error failed to pre-process ph1 packet (side: 1, status 1).
20:33:01 ipsec,error phase1 negotiation failed.
20:33:05 ipsec,error phase1 negotiation failed due to time up X.X.X.X[500]<=>Z.Z.Z.Z[500] 5654bdb3a0805b43:00000000000000
20:33:05 ipsec,error failed to get valid proposal.
20:33:05 ipsec,error failed to pre-process ph1 packet (side: 1, status 1).
20:33:05 ipsec,error phase1 negotiation failed.
Do you have any SNAT on the network path from SSTP client to SSTP server which is configured out of SSTP client?Just to let you know. This problem was confirmed by mikrotik to be an error finally.
After my further investigation, it is not linked to PFS nor to ros versions mismatch nor to SSTP only, as it also happens to L2TP. The basic of the problem lies in the dynamically assigned IP to the client device that suddenly becomes ivalid without any obvious reason at the clients ip address list.
For those who suffer by this problem like me, you can switch off the sstp/l2tp client, remove the invalid addresses from address lists, reboot the client and switch on the sstp/l2tp client. Then it should behave good at least for some time...
I have got a message that it was passed to programmers for correction. Hope it will be included in 6.28.
Hey, can we please have the .torrent files back for ALL RouterOS. I don't believe that I am the only one that uses the .torrent to download RouterOS. I myself support multiple different hardware flavors and to download each file separately can be a pain.
Thanks!
Thanks!
Not only are you! Mikrotik: please come back torrent download!
I did copying the .npk file as always, I have no way to do netinstall from remote location where I am some 500km from the device.Steen, did you try Netinstall or just copying .npk files?
For me, 6.27 is a good release. I have it running on couple of routerboards and on those never had kernel panics, sudden reboots or resets. Everything that i have set on earlier releases (5.x) working like a charm. Big plus from me!
And the reason is in Log, isn't it?I had cases where i copy .npk files and then after reboot, device simply wont upgrade
If you can netinstall the router I would do that. If not, you might try upgrading to 6.25 and then go to 6.27.Hello Folks!
Trying to upgrade CCR1016 from 6.24 to 6.27 failed due to kernel panic, and it reverted back to 6.24 again and support was generated. I put up a support case to MT with support file.
Anyone who have seen this and or know how to mitigate it ?
Try -please help me, someone can tell me where I find the download version 6.27 parael npk ccr1036-12G -4S
