tgyula
Re: RouterOS v6.27 released
Wed Mar 25, 2015 7:28 pm
Hey, can we please have the .torrent files back for ALL RouterOS. I don't believe that I am the only one that uses the .torrent to download RouterOS. I myself support multiple different hardware flavors and to download each file separately can be a pain.
Thanks!
Not only are you! Mikrotik: please come back torrent download!
mars
Fri Mar 27, 2015 5:58 pm
Thanks!
+10000.....
alobci
Mon Apr 06, 2015 12:04 am
I cannot access to user manager on mikrotik after i turn off the router bord i turn it on then its not working maybe its damage what can i do ?
steen
Mon Apr 06, 2015 9:23 am
Hello Folks!
Trying to upgrade CCR1016 from 6.24 to 6.27 failed due to kernel panic, and it reverted back to 6.24 again and support was generated. I put up a support case to MT with support file.
Anyone who have seen this and or know how to mitigate it ?
TomosRider
Tue Apr 07, 2015 10:03 am
Steen, did you try Netinstall or just copying .npk files?
For me, 6.27 is a good release. I have it running on couple of routerboards and on those never had kernel panics, sudden reboots or resets. Everything that i have set on earlier releases (5.x) working like a charm. Big plus from me!
rextended
Tue Apr 07, 2015 2:58 pm
Please put a disclaimer inside 6.27/6.28:
"ac" models wlan work only with "wireless-fp" package enabled.
using "wireless" package on ac models cause wlan to not be recognized from the system.
RB922UAGS-5HPacD S.N.:5F820473960B
steen
Tue Apr 07, 2015 9:14 pm
I did copying the .npk file as always, I have no way to do netinstall from remote location where I am some 500km from the device. :-)
TomosRider
Wed Apr 08, 2015 10:26 am
I had cases where i copy .npk files and then after reboot, device simply wont upgrade.Copy again in files dir and then copy to packages directorium...worked for me once. First mark old npk's for uninstall, ofc
Chupaka
Wed Apr 08, 2015 12:20 pm
And the reason is in Log, isn't it? :)
TomosRider
Wed Apr 08, 2015 11:47 pm
Well, yes, but im always on hurry so i skipped checking log.. :)
locodog
Sun Apr 12, 2015 4:10 am
There seems to be a problem with RB1100AHx when running hotspot and PPPoE at the same time. Users are unable to reach certain websites. On every other version and model of RB with same settings everything works good. Also, when RB1100AHx is running hotspot OR PPPoE, works good, but when it has both there is problem.
StubArea51
Trainer
Trainer
Sun Apr 12, 2015 8:45 am
Hello Folks!
If you can netinstall the router I would do that. If not, you might try upgrading to 6.25 and then go to 6.27.
ennnot
Tue Apr 14, 2015 12:02 pm
Hi!
I'm using MRTG (RB450G) with 6.27. The are some L2TP-servers. Edit comment for L2TP-interface cause a restart of L2TP-server. Is it normal process?
TomosRider
Tue Apr 14, 2015 12:42 pm
Simple...no.
killersoft
Sat Apr 18, 2015 3:47 pm
Just wondering if anyone else is suffering a failure of the "Reset Counters" in the Interface/Traffic TAB.
By where as an example in the Tx/Rx Bytes( and in my instance this interface connections to my cable modem ) and in my case shows 32Gb TX and 31Gb Rx respectively. But when I click on "Reset Counters" this does not clear to 0 as I would expect it to..
I am running a RB750G with 6.27 and v3.22 Firmware... Anyone else noticing this ?
0ldman
Sun Apr 19, 2015 3:22 am
I've got the same network loop error. There is no loop. The network has been in operation in this config for nearly 4 years, then 2PM this afternoon it just stopped.
0ldman
Mon Apr 20, 2015 5:21 pm
I figured it out. DDoS attack was spoofing MAC addresses in the network causing the equipment to falsely detect a loop.
Habib89
Fri Apr 24, 2015 1:59 am
hi
after updating to 6.27 the internet connection become very slow and some websites doesn't even open after 10 or 20 minutes,
it was working fine in 6.14 version.
is there any solution?
Chupaka
Tue Apr 28, 2015 4:08 pm
it depends on your setup, I think :)
sattlink
Mon Jun 08, 2015 6:17 am
please help me, someone can tell me where I find the download version 6.27 parael npk ccr1036-12G -4S
jebz
Mon Jun 08, 2015 1:58 pm
Try -
http://download2.mikrotik.com/routeros/ ... e-6.27.npk
tapsin
Mon Jul 27, 2015 11:04 am
Royalsaleh1
Mon Sep 21, 2015 10:09 pm
loop probably problems i need help thanks
Royalsaleh1
Mon Sep 21, 2015 10:23 pm
hello !
I have a problem
router rb 1100
internet in
broadband
out
hotspot
output ip 10.10.10.10
i have bridge
i have ip back
10.0.0.1 on bridge client dhcp
log : ether 6 loop probably
Users browsing this forum: Gennadiy51, gogle, wfburton and 33 guests
