Are you sure about this one :All credentials are fake like sdfadfasdf
/ppp secret add name=vpn password=dudako346456
OK, sorry for the insistence.it isn't dudako346456
Can you please tellme were my setup is wrong pleaseIt's not a problem of modele but of setup
Envoyé de mon SM-G925F en utilisant Tapatalk
Several things:Can you please tellme were my setup is wrong please
set 0 default-vlan-id=1
set 2 default-vlan-id=2
add address=10.1.1.2/24 comment=defconf interface=02lan network=10.1.1.0
Yeah hAP Lite can do itI have AP (groove, L4) with home LAN & internet access. Now I would like to add another AP which can bridge LAN to this WiFi and work as AP + isolated AP (for guests) at the same time. Is hAP lite OK for such task?
Can anyone send me an functional export of a harp lite with 2 wan a lan in bridge wit the wifi and the loadbalance and failover functional?
It is. But always take into account that all ethernets share common 100Mbit lane to the CPU and the CPU is not the fastest ever at all...Can this box be use to do a Dual WAN? Switch/ over/ Failover and /or Bandwidth Bonding? - Is that a function of the Router OS Level rather the box? Please guide. Thanks.
We have a 1 or 2 machines at a remote dusty workshop type location (where the DSL is crappy & the backup 3G USB modem is nothing better either) where putting anything expensive or complex (subject to maintenance) is out of the question.
Thanks. True. The performance wont be phenomenal, but the location does not have the bandwidth anyways. So, at the cost of a consumer router I'd prefer the HabLite.It is. But always take into account that all ethernets share common 100Mbit lane to the CPU and the CPU is not the fastest ever at all...Can this box be use to do a Dual WAN? Switch/ over/ Failover and /or Bandwidth Bonding? - Is that a function of the Router OS Level rather the box? Please guide. Thanks.
The bridge is trivial, the fail over is not difficult, but multi WAN is a thorny issue regardless of what router you select. You cannot simply configure the router to route traffic to either WAN indiscriminately, because it breaks stateful protocols such as HTTPS and others. You must sit down and manually make decisions as to what traffic will normally use which WAN, either by traffic type, source, or target; and then configure mangle rules and discretionary routing tables to ensure that all of this type of traffic goes to the same WAN all the time (subject to fail over). Everyone has to make these choices for himself depending on his own traffic characteristics, which is why there is no cookbook answer to this problem.If possible to do the above, I'd love to partake in this as well. Thanks.Can anyone send me an functional export of a harp lite with 2 wan a lan in bridge wit the wifi and the loadbalance and failover functional?
Thanks. Also, is there a chart for the various models that compares/ shows WAN to LAN throughout performance so people may choose appropriate device?The bridge is trivial, the fail over is not difficult, but multi WAN is a thorny issue regardless of what router you select. You cannot simply configure the router to route traffic to either WAN indiscriminately, because it breaks stateful protocols such as HTTPS and others. You must sit down and manually make decisions as to what traffic will normally use which WAN, either by traffic type, source, or target; and then configure mangle rules and discretionary routing tables to ensure that all of this type of traffic goes to the same WAN all the time (subject to fail over). Everyone has to make these choices for himself depending on his own traffic characteristics, which is why there is no cookbook answer to this problem.If possible to do the above, I'd love to partake in this as well. Thanks.Can anyone send me an functional export of a harp lite with 2 wan a lan in bridge wit the wifi and the loadbalance and failover functional?
Since this topic is not specific to the hAP lite, you should search the forum for other threads that deal with it, and discuss it there.
Not all in one place, I think, but at routerboard.com every device has a data sheet that shows bit and packet throughput for various configurations. In general, you get what you pay for.is there a chart for the various models that compares/ shows WAN to LAN throughout performance so people may choose appropriate device?
Of course, but wouldn't a product matrix + benchmarks be favorable for prospective and existing customers (and the Product seller/ Maker) so that they can easily choose the product of the right fit and scale. Going through each data sheet is like saying that we wont have a unified view on our product portfolio.Not all in one place, I think, but at routerboard.com every device has a data sheet that shows bit and packet throughput for various configurations. In general, you get what you pay for.is there a chart for the various models that compares/ shows WAN to LAN throughout performance so people may choose appropriate device?
Sent from my iPhone using Tapatalk
Lowest cost MikroTik cased unit with gigabit and multiple ports is hAP ac2. There are none powered by USB +5V. Go to https://mikrotik.com/products/group/wir ... and-office#! and use the filters in the left column to choose gigabit.Just got one, I haven't tested it out yet but I like the form factor a lot.
It's great for temp. use / live event / field testing or troubleshooting. No need to worry whether there's spare outlet, great for IoT. If there's a USB port it will work.
I did think about mAP but this has just enough RJ45 ports for simple port mirroring, or act as a switch to control several things together, ie LED display panel.
I really hope it has Gigabit Eth ports, as some of my gear must use them, otherwise it won't even connect and get an IP address. Is it the price point or the 5V USB supply keeping GbE ports away from it? I would really like to hear.
I work in a SI company offering professional audio/video-engineering solutions, so I think this is a great product for field deployment, as well as a great tool to learn the underlying protocols, how my things actually works
Power consumption of GbE chipsets.Just want to know why USB power and GbE don't mix together, is it because of the price, or technical challenges like 5V simply not sufficient for GbE? Since it seems all USB-powered only have FE available (mAP, mAP lite and hAP lite)
It is only a matter of time. As things get smaller power consumption will eventually decrease and passive cooling will be possible.Ever wondered why there is no passively cooled 10G switches?
Oh I see......hope they'll release one with USB-C in futurePower consumption of GbE chipsets.Just want to know why USB power and GbE don't mix together, is it because of the price, or technical challenges like 5V simply not sufficient for GbE? Since it seems all USB-powered only have FE available (mAP, mAP lite and hAP lite)
Thanks for that Link & Filter. Atleast something positive in terms of "Product Filtering"Lowest cost MikroTik cased unit with gigabit and multiple ports is hAP ac2. There are none powered by USB +5V. Go to https://mikrotik.com/products/group/wir ... and-office#! and use the filters in the left column to choose gigabit.Just got one, I haven't tested it out yet but I like the form factor a lot.
Or, if amount of RAM and storage offered by RB450Gx4 is not needed, a RBD52G (with wireless disabled) might be considered as well ... comes with a case and lower price-tag while offering same wired performance.Something like RB450Gx4 ...?
So how would I troubleshoot a RB951-2nD that keeps booting on its own-I cannot log in to them even after a hard reset. Also others have 'internet port'-port 1, blinking even with no ethernet cable plugged in. Another which seem not to be getting enough juice i am assuming the power supply on the PCB has an issue?yes, it is a SMIPSAny word on NAND storage? Is it going to be like a normal RouterBoard with somewhere between 32-64MiB minimum, or is it going to be more like an mAP in that respect, with the same kind of software update procedure as an mAP?
-- NathanCode: Select alltotal-hdd-space: 16.0MiB
Based on this and this Why people pair UBNT APs with MikroTik routers? Then..And after 6 years still the same ...we don't have any beamforming products yet.
