kristaps
Re: Tik App, MikroTik android utility ALPHA test
Fri Nov 25, 2016 5:41 pm
Thanks for reports and suggestions. We are really close to Final version.
New version is available for download.
APK. v43 http://www.mikrotik.com/download/share/ ... 0_0_43.apk
Become alpha tester:
https://play.google.com/apps/testing/co ... oid.tikapp
Download here:
https://play.google.com/store/apps/deta ... oid.tikapp
Cetalfio
Fri Dec 02, 2016 10:44 am
Hello kristaps, please you to consider the Dude client on tik-app to be able to monitor the network when we are out of office.
cetalfio
noyo
Wed Dec 07, 2016 1:22 am
Will there be support for RouterOS v5?
kristaps
Wed Dec 07, 2016 12:22 pm
Sorry But Tik-app Supports only RouterOS v6,
It would take to much time to add support for older RouterOS
ErfanDL
Wed Dec 07, 2016 4:03 pm
Can't set wireless tx power
Sent from my C6833 using Tapatalk
pacmanfan
Fri Dec 16, 2016 6:05 am
Any plans for an iOS version? I just switched from Android to iOS, and so far Tik-App is the only thing that's missing on iOS :(
kristaps
Fri Dec 30, 2016 5:05 pm
We will announce if we start beta iOS version for Winbox
http://www.mikrotik.com/download/share/ ... 0_0_45.apk
WHAT'S NEW
• Moved item actions under gear icon
• Fixed wlan 5GHz frequency list
• Fixed tool crashes
• Fixed time zone field issues
• Fixed long text scrolling
• Added fields to homescreen
• Other bug fixes
Download here:
lexell
Fri Jan 06, 2017 2:02 am
Some issues I've been able to collect during the last few months and which I've now confirmed to still be present in v0.0.45 after wiping app's data and cache (to start from scratch):
  • Menu order is not consistent with the order used in WebFig/WinBox. It also differs even among different router models (e. g. "System" is in a different position in the list when using Tik-App with RB951G and CRS109). It would be ideal to have the same order in TikApp as the one already used in WebFig and WinBox. Submenus seem okay since they're sorted alphabetically everywhere.
  • No Quick Set (which could actually be useful in a mobile app).
  • Being "too quick" while clicking through stuff (e. g. opening interface details) still occasionally crashes the app (tested on a very recent octacore Snapdragon with 4GB of mostly free RAM, so there should be no resource constraints on the phone's side as a reason for crashing.)
  • The app also tends to "time out" and disconnect from the router while sitting on an idle local Wi-Fi with very low packet loss or external interference. I have a suspicion this might either be related to phone turning off the display and then being immediately awakened by the power button or to the relevant router having a WebFig page with frequently updated data open at the same time.
  • Custom wireless scanning lists are only shown as "<unknown>,<unknown>" instead of the actual ranges (e. g. "2402-2422,2462-2482"). This also affects WebFig. Only WinBox and the CLI seem to display custom frequency range lists correctly as of now.
  • Interface and queue graph values could switch to regular SI suffixes instead of using up to (hard to read) 7-digit numbers and then the scientific notation. The Y-axis of one of my interface graphs in Tik-App looks like this: "0.0, 3000000.0, 6000000.0, 9000000.0, 1.2E7". The same graph from RouterOS's MRTG uses values of "0.00Mb, 3.00Mb, 6.00Mb, 9.00Mb, 12.00Mb" instead which are much more intuitive and "default" for the network world. The same goes for binary suffixes on memory and HDD graphs (KiB, MiB...) and CPU graph could include the "%" sign.
  • Resource graphs could have their Y-axis fixed to its maximum possible value depending on the router (128MiB RAM etc., CPU to 100% obviously) as is the case with the WebFig MRTG graphs.
  • Decimals in all graphs should also be properly limited (right now in between a "2.4" and "2.8" I have a "2.6000001" value instead of "2.6" on the CPU graph).
  • When going to Tools > Graphing > Resource Graphs, all of the entries (CPU, Memory and HDD) have "CPU Graph" and "Memory Graph" entries (daily/weekly/monthly/yearly depending on the selected tab) inside them instead of only one entry that would match the resource name (CPU, Memory or HDD). Both graphs always display the same (and correct) data - HDD utilization for the HDD resource..., however they are wrongly labeled (always "CPU" and "Memory") and duplicated.
  • It should be possible to sort lists (ARP entries, DHCP leases, firewall address list groups, firewall connections...) by at least their major parameters (IP/MAC address, name...).
  • Filtering needs some more work - IP routes only have destination address filtering now and only one filter rule is available, IP firewall connections or IP ARP (and likely other places which do have filters in WinBox) don't have filtering at all.
  • A bug in IP routes filtering (possibly also elsewhere if filtering is available in other places): tapping the filter button and then repeatedly selecting "Routes" from the top-right dropdown menu brings up more and more filtering fields. This actually allows for multiple-rule filtering in routes now, however multiple filters should likely be invoked by something more user-friendly (+/- buttons?) and unless other filtering rules than "dst. address" are available then multiple rules are not really useful anyway.
  • After tapping the search button in the top right corner, the second search button on the left of the newly-appeared search bar must also be tapped to pop up the keyboard and enable typing (even tapping the rest of the search bar's area doesn't do anything). The keyboard and an active cursor should ideally pop up only with the top-right search button to enable typing right away.
  • Display of both ping and traceroute results seems to be broken - traceroute has correct number of hops, however no data about them is displayed in the overview or in hop details. Ping also generates entries with no data.
  • No package upgrade check (I believe this was available in the previous versions at some point) and no upgrade download/installation.
  • Entering or editing static DNS servers is not available (this should be fairly important), also dynamic DNS servers are not displayed even if present.
  • Many other sections are still not fully finished too (both missing configurable parameters and omitting displaying of unmodifiable values). Often the missing entries are the ones with no value set/present or non-checked checkboxes - however not always, e. g. the aforementioned static DNS configuration or default route distance configuration in the DHCP Client. And ideally all entries (eve the unconfigured or null ones) should be available for viewing (I'd like to be explicitly reminded that e. g. my DHCP client configuration is not accepting the DHCP server's NTP IPs by seeing them empty instead of not seeing the Peer NTP fields at all).
Tested with RB951G-2HnD (6.38) and CRS109-8G-1S-2HnD-IN (6.37.3), Tik-App v0.0.45 on Android 6.0.1.
I can try to do some screenshots if any of the visual/UI issues can't be successfully replicated with the description alone.
Otherwise a good job, the app is much more complete and stable now compared to when I first tried it :-D
EDIT: some typos and more stuff regarding the resource graphs.
vents
Wed Jan 11, 2017 3:21 pm
Thank you for your effort helping us to improve the functionality of TikApp.
With your help, we have managed to repair several issues in v0.0.46 such us:
  • Editing static DNS servers
  • Package upgrade check
  • Ping and traceroute results
Other issues will be fixed in upcoming TikApp releases.
Please continue using TikApp and together we can make it more user-friendly.
mongo
Wed Jan 11, 2017 9:49 pm
Hi, with the latest version (.46) non of the views refresh i.e. If looking at interface traffic no refresh, if looking at wireless signal strength no refresh. This was not happening with the previous version. I am using a Samsung S7 edge fully updated. Tried rebooting the phone issue still remains.
** edit **
Just wiped app cache and cleared app data still not refreshing views
lindend
Thu Jan 12, 2017 2:24 pm
Queue Traffic upload and download rate counters appear to be showing total traffic that have gone through the queue and not the average traffic.
Edit: Tested on Nexus 6P on 7.1.1.
vortex
Wed Jan 18, 2017 1:39 am
BlackBerry Q5: BlackBerry OS 10.3.2 (Android 4.3) : v45 works. First version I've tried that does not disconnect on a device.
It still really needs to show the names of the nodes in the lease list.
pospanko
Wed Jan 18, 2017 11:43 am
We just installed app and I think that you are, again, going in wrong direction...
This app is good for someone, and for us in long terms, but... You always miss the point. I, and probably most of people here, wouldn't use winbox on phone, what you are trying to achieve.
We need phone apps. Basic functionality for work on field and check some stats and do basic tests.
Basic interface info, wireless scan, basic parameter setup, dhcp, pppoe, few tools and that's it. You can't expect do do real work on phone.
UBNT does that much better.
Create basic app, and listen what people want and add it if there is real demand.
You are developing this for 2 years now and still nothing usable. You could develop real usable app in month or two.
Just my 2 cents...
baragoon
Wed Jan 18, 2017 12:11 pm
Is iOS version in plans?
Отправлено с моего iPhone используя Tapatalk
Milkthief
Wed Jan 18, 2017 4:14 pm
Dear Mikrotik developers,
I'm mikrotik enthusiast and I work in a software house where I'm network infrastructures engineer and project manager (specialized on home automation, mobile app and software for electronics projects). I discovered this app only yesterday and I played with it the whole day... ;-)
I want to provide my experience to give some advice, my 2 cents...
I cannot deep-test all the functions, but I'd like to start with a couple of things about "user experience".
  • Winbox is huge. It is at limit of usability in a 13" laptop screen, will never be usable on a 5" smartphone touch. You choosed the way to reproduce winbox in a smartphone. Ok, you did it, but how much is it usable? Too little. At this point you cannot think to restart from zero, but you can put a switch button below "safe mode" and switch between full current interface and a simplified, mobile optimized, and fast interface. The current interface can be usable with a tablet, but not with a smartphone. Just give it to a normal user and let it try!
  • On the left menu, when you enter a submenu, you miss the back button. The user should use the one of Android, but that usage don't matches his Android user experience for that kind of side menu. Please, add a "<-" button near the padlock icon (padlock on the left and back arrow on the right)
  • When a user navigate between menu items on the side bar, he arrives on the submenu (i.e.: "IP" then "Firewall"), then he lands on the corresponding first tab in winbox. Where are other tabs? On the three points icon on the other side of the screen. This is not intuitive, and the icon is too small for a thumb. Why don't you consider it as a 3rd level submenu on the sidebar? Or you use a swiper system (like leafing through pages of a book) Swiper correspond with the tab concept when transposing a desktop interface with a mobile one.
Hope this can help and not let you angry... ;-)
vortex
Thu Jan 19, 2017 7:16 pm
v45 is working on:
Amazon Kindle Fire (1st Generation): pre-"Fire OS" naming 6.3.4 (Android 2.3.4)
ISSUES:
It crashes opening the Switch page after watching Traffic on an interface.
ronniee
Mon Jan 23, 2017 10:18 pm
also official iOS application for setup/manage MikroTik routers are needed
if MikroTik has decided to enter in SOHO category, this kind of application it has to be
you can see the others tp link, ubiq …
don’t waste time
bcall
Mon Feb 20, 2017 8:07 pm
This app was unstable and hard to use in November/December last year. Now, it's starting to look nice and perform well. Great job, Mikrotik!
To those of you that think this is a futile effort because a 5" device is too small, I offer these suggestions:
1) Provide constructive feedback to the Mikrotik team, including what your most critical tasks are within an app like this, where the app is not doing well, and where it is doing well
2) You might want to consider not trying to manage your entire network from a smart phone. Security aside, you're putting an awful lot of faith in a platform (Android, iOS, WIndows Phone, etc) that was never designed for what you're trying to use it for.
paams
Tue Feb 21, 2017 7:59 am
Hello There! For a quite long time i have been looking for such a tool where i could use and configure my Mikrotik devices at the top of the tower, as it always been very difficult to configure and make antenna alignment with taking a heavy laptop at the top of the tower alone at remote tower site. I have given try by downloading this TikApp from Google Play and it run smooth on my android smartphone at my NOC. Will soon give try to this in the field at remote tower site. A great piece of tool from Mikrotik to work on Android OS. I really appreciate Mikrotik for this. :) :)
Secondly, i have give try to download this apk TikApp tool from provided direct link at Mikrotik download page at http://www.mikrotik.com/download/share/ ... 0_0_29.apk , but i didn't get this apk file there and this link landed at only Mikrotik main download page i.e. https://mikrotik.com/download and not at http://www.mikrotik.com/download/share/ ... 0_0_29.apk exactly. May i know please where this apk file located on this download page. Thanks.
lexell
Mon Mar 13, 2017 10:19 am
Adding to my previous feedback:
  • Why was the menu design recently changed from WinBox-like two-column popup to in-line submenu slideouts? This imho hinders working speed and worsens the UI by requiring much slower and accuracy-requiring scrolling instead of occasional (and much faster) back button tap. Most often I'm accessing the IP submenus and in the old UI design after tapping the IP menu I was immediately able to tap more than half of its submenus as their column replaced the top-level column (which was logical seeing that I wanted to access some of the IP subsections and was not interested in other top-level sections anymore for the time being). I could also "overscroll" to the bottom by one fast swipe (where the second half of IP entries would quickly all be available). I could even muscle-memorize the specific subsections' placement. Now it pops the submenu into the middle of the top-level column and I have to tediously scroll again to get even to that first 13 or so items. I also can't overscroll to the bottom for the last 13 entries as the 1st level menu still occupies a large part of the column then. How was this change decided on? Was it even mentioned in the Play Store changelogs? If it's because of being better-suited for tall tablets in portrait mode, it shouldn't also be applied to small phone screens (or tablets in landscape mode). A settings toggle for phone vs. tablet UI layout would then be relevant.
  • The changelogs got pretty terse. From "more bug fixes" I have no idea if the new release fixes any of the issues I've reported before and I also don't know what new to check for further feedback. As of now this is an app for alpha testers, we're used to read changelogs, we can handle a bit more verbose ones (look at RouterOS ones - and I'm not on the RC branch...). Several latest versions also went without any annoucement in this thread (and Google Play doesn't show older versions or changelog history which then effectively makes it impossible to track the development process, further hindering the possibility of proper feedback).
Edit:
[*]When a user navigate between menu items on the side bar, he arrives on the submenu (i.e.: "IP" then "Firewall"), then he lands on the corresponding first tab in winbox. Where are other tabs? On the three points icon on the other side of the screen. This is not intuitive, and the icon is too small for a thumb. Why don't you consider it as a 3rd level submenu on the sidebar? Or you use a swiper system (like leafing through pages of a book) Swiper correspond with the tab concept when transposing a desktop interface with a mobile one.[/list]
  • I also vote for the screen swiping system with a top row with directly tappable and scrollable tab IDs - exactly how individual Interface entries are already done now. The triple-dot button should instead be used for special command buttons which occupy the window's right side in Winbox (Torch, Cable Test, Blink et al. for Interfaces) - if there are any for that section. This would further streamline the app, make it more intuitive and increase working speed.
erebusodora
Mon Mar 13, 2017 12:44 pm
On Lenovo Vibe P1 is workin good but 1 problem found. When import adreses (from adress.wbx file) and when i want to connect to adres from imported list it always show my first conection . Example my first conection is 192.168.0.1 and i want to connect to 192.168.0.6 from imported list but always return 192.160.0.1 (firs connection)
Stil no fixed in v. 0.0.51
ua3prq
Thu Mar 30, 2017 11:00 pm
Hello!
At this stage of development, the application already liked, because unlike existing similar already works! Phone Xiaomi RN3P.
Keep it up, Mikrotik!
fabvit
Thu Apr 20, 2017 6:53 pm
How can Tik-App access the QuickSet screen like the one in WebFig and WinBox?
fabvit
Fri Apr 21, 2017 10:03 am
I will try to rephrase my last post.
In both WebFig and WinBox there is the QuickSet page where I can chose from a list an WiFi Access Point to connect to.
Given that in the Tik App I was unable to find the QuickSet page, where can I , In the Tik App, see a list of available WiFi AP and then select one, write its password, and connect to it?
erebusodora
Mon Apr 24, 2017 1:10 pm
In version v.0.0.52 Ticket#2017031322000808 not fixed. Ping to same hosts's with TikApp TOTALY different with Winbox 3.11 . In TikApp ping show time=874 ms or time:unknow status timeout. In winbox 3.11 show real!!! ping time=0 or time =1 between MikrotikRb and hosts
http://www.kaolinovo.bg/raw/uploads/mikrotik/s1.jpeg
http://www.kaolinovo.bg/raw/uploads/mikrotik/s2.jpeg
hoftel
Mon Jun 12, 2017 1:24 pm
This app was recommended for me in Google Play store. Of course I immediately downloaded it and tried it out.
I love it! Since I am only a basic user I don't use many advanced features, but I love the fact that if my customers have problems I can check the severity of the problem immediately no matter where I am. Check capsman, is it online, is the cap online, check log... :)
Good job Mikrotik
idlemind
Sun Jun 18, 2017 7:54 pm
  1. Apply power to cAP Lite
  2. Connect Android phone to SSID broadcast by cAP Lite
  3. Launch TikApp
  4. Fail, no DHCP server on cAP Lite in default configuration from factory
The app will not work with the cAP Lite product. The default configuration that unit comes with is broken. The products documentation indicates it should be configured by default like almost all other MikroTik products; turn it on and get an IP at 192.168.88.0/24 but it doesn't. The configuration is missing a DHCP server and the Ethernet port is not setup as a WAN interface. I tried to post this in the release forums but got told to use WinBox w/Mac Telnet. Not a viable option if you're trying to streamline initial power-on configuration, especially with a tool like TikApp.
msatter
Sun Jun 18, 2017 8:18 pm
I think you have tried everything but did not use the recommended way.
Connect to wireless SSID “MikroTik” and open http://192.168.88.1 in your web browser.
The username is admin and there is no password. In case IP connection is not available, the
Winbox utility can be used to connect to the MAC address of the device.
As this app uses port 8291 and not the MAC address, it will not work with port 80 only devices.
vortex
Sat Aug 12, 2017 6:02 pm
Where is the latest apk?
csalcedo
Thu Aug 31, 2017 6:02 pm
anyone now how to import address and password into the app?
Shadeofspirit
Thu Aug 31, 2017 7:10 pm
near the address field there is a button - it opens the least of connections. at this least the button (looks like spanner) opens menu with import and export.
csalcedo
Thu Aug 31, 2017 7:55 pm
Yea I got that... What format does the file need to be in?
Shadeofspirit
Thu Aug 31, 2017 8:04 pm
it is a text file (passwords are also in clear text)
csalcedo
Thu Aug 31, 2017 8:57 pm
OK, now what format? spaces, coma newline for next device?
ipaddress, user, password, note ?
1.1.1.1, admin, admin, test
Shadeofspirit
Thu Aug 31, 2017 10:50 pm
some symbols i can't read (i don't know the format)
but the other is (all letters with CAPS are the settings, other - made by app):
��" hostADDRESS
keep-pwd loginYOURLOGIN pwdYOURPASSWORD
noteNOTE typeaddr group
secure-mode
Shadeofspirit
Thu Aug 31, 2017 10:51 pm
add one host to the list and export it
boldsuck
Sun Sep 03, 2017 4:29 pm
Hint:
You can change the "Encoding" under "Settings"
UTF-8 is almost always right nowadays.
cppprog
Sun Sep 03, 2017 11:03 pm
hi
why cant type in terminal in tikapp on android devices.only cursor blinking and soft keyboard not shown on screen to type.
jo2jo
Sat Oct 28, 2017 3:25 am
Just wanted to put in another request for an iOS version. The only similar app on iOS requires use of the MT API which we disable on our default configs ( + the app is expensive), we would much prefer an even basic version for iOS by Mikrotik which uses winbox pt 8291 by default.
thanks
it9mbz
Sun Nov 19, 2017 6:48 pm
Hi to everyone,
I'd like to use this app for check the beaming of a PtP link, but i can't find where is possible to read the signal strength as like in Wireless>Registration>(double click on item)>Signal in WinBox.
Is there somewhere this info in the app?
Thanks, Sergio.
msatter
Fri Nov 24, 2017 10:26 am
Using the app and going to the address section in IP - Firewall and having about 20.000 entries it does not display what I can understand.
Suggestion how to be able to make some lists visible.
  • only lists smaller then lets say 50 entries can be displayed and that includes 'All'
    lists with more then 50 are greyed out and are not selectable
    • it is possible that all lists are greyed out
WirtelPL
Sat Nov 25, 2017 10:27 pm
I'm connect to my RB951G-2HnD, but router not logged this fact.
EDIT: My mistake, router logged my connection. Sorry.
iphonedev
Thu Jan 04, 2018 1:51 pm
Following are the steps to follow for android utility ALPHA testing:
1) Apply as beta tester in the application
2) Install the application
3) Now the application has some accidental bugs or termination issues, but is expected as it is still in its infancy.
4) The best concept about the application is that it uses API to connect to RouterOS, but is compeleted directly with the port Winbox.
Let's halt how it goes with this tool that assurance much and it will behave itself was iOS.
Torontobb
Sat Jan 27, 2018 9:34 pm
If this app is not open source how can one be sure that data and access to routers are not logged, shared, or misused?
What is the guarrantee here to expose oneself to a third private party?
This is a serious concern.
Chupaka
Sun Jan 28, 2018 9:10 am
RouterOS is not open source, you cannot be sure that data and access to routers are not logged, shared, or misused :)
So you either trust MikroTik, or don't use its software and hardware
Cha0s
Mon Jan 29, 2018 9:24 pm
Sniff all the data that come in and out of your android device and see if it tries to connect to anywhere else beside your router.
I have to admit that it is a bit oxymoron to have "serious" concerns about 3rd party data exposure when you use android which is pretty much spyware on its own :P
JimmyNyholm
Tue Jan 30, 2018 12:44 am
Android is a virus :lol:
LucZWFM
Tue Jan 30, 2018 10:09 am
I am sorry to say, but I really do not like the Tikapp at all... It would be much nicer to have something that looks much more like winbox available for Android and iOS.
jimmyz
Sat Feb 03, 2018 3:21 pm
Hello, a direct link to the apk would be nice. (Not everyone has an account to Gplay).
Or maybe a public folder with directory listing of current and all previous versions!
Thank you :D
LShadow77
Sat Feb 03, 2018 10:31 pm
Hello! When will you develop the btest versions for android and linux? My Internet service provider has its own btest server for reliable measurement of speed it provides. I often use this in my job but i'm forced to run btest on the windows lap-top only. However, it would be desirable to use my android device for this measurement purpose. Also it would be pretty desirable to run the btest's server and client on routers under OpenWRT operation system which is kind of linux. Whether there will be it sometime? I hope for answer, thank you and sorry for my bad english.
ErfanDL
Sat Feb 03, 2018 10:36 pm
Please add dark theme
jimmyz
Wed Feb 21, 2018 12:48 pm
Someone please point me a place for a genuine latest version.
Chupaka
Wed Feb 21, 2018 1:56 pm
Here is it: https://play.google.com/apps/testing/co ... oid.tikapp
normis
Wed Feb 21, 2018 1:57 pm
Current Tikapp is basically a Winbox copy. What else did you expect?
Chupaka
Wed Feb 21, 2018 2:09 pm
By the way, I cannot find current wifi interface frequency - it's on Status page of WinBox, and in TikApp, there's no 'Channel' line in Status tab.
katem07
Wed Feb 21, 2018 2:23 pm
I'm using it for monitoring only , not for control
But new to me to know that Tik App is an official app and supported by Mikrotik
Tnxs Mr.Normis you did nice.
normis
Wed Feb 21, 2018 4:08 pm
how about
wlan1 > Wireless > Frequency
and also the Channel info in the Status tab
Chupaka
Wed Feb 21, 2018 6:49 pm
It's "auto"
as I said,
:( Only Last Linu Up/Down Time and Link Downs
yhfung
Wed May 09, 2018 10:41 am
When I attented the MUM Japan 2018 yesterday via YouTube, one of your colleague mentioned that iOS Tik App is coming. Please advise when will the iOS one be available for use?
docmarius
Wed May 09, 2018 7:52 pm
...Please advise when will the iOS one be available for use?
You mean the Apple or the Cisco IOS?
msatter
Wed May 09, 2018 7:55 pm
Cisco sucks in making tablets. ;-)
mica
Sat May 26, 2018 5:30 am
+1 need tik app for ios devices
TheDon
Mon May 28, 2018 7:41 pm
...and PLUS Another!
I've tried to use the web interface from an iPhone - and it is not great.
In a day and age of mobility and 'do it on your phone', iOS app would be welcomed!
skept2it
Wed May 30, 2018 12:13 pm
Hi
I like the android app (on phone and tablet), specially now with the color support for queues.
Possible improvements:
- Would be great if you could select your own "favorites" and add to home screen from what you want to look at quickly (like "queue tree" for example).
Or like sub pages from IP / firewall etc.
- Also on the first screen (CPU load etc.) show directly last critical issue the system logged ?
Would allow to be faster/more productive with the app
msatter
Thu Jun 07, 2018 12:17 pm
Thanks for the update to 0.68 and the TikAPP does now work again with the secure login.
ronniee
Mon Jun 18, 2018 2:14 pm
any news about IOS version?
shahbazian
Trainer
Trainer
Sun Jun 24, 2018 4:32 pm
TikApp stable version when?
Sent from my SM-G950F using Tapatalk
Chupaka
Mon Jun 25, 2018 11:35 am
Well, current version is quite stable. If it's unstable for you - please write to support@mikrotik.com with detailed description of your problem.
shahbazian
Trainer
Trainer
Mon Jun 25, 2018 12:40 pm
There is no problem.
Just for google play store issue.
Chupaka
Mon Jun 25, 2018 12:52 pm
What issue? You just need to click a button once :)
pietroscherer
Trainer
Trainer
Mon Jun 25, 2018 2:02 pm
+1 :D
jebz
Tue Jun 26, 2018 2:38 am
I like these suggested features. :-)
ronniee
Tue Jun 26, 2018 7:19 am
+1 :D
and also a dude client for IOS/ipad ?
thebiggboss78
Sat Aug 25, 2018 11:35 am
+1 :D
Any updates on that iOS version? Official Tik-app for iPad would be a lifesaver!!
antispam
Thu Sep 06, 2018 11:49 am
some leaked photos of iOS version.
https://twitter.com/mikrotik_com/status ... 6277917696
Could this design be on android also?
https://imgur.com/a/xOQIUEa
Chupaka
Thu Sep 06, 2018 11:53 am
And 6.43 version :)
Samar
Sat Sep 15, 2018 2:39 pm
Sveiki Normis.
Publicējiet caur "apple test flight"?
Hi Normis.
Publish on Apple TestFlight?
TikApp for iOS
ronniee
Tue Sep 18, 2018 10:24 am
alpha beta test option, for TikApp on IOS?
come on
antispam
Fri Sep 28, 2018 11:02 pm
Your prayers have been answered https://testflight.apple.com/join/wGEkmFU9
Sweet sound of routing
Samar
Sat Sep 29, 2018 2:03 pm
It’s exelent! Thank you!
vortex
Tue Oct 02, 2018 6:08 pm
I need the latest apk.
raffav
Fri Oct 05, 2018 7:46 pm
On IPad air 1 iOS 12 it crash when I open some mk device (all is using beta ros version)
Sent from my XT1580 using Tapatalk
raffav
Sat Oct 06, 2018 4:41 pm
Maybe is time to create a iOS thread
Also like the new page quick viewer
Hope to see this on android version too
nabilx
Sun Oct 14, 2018 3:33 am
When this awesome Main menu will come to the android version?
rushlife
Wed Oct 17, 2018 1:18 pm
I will be very disappointed if version for Apple iOS will be better then version for Android. I am a "little bit" for linux like (based) devices, not for Apple proprietary sh*ts.
normis
Wed Oct 17, 2018 2:42 pm
Funny conflict in your sentence :D You like it, but you don't want it.
nescafe2002
Forum Veteran
Forum Veteran
Wed Oct 17, 2018 5:46 pm
Yeah, please stop development for iOS immediately because one user dislikes Apple..
saper2
Sun Oct 21, 2018 4:42 pm
Sorry but it's already 2 users, I don't like bitten-apple too :D
DummyPLUG
Sun Oct 21, 2018 7:55 pm
Make it 3, an Apple a day scare admin away.
filipelias
Tue Oct 30, 2018 1:18 am
Hi, I like the design overhaul a lot. I've noticed a few bugs. On the main screen after logging in, the app is prompting me to update to the latest version, but I have already the latest version. Here are a few screenshots:
raffav
Tue Oct 30, 2018 2:02 am
@filipelias Your Firmware(BootLOADER) need an update, not software(RouterOS)
I committed the same "bug" as you
Chupaka
Tue Oct 30, 2018 6:25 am
Yeah, the same confusion :) It took me a dozen minutes to understand that it's not about RouterOS itself
P.S. In Advanced Settings, every submenu has duplicated items for me:
nescafe2002
Forum Veteran
Forum Veteran
Tue Oct 30, 2018 6:28 am
Comes with the phone. You also have double battery indicators and alarm clocks :)
erebusodora
Tue Oct 30, 2018 9:18 am
Still no fixed :( on version 0.0.38
With new version bug is fixed. New version is NICE ;) Very NICE
Chupaka
Tue Oct 30, 2018 9:28 am
Is it only me, or CAPsMAN is completely missing in new app?..
ognjen
Tue Oct 30, 2018 5:08 pm
I have CAPsMAN menu in TikApp, look below
Now version of TikApp is soooo good, ty mikrotik developers :)
Simono
Tue Oct 30, 2018 5:35 pm
New version could save settings topic display etc if I enable it.
Wysłane z mojego TA-1021 przy użyciu Tapatalka
Chupaka
Tue Oct 30, 2018 7:05 pm
Thanks, clearing the cache from main screen returned it back. And reordered all the rest menu items :)
msatter
Tue Oct 30, 2018 7:28 pm
WOW....I am speechless, good that I can still type. :wink:
Looks great and blistering fast. For the firstime I could see the Addresslist in Firewall. It timed out but still I could see addresses.
Now don't have to start the computer to use Winbox and now I trust myself to do stuff from the tablet.
Many THANKS!!
pacmanfan
Wed Oct 31, 2018 4:49 pm
In the new iOS app I have some trouble with PPPoE.
1) In PPP Interface, if I select a dynamic PPPoE interface the interface stats never load and the Winbox connection complete stops working. I have to task kill and restart iOS Winbox to do anything else on the router, but I consistently cannot get dynamic PPPoE interfaces to load. See:
2) Editing PPP Secrets, the Winbox connection sometimes locks up when loading the secret's data. This is inconsistent, and I can't reproduce this morning, so maybe was fixed in 0.20? Will update this if I notice more.
3) Option to remove items in PPP Active Connections is missing, like we have on desktop Winbox.
ErfanDL
Wed Oct 31, 2018 8:34 pm
Fix the master password bug
ErfanDL
Thu Nov 01, 2018 10:29 am
please add the TX rate and RX rate in hotspot active menu
chm0d755
Thu Nov 01, 2018 1:16 pm
The application sometimes crashes when opening IP --> ARP when there are around 2000 static arp records. May be crashes in other long list of records (queues, firewall rules...)
For example, you can make the app to load parts arp records while scrolling down, but searching to work the entire list.
Can the main menus in android app be sorted as in winbox? :)
Thanks.
victorsoares
Mon Dec 03, 2018 2:30 pm
Hi, I just bought a new phone with the android one thing, a Xiaomi MI A2 Lite, running android 8.1.0, on my last phone the app was working great, but on this one I'm able to log in to any equipment except CCR's. It gets stuck on "Downloading plugins" and if I check the log it says that I successfully logged in and then logged out from tik app. Anyone else having this problem? I already tried clearing the cache and reinstalling the app, also checked all the permissions and allowed unrestricted access to internet on the app. Tried it from my home network and from LTE.
ivicask
Mon Dec 03, 2018 3:00 pm
I wonder is i possible to add some kinda of bandwidth test into this app?So i can quickly test actual wifi performance from router to my phone directly, it would be the most useful thing ever.
nemoforum
Wed Jan 16, 2019 11:08 pm
Mikrotik App (latest from Play Store, clean install) force close right after start on OnePlus 6T (latest stable firmware).
nemoforum
Thu Jan 17, 2019 11:48 pm
OnePlus 6T, Mikrotik App (latest)
Force close right after start:
01-17 23:13:39.415   906  2950 I ActivityManager: START u0 {act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 cmp=com.mikrotik.android.tikapp/.activities.MainActivity bnds=[844,1106][1048,1443]} from uid 10008 pid 3160
01-17 23:13:39.415   906  2950 D OneplusAppPreload: com.mikrotik.android.tikapp is not preload, feed it  in ActivityStarter
01-17 23:13:39.419   743   743 E ANDR-IOP: IOP HAL: Received pkg_name = com.mikrotik.android.tikapp pid = -1
01-17 23:13:39.420   906  1428 E OnePlusSmartBoostManager: cmd: iop_start -1 com.mikrotik.android.tikapp /data/app/com.mikrotik.android.tikapp-t9-lRKlMiU5bURpDuPFaqQ== false length = 109
01-17 23:13:39.421   963 16728 E ANDR-RAMBOOST_SERVER: ramboost cmd_len = 109 cmd: iop_start -1 com.mikrotik.android.tikapp /data/app/com.mikrotik.android.tikapp-t9-lRKlMiU5bURpDuPFaqQ== false
01-17 23:13:39.428   906  2950 D ActivityTrigger: activityStartTrigger: Activity is Triggerred in full screen ApplicationInfo{92350bc com.mikrotik.android.tikapp}
01-17 23:13:39.428   906  2950 E ActivityTrigger: activityStartTrigger: not whiteListedcom.mikrotik.android.tikapp/com.mikrotik.android.tikapp.activities.MainActivity/95
01-17 23:13:39.429   906  2950 D ActivityTrigger: activityResumeTrigger: The activity in ApplicationInfo{92350bc com.mikrotik.android.tikapp} is now in focus and seems to be in full-screen mode
01-17 23:13:39.429   906  2950 E ActivityTrigger: activityResumeTrigger: not whiteListedcom.mikrotik.android.tikapp/com.mikrotik.android.tikapp.activities.MainActivity/95
01-17 23:13:39.433  3160  3160 D Stats   : Intent.getPackage() is null. therefore try to get package name from componentName.getPackageName(): com.mikrotik.android.tikapp
01-17 23:13:39.435   906  2950 D ActivityTrigger: activityResumeTrigger: The activity in ApplicationInfo{92350bc com.mikrotik.android.tikapp} is now in focus and seems to be in full-screen mode
01-17 23:13:39.435   906  2950 E ActivityTrigger: activityResumeTrigger: not whiteListedcom.mikrotik.android.tikapp/com.mikrotik.android.tikapp.activities.MainActivity/95
01-17 23:13:39.435   906  1027 D RestartProcessManager: Update Total Launch Times :com.mikrotik.android.tikapp
01-17 23:13:39.435   906  1027 D RestartProcessManager: updateSelf :  com.mikrotik.android.tikapp, size : 30
01-17 23:13:39.435   906  1027 D RestartProcessManager: Increase Total Launch Time : com.mikrotik.android.tikapp, times : 1, index : 29
01-17 23:13:39.435   906  1027 D RestartProcessManager: Last Running Package : com.mikrotik.android.tikapp , start time 1547759619435
01-17 23:13:39.452  3160  4384 D GridItemProvider: saveToolBoxItemsToPreference: jsonStr= [{"id":0,"intent":{"mAction":"android.intent.action.MAIN","mCategories":["android.intent.category.LAUNCHER"],"mComponent":{"mClass":"com.mikrotik.android.tikapp.activities.MainActivity","mPackage":"com.mikrotik.android.tikapp"},"mContentUserHint":-2,"mFlags":270532608,"mPackage":"com.mikrotik.android.tikapp"},"itemType":0,"launchCount":24,"restored":0,"serialNumber":0},{"id":0,"intent":{"mAction":"android.intent.action.MAIN","mCategories":["android.intent.category.LAUNCHER"],"mComponent":{"mClass":"com.android.vending.AssetBrowserActivity","mPackage":"com.android.vending"},"mContentUserHint":-2,"mFlags":270532608,"mPackage":"com.android.vending"},"itemType":0,"launchCount":61,"restored":0,"serialNumber":0},{"id":0,"intent":{"mAction":"android.intent.action.MAIN","mCategories":["android.intent.category.LAUNCHER"],"mComponent":{"mClass":"com.android.settings.Settings","mPackage":"com.android.settings"},"mContentUserHint":-2,"mFlags":270532608,"mPackage":"com.android.settings"},"itemType":0,"launchCount":232,"restored":0,"serialNumber":0},{"id":0,"intent":{"mAction":"android.intent.action.MAIN","mCategories":["android.intent.category.LAUNCHER"],"mComponent":{"mClass":"org.thunderdog.challegram.MainActivity","mPackage":"org.thunderdog.challegram"},"mContentUserHint":-2,"mFlags":270532608,"mPackage":"org.thunderdog.challegram"},"itemType":0,"launchCount":34,"restored":4,"serialNumber":0},{"id":0,"intent":{"mAction":"android.intent.action.MAIN","mCategories":["android.intent.category.LAUNCHER"],"mComponent":{"mClass":"com.whatsapp.Main","mPackage":"com.whatsapp"},"mContentUserHint":-2,"mFlags":270532608,"mPackage":"com.whatsapp"},"itemType":0,"launchCount":239,"restored":4,"serialNumber":0},{"id":0,"intent":{"mAction":"android.intent.action.MAIN","mCategories":["android.intent.category.LAUNCHER"],"mComponent":{"mClass":"com.google.android.maps.MapsActivity","mPackage":"com.google.android.apps.maps"},"mContentUserHint":-2,"mFlags":270532608,"mPackage":"com.google.android.apps.maps"},"itemType":0,"launchCount":69,"restored":4,"serialNumber":0},{"id":0,"intent":{"mAction":"android.intent.action.MAIN","mCategories":["android.intent.category.LAUNCHER"],"mComponent":{"mClass":"com.joaomgcd.autoapps.ActivityLaunchApp","mPackage":"com.joaomgcd.autolocation"},"mContentUserHint":-2,"mFlags":270532608,"mPackage":"com.joaomgcd.autolocation"},"itemType":0,"launchCount":15,"restored":0,"serialNumber":0},{"id":0,"intent":{"mAction":"android.intent.action.MAIN","mCategories":["android.intent.category.LAUNCHER"],"mComponent":{"mClass":"com.ring.launch.LaunchActivity","mPackage":"com.ring.future"},"mContentUserHint":-2,"mFlags":270532608,"mPackage":"com.ring.future"},"itemType":0,"launchCount":113,"restored":0,"serialNumber":0},{"id":0,"intent":{"mAction":"android.intent.action.MAIN","mCategories":["android.intent.category.LAUNCHER"],"mComponent":{"mClass":"com.ftband.app.StartActivity.Mono","mPackage":"com.ftband.mono"},"mContentUserHint":-2,"mFlags":270532608,"mPackage":"com.ftband.mono"},"itemType":0,"launchCount":39,"restored":0,"serialNumber":0},{"id":0,"intent":{"mAction":"android.intent.action.MAIN","mCategories":["android.intent.category.LAUNCHER"],"mComponent":{"mClass":"com.google.android.apps.photos.home.HomeActivity","mPackage":"com.google.android.apps.photos"},"mContentUserHint":-2,"mFlags":270532608,"mPackage":"com.google.android.apps.photos"},"itemType":0,"launchCount":212,"restored":0,"serialNumber":0},{"id":0,"intent":{"mAction":"android.intent.action.MAIN","mCategories":["android.intent.category.LAUNCHER"],"mComponent":{"mClass":"com.android.camera.CameraLauncher","mPackage":"com.google.android.GoogleCamera"},"mContentUserHint":-2,"mFlags":270532608,"mPackage":"com.google.android.GoogleCamera"},"itemType":0,"launchCount":43,"restored":0,"serialNumber":0},{"id":0,"intent":{"mAction":"android.intent.action.MAIN","mCategories":["android.intent.category.LAUNCHER"],"mComponent":{"mClass":"com.vrem.wifianalyzer.SplashActivity","mPackage":"com.vrem.
01-17 23:13:39.453   906  1052 I ActivityManager: Start proc 16729:com.mikrotik.android.tikapp/u0a131 for activity com.mikrotik.android.tikapp/.activities.MainActivity
01-17 23:13:39.467   906  2950 D OnePlusSmartBoostManager: writeHotCount com.mikrotik.android.tikapp, pid=16729
01-17 23:13:39.475   906  2950 D OneplusAppPreload: com.mikrotik.android.tikapp is not preload, collectAppFocusEvent
01-17 23:13:39.523 16729 16747 I FA      :   adb shell setprop debug.firebase.analytics.app com.mikrotik.android.tikapp
01-17 23:13:39.556   906  1027 D RestartProcessManager: Duration is too short, ignore : 119 in com.mikrotik.android.tikapp
01-17 23:13:39.584 16729 16729 E AndroidRuntime: Process: com.mikrotik.android.tikapp, PID: 16729
01-17 23:13:39.584 16729 16729 E AndroidRuntime: java.lang.RuntimeException: Unable to start activity ComponentInfo{com.mikrotik.android.tikapp/com.mikrotik.android.tikapp.activities.MainActivity}: android.view.InflateException: Binary XML file line #27: Binary XML file line #27: Error inflating class ImageView
01-17 23:13:39.584 16729 16729 E AndroidRuntime: 	at com.mikrotik.android.tikapp.activities.MainActivity.onCreate(MainActivity.java:193)
01-17 23:13:40.055   906  1027 W ActivityManager: Activity pause timeout for ActivityRecord{2c4e819 u0 com.mikrotik.android.tikapp/.activities.MainActivity t2784 f}
01-17 23:13:43.586 16729 16729 E AndroidRuntime: Process: com.mikrotik.android.tikapp, PID: 16729
01-17 23:13:43.586 16729 16729 E AndroidRuntime: java.lang.RuntimeException: Unable to start activity ComponentInfo{com.mikrotik.android.tikapp/com.mikrotik.android.tikapp.activities.MainActivity}: android.view.InflateException: Binary XML file line #27: Binary XML file line #27: Error inflating class ImageView
01-17 23:13:43.586 16729 16729 E AndroidRuntime: 	at com.mikrotik.android.tikapp.activities.MainActivity.onCreate(MainActivity.java:193)
01-17 23:13:43.599   906  2951 D AbnormalMonitor: appCrash :com.mikrotik.android.tikapp
01-17 23:13:43.657   906  3389 I ActivityManager: Process com.mikrotik.android.tikapp (pid 16729) has died: cch  CRE
01-17 23:13:43.664   772  2127 W SurfaceFlinger: Attempting to destroy on removed layer: AppWindowToken{c1052bf token=Token{8e4a0de ActivityRecord{2c4e819 u0 com.mikrotik.android.tikapp/.activities.MainActivity t2784}}}#0
MDE
Thu Jan 31, 2019 3:12 pm
What bugfixes came with the update 31 Jan 2019
Sent from my VTR-L29 using Tapatalk
msatter
Thu Jan 31, 2019 11:24 pm
Looks realy good and the addresslists works now and the APP does not crash anymore on reading the lists.
jimmyz
Fri Feb 01, 2019 9:39 am
v1.1.1
• Bug fixes
v1.1.0
• Added database unlock using fingerprint/biometrics (password needs to be updated)
• Added groups for managed devices
• Added item list sorting and filtering
• Added System -> Licence import/export
• Allow to reset managed devices if forgot password
• Show overview for Ping and Torch
• Load item lists faster
• Fixed device discovery issues for Android P
It looks OK on a Huawei P10 plus pie
Chupaka
Fri Feb 01, 2019 10:33 am
Should read as "allow to reset the list of managed devices, not devices themself" :)
JT1231
Sat Feb 02, 2019 1:09 am
Sorry if this question has been asked I just created my account today, I was wondering if there was a way for the Mikrotik app to discover a router via ethernet as I am using the app on a chromebook with an adapter. I was also wondering if there was a way to refresh the discover page as I normally don't find any devices show up but I can login to them manually with an IP/username.
florid
Fri Feb 08, 2019 1:34 am
Is it possible to increase the request timeout limit?
I use this app to connect to a remote router in different country. It always disconnected with timeout message when pulling 'big' data such as view Log / Address list etc.
shujanster
Wed Feb 20, 2019 2:51 am
Version 1.1.2 bug report
1. PPPoE server interface unknown.
2. Routes reachable null.
3. BGP peers not showing.
4. Logging rules null.
5. Log topics: null null.ImageImageImageImageImage
Sent from my Redmi Note 5 using Tapatalk
normis
Wed Feb 20, 2019 9:19 am
Thanks, we have fixed these issues.
mikelaurense
Sun Feb 24, 2019 2:03 pm
When updating the router via the iOS app, it hangs at 99% (probably because the router is rebooted). After a while it returns to the login screen, but there is no way to cancel this dialog
omb
Mon Feb 25, 2019 2:24 pm
Yes, I'm facing the same issue asi you are. Stuck at "Downloading plugins" and in the MTik log is shown "user admin has logged in from %IP% via tikapp" and after few second "... logged out..."
I've tried to add a simple FW input rule form my MAC but without success, neither over LAN nor WAN (LTE).
Does anyone succesfully resolve this issue?
omb
Thu Mar 07, 2019 8:42 am
UPDATE: The strange thing is, that with the same phone and same Tik App I'm able to connect to my newly bought and configured RB951G-2HnD. So it looks like there is einther some missconfiguration or incompatibility between RB750Gr3 and Tik App. I tried second RB750Gr3 and get stuck at the same point "Downloading plugins", so it looks like that it would be some incompatibility than misconfiguration.
Both RB750Gr3 are running version RouterOS 6.42.6, RB951G-2HnD is running 6.43.12
omb
Thu Mar 07, 2019 9:02 am
UPDATE2:
I'M REALLY DUMB!
Dealing with problem that has been resolved. I have just one advise for all in here - KEEP YOUR DEVICE UP TO DATE!
Upgrading RB to latest version and problem resolved...
ronniee
Tue Mar 19, 2019 12:11 pm
The first intro screen after login "New software available" has been removed (iOS version 1.0.1)? Why? It was easy to upgrade with 1 click.
Now I don't find, or isn't easy to tell customers how to upgrade there router with this app.
Setting-> System -> Packages -> Check for upgrade here the new version not show for ex I have 6.43.x doesnt show for me 6.44.1.
this is a bug?
what is the easyest way to upgrade a router?
normis
Tue Mar 19, 2019 12:56 pm
It's still there on main screen. Are you in the correct upgrade channel? Maybe there is no new version
r00t
Long time Member
Long time Member
Tue Mar 19, 2019 3:34 pm
Please make initial screen after connect (dashboard?) configurable. I can't care less about kid control or internet detect, these are just taking space.
Instead, having last 10 log entries, graph of traffic on selected interfaces, list of registered wifi clients, or DHCP clients... or simply shortcuts for some other pages would be far more useful.
I know Tik App is aimed at SOHO users to configure routers without PC, but a bit of customization would make even better.
anav
Tue Mar 19, 2019 3:46 pm
Where can we find the latest version of the app, or more accurately how do we know if we have the latest version of the app installed.
Perhaps on your MT download page you can have an information entry?
Perhaps another blue square next to WINBOX - THEDUDE - NETINSTALL - MT APP -
The pull down for this blue box would simply show two entries plus the circular LOGO with red markings) so that we get used to it.
a. IOS Version 0.24 ?? (+Changelog history Link)
b. Android Version x.xx ?? ((+Changelog history Link)
Looking for an update myself, via google search I found these imposters and perhaps an education piece to NOT use them (not official or recommended).
https://tiktool-mobile-winbox-ios.soft112.com/
https://itunes.apple.com/us/app/iwinbox ... 81490?mt=8
msatter
Tue Mar 19, 2019 4:59 pm
Chupaka
Tue Mar 19, 2019 5:14 pm
BTW, I found that enabling Internet detect shows graphs of your WAN interfaces =)
anav
Tue Mar 19, 2019 6:32 pm
ARE YOU DEAF??
My post has nothing to do with getting the APP. It has everything to do with making sure the APP is up to date and informing MT users which is the latest app version.
For example my APP was on version 0.24. I was fat dumb and happy. NO INDICATIONS were provided UNLIKE other apps, that my app was out of date or that updates were available.
Just for giggles today I went to the APP store and saw the APP. Didnt see any version number but downloaded it again just for shits and giggles. I was UNPLEASANTLY surprised that he version went to 1.0.1.
Thus two things come to the fore.
a. the APP is not auto-updating or at least not informing users that there is an update available (which all my other apps do).
b. there is no visible means for me to know what is the latest app version available and probably should be using.
msatter
Tue Mar 19, 2019 7:08 pm
I AM NOT DEAF I ONLY CAN'T READ.
anav
Tue Mar 19, 2019 7:23 pm
Ahh, that explains it. I wasn't using deaf in the literal sense but in the context of not paying attention. Although I don't know why I am explaining this in text as you cannot read.
Perhaps I should yell very loudly into the air and you may hear me. ;-)
r00t
Long time Member
Long time Member
Tue Mar 19, 2019 7:52 pm
I would rather not have to join the botnet just for the privilege of seeing interface graphs...
Chupaka
Wed Mar 20, 2019 12:24 am
If you don't want to join botnet, remove this app from your phone :lol:
normis
Wed Mar 20, 2019 8:48 am
Have you used a smartphone before? The mechanism is identical to any other app on your phone. Make sure Google Play or AppStore (depends on your phone model) is checking for software updates. If you need assistance, you can always ask a younger family member.
anav
Wed Mar 20, 2019 10:25 am
Too funny, that is exactly how I get most of my 'how to use my phone' information!! Stay tuned.
msatter
Wed Mar 20, 2019 12:17 pm
The app is still in the Beta channel (Play Store) and it will appear in list of updated apps each time when being updated. I don't auto-update for security reasons.
On the page of the app the version number is being displayed.
v1.1.5
• Show if wireless interface is managed by CAPsMAN
• Added "Limited Access" tag to internet detect
• Show remove config option after config is reset
• Bring ordered by field value to top of item cell
Update: not in the Beta channel anymore and if you are on Beta, install again after leaving the Beta channel in the Play Store.
normis
Wed Mar 20, 2019 12:36 pm
Neither of the two apps are in Beta anymore. Delete them, and install them again from the regular stores, if you still see the beta.
raffav
Wed Mar 20, 2019 12:46 pm
@normis
On the last MUM in the introduction by MT was told that you want to add some functionality that exists on the mobile app in the Winbox that mean that winbox will rebuild?
Features request: please add the search also in the iOS app
also please add the ability to sort them on both apps
normis
Wed Mar 20, 2019 1:02 pm
No, the reverse. Winbox is not getting features, mobile apps are getting features.
Yes, saved device search and sorting is coming to iOS too.
msatter
Wed Mar 20, 2019 1:07 pm
I uninstalled the APP and installed it again but is still stating beta on the APP page and shows up in my beta list in the Play Store.
Got it. I have first to leave the Beta for this APP.
So unstalling is not working and first you have Leave Beta.
krisjanisj
Wed Mar 20, 2019 1:15 pm
As @msatter already mentioned - steps to move to Public release channel for Android App:
1) In MikroTik PlayStore page You need to leave BETA
Before:
After:
2) Uninstall BETA app
3) Install the app again, now it should use the public version of app.
anav
Wed Mar 20, 2019 5:17 pm
Hate to burst your bubble, but since I know you are fallible... ;-P
I checked with my younger 'experts' and my settings and use of the Iphone were correct. Automated updates is selected.
I am repeating myself, but apps that have updates ready do show up when I select the App Store and I simply have to select udpate per app or update all. This has worked well for sometime. That is why when I was sitting at 0.24, with no updates being presented as an option, I assumed I was good to go. Then I checked the MT website for downloads where ALL other firmwares are communicated and noted there was no banner or any positive communication to let us know what versions were current and any changelog history. Sorry if have expectations of some sorta standard approach to config management LOL. Much thanks to a poster who noted that the version is available on the APP itself when searching on the APP store. It is not readily visible, one has to click on the APP selection to get the more detailed info (something I rarely do, just download and go). This info should be mirrored/available on the website is my recommendation. Which I sadly have to make,.......
What would have been the proper response is......
Great Phukin Idea Mate. I will get that up on our website tomorrow,,,,,,, errr make that in one week we are having serious forum website issues at the moment which are taking up our non-coder monkeys time. I didnt mean that literally, although sometimes I do have the urge to send you bananas. :-)
normis
Thu Mar 21, 2019 8:58 am
Well the above posters already gave a hint. You have joined a private beta program and installed that invite-only version. You should delete it, delete the "TestFlight" app which manages the Beta programs, and then install the application that is meant for everyone (the one in the AppStore).
nostromog
Thu Mar 21, 2019 10:32 am
Probably it is different for Android, but I have not left the beta and I'm on 1.1.5.
I will eventually leave the beta, but I'm traveling with bad connectivity, and the threat to lose all my settings was enough to stop me holding the button
krisjanisj
Thu Mar 21, 2019 10:51 am
What @normis mentioned was for IOS devices. See either mine or @msatter posts above with explanation for Android
anav
Thu Apr 04, 2019 7:28 pm
Just wanted to chime in that the APP is working great ---> Router accessed remotely via IKEv2 connection to get to the router and then access APP once internal to the router.
nostromog
Fri Apr 05, 2019 2:05 am
Fully agreed, last versions are good!
One nit: I have a mAL Lite as Travel Router, and it has the main wireless interface in station mode (I called it sta1). The app shows it as "sta1. Connected to _______"
It uses /interface wireless get sta1 ssid , instead of ([/interface wireless monitor sta1 as-value once ]->"ssid") which is the real connected ssid. In my case, as I use a connect-list. It actually offers me to enter ssid and password if I click on it, but it does not work because of the connect list itself...
Fraction
Tue Apr 09, 2019 5:35 pm
Any plans to add support for RoMON-connections?
Chupaka
Tue Apr 09, 2019 5:50 pm
Probably we should rename this topic so that it doesn't contain "alpha" anymore... Or start a new one and make it sticky in Announcements :)
sterod
Sun Apr 21, 2019 5:03 pm
Can you please add the option to sort the list of Saved devices by their Note
I have over a hundred devices in this list and without sorting its very difficult to find a particular host. I realize the search magnifying glass button is there, but I would prefer an ordered list to begin with.
Thank You
Sent from my Pixel 3 using Tapatalk
ursulab
Fri May 10, 2019 2:21 pm
Is there a way to restrict which menus a user can see like with webfig skins? I don't want a basic user that only needs to change their wifi ssid and password or access the Kid Control to go digging around all the other menus. With webfig it sort of works that a regular user can't see the menu items (although it can still be accessed if they know how), but with the mobile app it's all right there.
If the mobile app just uses the skin as presented by webfig it would be awesome! :D
Ayaz
Re: Tik App, MikroTik android utility ALPHA test
Wed May 22, 2019 3:52 pm
Hi, Dear all
Is this app uses secure connection to access a routeros device?
vortex
Sat May 25, 2019 5:41 pm
When will you put the app on another store?
Chupaka
Sun May 26, 2019 1:08 am
What store?
raffav
Mon May 27, 2019 4:15 pm
What store?
like store outside google and apple, just the APK
Maybe huawei smartphone detected :mrgreen: :mrgreen: :lol:
AzAel76
Tue May 28, 2019 1:14 am
The recent release 1.2.2 is a Massive improvement in functionality. Well done all. I have used it a couple of times already since the update and it is working very well.
yacsap
Tue May 28, 2019 2:49 am
What store?
Or maybe they got it from Hong Meng Play Store :mrgreen: :lol: :mrgreen:
vortex
Wed May 29, 2019 8:59 pm
What store?
Like Amazon or Aptoide.
vitaly2016
Mon Jun 24, 2019 1:09 pm
How to manage more then 1 device in this application?
"SAVED" tab reports "No devices saved" and there is no option to save current connection.
Dotted menu "Import devices"/"Export devices" doesn't seem to work.
Chupaka
Mon Jun 24, 2019 1:15 pm
There are two big buttons next to each other: "SAVE" and "CONNECT"
vitaly2016
Mon Jun 24, 2019 1:45 pm
Thank you. I really wonder how can I miss this really big button "SAVE".
myke1124
Mon Jul 22, 2019 7:23 pm
"Kid Control" in the apple app is missing.
JanezFord
Tue Jul 23, 2019 11:53 am
With latest update in IOS 1.0.10 I cant't connect anymore: invalid username/password for every device. Anyone else experiencing this?
JF.
normis
Tue Jul 23, 2019 11:56 am
Upgrade your RouterOS too, the authentication process is different in new versions
jimmyz
Tue Jul 23, 2019 1:40 pm
Oh, please do. Not everyone has (or wants to have) a playstore account.
normis
Tue Jul 23, 2019 1:49 pm
You can't have the cake and eat it
P.S.: or ... Και την πίτα ολόκληρη και τον σκύλο χορτάτο
nescafe2002
Forum Veteran
Forum Veteran
Tue Jul 23, 2019 2:06 pm
JanezFord: Update your app to version 1.0.11 if you cannot connect to ROS >= 6.45:
1.0.11 Jul 23, 2019
- Login: Fixed connection issue for RouterOS 6.45
JanezFord
Tue Jul 23, 2019 4:12 pm
1.0.11 Jul 23, 2019
It works! Todays update to 1.0.11 fixes the problem.
JF
JanezFord
Tue Jul 23, 2019 4:15 pm
I am running 6.45.1 ... I do not dare to upgrade to 6.45.2 due to SPF+ problems on 4011. I use SPF+ port for WAN.
It works OK now with todays release of Mikrotik IOS app 1.0.11. 1.0.10 was the problem.
JF.
sibi1979
Thu Jul 25, 2019 11:51 am
IOS app v1.0.11 :
1. Kid Control is currently still missing in the IOS app v1.0.11. It is not possible to add it to the main screen. When will it be implemented ?
2. When going to "IP - Kid Control - Kids" & add a new kid - apply config, the app crashes.
3. Upgrading the caps is not working (all configured through capsman)
How can I restrict the features in the Mikrotik app (Android & IOS) so that the end user can only use the kid control & change SSID / password ?
It would be good to have a separate topic for the Android and IOS app on this forum. Also a tab with an overview of the software versions with related bug fixes.
The mobile app is a very strong feature. it is the only visible point for my customers and a strong selling point.
Thanks a lot !
raffav
Sat Aug 24, 2019 12:21 pm
The new version on android crash when you enter master password
Sent from my Moto Z3 Play using Tapatalk
vortex
Mon Aug 26, 2019 7:34 pm
Antitrust?
normis
Tue Aug 27, 2019 2:12 pm
Ask Apple
krafg
Mon Sep 16, 2019 3:33 pm
Sorry, I not know if this is the correct theard to this, but I'm using the last release (v1.3.2) and I get this (see attached image)
Regards.
normis
Mon Sep 16, 2019 3:56 pm
Looks like legend is missing some text, please report such issues to support@mikrotik.com
What Android are you running, and what routerOS version?
nabilx
Tue Oct 01, 2019 7:26 pm
Hi
I'm intersted in translating the app to arabic language , is there something like that available I will be happy to help.
vortex
Sun Oct 27, 2019 3:40 am
Ask Apple
Why should Apple decide how an Android application is distributed?
MicroW
Re: MikroTik smartphone app (ex Tik-App)
Thu Nov 14, 2019 12:20 pm
The link doesn't seem to be working for me for some reason?
Chupaka
Thu Nov 14, 2019 2:28 pm
I updated the link (the app is out of testing for some time already), but generally you should just search for "MikroTik" in Play Store or Apple Store.
myke1124
Thu Nov 21, 2019 2:02 am
IOS app v1.0.11 :
@normis -> Is this something that was overlooked with iOS ? Is this something we will see in the future?
Chaosphere64
Tue Nov 26, 2019 9:15 am
IOS App v1.0.23
The app does not show the current configuration on wider parts of the CAPsMAN menus. Example Datapath menu: I configured two datapathes, and both are shown here, but the configuration inside is blank from the perspective of the app (no VLAN ID, no CtoC Forwarding etc.). Same settings are shown on Android without a problem.
Etz
Wed Dec 25, 2019 11:59 pm
How do you delete saved device/group from app?
EDIT: Nevermind, noob on IOS, found it. :lol:
thobias
Fri Feb 14, 2020 12:57 pm
Android V1.3.10
Missing some menu items
IP->Firewall->Address Lists: cannot filter by address
Also comment field seems to be missing from most, if not all menus when adding new items
CyB3RMX
Mon Mar 02, 2020 9:50 am
should be nice to have push notifications via the App... and personalize them via scripting in the router.. So you can make your own notifications... Right now i use telegram but would be nice to be able to use this feature as native.
normis
Mon Mar 02, 2020 9:54 am
The app doesn't stay connected to the router when you don't use it, and there is no cloud service in between.
jmba
Mon Mar 02, 2020 11:51 pm
It is possible to create a shortcut in the app main menu for example of a script?
Thank you
ClintStallman
Sat Aug 15, 2020 10:49 pm
UPDATE2:
I'M REALLY DUMB!
I am facing the same issue and it is driving me crazy, the issue is there since 3 routerOs upgrades(stable versions always) and 2 iOS app upgrades
Description: cannot connect to cAP AC via iOS app 1.2.6 and even cannot load the web interface( tested with chrome and safari, same result), loading for long time than timeot.
Some facts:
- the internet and reacheability of crs112 and other devices on wlan and lan is OK from the iphone through the AP
- The app can find the AP in discovered.
- connection is working from laptop and from huawei mobile(web and also android app and winbox)
- RouterOS version - 6.47.1 stable
- rebooted, upgraded today, still no success
- connection from iOS app and web working and always worked to CRS112 with same routerOS
- iphone and huawei connects from same subnet etc. I have no fw rule to block myself , ip services is enabled for winbox, api and everything...
- logs showing the same as above
- I changed the IP for iphone and assigned a static one, different one from same subnet. the web page loaded but cannot log in and than timeout, than opened the app and the connection loaded and authenticated for 2 seconds worked than disconnected...and not worked since this anymore even the load of the web page
please help me to troubleshoot it further, I can collect any logs just send me what would be healpfull, thanks.
I found some info that the power is so low and cannot load the page so I tested it with poe injection not just with poe from the crs, no luck
update: I downloaded an cli app for iOS, tested ping and telnet to the AP and no luck, request timeout.
macsrwe
Wed Feb 10, 2021 2:14 am
How do I associate a saved router with a group? If I do as little as edit the name of a saved router, it gets saved into the "No group" group. I can delete the router entry, but I can't move it up or down, and there's nowhere to specify the group on the page where one adds or edits routers (login).
raffav
Wed Feb 10, 2021 2:20 am
tools> adv mode then you will have group filed where you can add/create a group
macsrwe
Wed Feb 10, 2021 3:07 am
I don't have a "tools." I have a gear, which opens up to Settings, and there is nothing there about either an advanced mode or groups (I had checked it previously for a groups control).
I hate to sound stupid, especially since it's obvious I had this working before. Either my memory is failing or MT did an app update since and lost a feature. I'm running 1.2.8, the current Apple App Store version.
macsrwe
Wed Feb 10, 2021 3:10 am
On another note, my usual practice to test for DNS failure is to go into terminal and type ":put [:resolve some_domain_name]". Since there's no terminal in the app, what do people do instead?
Maybe it would be a good idea for MT to add a "resolve" screen inside the DNS tool, or inside Tools.
raffav
Wed Feb 10, 2021 3:33 am
Lool sorry I did not realised that this is the mobile app sorry my bad [emoji2357]
Chupaka
Wed Feb 10, 2021 12:54 pm
Are you sure there's no?.. At least in Android version we have one.
macsrwe
Wed Feb 10, 2021 1:04 pm
There's no Terminal (or New Terminal) in the top-level menu, and no Telnet in the Tools menu. Maybe it's hidden somewhere else, but it's not where it would be in Winbox.
r00t
Long time Member
Long time Member
Wed Feb 10, 2021 2:57 pm
This is rather annoying, as you can't just use the app to monitor router for a longer time. Yesterday I wanted to watch log output, but App always froze after a minute (just stopped displaying new log entries) and then when I touched the display it disconnected. App was running in the foreground all the time, with screen on. So why not keep connection alive like desktop winbox does? I have to constantly do something with the App otherwise connection timeouts... stupid.
jimmyz
Thu Feb 11, 2021 9:10 am
+1, maybe add a switch for the user to "Stay always connected", on the price of an empty batterty.
mozerd
Forum Veteran
Forum Veteran
Thu Feb 11, 2021 11:32 pm
I just installed the Tikapp for IOS on my iPhone8 and from what I can see it does not have anywhere near the functionality of Winbox ??? in fact the functionality is very limited. What am I missing?
[Edit] My apologies... found the Advanced settings ... Everything I need is there ... if anyone is wondering where they are look for the gear top right corner.
Mikhalich
Mon Feb 15, 2021 1:06 pm
Can we hope for the appearance of Dude functionality in the Mikrotik application? At least the ability to view maps like in Dude app for Windows?
macsrwe
Mon Feb 15, 2021 11:51 pm
If the boys in Latvia are answering questions these days, I'm still waiting for an answer to this one.
Plus another one: I can create new firewall rules in the app, but I can't move them into the proper positions. They won't drag, and I can't find any control anywhere in either the Filters or the Rule panels that lets me type in an absolute numeric position like the CLI has.
macsrwe
Wed Mar 17, 2021 9:22 pm
My MikroTik app seems to have silently grown a new option for "Group" and "Note" in the save dialog box, so that's no longer a lack.
Still can't rearrange my firewall rules, though.
prmfeddema
Sat Mar 20, 2021 3:49 pm
Thanks for all the hard work in the app over there years - but can i make a suggestion: Mikrotik seems to be only one who understand kid control properly and while i have no problem using winbox to do settings, my other half just wants to use the app. That being said: the kid control menu in the app (the one straight from the home screen, not the one through the advanced menu) has some sync problems (adding times to access the internet is not updated when adding a time slot, bandwidth cannot be set and the override time slots are not visible). Is there a way to get this fixed/updated? I wouldn't mind a small donation to get this moving forward.
EvertVB
Sun Jul 04, 2021 1:37 pm
Can you share the process of deleting a Device.
macsrwe
Sun Jul 04, 2021 1:39 pm
In IOS, drag it left.
EvertVB
Mon Jul 05, 2021 3:00 pm
Great that worked - it brings up in Red the Delete option
raffav
Mon Aug 02, 2021 7:20 pm
I suggest you send a email to support directly,
Also just to confirm check user group where admin is and check if they have a full access to system
neogoth
Wed Aug 04, 2021 9:16 am
Let me guess you are using Apple? Apple is not open source at all. Android is completely Open Source (AOSP). So everyone can clearly see that you have no knowledge on that part and only wanna be funny about a wrong thing. Pathetic.
normis
Wed Aug 04, 2021 9:19 am
Let me stop you right there. Please keep on topic. This is not a place for another OS war.
skullzaflare
Fri Aug 06, 2021 5:22 pm
Hey guys i noticed from the newsletter that there are two Mikrotik apps in the gplay store now, "Mikrotik Pro" which is the ugly one i have always used in the past and a "Mikrotik Home"
I do really like the flow and interface in the "Home" version but it appears to not function at all for wifi related things on dual band routers (turns the 5g off and adjusts 2g even though app only lists 5g settings)
Is the Home version going to get more functionality added/fixed?
rextended
Fri Aug 06, 2021 5:31 pm
It's time to add port knocking and cloud checking to this App...
viewtopic.php?f=2&t=177027&p=868541#p868519
viewtopic.php?f=2&t=134538&p=871149#p871149
Reason: There is no need to yell.
anav
Sat Aug 28, 2021 4:44 pm
Yes I want to port knock into my wireguard connection ;-PP
creatin
Mon Sep 27, 2021 1:14 pm
Why isn't there Terminal in IOS version? Are there any other functionalities missing on IOS but can be found on Android?
macsrwe
Mon Sep 27, 2021 1:17 pm
I assume it's because Android has *nix underpinnings/hooks, while iOS doesn't.
microtikgroup
Wed Sep 29, 2021 6:25 am
i used to connect very quickly from my iPhone using the tikapp. but now i am getting "failed to establish secure connection" ? within the same LAN network. is there something I need to change?
Chupaka
Wed Sep 29, 2021 6:21 pm
What has changed between "quickly connect" and "failed to establish a connection"? :)
rextended
Wed Sep 29, 2021 7:20 pm
Someone at Apple decided that he no longer need the app...
microtikgroup
Wed Sep 29, 2021 7:21 pm
nothing
no config changes or anything like that
microtikgroup
Fri Oct 01, 2021 1:24 pm
fixed my problem. deleted the app already!
creatin
Tue Oct 05, 2021 1:00 pm
I'm using a lot of scripts on my MT devices, scripts are ran through Terminal which is not available on IOS.
Not sure why IOS bans use of Terminal in MT app.
macsrwe
Tue Oct 05, 2021 3:23 pm
Scripts can be run by clicking the Run Script button. Scripts can be edited in the app also. You don't "need" terminal to run scripts.
rextended
Tue Oct 05, 2021 3:27 pm
Because Apple has decided, for you, that you don't need the terminal, Apple informs you that you have to comply.
Larsa
Tue Oct 05, 2021 4:06 pm
Please no fud or os-war. Can you provide a reliable source that states ios apps won't allow ssh connections in console like mode?
rextended
Tue Oct 05, 2021 4:26 pm
Don't ask me, I didn't say it, and I don't have those conditioning tools.
macsrwe
Tue Oct 05, 2021 4:35 pm
There is an iOS app named Shelly that allows SSH connections to addresses, but of course I don't know how much of the underlying mechanism they had to provide themselves, because iOS is not built on a Unix base
Larsa
Tue Oct 05, 2021 4:41 pm
IOS is based on BSD "unix"
rextended
No, on XNU "Xnu is Not Unix" / Darwin
Larsa
Tue Oct 05, 2021 4:42 pm
Ok. But fwiw, we've been doing some custom made apps using both ssh and rdp and never heard about bans of terminal or console like connections in ios. Also, there are plenty of similar "console" apps in apple appstore so the issue is likely related to something else.
macsrwe
Tue Oct 05, 2021 4:55 pm
Sorry, I learned something today.
Larsa
Tue Oct 05, 2021 5:00 pm
Well, actually both apple darwin (xnu/macos) and ios are based on bsd. Steve Jobs once issued a competition between two rnd departments responsible for "ipod os" and "mac os". A slimmed down version of mac os won.
https://en.wikipedia.org/wiki/Compariso ... ng_systems
https://en.wikipedia.org/wiki/IOS
jbl42
Tue Oct 05, 2021 5:17 pm
Android is "phoning home" all kind of stuff to Google and every other 3rd party willing to pay Google for data. Not to speak of all the ad-tracking networks it talks to all the time.
And no, Android is not open source. Big parts are, but the relevant data sensitive bits (Google Play Service and similar Google specific system stuff) are closed source. You pay for Android not with money but with your data. Its their business model. Always was.
So yes it is funny to have "serious concerns" about the MT app running on an Android.
But back to MT: A lot of MT devices are used in companies of all sizes. And trust me, we would notice if MT devices would initiate connections to "phone home" or somewhere else. Because the only way to pone home would be using our tightly monitored network infrastructure. MT devices would not last long here if something like this would be discovered. Same applies to most other companies similar to us.
If you do not trust MT, you probably should be using some other brand you trust more.
macsrwe
Tue Oct 05, 2021 5:21 pm
I don't think anyone has a "matter of trust" with MT. We're just puzzled as to why they would put in the work to provide the Terminal menu function in the Android version, but leave it entirely out of the iOS version.
rextended
Tue Oct 05, 2021 6:19 pm
@jbl42 RouterOS "phone home", on default settings, you do not notice that on your tightly monitored network???
jbl42
Tue Oct 05, 2021 9:17 pm
Yes of course we know MTs are phoning home. And yes we know they stop doing it after after we configured them.
And our tight monitoring is nothing special or to be proud of. It's just what is mandated in our highly regulated domain. And all of our competitors do the same. Because they have to. Same as we have to. This was actually my point.
Still not sure what point you where trying to make tough.
rextended
Wed Oct 06, 2021 2:14 am
Simply: on default settings, RouterOS "phone home"
creatin
Fri Oct 08, 2021 3:15 pm
I'm using scripts to provide me some data on the screen, like number of connections, free DHCP addresses, etc.
Running them by pressing Run Script button doesn't display data I usually get on the terminal
macsrwe
Fri Oct 08, 2021 6:32 pm
Whenever I have scripts that need to tell me something, I usually do both a :put and a :log warn, because I can never be sure in what environment they're going to be running. I realize in the app, you can't have both the scripts and the log windows open at the same time like you can in Winbox, so that's a bummer. But in a pinch you can get the information you needed.
anav
Thu Dec 30, 2021 12:09 am
Why can I not access the Capac itself via the IPHONE MT APP and MAC ADDRESS of the virtual WLAN.
It does not show under discovered and I can only connect by using IP address and port.
I have double checked all settings and no joy.
mkx
Thu Dec 30, 2021 9:58 am
Do you have local-forwarding set? Do you have the VAP interface listed as allowed interface under /tool mac-server mac-winbox? Do you have VAP interface mentioned in /ip neighbor discovery-settings?
hecatae
Fri Mar 18, 2022 9:20 pm
If I close the app without logging out of any mikrotik, the warning wrong username+ password crops up.
Chupaka
Thu May 26, 2022 1:56 pm
When I try to edit WireGuard peer to change Allowed Address, it fails: not showing current value and tries to comma-separate empty values on editing.
Also, Tx and Rx values greater than 2G are shown negative.
RouterOS 7.2.3
owsugde
Tue Jun 28, 2022 5:40 pm
With the newest iOS app version (1.2.10) I'm being shown the "Secure your router by setting a password" screen with every login to any device.
And yes, I have in fact set passwords other than "admin".
Chupaka
Wed Jun 29, 2022 2:49 pm
In the recent upgrade (Android, App v1.3.23) editing Wireguard's "Allowed Address" was fixed, but Tx and Rx values for Wireguard peers are still negative if greater than 2G in reality.
Users browsing this forum: akakua, biomesh, DanMos79, DenisPDA, eworm, Google [Bot], irrwitzer, krasikrumov and 68 guests
