normis
Re: Tik App, MikroTik android utility ALPHA test
Mon Jul 13, 2015 4:34 pm
This is not the correct link! Click the FIRST Link!
https://plus.google.com/communities/108 ... 3530666627
geo_stef
Tue Jul 14, 2015 1:21 am
Normis you have to approve us for becoming beta testers?
normis
Tue Jul 14, 2015 8:50 am
When you join the G+ ALPHA tester group, the download link becomes working
ochyst
Tue Jul 14, 2015 11:01 am
Nice, its that whats help me at top of tower :D Nice work
mgisbers
Trainer
Trainer
Tue Jul 14, 2015 2:03 pm
Thanks for letting me join the alpha program. Badly I cannot make much use of that app.
All of my devices running RouterOS are using SSL certificates and I found no way to configure the app to use SSL instead of unencrypted communication.
Is it possible to use SSL or, at least, are there plans to add SSL support in near future?
Regard,
Michael Gisbers
Chupaka
Tue Jul 14, 2015 3:05 pm
SSL in WinBox protocol?.. what do you mean?
gmsmstr
Trainer
Trainer
Tue Jul 14, 2015 9:09 pm
Android lolipop samsug note 3.
1.. When you scroll over in interfaces, to something like traffic, the menu bar does not follow, i.e. you see "General poe sfp" but you are viewing the traffic graph
2. traffi graphi looks good, tx/rx bytes should be translated to mbits etc.
3. opening bgp instance crashes the app
4.. opening queue crashes app
5. saving managed routers, alllows you to save to the same name, i.e. i had 5 of the same name with different credentials.
6.. seams like anything in routing crashes
7.. ip routes, with full table, bad juju, crashes.. starts to display
Getting there guys! keep it up.
Hammy
Forum Veteran
Forum Veteran
Tue Jul 14, 2015 11:08 pm
Is there any other way how to participate on testing without forcing me to agree Google privacy rules? I am not willing to agree with them. Why are you involving third company into relationship between mikrotik and your customers? Please, for example, provide the possibility to download the application from the user account pages on your website. Thank you very much.
Publishing through the Play Store is the correct way of doing it.
normis
Wed Jul 15, 2015 8:24 am
Hammy is right. If you don't want to agree with Google Privacy rules, better stay away from Android.
jarda
Wed Jul 15, 2015 8:51 am
I have nothing against Google play but Google plus is the thing I don't want to sign in.
vortex
Wed Jul 15, 2015 9:29 am
See above. Normis has already published a link to the apk for devices without Google Play.
jarda
Wed Jul 15, 2015 4:46 pm
I know. I used that link. Last post was just an answer to previous post.
grawerpl
Thu Jul 16, 2015 10:46 am
Is there any plane to release this app for windows phone (i hate android so my question can be trivial but still).
normis
Thu Jul 16, 2015 10:54 am
We will consider iOS, but Windows Phone is very unlikely.
travisms
Thu Jul 16, 2015 10:57 am
Nice app!
Crashed when clicking on PPTP Client interface - RB2011 rack, Galaxy S6.
grawerpl
Thu Jul 16, 2015 11:02 am
Still better iOS then Android (i hate it after installed lilipop :D)
Will be nice if you consider WP (after WPX will appear) - even if this OS is 3rd placed
PS: did you consider port this app to Windows Tablets ?
normis
Thu Jul 16, 2015 11:23 am
Although Windows 10 is a de facto successor to Windows RT, Microsoft has explicitly deemed Windows RT devices to be incompatible with Windows 10
I don't think this is a good idea anymore.
grawerpl
Thu Jul 16, 2015 12:34 pm
yes you have right but if i remember from about 2 years MS stopped selling tablets witch RT so now you can only buy Tablets witch full W8.1.
Secont thing is that MS says that form WX you can create in one app for all platform version (this even added android and iOS)
http://blogs.windows.com/buildingapps/2 ... -platform/
and other
https://visualstudiomagazine.com/articl ... tools.aspx
I think its worthy of consideration
vortex
Thu Jul 16, 2015 1:21 pm
Just run Winbox on that.
SystemErrorMessage
Thu Jul 16, 2015 4:26 pm
applied to join, I have several MT devices i'd like to try this on and several android devices too. If you dont want to agree with google's privacy rules either get a custom rom such as cyanogen or get a development platform which both do not come with google play or google services by default.
normis, the google play link doesnt work, also i cant have google services and google play on my tablet because it is a developer platform (they just wont run).
Geeek
Fri Jul 17, 2015 1:09 am
Versão para iOS?
Hammy
Forum Veteran
Forum Veteran
Fri Jul 17, 2015 3:22 am
I loaded Tik-App for the first time. I went to discovery, selected my router, input (and saved) my username and password. I connected to the router and then rebooted it. The application crashed shortly after.
Sent from my Nexus 6 using Tapatalk
noyo
Sat Jul 18, 2015 10:56 am
Rb493 with r52n-m. Go to wireless - data rates --> tik-app crashed
Same here on hap lite.
And crashed RB 711 v6.30.1, android 4.4.2
ricky011
Sun Jul 19, 2015 9:54 am
Similar here, after tapping Status for a VirtualAP in Wireless menu, the app crashed....
Sent from my POMP-W89 using Tapatalk
jarda
Mon Jul 20, 2015 11:56 pm
Crashing and crashing.... Is there newer version than 0.0.7 available that at least doesn't crash?
normis
Tue Jul 21, 2015 8:33 am
Currently ir crashes, if you click on a menu that has not yet been implemented, but is shown. The menu layout is complete, but the features - not
jarda
Tue Jul 21, 2015 8:36 am
Very funny to read it now.
normis
Tue Jul 21, 2015 8:38 am
Links work fine. We also have testers from Brazil, who use the app.
I tried to search for TikApp but i haven't found.
you can't. use the links as instructed.
ochyst
Thu Jul 23, 2015 12:51 am
Normis, the most of missing function is a wireless resgistration table.
It helps me and other peoples, which is situated at the top of wireless towers.
Please, implement it, or let me known, where i can found this table.
Edit: I founded It, but i need to see the signals of every stations at one table and need sorting by signals.
Thanks ;)
ochyst
Thu Jul 23, 2015 12:54 am
"winbox" for android, I like it ;) It will be a very powerful thing, which helps everybody!
jonburrows
Thu Jul 23, 2015 2:08 pm
Well, and Ubuntu for phones (Ubuntu Touch)?
  1. http://www.ubuntu.com/phone/developers
normis
Thu Jul 23, 2015 2:37 pm
if we ever make another app (too soon to tell, this is just alpha 1), here is some food for thought:
Android 76.60%
iOS 19.70%
Windows phone 2.80%
Blackberry 0.40%
Symbian 0.00%
Ubuntu 0.00%
Others 0.50%
global market share in percent, IDC, 2014 Q4
angboontiong
Fri Jul 24, 2015 6:39 am
We have started working on an Android utility that gives you ability to configure your router more conveniently, while on the go.
You must apply to the closed testing group:
Then you will be given access to the download:
https://play.google.com/apps/testing/co ... oid.tikapp
Let us know how it works for you, and what you think about it.
i followed the instruction but no link given to download...
normis
Fri Jul 24, 2015 8:27 am
second link is the download ling, ang!
first link = sign up. when done:
second link = download
Hammy
Forum Veteran
Forum Veteran
Mon Jul 27, 2015 7:09 pm
Reading is hard.
legrang
Wed Jul 29, 2015 3:42 pm
Doesn't work.
normis
Wed Jul 29, 2015 4:02 pm
OK, again.
first link = sign up. WHEN YOU HAVE BEEN CONFIRMED:
legrang
Wed Jul 29, 2015 4:28 pm
I've figured out what the problem with my login was. I use more than one Google account and despite being singed in with the account associated the G+ group, I had to sign out the other accounts to access the download page.
As to this:
OK, again.
I hope what I posted will show you that not all problems are caused by users not following instructions. The other people who struggle are likely not stupid people who can't read, but are affected by something that doesn't affect you or that you don't know about yet. In general, that is a good attitude with which to approach customer support.
Hammy
Forum Veteran
Forum Veteran
Wed Jul 29, 2015 4:33 pm
As to this:
OK, again.
User Error is responsible for most issues in IT. ;-)
kristaps
Thu Aug 06, 2015 4:19 pm
Now you can become beta tester without Google Plus Group
Click on this link https://play.google.com/apps/testing/co ... oid.tikapp it will allow you to install Alpha
i you are having problems connecting try to connect to demo.mt.lv and check your Firewall settings
noyo
Fri Aug 07, 2015 11:06 pm
No loading data - data races. And next tabs
cREoz
Sat Aug 08, 2015 12:38 am
Thanks for remove TCP ping!
No advanced settings for Wireless interface.
deanMKD1
Sat Aug 08, 2015 1:17 am
Downloaded , instaled on my LG F60 and works great. Tested loggedin in my local network from 192.168.88.1 , and tested from logeed from API and works great. SOme menus are shown but white without data to configure. No force close for me in test period. Android 4.4.4. This will be great app. Thanks MikroTIk. :D
EDIT: I get force close when try to Add SImple Quees. :(
Anyway app is still in beta, but will be fixed i hope so.
kgninfos
Sun Aug 09, 2015 5:53 pm
when you edit a pppoe client connection there is option to edit password but no option to edit username ??
mahnet
Long time Member
Long time Member
Tue Aug 11, 2015 8:46 pm
i do not find this on playstore
Chupaka
Tue Aug 11, 2015 10:32 pm
find by link or what?..
noyo
Wed Aug 12, 2015 12:20 am
Kliwer
Wed Aug 12, 2015 11:06 pm
RB SXT G-5HPnD r2
Menu->Wireless = crash
Thank you, this will be very useful app.
deanMKD1
Thu Aug 13, 2015 2:19 am
Read carefullly !!
First apply for Tester, click on ask for join red button. https://plus.google.com/communities/108 ... 3530666627
Second Download app from: https://play.google.com/apps/testing/co ... oid.tikapp
This is direct link from Google Play Tik App:
https://play.google.com/store/apps/deta ... jUecw_cB1E
Is more clear now ??
CsXen
Thu Aug 13, 2015 2:30 pm
HI.
If I want to see the LOG, i get: "There are too many items to show them all. Please specify more specific filter."
Nowhere can I specify filter. And I can't see any entries.
I hope, this will be great app for managing MTik. :)
Feature request: On the interfaces page, can you put the status of the interface visible (R -running, S-slave...etc.), and the actual Tx/Rx rate?
It should be very good not to check every interface individually, just see, they are running... :)
biland
Sat Aug 15, 2015 2:25 pm
if i want to change the clock , in time zone name i can see all the options, but when i click one, i get a empty field and after that when i klick ok , an error in time zone
using a note4 android 5.01
Robox
Thu Aug 20, 2015 7:58 am
ver. 0.0.9
not connect if non standart use port
Keyal
Fri Aug 21, 2015 9:56 pm
Hi people, greetings from Colombia.
V0.0.10 Installed and testing on Samsung S4 mini Duos Android 4.4.2 (GT-I9192) with RB951G-2HnD and hAP Lite ... soon news about it ;)
fabrix
Sat Aug 22, 2015 1:23 am
Installed 0.0.10 on Samsung Tab 4 10".
Very nice
vortex
Sat Aug 22, 2015 7:29 pm
Official apk of the latest version?
I can check if it's now more stable on BlackBerry 10.3.1
deanMKD1
Mon Aug 24, 2015 11:39 pm
App is available ONLY for beta testers for now ! For that you cant found in Google Play ;)
vortex
Mon Aug 24, 2015 11:47 pm
An apk was released before.
vortex
Mon Aug 31, 2015 9:48 pm
0.0.7 still stable on the new Jolla 1.1.7.28 (still Android 4.1.2)
kristaps
Tue Sep 01, 2015 10:49 am
Hi you can get newest .apk here
http://www.mikrotik.com/download/share/ ... 0_0_11.apk
If you have any suggestion what should we add to this app, please feel free share your thoughts.
noyo
Tue Sep 01, 2015 11:09 am
If you have any suggestion what should we add to this app, please feel free share your toughs.
Correct mistakes.....
look carefully....
honzam
Tue Sep 01, 2015 4:14 pm
Can you please share some changelog of tikapp? What is fixed?
Siona
Tue Sep 01, 2015 4:57 pm
It is not showing remembered parameters for lte connections in editing mode.
vortex
Tue Sep 01, 2015 9:10 pm
With 0.0.11 :
BlackBerry Z10, still BlackBerry 10 OS 10.3.1 : still crashes very quickly, as expected. Waiting for a BB10 release as good as previous ones.
Jolla Phone, Sailfish OS 1.1.7.28 : crashed once scrolling in Bridge Traffic page, but I could not make it happen again.
Aaelyen
Tue Sep 01, 2015 9:34 pm
If you could add the ability to run a btest to a MikroTik from an Android device, that would be amazing!
kristaps
Wed Sep 02, 2015 3:09 pm
v0.0.11
• Tools/Graphing - Added graphs
• File - Changed icon backgrounds
• Bug fixes
v0.0.10
• Detect installed packages
• Added IPv6 DHCP
• Added KVM
• Added flags
• Bug fixes
v0.0.9
• Connect without TCP ping
• Search function
• Bug fixes
v0.0.8
• Connect to specified port
• Option to save router password
• Saving router with same address and user doesn't create duplicate record
• Correct log time
• Better readability for traffic data
• Bug fixes
You can use this tool https://play.google.com/store/apps/deta ... ools&hl=en for traffic measuring it will be better then btest.
vortex
Wed Sep 02, 2015 3:13 pm
I think the luck of people with BB 10.3.1 varies. That it crashes for me does not mean it will crash for everybody. Nearly immediate crashes after app launch are not exclusive to Tik App. I just tried to enter the Interfaces page, but I think it is the same with any other.
The one Jolla crash that happened is more strange. I scrolled down the Bridge Traffic page to the graph and I think I was still kind of moving around when it happened.
vortex
Wed Sep 02, 2015 3:43 pm
0.0.11 on Note 3 with Lollipop did not crash.
honzam
Wed Sep 02, 2015 4:42 pm
First quick test 0.0.11 - no crash. :) Thanks
kristaps
Thu Sep 03, 2015 10:15 am
honzam
on what device you use it ?
Also Others if you could make suggestions what is missing or what should we add in this tool feel free to write
efaden
Thu Sep 03, 2015 4:16 pm
Can you add the ability to port-knock? E.g. hit a random sequence of ports via tcp/udp and send some set of data to each port?
kristaps
Fri Sep 04, 2015 4:20 pm
New version available
• Hide passwords in list view
• Fixed multiple tools
• Other bug fixes
https://play.google.com/store/apps/deta ... id.tikapp
if you are no beta tester click on this link https://play.google.com/apps/testing/co ... oid.tikapp
OSPF
BGP
MPLS
viewing / editing feedback would be appreciated
We will thing how we can implement port port-knock.
efaden
Fri Sep 04, 2015 4:24 pm
Let me know if you need testing for the port knock or the rules I use. But basically I have layer 7 rules and then hit ports via UDP and check for the data. Would love to see a tried and true open source "port knock" algorithm implemented... but this works.
honzam
Fri Sep 04, 2015 10:29 pm
honzam
Samsung Galaxy Xcover 2
My suggestions:
- Make posibility to mac access in neighbors
- different background for home screen - adjustable
- rb532 on home screen show (mipsel). Right is mipsle
- autoupgrade for Tik App
deanMKD1
Sat Sep 05, 2015 1:31 am
honzam
Same here. RB2011, show me like mipsel. Right is mipsbe. :D
efaden
Mon Sep 07, 2015 11:25 pm
In addition to the port knocking... Some sort of tunnel ipsec, l2tp,etc built in to securely connect to remote routers
Sent from my SCH-I545 using Tapatalk
shadowskippie
Tue Sep 08, 2015 10:04 am
Good morning.
Before i start, please point out if anything i'm about to ask is actually in the app and i'm just missing it.
I'm really liking the app. this will allow me to check my routers from my tablet without having to use an ssh client, fantastic. :D
Within 5 mins of test though i came across some problems
I cannot find safemode. this for me is very important as i have a way of royally screwing up now and then, and then having it save my smoking bacon every single time :shock:
next, a copy command. i like being able to copy a firewall command if i need the same yet subtly different rule.
moving past this tried to add the new rule manually and hit another issue. creating a firewall rule i set the chain to input, but it didn't take until i set it to output first then input.
I then selected protocol as tcp but when i wanted to add in the port the fields would not show. I'll add that i never saved the rule in place to see if it would bring up the required fields as i didn't want this incomplete rule to mess up my firewall in some way (subtle jab at the safe mode above)
vortex
Fri Sep 11, 2015 11:56 pm
I upgraded my BlackBerry Z10 to the just released BlackBerry 10 OS 10.3.2.2474 (still Android 4.3).
Now TikApp 0.0.11 does not crash.
But going into a page (not menu) is sluggish, specially Interfaces, which usually gets stuck mid slide at 27% CPU consumption by the app until it times out and I get kicked out to the login screen (this can also happen for example in DHCP Server).
Annoyance: the back button takes you to the main screen, not to the previous menu.
Reborns
Sat Sep 12, 2015 5:25 pm
Version 0.0.12 Not working with ROS 5.26 , i can see in ROS logs "user admin logged in from .... via winbox" but on phone it shows connecting ...
Moc
Sun Sep 13, 2015 4:36 am
I registred for the beta app, but after the link to install it say that the app is not found. So I cannot install it.
efaden
Sun Sep 13, 2015 2:09 pm
You need to give it a few minutes after you sign up... it will 404 for like 5 to 10 minutes sometimes.
soyelpulpo
Re:
Mon Sep 14, 2015 7:45 am
Use the VPN feature of your mobile device instead making the app more complex and heavy. Create a VPN connection to your remote site then access using such connection.
Sent from my Nexus 4 using Tapatalk
vortex
Thu Sep 17, 2015 6:00 pm
I noticed a very good deal on the Fire HD 7 at amazon.de yesterday, so I ordered it today now that I've seen that the new models are not worth it.
CsXen
Sat Sep 19, 2015 12:57 pm
Hi.
+1. On my old RB112 with ROS 5.26, I see the same issue. Connecting... forever. I tried on ETH and over wifi.
Regards: CsXen
toto99303
Wed Sep 23, 2015 2:54 pm
Awesome app! I was hoping you will make such an app at some point, and here it is, thanks!!
Some minor feedback from first look:
Memory is in negative values with CCRs, also please specify if this is free or used memory :)
Ham
Fri Sep 25, 2015 3:06 am
I am loving the application so far, a feature request of sorts it's something I dont think is yet available in the app.
Being able to see wlan registration table, or a alignment mode of sorts.
Being able to use the mobile application to align new CPE's to a AP, would be a very handy tool out on the field for technicians.
f1studio
Tue Sep 29, 2015 8:38 pm
Hello!
I registered as tester, but i can not find the app in google play. That is a Google's answer: We're sorry, the requested URL was not found on this server.
What am I do wrong?
AndyML
Tue Sep 29, 2015 9:33 pm
Hello!
What am I do wrong?
Yeah - me too. Apparently we're really late to the party! Last post before yours was 2011.
f1studio
Wed Sep 30, 2015 12:25 am
Hello!
What am I do wrong?
In my case right after registration as tester, i press the link named "Download Tik-App on Google Play" app tester's page https://play.google.com/apps/testing/co ... oid.tikapp I saw this app in Google Play on PC for a short time. After that I used my phone to find Tik-App in Google Play. Not found the App. Then look back to PC and after page has reloaded the App is disappear.
f1studio
Wed Sep 30, 2015 12:54 am
It works. I just re-entered to Google Play and saw that the Tik-App is now available. App looks very useful and convenient.
sanjeevthapa
Mon Oct 05, 2015 5:56 pm
Much more bugs, crash when look the logs reports when the log hit is more then 1-2 sec continuously and widget arrangements is not putted like win box manner
vortex
Fri Oct 09, 2015 8:26 pm
With 0.0.11:
Amazon Fire HD 7 (4th generation, 2014), Fire OS 4.5.5 (Android 4.4.3) : it works well.
revellion
Mon Oct 12, 2015 11:54 am
Nice app!. Testing it currently.
deanMKD1
Fri Oct 16, 2015 12:06 am
Tik App broke my Guest network DHCP, when disable simple queue for guest network. When disabling from WinBox, there is not issue with Guest DHCP, but when use app, broke my guest DHCP server , and must configure guest network from start. :?
TikApp v0.0.13 RoS 6.20
kristaps
Thu Oct 22, 2015 10:39 am
Thanks for reporting, we will try to replicate this issue.
pukkita
Trainer
Trainer
Thu Oct 22, 2015 11:50 am
Does it support RoMON? If not that could be a great feature (no android device to test it yet)
kristaps
Thu Oct 22, 2015 12:04 pm
not right now, but we will include it in our TODO list
but first we are working hard for Secure Connection and MAC-winbox to work on android.
deanMKD1
Fri Oct 30, 2015 1:17 pm
Another Bug..
- App crushed when try to make a new VirtualAP. - NEW
- DHCP crush when disable / enable simple queue for Guest network (Reported Issue)
kristaps
Fri Nov 06, 2015 4:50 pm
New version will be available for download in few hours.
Changelog:
• Get plugins for specific router and RouterOS version
• Show report bug on unimplemented inputs (report if any found)
• Mark changed and invalid input fields
• Bug fixes
Become alpha tester:
Download here:
nimbo78
Sun Nov 08, 2015 9:37 pm
need info text back to the home screen - ROS version, identity and etc
dadoremix
Sun Nov 08, 2015 10:00 pm
For ios any?
CyberTod
Long time Member
Long time Member
Mon Nov 09, 2015 2:07 pm
Since latest version or perhaps v6.33 there is problem with scripts :
When opening a script the rights are not read - no checkmarks and there is no execute script option. Trying to set some permission on the script and apply gives an error.
esturniolo
Tue Nov 10, 2015 8:53 pm
Hi all.
I tried to connect to my router with the own RouterOs DDNS xxxxxxx.mynetname.net over internet and never reached it.
Is this ok?
The app should only work via lan?
kristaps
Fri Nov 13, 2015 6:23 pm
New version is available for download.
Changelog:
• Added action buttons (e.g. Run script)
• Fixed connection to non-default ports
• Fixed multiple checkbox fields
• Other bug fixes
Download here: https://play.google.com/store/apps/deta ... id.tikapp
It should fix CyberTod issue.
esturniolo
it should work you probably need to add Firewall filter exception for winbox port 829.
Are you able to connect with regular winbox to your router ?
wombat
Mon Nov 16, 2015 4:22 pm
Hi!
How can I do upgrade / equivalenf System/Packages/Check for update/Upgrade?
I have the latest build.
Thank you.
Gabriel
naveen4u12
Thu Nov 19, 2015 8:43 am
superb app.
kgninfos
Wed Nov 25, 2015 6:24 am
As reported in ticket wireless scan is broken in this version getting error "Object does not exist"
speedmax
Wed Nov 25, 2015 7:16 am
EDIT: new way to download. Just one link: https://play.google.com/apps/testing/co ... oid.tikapp
Can you please add CPU and RAM usage like in initial version. In current its not available. Can we add files via app?
CsXen
Wed Nov 25, 2015 12:16 pm
Hi.
I upgraded to the latest version. it was a BIG mistake. :) In the 0.0.13, app started very fast, I pushed Connect and I'm in. In 0.0.16 I got an "Downloading plugins" line for about a minute... It isn't too cheap on mobile internet. And it seems not cached. If I tried again to log into the same router, it downloaded again.. and again... Please give back the speed for us and don't download if unnecessary. (It wasn't needed in 0.0.13 ?)
Another BUG: in the LOG menu, I seen the oldest and not the newest entries.. with 1000 line in log, it isn't fun to search the recent entries.
So I rolled back to the latest STABLE release: 0.0.13 :)
Best regards: CsXen
kristaps
Wed Nov 25, 2015 1:40 pm
This bug has been fixed and wireless scan should work in next version.
Quick resource overview will be aviable in upcoming versions.
Hi.
Best regards: CsXen
Version 0.0.13 and earlier used same plugin files for all RouterOS versions which may cause wrong fields showing up in menus.
Starting from version 0.0.14, app downloads necessary plugin files for specific RouterOS version. Theese files are downloaded and saved to phone and next time when You connect, they aren't beign downloaded again. "Downloading plugins" are also showing when theese files are loaded from phone memory.
kristaps
Fri Nov 27, 2015 5:34 pm
Changelog:
• Made disabled/read only texts selectable and copyable
• Added log level colors (error/warning/info)
• Added Advanced mode/Simple mode option
• Redownload broken plugin files
• Faster plugin loadinga
• Fix search - show more than only one matched item
• Fix "object does not exist" bug in wireless scan
Download here:
kgninfos
Sat Nov 28, 2015 2:04 pm
i was bale to scan in the new version but where is the option to connect to a wifi network ??
cross
Sun Nov 29, 2015 11:44 pm
Hm not available in GOOGLE PLAY
andriys
Mon Nov 30, 2015 12:46 pm
Use the first link to join the alpha testers group. The second link will work as soon as you become a member.
cross
Wed Dec 02, 2015 4:35 pm
thx worked
pourhosaini
Sat Dec 05, 2015 11:21 am
can anyone send me the APK file
i cant download it
tnx
gaid78
Sun Dec 06, 2015 3:01 am
View log. Not correct display time (include TZ?)
kgninfos
Mon Dec 07, 2015 5:42 am
Mikrotik where is the option to connect to a wifi network after doing scan??
deanMKD1
Sat Dec 19, 2015 11:21 pm
@normis
Unfinished part in app.
Tools > SSH
gladstonreis
Fri Dec 25, 2015 8:59 pm
The url is broken.
normis
Wed Dec 30, 2015 11:14 am
The url is broken.
It is not broken. You must become tester first https://play.google.com/apps/testing/co ... oid.tikapp
Teno
Sat Jan 02, 2016 12:03 am
So far ok for both Huawei G620s and Samsung Galaxy Tab 3.
Both local and remote!
CyberTod
Long time Member
Long time Member
Mon Jan 04, 2016 2:12 pm
In System -> Resources the uptime is not shown correctly.
It shows only the hours or sometimes +12h depending maybe on how much they are, two exapmles from different routers :
45d 19:11 - shown in app as 19:11
3d 01:34 - shown in app as 13:34
kristaps
Mon Jan 04, 2016 5:30 pm
Thanks for Reporting to us. We will look at this.
p0wer
Tue Jan 05, 2016 10:37 pm
It is not possible to connect with MAC ("MAC connections are not supported") - is this Android limitation or is it TODO? This is a huge con when servicing devices that don't have IP address set (0.0.0.0).
msatter
Wed Jan 20, 2016 4:44 pm
I have tried this APP on my Nexus 2013 and noticed that it heats up my tablet on the backside next to camera. I am using my tablet a few hours daily but never had any heating up that I could feel.
It start after starting up the APP and closing it down does not change the heating up. Only a reboot will cool down the tables again.
I used the previous version and the version release a few day's ago and I am still using KitKat version 4.4 KRT16O.
taiyeelong
Thu Jan 21, 2016 3:37 pm
RB2011L with version v5.19 show not support.
gaid78
Sun Jan 24, 2016 8:56 pm
View log. Display Topics: null, null, null.
michallasisz
Mon Jan 25, 2016 8:48 pm
Nice App. It will be nice if in future releases app will have ability to sort for example scan results by signal or SSID.
y64xkuo
Mon Feb 01, 2016 10:53 am
Seems promising!
SystemErrorMessage
Sat Feb 20, 2016 9:26 pm
Is it possible to download this without google play? I have this on my phone but i would prefer to use it on my tablet which is a developer one where google play and services would refuse to install and work. I know you can connect via http using browser but on android browsers tend to be a resource hog and the tik app lets you connect using mac address.
0ldman
Fri Feb 26, 2016 5:28 pm
A manual download link would be appreciated.
For whatever reason I was having trouble getting the alpha to download on my phone.
edh
Sun Feb 28, 2016 5:40 pm
I'm unable to run scripts using the app, I press run and get an empty confirm dialogue, nothing happens if I click OK. Is anyone else seeing this behavior?
kristaps
Fri Mar 04, 2016 5:52 pm
Hello most things should be fixed by now. Thanks for testing and giving your feedback.
Yes You can get it without google play Here is latest v26 version apk.
http://www.mikrotik.com/download/share/ ... 0_0_26.apk
Changelog:
• Fixed some tools
• Fixed missing tabs
• Added missing input fields
• Conenction stability improvements
• Some bug fixes
Download here:
ka4opi4a
Wed Mar 09, 2016 1:12 pm
I can't connect to hap ac running 6.35rc19. On connection attemp the app stop working.
nishadul
Thu Mar 10, 2016 3:02 pm
I have installed Tikapp in my Symphony W160, but problem is connection failed, when I try to connect ROS x86 then show Downloading plugins...
It's do not complete. after few minute message show Tik-App isn't responding, do you want to close it? Wait, Report. OK.
My phone model is Symphony W160, Android version 4.2.2
Pl suggest me how to solve the problem.
kristaps
Thu Mar 10, 2016 5:41 pm
Yes there is issue You cannot connect to RC version now with v26 Tik-app Version That will be fixed in v27. You can connect demo.mt.lv and demo2.mt.lv
What android version does Symphony W160 Have? Do you have issue connecting to demo.mt.lv and demo2.mt.lv also?
Try to send report to google we should receive crash log from console.
vortex
Sat Mar 19, 2016 1:22 am
v26 is working with:
BlackBerry Passport: BlackBerry OS 10.3.2 (Android 4.3)
Amazon Fire Phone: Fire OS 4.6.6 (Android 4.4.4)
vortex
Sat Mar 19, 2016 2:58 pm
- Jolla Phone: Sailfish OS 2.0.0.10 (Android 4.1.2)
- Samsung Galaxy Note 3: Android 5.0
On the Samsung and the BlackBerry it happened that some page like firewall would wait and wait. I had to restart the app to get it to work (logging in again was not enough). So this seems like a general problem.
Where is the lease list?
ZETA992
Mon Mar 21, 2016 10:51 am
asus zenfone 2 ze551ml(Android 5.0)
1)CAPsMAN-Remote Cap and collapse app(Not Responding)
2)CAPsMAN-Registration Table- All interfaces to register clients is "unknown"
vortex
Wed Mar 23, 2016 12:15 am
Samsung Galaxy Tab PRO 12.2 WiFi: Android 5.1.1
nishadul
Thu Mar 24, 2016 9:24 am
I have try to domo.mt.lv and demo2.mt.lv but problem is same downloading plugins..........
android version is 4.2.2 of my symphony w160, I have installed Tikapp v27
vortex
Thu Mar 24, 2016 10:50 pm
OFF TOPIC: Fire Phone's settings page is terrible.
vortex
Thu Mar 24, 2016 11:10 pm
And TouchWiz is just chaos.
kristaps
Fri Apr 01, 2016 5:59 pm
Thanks Vortex and others for feedback, greatly appreciated.
Hello new Beta version with some improvements. Thanks for testing and giving your feedback.
Yes You can get it without google play Here is latest v28 version apk.
http://www.mikrotik.com/download/share/ ... 0_0_28.apk
Changelog:
WHAT'S NEW
• Added interface Tx/Rx Rate to list view
• Fixed wbx import
• Save wbx file with custom name
• Other bug fixes
Download here:
https://play.google.com/store/apps/deta ... oid.tikapp
nishadul
Fri Apr 01, 2016 6:28 pm
Tik App not work with symphony W160, Android version 4.2.2.
If open Tik app then message show connecting then show downloading plugins......
vortex
Fri Apr 01, 2016 7:52 pm
The app does not raise a "malformed IPv4 address" error.
It shows "connection refused". Which was a further issue.
vortex
Fri Apr 01, 2016 8:15 pm
It is very annoying that the back button still returns to the main page instead of the previous menu.
vortex
Fri Apr 01, 2016 8:16 pm
Is it normal that it disconnects after a very short idle time?
vortex
Fri Apr 01, 2016 9:41 pm
I saw something weird: a very temporary duplication of a disabled VLAN on the interface list. Normally when browsing back from the VLAN detail. Triplication browsing back from the interface.
vortex
Fri Apr 01, 2016 10:04 pm
It seems it would be good making the Interfaces, Routes and Firewall pages open faster for slower devices.
vortex
Fri Apr 01, 2016 11:31 pm
v.28 is working on:
- Samsung Galaxy Tab PRO 12.2 WiFi: Android 5.1.1
- Amazon Fire Phone: Fire OS 4.6.6 (Android 4.4.4)
- Amazon Kindle Fire HDX LTE (7"): Fire OS 4.5.5.1 (Android 4.4.3)
- Amazon Kindle Fire HDX LTE (7"): Fire OS 4.5.4 (Android 4.4.3)
- Amazon Kindle Fire HDX LTE (7"): Fire OS 4.5.2 (Android 4.4.3)
- BlackBerry Passport: BlackBerry OS 10.3.2 (Android 4.3) [now with "Blackberry Runtime for Android" bugfix from BlackBerry World installed]
erebusodora
Mon Apr 04, 2016 12:50 pm
Tik App not working with forwardin ports. Example: add action=dst-nat chain=dstnat comment=Sre dst-port=294 protocol=tcp to-addresses=10.1.3.10 to-ports=8728
I write this line in mikrotik with public ip but nothing hapens.
When try to connect to public IP example: 193.108.200.201 all is ok.
kristaps
Mon Apr 04, 2016 4:30 pm
nishadul we are looking at this issue. It looks like specific problem with some version of Vendor specific Android OS.
Thanks vortex for reports. Yes for now it disconnects if you minimize then it disconnects .But we will make some timeout longer. How do you mean. "Triplication browsing back from the interface."
Thanks erebusodora. we will check that issue.
soonwai
Tue Apr 05, 2016 8:44 pm
Please, please, please Mikrotik a similar app for iOS. My wife refuses to lend me her Android phone. :(
vortex
Tue Apr 05, 2016 8:59 pm
I guess it is still early enough to switch to a (good) truly cross platform SDK.
vortex
Thu Apr 07, 2016 7:58 pm
BlackBerry Q5: BlackBerry OS 10.3.2 (Android 4.3) : v28 works
BlackBerry Q5: BlackBerry OS 10.2.1 (Android 4.2.2) -> Cannot even connect because I cannot scroll down to the button [old version, who cares, this was a general problem usually with Android apps on square screens]
How to connect now: swiping from the top of the screen shows a button to hide the bottom bar
kristaps
Fri Apr 08, 2016 3:42 pm
Thanks for update Vortex.
apk download http://www.mikrotik.com/download/share/ ... 0_0_29.apk
Changelog:
• Added directory selection for exporting wbx
• Improved connection stability
• Keep connection alive in background
• Fixed item moving
• Other bug fixes
Download here:
notToNew
Sun Apr 10, 2016 11:12 pm
v28 works, v29 crashes at connect., always!
Sent the chrashlog per mail, hope this helps.
jebz
Mon Apr 11, 2016 3:58 am
Latest Tik-App Tool Ping doesn't work.
IP, DNS, Dynamic Servers, doesn't separate the entries you get results like: 43.229.61.243.229.62.28.8.8.8 It would be nice to have a coma and space between entries.
kristaps
Mon Apr 11, 2016 12:31 pm
Thanks, notToNew and jebz
We will fix this issues.
casr43
Mon Apr 11, 2016 5:14 pm
Samsung S4 mini android 4.4.2. Tik-App v30. The app has stopped when downloading plugins. Same behavior on the demo.mt.lv and on my devices. Does not work with version 28.
kristaps
Mon Apr 11, 2016 5:18 pm
Can you please send report form app to support@mikrotik.com
casr43
Mon Apr 11, 2016 5:47 pm
The report was sent. I'm sorry, does not work with version 26. In phone official firmware without root.
casr43
Thu Apr 14, 2016 9:02 am
Can eat at the forum Samsung S4 mini? Check, please, Tik-App v30. Stops on downloading plug-ins?
kristaps
Thu Apr 21, 2016 4:54 pm
casr43 Your issue should be fixed in v32 Version
http://www.mikrotik.com/download/share/ ... 0_0_32.apk
casr43
Tue Apr 26, 2016 5:43 pm
Thank you!! Work versions 32 and 33.
boldsuck
Sat Apr 30, 2016 9:26 pm
Thank you for this app. I use it on:
HTC one m7 - Android 5.0.2
Google Nexus 10 - Android 5.1.1
This Alpha testing app has already a lot of features and full ipv6 support, you can't find this on all the other 'stable' and paid apps in the Playstore for Android devices.
IPv6 addresses in System/Users & IP/Services 'Allowed Address' are not shown correctly.
Example: fe80::/10 looks 0.0.0.0/0
vortex
Sat May 14, 2016 4:45 pm
v.32 is working on:
- BlackBerry Q5: BlackBerry OS 10.3.2 (Android 4.3)
- Jolla Phone: Sailfish OS 2.0.1.11 (Android 4.1.2)
ISSUES:
- Connection timeout can happen
- On slower devices, interface entry opens with a smaller set of tabs, after a little bit becomes fully populated. If clicking before this, the wrong page might be opened.
- Opening a page can wait and wait
- Crash after leaving idle for a while, then interacting again.
vortex
Wed May 25, 2016 1:27 am
1. The apk links don't work anymore directly. You have to go through HTTPS.
2. v32 is working on:
Amazon Kindle Fire (1st Generation): pre-"Fire OS" naming 6.3.4 (Android 2.3.4)
ISSUES:
It is very slow opening bigger pages like Firewall, are you using something like Cordova? Even this has a dual-core 1GHz CPU (but only 512MB RAM total).
erebusodora
Wed Jun 08, 2016 8:11 am
On Lenovo Vibe P1 is workin good but 1 problem found. When import adreses (from adress.wbx file) and when i want to connect to adres from imported list it always show my first conection . Example my first conection is 192.168.0.1 and i want to connect to 192.168.0.6 from imported list but always return 192.160.0.1 (firs connection)
kristaps
Wed Jun 08, 2016 5:08 pm
Thanks @erebusodora we will check that.
@vortex We will see what we can do to improve older/slower device responsiveness on Tik-app
here is latest v33 Tik-app that we released on 22 April.
http://www.mikrotik.com/download/share/ ... 0_0_33.apk
We have lot of bug reports and we are going to work on them.
Thanks everyone for reporting.
vortex
Fri Jun 17, 2016 8:54 pm
v33:
CANNOT OPEN APK:
v32 still opens
v33 apk can be opened on Fire Phone
vortex
Fri Jun 17, 2016 9:06 pm
DHCP Leases:
- It is not showing the device name
- Many IP addresses appear twice, separated by a comma
vortex
Fri Jun 17, 2016 9:14 pm
OS update:
- Amazon Fire Phone: Fire OS 4.6.6.1 (Android 4.4.4)
v33 works, but had many disconnects with RB2011 running latest bugfix, as it sometimes happened before (v33 also on 4.6.6).
Some pages can slow down. This is a powerful device.
vortex
Fri Jun 17, 2016 9:27 pm
v33:
CANNOT OPEN APK:
v32 still opens
I could open it using a file manager. Maybe you changed MIME type?
Several disconnects.
Filter Rules just waits and waits (or disconnects).
hashirvani
Wed Jun 22, 2016 10:39 pm
Thank for this app as mikrotik
chingachkuk
Fri Jun 24, 2016 9:06 am
Будет ли поддержка старых версии RouterOS 5.26?
ZupoLlask
Mon Jun 27, 2016 2:46 pm
Hi Support!
I'm unable to have NAT rules changed (bottom notification with undo option shows up; I'm able to enable/disable those same rules) using latest app version.
Can you please check if you can reproduce this behavior?
Thanks.
diablothebest
Fri Jul 22, 2016 12:43 am
Can you share last version APK link?
AzAel76
Fri Jul 22, 2016 7:02 pm
No longer works with 6.36. hangs on "Downloading Plugins"
Pea
Fri Jul 22, 2016 9:59 pm
I confirm, Tik-App v0.0.33 does not work with 6.36 ROS, stuck on "Downloading plugins..." with Mikrotik RB951G-2HnD
Shadeofspirit
Tue Jul 26, 2016 10:17 pm
v33 works with ros 6.36 (rb2011uias) both secure and not secured mode
Shadeofspirit
Wed Jul 27, 2016 10:06 pm
torch in tik-app (v33) doesn't collect all selected information. in tik-app there no information about src and dsc address
notToNew
Wed Aug 03, 2016 9:37 am
Login in v34 under 6.36 overVPN finally works. Thank you.
boldsuck
Sat Aug 06, 2016 7:11 pm
In version 0.0.34 the same
ISSUES:
RouterOS: 6.36 (current)
boldsuck
Sat Aug 06, 2016 8:20 pm
FEATURE WISH:
Hide some menu items like 'Design Skin' in Webfig.
kristaps
Fri Aug 12, 2016 4:27 pm
Thanks for reports, right now Secure mode isnt working as it should it could cause out of sync errors and random crashes, i Suggest to disable it for now.
We are working on v35 that are going to fix most off issue.
ndasjowo
Mon Sep 05, 2016 9:19 am
We will be waiting...
vortex
Fri Sep 09, 2016 11:25 pm
v33:
It works but stops responding:
- Jolla Phone: Sailfish OS 2.0.2.51 (Android 4.1.2)
How to reproduce:
- Go into a DHCP server and press the back button
vortex
Fri Sep 09, 2016 11:58 pm
v33:
It works, but it disconnected once doing the same action as in the Jolla:
- Amazon Kindle Fire HDX LTE (7"): Fire OS 4.5.5.2 (Android 4.4.3)
kristaps
Thu Sep 15, 2016 7:23 pm
Thanks for reports and suggestions.
APK. v35 http://www.mikrotik.com/download/share/ ... 0_0_35.apk
Changelog:
• Fixed IP firewall
• Less random crashes
• Fixed some tools
• Other bug fixes
Download here:
boldsuck
Sun Sep 25, 2016 7:40 pm
In version 0.0.35
ISSUES FIXED: 8)
IPv6 addresses in System/Users & IP/Services 'Allowed Address' are shown correctly, now.
RouterOS: 6.36 & 6.37(current)
Thanx for the nice app.
On 10" and bigger devices 'Firefox & Webfig' is just as fine.
David1234
Tue Sep 27, 2016 1:47 pm
can I download the MikroTik android utility using google play?
Thanks ,
Chupaka
Tue Sep 27, 2016 2:29 pm
vortex
Tue Sep 27, 2016 5:00 pm
v35:
System/Resources opens an empty "PCI" page.
System/Routerboard has weird content.
Disconnects can still happen.
kristaps
Wed Sep 28, 2016 3:42 pm
Thanks for feedback, we are working on stability issue in secure mode.
mthqwork
Tue Oct 11, 2016 11:40 pm
Just installed. Looks promising, i will do some tests and reply you back with bugs, results, experiences :)
erebusodora
Thu Oct 20, 2016 8:24 am
Still no fixed :( on version 0.0.38
raffav
Fri Oct 21, 2016 2:14 pm
Hello
it not allowed to upgrade device using the Tik App ?
if yes i cant find it
Netsplite
Thu Oct 27, 2016 1:11 pm
Works like a charm on my S7 Edge and a CCR1016-12G, only small thing I noticed is with Queue Tree display:
- Open Queue view -> Go to Queue tree -> Will sort incorrectly no matter the sorting method (WAN2 before WAN1)
Have WAN 1 / WAN1-OUT and WAN2 / WAN2-OUT however it will always list WAN2 first but in Winbox it's correctly sorted so think it has an order by ID / creation date or something else underwater that is sorting it that way :)
If you guys need screenshots or additional information just let me know, love the progress so far so keep up the good work :D
kristaps
Fri Nov 25, 2016 5:41 pm
Thanks for reports and suggestions. We are really close to Final version.
APK. v43 http://www.mikrotik.com/download/share/ ... 0_0_43.apk
Download here:
Cetalfio
Fri Dec 02, 2016 10:44 am
Hello kristaps, please you to consider the Dude client on tik-app to be able to monitor the network when we are out of office.
cetalfio
noyo
Wed Dec 07, 2016 1:22 am
Will there be support for RouterOS v5?
kristaps
Wed Dec 07, 2016 12:22 pm
Sorry But Tik-app Supports only RouterOS v6,
It would take to much time to add support for older RouterOS
ErfanDL
Wed Dec 07, 2016 4:03 pm
Can't set wireless tx power
Sent from my C6833 using Tapatalk
pacmanfan
Fri Dec 16, 2016 6:05 am
Any plans for an iOS version? I just switched from Android to iOS, and so far Tik-App is the only thing that's missing on iOS :(
kristaps
Fri Dec 30, 2016 5:05 pm
We will announce if we start beta iOS version for Winbox
http://www.mikrotik.com/download/share/ ... 0_0_45.apk
WHAT'S NEW
• Moved item actions under gear icon
• Fixed wlan 5GHz frequency list
• Fixed tool crashes
• Fixed time zone field issues
• Fixed long text scrolling
• Added fields to homescreen
• Other bug fixes
Download here:
lexell
Fri Jan 06, 2017 2:02 am
Some issues I've been able to collect during the last few months and which I've now confirmed to still be present in v0.0.45 after wiping app's data and cache (to start from scratch):
  • Menu order is not consistent with the order used in WebFig/WinBox. It also differs even among different router models (e. g. "System" is in a different position in the list when using Tik-App with RB951G and CRS109). It would be ideal to have the same order in TikApp as the one already used in WebFig and WinBox. Submenus seem okay since they're sorted alphabetically everywhere.
  • No Quick Set (which could actually be useful in a mobile app).
  • Being "too quick" while clicking through stuff (e. g. opening interface details) still occasionally crashes the app (tested on a very recent octacore Snapdragon with 4GB of mostly free RAM, so there should be no resource constraints on the phone's side as a reason for crashing.)
  • The app also tends to "time out" and disconnect from the router while sitting on an idle local Wi-Fi with very low packet loss or external interference. I have a suspicion this might either be related to phone turning off the display and then being immediately awakened by the power button or to the relevant router having a WebFig page with frequently updated data open at the same time.
  • Custom wireless scanning lists are only shown as "<unknown>,<unknown>" instead of the actual ranges (e. g. "2402-2422,2462-2482"). This also affects WebFig. Only WinBox and the CLI seem to display custom frequency range lists correctly as of now.
  • Interface and queue graph values could switch to regular SI suffixes instead of using up to (hard to read) 7-digit numbers and then the scientific notation. The Y-axis of one of my interface graphs in Tik-App looks like this: "0.0, 3000000.0, 6000000.0, 9000000.0, 1.2E7". The same graph from RouterOS's MRTG uses values of "0.00Mb, 3.00Mb, 6.00Mb, 9.00Mb, 12.00Mb" instead which are much more intuitive and "default" for the network world. The same goes for binary suffixes on memory and HDD graphs (KiB, MiB...) and CPU graph could include the "%" sign.
  • Resource graphs could have their Y-axis fixed to its maximum possible value depending on the router (128MiB RAM etc., CPU to 100% obviously) as is the case with the WebFig MRTG graphs.
  • Decimals in all graphs should also be properly limited (right now in between a "2.4" and "2.8" I have a "2.6000001" value instead of "2.6" on the CPU graph).
  • When going to Tools > Graphing > Resource Graphs, all of the entries (CPU, Memory and HDD) have "CPU Graph" and "Memory Graph" entries (daily/weekly/monthly/yearly depending on the selected tab) inside them instead of only one entry that would match the resource name (CPU, Memory or HDD). Both graphs always display the same (and correct) data - HDD utilization for the HDD resource..., however they are wrongly labeled (always "CPU" and "Memory") and duplicated.
  • It should be possible to sort lists (ARP entries, DHCP leases, firewall address list groups, firewall connections...) by at least their major parameters (IP/MAC address, name...).
  • Filtering needs some more work - IP routes only have destination address filtering now and only one filter rule is available, IP firewall connections or IP ARP (and likely other places which do have filters in WinBox) don't have filtering at all.
  • A bug in IP routes filtering (possibly also elsewhere if filtering is available in other places): tapping the filter button and then repeatedly selecting "Routes" from the top-right dropdown menu brings up more and more filtering fields. This actually allows for multiple-rule filtering in routes now, however multiple filters should likely be invoked by something more user-friendly (+/- buttons?) and unless other filtering rules than "dst. address" are available then multiple rules are not really useful anyway.
  • After tapping the search button in the top right corner, the second search button on the left of the newly-appeared search bar must also be tapped to pop up the keyboard and enable typing (even tapping the rest of the search bar's area doesn't do anything). The keyboard and an active cursor should ideally pop up only with the top-right search button to enable typing right away.
  • Display of both ping and traceroute results seems to be broken - traceroute has correct number of hops, however no data about them is displayed in the overview or in hop details. Ping also generates entries with no data.
  • No package upgrade check (I believe this was available in the previous versions at some point) and no upgrade download/installation.
  • Entering or editing static DNS servers is not available (this should be fairly important), also dynamic DNS servers are not displayed even if present.
  • Many other sections are still not fully finished too (both missing configurable parameters and omitting displaying of unmodifiable values). Often the missing entries are the ones with no value set/present or non-checked checkboxes - however not always, e. g. the aforementioned static DNS configuration or default route distance configuration in the DHCP Client. And ideally all entries (eve the unconfigured or null ones) should be available for viewing (I'd like to be explicitly reminded that e. g. my DHCP client configuration is not accepting the DHCP server's NTP IPs by seeing them empty instead of not seeing the Peer NTP fields at all).
Tested with RB951G-2HnD (6.38) and CRS109-8G-1S-2HnD-IN (6.37.3), Tik-App v0.0.45 on Android 6.0.1.
I can try to do some screenshots if any of the visual/UI issues can't be successfully replicated with the description alone.
Otherwise a good job, the app is much more complete and stable now compared to when I first tried it :-D
EDIT: some typos and more stuff regarding the resource graphs.
vents
Wed Jan 11, 2017 3:21 pm
Thank you for your effort helping us to improve the functionality of TikApp.
With your help, we have managed to repair several issues in v0.0.46 such us:
  • Editing static DNS servers
  • Package upgrade check
  • Ping and traceroute results
Other issues will be fixed in upcoming TikApp releases.
Please continue using TikApp and together we can make it more user-friendly.
mongo
Wed Jan 11, 2017 9:49 pm
Hi, with the latest version (.46) non of the views refresh i.e. If looking at interface traffic no refresh, if looking at wireless signal strength no refresh. This was not happening with the previous version. I am using a Samsung S7 edge fully updated. Tried rebooting the phone issue still remains.
** edit **
Just wiped app cache and cleared app data still not refreshing views
lindend
Thu Jan 12, 2017 2:24 pm
Queue Traffic upload and download rate counters appear to be showing total traffic that have gone through the queue and not the average traffic.
Edit: Tested on Nexus 6P on 7.1.1.
vortex
Wed Jan 18, 2017 1:39 am
BlackBerry Q5: BlackBerry OS 10.3.2 (Android 4.3) : v45 works. First version I've tried that does not disconnect on a device.
It still really needs to show the names of the nodes in the lease list.
pospanko
Wed Jan 18, 2017 11:43 am
We just installed app and I think that you are, again, going in wrong direction...
This app is good for someone, and for us in long terms, but... You always miss the point. I, and probably most of people here, wouldn't use winbox on phone, what you are trying to achieve.
We need phone apps. Basic functionality for work on field and check some stats and do basic tests.
Basic interface info, wireless scan, basic parameter setup, dhcp, pppoe, few tools and that's it. You can't expect do do real work on phone.
UBNT does that much better.
Create basic app, and listen what people want and add it if there is real demand.
You are developing this for 2 years now and still nothing usable. You could develop real usable app in month or two.
Just my 2 cents...
baragoon
Wed Jan 18, 2017 12:11 pm
Is iOS version in plans?
Отправлено с моего iPhone используя Tapatalk
Milkthief
Wed Jan 18, 2017 4:14 pm
Dear Mikrotik developers,
I'm mikrotik enthusiast and I work in a software house where I'm network infrastructures engineer and project manager (specialized on home automation, mobile app and software for electronics projects). I discovered this app only yesterday and I played with it the whole day... ;-)
I want to provide my experience to give some advice, my 2 cents...
I cannot deep-test all the functions, but I'd like to start with a couple of things about "user experience".
  • Winbox is huge. It is at limit of usability in a 13" laptop screen, will never be usable on a 5" smartphone touch. You choosed the way to reproduce winbox in a smartphone. Ok, you did it, but how much is it usable? Too little. At this point you cannot think to restart from zero, but you can put a switch button below "safe mode" and switch between full current interface and a simplified, mobile optimized, and fast interface. The current interface can be usable with a tablet, but not with a smartphone. Just give it to a normal user and let it try!
  • On the left menu, when you enter a submenu, you miss the back button. The user should use the one of Android, but that usage don't matches his Android user experience for that kind of side menu. Please, add a "<-" button near the padlock icon (padlock on the left and back arrow on the right)
  • When a user navigate between menu items on the side bar, he arrives on the submenu (i.e.: "IP" then "Firewall"), then he lands on the corresponding first tab in winbox. Where are other tabs? On the three points icon on the other side of the screen. This is not intuitive, and the icon is too small for a thumb. Why don't you consider it as a 3rd level submenu on the sidebar? Or you use a swiper system (like leafing through pages of a book) Swiper correspond with the tab concept when transposing a desktop interface with a mobile one.
Hope this can help and not let you angry... ;-)
vortex
Thu Jan 19, 2017 7:16 pm
v45 is working on:
ISSUES:
It crashes opening the Switch page after watching Traffic on an interface.
ronniee
Mon Jan 23, 2017 10:18 pm
also official iOS application for setup/manage MikroTik routers are needed
if MikroTik has decided to enter in SOHO category, this kind of application it has to be
you can see the others tp link, ubiq …
don’t waste time
bcall
Mon Feb 20, 2017 8:07 pm
This app was unstable and hard to use in November/December last year. Now, it's starting to look nice and perform well. Great job, Mikrotik!
To those of you that think this is a futile effort because a 5" device is too small, I offer these suggestions:
1) Provide constructive feedback to the Mikrotik team, including what your most critical tasks are within an app like this, where the app is not doing well, and where it is doing well
2) You might want to consider not trying to manage your entire network from a smart phone. Security aside, you're putting an awful lot of faith in a platform (Android, iOS, WIndows Phone, etc) that was never designed for what you're trying to use it for.
paams
Tue Feb 21, 2017 7:59 am
Hello There! For a quite long time i have been looking for such a tool where i could use and configure my Mikrotik devices at the top of the tower, as it always been very difficult to configure and make antenna alignment with taking a heavy laptop at the top of the tower alone at remote tower site. I have given try by downloading this TikApp from Google Play and it run smooth on my android smartphone at my NOC. Will soon give try to this in the field at remote tower site. A great piece of tool from Mikrotik to work on Android OS. I really appreciate Mikrotik for this. :) :)
Secondly, i have give try to download this apk TikApp tool from provided direct link at Mikrotik download page at http://www.mikrotik.com/download/share/ ... 0_0_29.apk , but i didn't get this apk file there and this link landed at only Mikrotik main download page i.e. https://mikrotik.com/download and not at http://www.mikrotik.com/download/share/ ... 0_0_29.apk exactly. May i know please where this apk file located on this download page. Thanks.
lexell
Re: Tik App, MikroTik android utility ALPHA test
Mon Mar 13, 2017 10:19 am
Adding to my previous feedback:
  • Why was the menu design recently changed from WinBox-like two-column popup to in-line submenu slideouts? This imho hinders working speed and worsens the UI by requiring much slower and accuracy-requiring scrolling instead of occasional (and much faster) back button tap. Most often I'm accessing the IP submenus and in the old UI design after tapping the IP menu I was immediately able to tap more than half of its submenus as their column replaced the top-level column (which was logical seeing that I wanted to access some of the IP subsections and was not interested in other top-level sections anymore for the time being). I could also "overscroll" to the bottom by one fast swipe (where the second half of IP entries would quickly all be available). I could even muscle-memorize the specific subsections' placement. Now it pops the submenu into the middle of the top-level column and I have to tediously scroll again to get even to that first 13 or so items. I also can't overscroll to the bottom for the last 13 entries as the 1st level menu still occupies a large part of the column then. How was this change decided on? Was it even mentioned in the Play Store changelogs? If it's because of being better-suited for tall tablets in portrait mode, it shouldn't also be applied to small phone screens (or tablets in landscape mode). A settings toggle for phone vs. tablet UI layout would then be relevant.
  • The changelogs got pretty terse. From "more bug fixes" I have no idea if the new release fixes any of the issues I've reported before and I also don't know what new to check for further feedback. As of now this is an app for alpha testers, we're used to read changelogs, we can handle a bit more verbose ones (look at RouterOS ones - and I'm not on the RC branch...). Several latest versions also went without any annoucement in this thread (and Google Play doesn't show older versions or changelog history which then effectively makes it impossible to track the development process, further hindering the possibility of proper feedback).
Edit:
[*]When a user navigate between menu items on the side bar, he arrives on the submenu (i.e.: "IP" then "Firewall"), then he lands on the corresponding first tab in winbox. Where are other tabs? On the three points icon on the other side of the screen. This is not intuitive, and the icon is too small for a thumb. Why don't you consider it as a 3rd level submenu on the sidebar? Or you use a swiper system (like leafing through pages of a book) Swiper correspond with the tab concept when transposing a desktop interface with a mobile one.[/list]
  • I also vote for the screen swiping system with a top row with directly tappable and scrollable tab IDs - exactly how individual Interface entries are already done now. The triple-dot button should instead be used for special command buttons which occupy the window's right side in Winbox (Torch, Cable Test, Blink et al. for Interfaces) - if there are any for that section. This would further streamline the app, make it more intuitive and increase working speed.
erebusodora
Mon Mar 13, 2017 12:44 pm
Stil no fixed in v. 0.0.51
ua3prq
Thu Mar 30, 2017 11:00 pm
Hello!
At this stage of development, the application already liked, because unlike existing similar already works! Phone Xiaomi RN3P.
Keep it up, Mikrotik!
fabvit
Thu Apr 20, 2017 6:53 pm
How can Tik-App access the QuickSet screen like the one in WebFig and WinBox?
fabvit
Fri Apr 21, 2017 10:03 am
I will try to rephrase my last post.
In both WebFig and WinBox there is the QuickSet page where I can chose from a list an WiFi Access Point to connect to.
Given that in the Tik App I was unable to find the QuickSet page, where can I , In the Tik App, see a list of available WiFi AP and then select one, write its password, and connect to it?
erebusodora
Mon Apr 24, 2017 1:10 pm
In version v.0.0.52 Ticket#2017031322000808 not fixed. Ping to same hosts's with TikApp TOTALY different with Winbox 3.11 . In TikApp ping show time=874 ms or time:unknow status timeout. In winbox 3.11 show real!!! ping time=0 or time =1 between MikrotikRb and hosts
http://www.kaolinovo.bg/raw/uploads/mikrotik/s1.jpeg
http://www.kaolinovo.bg/raw/uploads/mikrotik/s2.jpeg
hoftel
Mon Jun 12, 2017 1:24 pm
This app was recommended for me in Google Play store. Of course I immediately downloaded it and tried it out.
I love it! Since I am only a basic user I don't use many advanced features, but I love the fact that if my customers have problems I can check the severity of the problem immediately no matter where I am. Check capsman, is it online, is the cap online, check log... :)
Good job Mikrotik
idlemind
Sun Jun 18, 2017 7:54 pm
  1. Apply power to cAP Lite
  2. Connect Android phone to SSID broadcast by cAP Lite
  3. Launch TikApp
  4. Fail, no DHCP server on cAP Lite in default configuration from factory
The app will not work with the cAP Lite product. The default configuration that unit comes with is broken. The products documentation indicates it should be configured by default like almost all other MikroTik products; turn it on and get an IP at 192.168.88.0/24 but it doesn't. The configuration is missing a DHCP server and the Ethernet port is not setup as a WAN interface. I tried to post this in the release forums but got told to use WinBox w/Mac Telnet. Not a viable option if you're trying to streamline initial power-on configuration, especially with a tool like TikApp.
msatter
Sun Jun 18, 2017 8:18 pm
I think you have tried everything but did not use the recommended way.
Connect to wireless SSID “MikroTik” and open http://192.168.88.1 in your web browser.
The username is admin and there is no password. In case IP connection is not available, the
Winbox utility can be used to connect to the MAC address of the device.
As this app uses port 8291 and not the MAC address, it will not work with port 80 only devices.
vortex
Sat Aug 12, 2017 6:02 pm
Where is the latest apk?
csalcedo
Thu Aug 31, 2017 6:02 pm
anyone now how to import address and password into the app?
Shadeofspirit
Thu Aug 31, 2017 7:10 pm
near the address field there is a button - it opens the least of connections. at this least the button (looks like spanner) opens menu with import and export.
csalcedo
Thu Aug 31, 2017 7:55 pm
Yea I got that... What format does the file need to be in?
Shadeofspirit
Thu Aug 31, 2017 8:04 pm
it is a text file (passwords are also in clear text)
csalcedo
Thu Aug 31, 2017 8:57 pm
OK, now what format? spaces, coma newline for next device?
ipaddress, user, password, note ?
1.1.1.1, admin, admin, test
Shadeofspirit
Thu Aug 31, 2017 10:50 pm
some symbols i can't read (i don't know the format)
but the other is (all letters with CAPS are the settings, other - made by app):
��" hostADDRESS
keep-pwd loginYOURLOGIN pwdYOURPASSWORD
noteNOTE typeaddr group
secure-mode
Shadeofspirit
Thu Aug 31, 2017 10:51 pm
add one host to the list and export it
boldsuck
Sun Sep 03, 2017 4:29 pm
Hint:
You can change the "Encoding" under "Settings"
UTF-8 is almost always right nowadays.
cppprog
Sun Sep 03, 2017 11:03 pm
hi
why cant type in terminal in tikapp on android devices.only cursor blinking and soft keyboard not shown on screen to type.
jo2jo
Sat Oct 28, 2017 3:25 am
Just wanted to put in another request for an iOS version. The only similar app on iOS requires use of the MT API which we disable on our default configs ( + the app is expensive), we would much prefer an even basic version for iOS by Mikrotik which uses winbox pt 8291 by default.
thanks
it9mbz
Sun Nov 19, 2017 6:48 pm
Hi to everyone,
I'd like to use this app for check the beaming of a PtP link, but i can't find where is possible to read the signal strength as like in Wireless>Registration>(double click on item)>Signal in WinBox.
Is there somewhere this info in the app?
Thanks, Sergio.
msatter
Fri Nov 24, 2017 10:26 am
Using the app and going to the address section in IP - Firewall and having about 20.000 entries it does not display what I can understand.
Suggestion how to be able to make some lists visible.
  • only lists smaller then lets say 50 entries can be displayed and that includes 'All'
    lists with more then 50 are greyed out and are not selectable
    • it is possible that all lists are greyed out
WirtelPL
Sat Nov 25, 2017 10:27 pm
I'm connect to my RB951G-2HnD, but router not logged this fact.
EDIT: My mistake, router logged my connection. Sorry.
iphonedev
Thu Jan 04, 2018 1:51 pm
Following are the steps to follow for android utility ALPHA testing:
1) Apply as beta tester in the application
2) Install the application
3) Now the application has some accidental bugs or termination issues, but is expected as it is still in its infancy.
4) The best concept about the application is that it uses API to connect to RouterOS, but is compeleted directly with the port Winbox.
Let's halt how it goes with this tool that assurance much and it will behave itself was iOS.
Torontobb
Sat Jan 27, 2018 9:34 pm
If this app is not open source how can one be sure that data and access to routers are not logged, shared, or misused?
What is the guarrantee here to expose oneself to a third private party?
This is a serious concern.
Chupaka
Sun Jan 28, 2018 9:10 am
RouterOS is not open source, you cannot be sure that data and access to routers are not logged, shared, or misused :)
So you either trust MikroTik, or don't use its software and hardware
Cha0s
Mon Jan 29, 2018 9:24 pm
Sniff all the data that come in and out of your android device and see if it tries to connect to anywhere else beside your router.
I have to admit that it is a bit oxymoron to have "serious" concerns about 3rd party data exposure when you use android which is pretty much spyware on its own :P
JimmyNyholm
Tue Jan 30, 2018 12:44 am
Android is a virus :lol:
LucZWFM
Tue Jan 30, 2018 10:09 am
I am sorry to say, but I really do not like the Tikapp at all... It would be much nicer to have something that looks much more like winbox available for Android and iOS.
jimmyz
Sat Feb 03, 2018 3:21 pm
Hello, a direct link to the apk would be nice. (Not everyone has an account to Gplay).
Or maybe a public folder with directory listing of current and all previous versions!
Thank you :D
LShadow77
Sat Feb 03, 2018 10:31 pm
Hello! When will you develop the btest versions for android and linux? My Internet service provider has its own btest server for reliable measurement of speed it provides. I often use this in my job but i'm forced to run btest on the windows lap-top only. However, it would be desirable to use my android device for this measurement purpose. Also it would be pretty desirable to run the btest's server and client on routers under OpenWRT operation system which is kind of linux. Whether there will be it sometime? I hope for answer, thank you and sorry for my bad english.
ErfanDL
Sat Feb 03, 2018 10:36 pm
Please add dark theme
jimmyz
Wed Feb 21, 2018 12:48 pm
Someone please point me a place for a genuine latest version.
Chupaka
Wed Feb 21, 2018 1:56 pm
Here is it: https://play.google.com/apps/testing/co ... oid.tikapp
normis
Wed Feb 21, 2018 1:57 pm
Current Tikapp is basically a Winbox copy. What else did you expect?
Chupaka
Wed Feb 21, 2018 2:09 pm
By the way, I cannot find current wifi interface frequency - it's on Status page of WinBox, and in TikApp, there's no 'Channel' line in Status tab.
katem07
Wed Feb 21, 2018 2:23 pm
I'm using it for monitoring only , not for control
But new to me to know that Tik App is an official app and supported by Mikrotik
Tnxs Mr.Normis you did nice.
normis
Wed Feb 21, 2018 4:08 pm
how about
wlan1 > Wireless > Frequency
and also the Channel info in the Status tab
Chupaka
Wed Feb 21, 2018 6:49 pm
It's "auto"
as I said,
:( Only Last Linu Up/Down Time and Link Downs
yhfung
Wed May 09, 2018 10:41 am
When I attented the MUM Japan 2018 yesterday via YouTube, one of your colleague mentioned that iOS Tik App is coming. Please advise when will the iOS one be available for use?
docmarius
Wed May 09, 2018 7:52 pm
...Please advise when will the iOS one be available for use?
You mean the Apple or the Cisco IOS?
msatter
Wed May 09, 2018 7:55 pm
Cisco sucks in making tablets. ;-)
mica
Sat May 26, 2018 5:30 am
+1 need tik app for ios devices
TheDon
Mon May 28, 2018 7:41 pm
...and PLUS Another!
I've tried to use the web interface from an iPhone - and it is not great.
In a day and age of mobility and 'do it on your phone', iOS app would be welcomed!
skept2it
Wed May 30, 2018 12:13 pm
Hi
I like the android app (on phone and tablet), specially now with the color support for queues.
Possible improvements:
- Would be great if you could select your own "favorites" and add to home screen from what you want to look at quickly (like "queue tree" for example).
Or like sub pages from IP / firewall etc.
- Also on the first screen (CPU load etc.) show directly last critical issue the system logged ?
Would allow to be faster/more productive with the app
msatter
Thu Jun 07, 2018 12:17 pm
Thanks for the update to 0.68 and the TikAPP does now work again with the secure login.
ronniee
Mon Jun 18, 2018 2:14 pm
any news about IOS version?
shahbazian
Trainer
Trainer
Sun Jun 24, 2018 4:32 pm
TikApp stable version when?
Sent from my SM-G950F using Tapatalk
Chupaka
Mon Jun 25, 2018 11:35 am
Well, current version is quite stable. If it's unstable for you - please write to support@mikrotik.com with detailed description of your problem.
shahbazian
Trainer
Trainer
Mon Jun 25, 2018 12:40 pm
There is no problem.
Just for google play store issue.
Chupaka
Mon Jun 25, 2018 12:52 pm
What issue? You just need to click a button once :)
pietroscherer
Trainer
Trainer
Mon Jun 25, 2018 2:02 pm
+1 :D
jebz
Tue Jun 26, 2018 2:38 am
I like these suggested features. :-)
ronniee
Tue Jun 26, 2018 7:19 am
+1 :D
and also a dude client for IOS/ipad ?
thebiggboss78
Sat Aug 25, 2018 11:35 am
+1 :D
Any updates on that iOS version? Official Tik-app for iPad would be a lifesaver!!
antispam
Thu Sep 06, 2018 11:49 am
some leaked photos of iOS version.
https://twitter.com/mikrotik_com/status ... 6277917696
Could this design be on android also?
https://imgur.com/a/xOQIUEa
Chupaka
Thu Sep 06, 2018 11:53 am
And 6.43 version :)
Samar
Sat Sep 15, 2018 2:39 pm
Sveiki Normis.
Publicējiet caur "apple test flight"?
Hi Normis.
Publish on Apple TestFlight?
TikApp for iOS
ronniee
Tue Sep 18, 2018 10:24 am
alpha beta test option, for TikApp on IOS?
come on
antispam
Fri Sep 28, 2018 11:02 pm
Your prayers have been answered https://testflight.apple.com/join/wGEkmFU9
Sweet sound of routing
Samar
Sat Sep 29, 2018 2:03 pm
It’s exelent! Thank you!
vortex
Tue Oct 02, 2018 6:08 pm
I need the latest apk.
raffav
Fri Oct 05, 2018 7:46 pm
On IPad air 1 iOS 12 it crash when I open some mk device (all is using beta ros version)
Sent from my XT1580 using Tapatalk
raffav
Sat Oct 06, 2018 4:41 pm
Maybe is time to create a iOS thread
Also like the new page quick viewer
Hope to see this on android version too
nabilx
Sun Oct 14, 2018 3:33 am
When this awesome Main menu will come to the android version?
rushlife
Wed Oct 17, 2018 1:18 pm
I will be very disappointed if version for Apple iOS will be better then version for Android. I am a "little bit" for linux like (based) devices, not for Apple proprietary sh*ts.
normis
Wed Oct 17, 2018 2:42 pm
Funny conflict in your sentence :D You like it, but you don't want it.
nescafe2002
Forum Veteran
Forum Veteran
Wed Oct 17, 2018 5:46 pm
Yeah, please stop development for iOS immediately because one user dislikes Apple..
saper2
Sun Oct 21, 2018 4:42 pm
Sorry but it's already 2 users, I don't like bitten-apple too :D
DummyPLUG
Sun Oct 21, 2018 7:55 pm
Make it 3, an Apple a day scare admin away.
filipelias
Tue Oct 30, 2018 1:18 am
Hi, I like the design overhaul a lot. I've noticed a few bugs. On the main screen after logging in, the app is prompting me to update to the latest version, but I have already the latest version. Here are a few screenshots:
raffav
Tue Oct 30, 2018 2:02 am
@filipelias Your Firmware(BootLOADER) need an update, not software(RouterOS)
I committed the same "bug" as you
Chupaka
Tue Oct 30, 2018 6:25 am
Yeah, the same confusion :) It took me a dozen minutes to understand that it's not about RouterOS itself
P.S. In Advanced Settings, every submenu has duplicated items for me:
nescafe2002
Forum Veteran
Forum Veteran
Tue Oct 30, 2018 6:28 am
Comes with the phone. You also have double battery indicators and alarm clocks :)
erebusodora
Tue Oct 30, 2018 9:18 am
With new version bug is fixed. New version is NICE ;) Very NICE
Chupaka
Tue Oct 30, 2018 9:28 am
Is it only me, or CAPsMAN is completely missing in new app?..
ognjen
Tue Oct 30, 2018 5:08 pm
I have CAPsMAN menu in TikApp, look below
Now version of TikApp is soooo good, ty mikrotik developers :)
Simono
Tue Oct 30, 2018 5:35 pm
New version could save settings topic display etc if I enable it.
Wysłane z mojego TA-1021 przy użyciu Tapatalka
Chupaka
Tue Oct 30, 2018 7:05 pm
Thanks, clearing the cache from main screen returned it back. And reordered all the rest menu items :)
msatter
Tue Oct 30, 2018 7:28 pm
WOW....I am speechless, good that I can still type. :wink:
Looks great and blistering fast. For the firstime I could see the Addresslist in Firewall. It timed out but still I could see addresses.
Now don't have to start the computer to use Winbox and now I trust myself to do stuff from the tablet.
Many THANKS!!
pacmanfan
Wed Oct 31, 2018 4:49 pm
In the new iOS app I have some trouble with PPPoE.
1) In PPP Interface, if I select a dynamic PPPoE interface the interface stats never load and the Winbox connection complete stops working. I have to task kill and restart iOS Winbox to do anything else on the router, but I consistently cannot get dynamic PPPoE interfaces to load. See:
2) Editing PPP Secrets, the Winbox connection sometimes locks up when loading the secret's data. This is inconsistent, and I can't reproduce this morning, so maybe was fixed in 0.20? Will update this if I notice more.
3) Option to remove items in PPP Active Connections is missing, like we have on desktop Winbox.
Users browsing this forum: No registered users and 15 guests
