Happy to helpThanks for that Quindor! I am aiming to consolidate. I tried all sorts of things with the CRS but just couldn't get it, even with a very basic NAT config, to hit over 30ish. I don't mind leaving it as a switch, it replaced my excessive cisco 2960s.
I'll order one of these and see what I can get out of it. Thanks again for the quick response!
/interface wireless
set [ find default-name=wlan2 ] adaptive-noise-immunity=ap-and-client-mode antenna-gain=1 band=5ghz-a/n/ac channel-width=20/40/80mhz-Ceee country=russia \
disabled=no distance=indoors frequency=auto hw-protection-mode=rts-cts mode=ap-bridge name=wlan-5GHz ssid=78 wireless-protocol=802.11
root@Jolla nemo# iw wlan0 link
Connected to ************(on wlan0)
SSID:
freq: 5180
signal: -40 dBm
tx bitrate: 390.0 MBit/s
1 R name="wlan2" mtu=1500 l2mtu=1600 arp=enabled interface-type=Atheros AR9888 mode=ap-bridge
frequency=5180 band=5ghz-onlyac channel-width=20/40/80mhz-Ceee scan-list=default wireless-protocol=802.11 vlan-mode=no-tag vlan-id=1
wds-mode=disabled wds-default-bridge=none wds-ignore-ssid=no bridge-mode=enabled default-authentication=yes default-forwarding=yes
default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=no security-profile=default compression=no
I was having similar problems, please see http://forum.mikrotik.com/viewtopic.php?f=13&t=105764I would like to give you guys a heads up and ask for advice, because it seems there is a faulty series of HAP AC with somehow corrupted switch causing terrible performance on ethernet ports - I still hope its some kind of software issue (or maybe wrong config) but support is not responding to our emails, so we are kept in the dark here...
More information can be found here: http://forum.mikrotik.com/viewtopic.php?f=3&t=106176 If anybody knows what can cause this I would love to hear about it.
based on my experienceIs there any guidance on how many active users/devices can successfully link up to a hAP ac? The 2nd gen UniFi AC units state they'll handle 200 concurrent users...
Also, what antennae are compatible with the hAP ac?
Thanks.
I follow the logic - however I recently asked my distributor about about doing an outdoor event and they recommended Ruckus saying:i think no matter the brand and no matter what marketing says:
maximum devices associated recommended are 50 per radio
of that 50 associated devices maximum 25-30 devices with concurrent traffic per radio
I know they have BeamFlex+, but the detail says it's about synthetic polarisation and I find it hard to believe that offers the claimedRuckus would be a better option as each AP can cover up to 500 users and is designed for Density amongst users in these types of environments
, but perhaps it really is worth paying top dollar for tog dog equipment.8X expanded coverage
I know they have BeamFlex+, but the detail says it's about synthetic polarisation and I find it hard to believe that offers the claimedRuckus would be a better option as each AP can cover up to 500 users and is designed for Density amongst users in these types of environments, but perhaps it really is worth paying top dollar for tog dog equipment.8X expanded coverage
Which country? US?My order delivery just changed again.
You could, but the US model will have a non-removable lock, so you can't change the country. This is now required for new products, as per new rules in US.So, can I order the international model and set my country to United States? Will it automatically only use the legal US frequency range? I don't want to get into trouble. The US resellers are nearing June now.
Wish I knew that sooner.You could, but the US model will have a non-removable lock, so you can't change the country. This is now required for new products, as per new rules in US.So, can I order the international model and set my country to United States? Will it automatically only use the legal US frequency range? I don't want to get into trouble. The US resellers are nearing June now.
Yes, you can order the international model and use it, however it's your responsibility to set proper country in settings. I believe the US-one is the same as the international one except the country setting is enforced by the wireless chip firmware rather than by ROS.So, can I order the international model and set my country to United States? Will it automatically only use the legal US frequency range? I don't want to get into trouble. The US resellers are nearing June now.
They (Roc-Noc) are such "teasers" aren't they..Just ordered the international version from Roc-Noc.
10 minutes later they called me back to tell me that can't sell it to me. "It's for export only." "No idea when the US version will be available."
I called him today to see if his stock was real. He said basically the same. Thanks for tryingJust ordered the international version from Roc-Noc. 10 minutes later they called me back to tell me that can't sell it to me. "It's for export only." "No idea when the US version will be available."
From the hAP AC brochure, it shows as 29dBM for 2.4Ghz and 28dBM for 5Ghz. That's 794mW and 631mW respectively. Hope that helps.So I have a RB951G and fairly happy with the coverage however the wifi is dropping out until a reboot of the device brings it back. It's up to date at 6.34.4. I know that it shows a 1000mW power output for the wifi where the HAP AC doesn't mention the power. Can anyone offer any info on this? How do they compare?
Would the HAP AC fit into the Inspot with its case?Got my hAP AC from EuroDK today, and with some minor modding of the bracket it fits perfectly in the Stationbox Inspot. Also replaced the antennas, was much easier than anticipated (the glue comes away very easily with a hot air dryer). Now just need to get it mounted and enjoy my new AC wireless network .
Yes, it has the same dimensions as the RB951G, even down to the spacing of the plastic feet. To be honest this is probably the best way of doing things, I didn't get as large of an improvement as I'd hoped from using custom omni antennas.Would the HAP AC fit into the Inspot with its case?Got my hAP AC from EuroDK today, and with some minor modding of the bracket it fits perfectly in the Stationbox Inspot. Also replaced the antennas, was much easier than anticipated (the glue comes away very easily with a hot air dryer). Now just need to get it mounted and enjoy my new AC wireless network .
according to data-sheets tx power and rx sensitivity are very similarSo I have a RB951G and fairly happy with the coverage however the wifi is dropping out until a reboot of the device brings it back. It's up to date at 6.34.4. I know that it shows a 1000mW power output for the wifi where the HAP AC doesn't mention the power. Can anyone offer any info on this? How do they compare?
We have made some tests already with multiple Android phones and didn't notice any issues with third chain however we do understand that there are various ways to configure AP and maybe some configuration you made cause this.Duplicate post about a hAP AC related problem that I encountered two days ago:
I noticed that when all three chains were enabled on the 2.4GHz interface of the hAP AC, not all devices could associate. For example two phones, one with Android and the other with Windows Phone could not connect, even at 2m away. When I turned off chain 2 (the third chain) the devices which were not associating before, could connect successfully. Same with chain 1, although speeds seemed to be lower in this case.
The 5GHz interface does not seem to have such a problem. I think (I am not sure though) that this is something that occured lately. Unfortuantely, it was not reported earlier so I cannot give any further info. But my observation above was made two days ago, with RC45. It existed for at least two weeks back though.
Has anyone experienced similar behaviour?
/system logging add topics=wireless
Yes, according to the rules you are. AFAIK u can buy & import non-aprvd hw but you can't sell it to anyone as a standard network eq.Ordered 2 from amazon...
So now I am an importer?
Come on.
I would like to do something with CapsMan. But it is really starting to look like an fcc thing here in the states.Yes, according to the rules you are. AFAIK u can buy & import non-aprvd hw but you can't sell it to anyone as a standard network eq.Ordered 2 from amazon...
Come on.
This sounds ridiculous, but in fact makes sense - it allows you to buy any chips from e.g. Atheros as long as they are not end-user products.
Please guys, what shows your Health on RouterOS v.6.35 & fw. 3.31!!!
To TaurusThree:Please guys, what shows your Health on RouterOS v.6.35 & fw. 3.31!!!
6.35/ 3.31What ver. RouterOS and firmware on your RB?.
Hi guys,
Just got a hAP AC and connected it out of the box. It sits just behind me for try-out.
I connected to it and set a wifi password, nothing else is changed for starters.
I fired up Xirrus WiFi Analyzer an ViStumbler and see a difference in 2.4 and 5 GHz signal strength: -25 dbm on 2.4 and -50 dbm on 5 GHz. Is this normal? I would expect them to be close together, because it is only 1 meter distance?
Or is some additional changes in settings required?
It is just my first steps in the Mikrotik world so I might be wrong off course.
You can see the allowed channels and TX power with "country-info":Well, I set the country correctly, Netherlands in fact and I don't see much difference. Is there also difference between countries in the EU?
/interface wireless info country-info netherlands
country: netherlands
ranges: 2402-2482/b,g,gn20,gn40(20dBm)
2417-2457/g-turbo(20dBm)
5170-5250/a,an20,an40,ac20,ac40,ac80,ac160(20dBm)/passive
5250-5330/a,an20,an40,ac20,ac40,ac80,ac160(23dBm)/passive
5490-5710/a,an20,an40,ac20,ac40,ac80,ac160(27dBm)/passive
5190-5310/a-turbo(20dBm)
5180-5300/a-turbo(20dBm)
5520-5680/a-turbo(27dBm)/passive
5510-5670/a-turbo(27dBm)/passive
902-927/b,g,g-turbo,gn20,gn40(30dBm)
/interface wireless set wlan2 dfs-mode=radar-detect frequency=auto
You can add an USB drive for (log) storage, if needed.Please consider releasing a 2nd release-version of this device with more NAND, at least 32MB.
I like the device, and i like the proce, but 16MB NAND is almost to less to debug the device.
I just had to uninstall most packages including advanced-tools, ipv6, lte, ... just that the device allows debugging ipsec without bootloop.
thank you!!
at over 140 dollars the pennies to increase the storage amount should have been a no brainer. i could understand it on 30-50 dollar device...You can add an USB drive for (log) storage, if needed.Please consider releasing a 2nd release-version of this device with more NAND, at least 32MB.
thank you!!
that a good point actually.Please consider releasing a 2nd release-version of this device with more NAND, at least 32MB.
thank you!!
/interface wireless
set [ find default-name=wlan2 ] band=5ghz-onlyac channel-width=\
20/40/80mhz-eeCe country=russia disabled=no distance=indoors frequency=\
5300 frequency-mode=regulatory-domain mode=ap-bridge name=WiFi_5Ghz \
security-profile=profile1 ssid=SoluS_5Ghz_MKTK wireless-protocol=802.11
I have the same problem - low speed and stability issues (disconnects for ex.). also Google Nexus 5 can't connect in 5 GHz with 802.11AC-only mode, but with ZyXEL wac-6503d-s Nexus 5 works in 802.11ac fine.Hi guys,
I've just bought HAP AC instead of 750GL and I have some difficulties with configuring WiFi.
I have my home network like that:
Before HAP AC I used TpLINK Archer C7 (5Ghz AC Wifi) to connect my laptop with AzureWave AW-CE123H (5 Ghz AC 2*2) wifi card. It was connected to LAN5 and worked just as AP.
I test connection speed by copying file from my NAS via SMB.
When using Archec C7 I get about 330 mbps (laptop shows connection speed 667 mbps):
But when I using HAP AC as WiFi Access Point, I only have about 150 mbps (laptop shows connection speed 400 mbps):
WiFi config:What am I doing wrong?Code: Select all/interface wireless set [ find default-name=wlan2 ] band=5ghz-onlyac channel-width=\ 20/40/80mhz-eeCe country=russia disabled=no distance=indoors frequency=\ 5300 frequency-mode=regulatory-domain mode=ap-bridge name=WiFi_5Ghz \ security-profile=profile1 ssid=SoluS_5Ghz_MKTK wireless-protocol=802.11
/interface wireless
set [ find default-name=wlan1 ] adaptive-noise-immunity=ap-and-client-mode antenna-gain=2 band=2ghz-onlyn channel-width=20/40mhz-Ce country=russia disabled=no \
distance=indoors hw-protection-mode=rts-cts mode=ap-bridge multicast-helper=full name=wlan-2.4GHz ssid=78 tx-power=23 tx-power-mode=all-rates-fixed \
wireless-protocol=802.11 wmm-support=enabled
set [ find default-name=wlan2 ] adaptive-noise-immunity=client-mode band=5ghz-a/n/ac channel-width=20/40/80mhz-eCee country=russia disabled=no distance=indoors \
frequency=auto hw-protection-mode=rts-cts max-station-count=20 mode=ap-bridge multicast-helper=full name=wlan-5GHz preamble-mode=long ssid=78 tx-power=20 \
tx-power-mode=all-rates-fixed wireless-protocol=802.11 wmm-support=enabled
Can you show the output of: /system health printHmm... Yes, I see that signal strength of HAP AC is a bit lower than Archer C7, but they both have too weak signal for my other room behind 0.7 meter brick wall, so it's not a big problem. I'd like to have maximum speed in room with HAP AC. My laptop is about 3-4 meters from access point. And yes, my HAP AC mounted vertically - about 1 meter above the floor.
Meanwhile, just selecting another frequency (5220 Mhz) I've got conection with theoretically 867 mbps as with Archer C7.
But SMB transfer speed is too slow again - about 220 mbps:
CPU load is below 40%. What is limiting factor now?
[admin@MikroTik] /system health> print
voltage: 23.8V
temperature: 61C
Try to cool the router.Can you show the output of: /system health printCode: Select all[admin@MikroTik] /system health> print voltage: 23.8V temperature: 61C
voltage: 23.9V
temperature: 53C
Does it change the situation?Today is a bit coolier...
for my installation with stability and perfomance issue - no...Does it change the situation?Today is a bit coolier...
Unfortunately - no... Now it's about 47*C and speed ia about 200 MbpsDoes it change the situation?
Connect via Winbox "Neighbours" to MAC Address of the device. Username and password remain the same.I screwed up setting. Can not connect to the unit. How can I reset the hAP AC? It is powered through POE.
It should easily achieve much higher speeds. What kind of configuration did you put in? In my tests (you can find here) it could do 1Gbit of NAT using fastpath/fasttrack without a problem? For a real internet speedtest it did 200Mbit (Max of my internet connection) with about 16% CPU usage.Hello,
Just bought the hap ac and set it up as a router with wireless. I am measuring throughput speed on the internet connection and comparing it to a Sophos SG135 UTM with accesspoints (AP-55c) connected to it for wlan.
What should the throughput be on the HAP ac? I am measuring a maximum of 105-130 Mb/s outgoing, when my connection is a 500 Mb/s line. That is for wireless connections and also wired lan connections.
When I connect and run through the Sophos UTM I'm getting 400+ Mb/s wireless and around 480 Mb/s for the wired connection.
Network topology is exactly the same, except for the router/wlan devices obviously.
It seems that the HAP ac throughput is not up-to-par for this generation internet speeds.
I started with the standard AP config, then modified that with firewall rules, mangle rules, ques and addresslists that are used in the firewall rules. Didn't do much else.it could do 1Gbit of NAT using fastpath/fasttrack without a problem? For a real internet speedtest it did 200Mbit (Max of my internet connection) with about 16% CPU usage.
Could you try with the queues and mangle rules disabled? Not saying you cannot use those, but depending on their configuration they can have a very big impact on performance. Try it with firewall and NAT only and see what speeds you get and then slowly re-enable to queues and mangle rules to see when it drops.I started with the standard AP config, then modified that with firewall rules, mangle rules, ques and addresslists that are used in the firewall rules. Didn't do much else.it could do 1Gbit of NAT using fastpath/fasttrack without a problem? For a real internet speedtest it did 200Mbit (Max of my internet connection) with about 16% CPU usage.
Ok, I did a complete reset and setup the MT with quicksettings as a Dual Home AP. So almost no (only basic) firewall etc. rules. My WAN connection has a downloadspeed of 500 Mb/s.Could you try with the queues and mangle rules disabled? Not saying you cannot use those, but depending on their configuration they can have a very big impact on performance. Try it with firewall and NAT only and see what speeds you get and then slowly re-enable to queues and mangle rules to see when it drops.I started with the standard AP config, then modified that with firewall rules, mangle rules, ques and addresslists that are used in the firewall rules. Didn't do much else.
Ok, can you provide some recommended settings for wireless? For ex. for Russia region.When talking about Wireless testing, make sure you enable 20/40/80MHz Channel setting, I have seen some of you who only have 20 or 40MHz for some reason. This, of course, will cut your speed in half or to 25%.
Can someone provide some recommended settings for wireless. HAP AC + iPad Pro 12.9, for maximum speed!Ok, can you provide some recommended settings for wireless? For ex. for Russia region.When talking about Wireless testing, make sure you enable 20/40/80MHz Channel setting, I have seen some of you who only have 20 or 40MHz for some reason. This, of course, will cut your speed in half or to 25%.
http://i.imgur.com/OXOZs7i.jpg - 100 mb ISP Speed. And HAP AC + iPad Pro 12.9. Simply amazing. Temperature of the device is 47 C. Big thanks to MikroTik professionals!!I'm not quite sure why you are asking these questions, wireless in a mikrotik device works the same as with other vendors? If you are unfamiliar with wireless in general, this is most often the best way setting up wireless.
There is no "Best" setting really. It depends on your environment, placement of the AP and your client, type of client, etc.
Do an airscan and a frequency usage scan to see which channel can best be used and how much of the spectrum is still free. Be sure to pay attention to 20Mhz, 40Mhz or 80Mhz width. You can find charts about this online.
When performance testing, select a free 80Mhz band and test with your devices. 80Mhz will give you the best throughput, but choosing 40Mhz or even 20Mhz is sometimes preferably when the spectrum is "dirty" or when range is more important then throughput.
And that should be it. With that said you should achieve the best wireless performance.
What I did notice is that trying to place the access-point most optimally can defintly help with the signal. Make sure there are no big objects blocking the line of sight to your device. Or, if there are walls and such in between the path to minimize that as much as possible. Things like reinforced concrete or an aquarium or even a big flat screen TV can really kill you signal. Also try mounting the access-point to the ceiling or high up on the wall so the signal can spread around and bounce freely. Lots of variables to consider!
What's new in 6.36rc13 (2016-May-17 12:20):same voltage sensor as problem as above
Voltage reading shows 16V PSU is at 24 V (measured)
Can this be fixed with software or do I need to RMA ?
same problem with my hAP ac. And I think this is HW problem too, because my friend bought hAP ac and expirience same problems.....I have international unit. I did change country but with no effect - it looks like HW problem.
I have connected the less affected unit and tried this again with all channels. It works on 1 - 6 but on 7-13 I am not able to connect. Sometimes it shows "connected" in mikrotik log but few seconds later it disconnects. It acts like you have very poor signal or extreme interference.
I even tried different chains setup at problematic channels:
with chains 0+1+2 I am not able to connect
with only chain 0 it works but only few Mb/s
with only chain 1 it works but only few Mb/s
with only chain 2 I am able to connect but works as badly, I am not able to complete speedtest.
with chain 0+1 or 0+2 I am not able to connect.
And with configuration 1+2 I don't even see the network in other devices!
And yes, both chains are Tx+Rx and Yes, with single chain I saw the network on all chains and yes, I check on both devices and even after 1minute I don't see the network! Quite mystery...
/interface wireless
set [ find default-name=wlan1 ] adaptive-noise-immunity=ap-and-client-mode antenna-gain=2 band=2ghz-onlyn \
channel-width=20/40mhz-Ce country=russia2 disabled=no distance=indoors frequency=auto frequency-mode=\
regulatory-domain hw-protection-mode=rts-cts mode=ap-bridge name=wlan-2.4GHz ssid=78 tx-power=17 tx-power-mode=\
set [ find default-name=wlan2 ] adaptive-noise-immunity=ap-and-client-mode antenna-gain=1 band=5ghz-a/n/ac \
channel-width=20/40/80mhz-Ceee country="united states" disabled=no distance=indoors frequency-mode=\
regulatory-domain guard-interval=long hw-protection-mode=rts-cts max-station-count=20 mode=ap-bridge name=wlan-5GHz \
ssid=78 wireless-protocol=802.11 wmm-support=enabled wps-mode=disabled
add name=bridge1
set [ find default-name=ether1 ] name=ether1-wan
set [ find default-name=ether2 ] name=ether2-lan
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1-wan keepalive-timeout=disabled name=pppoe-out1 password=******** use-peer-dns=yes user=********
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce disabled=no frequency=2422 mode=ap-bridge ssid=RB962UiGS-2HnT wireless-protocol=802.11 wps-mode=disabled
set [ find default-name=wlan2 ] band=5ghz-onlyac channel-width=20/40/80mhz-Ceee disabled=no mode=ap-bridge ssid=RB962UiGS-5HacT wireless-protocol=802.11 wps-mode=disabled
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" mode=dynamic-keys wpa2-pre-shared-key=********
add name=dhcp_pool1 ranges=192.168.100.2-192.168.100.254
add add-arp=yes address-pool=dhcp_pool1 disabled=no interface=bridge1 lease-time=1d name=dhcp1
add bridge=bridge1 interface=ether2-lan
add bridge=bridge1 interface=wlan1
add bridge=bridge1 interface=wlan2
add address=192.168.100.1/24 interface=bridge1 network=192.168.100.0
/ip dhcp-server config
set store-leases-disk=never
/ip dhcp-server lease
add address=192.168.100.99 client-id=1:64:51:6:d8:60:ee mac-address=64:51:06:D8:60:EE server=dhcp1
add address=192.168.100.100 client-id=1:64:51:6:d8:60:ec mac-address=64:51:06:D8:60:EC server=dhcp1
add address=192.168.100.0/24 gateway=192.168.100.1
add action=src-nat chain=srcnat comment=NAT to-addresses=mywanipaddress
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set irc disabled=yes
set h323 disabled=yes
set sip disabled=yes
set pptp disabled=yes
/ip service
set telnet disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=pppoe-out1 type=external
add interface=bridge1 type=internal
/system clock
set time-zone-name=Asia/Shanghai
add chain=forward action=fasttrack-connection connection-state=established,related
add chain=forward action=accept connection-state=established,related
add chain=forward action=drop connection-state=invalid
Mine is working just fine.Most likely, the root cause should be fast track/path was broken on HAP AC.
Any comment?
1. pppoe client use ether2 to dial out, Bridged ether3, wlan1,wlan2, fast track is checked, test was always through ether3 (even i directly plug ether2 to desktop pc still the same)Mine is working just fine.Most likely, the root cause should be fast track/path was broken on HAP AC.
Any comment?
1) what interfaces are involved in testing? Ip pppoe make sure that you have version that have pppoe fastpath support added, if wireless make sure that you are running proper wireless package.
2) do you see fastpath counters counting?
1) with pppoe you need RouterOS version at least 6.35, and make sure that there are no encryption.Even fast track is chekced, the NAT speed are exactly the same when it is not enabled. If a performance feature has no improve on performance, what's the meaning of enabled or not?
Did your HAP AC can exceed 200Mbps NAT?
Thanks.
Hi, macgaiver1) with pppoe you need RouterOS version at least 6.35, and make sure that there are no encryption.Even fast track is chekced, the NAT speed are exactly the same when it is not enabled. If a performance feature has no improve on performance, what's the meaning of enabled or not?
Thanks.
2) in /ip settings and /bridge settings, and in /ip firewall connection there are fastpath and fasttrack counters.
I can run all 500Mbps that i have at home getting only ~60% load, but i can reach those speeds only while torrenting. and i chronically dislike speedtest .
Security profile need to be without encryption.Hi, macgaiver
What encryption you mean? Those mschap/pap/... under pppoe client settings?
Would you post your exported configuration? I go check these settings soon.Security profile need to be without encryption.Hi, macgaiver
How do you test? Have you tested what speed can be achieved over cable?I'm having trouble getting anything above 320/330 Mbps over WiFi from hAP ac , this is with a 80MHz 2x2 client.
Serving data over a single http/tcp connection from a really simple http server I wrote in go, that's running on my tiny old hp n40l and serving a random block of bytes in a loop to my 2015 chromebook pixel ls.How do you test? Have you tested what speed can be achieved over cable?
What is it BF? Which country settings is better? I need maximum perfomance and signal strengthLittle differences between 2.4 and 5 are normal since according to the documentation, but in your case probably difference comes from country regulations.
Remember that 802.11ac is way more complicated (with BF, DFS) than 802.11n, so simple software analyzer may not be accurate.
2. You are using latest Firmware version;
3. You have enabled wireless-cm2/wireless-rep package;
FP package was deprecated and not supported anymore.What is better cm2 or fp for apple devices? What is it wireless-rep?
6.37 already has itAfter "rep" package wireless comes again?
iperf -c 192.168.1.253 -t 30 -i 5
Client connecting to 192.168.1.253, TCP port 5001
TCP window size: 22.5 KByte (default)
[ 4] local 192.168.1.10 port 57665 connected with 192.168.1.253 port 5001
[ ID] Interval Transfer Bandwidth
[ 4] 0.0- 5.0 sec 194 MBytes 325 Mbits/sec
[ 4] 5.0-10.0 sec 216 MBytes 363 Mbits/sec
[ 4] 10.0-15.0 sec 186 MBytes 313 Mbits/sec
[ 4] 15.0-20.0 sec 219 MBytes 367 Mbits/sec
[ 4] 20.0-25.0 sec 230 MBytes 387 Mbits/sec
[ 4] 25.0-30.0 sec 218 MBytes 366 Mbits/sec
[ 4] 0.0-30.0 sec 1.23 GBytes 354 Mbits/sec
My results:@alber you are awesome! Thank you very much for all your answers! :DYou can prvovide iperf command with intresting for you params, I will do these tests
I always use iperf2 from https://iperf.fr/iperf-download.php, if you want you can use iperf3 too but the command line switches are a bit different.
If you are using iperf (2) then use the following settings please:
server: "iperf -s -w 1MB"
1 Channel
client: "iperf -c xxx.xxx.xxx.xxx -w 1MB -R -P 1 -t 30"
4 Channels
client: "iperf -c xxx.xxx.xxx.xxx -w 1MB -R -P 4 -t 30"
16 Channels
client: "iperf -c xxx.xxx.xxx.xxx -w 1MB -R -P 16 -t 30"
A second set (if you are willing):
server: "iperf -s -w 64KB"
1 Channel
client: "iperf -c xxx.xxx.xxx.xxx -w 64KB -R -P 1 -t 30"
4 Channels
client: "iperf -c xxx.xxx.xxx.xxx -w 64KB -R -P 4 -t 30"
16 Channels
client: "iperf -c xxx.xxx.xxx.xxx -w 64KB -R -P 16 -t 30"
That should give us a good overview of total bandwidth attainable using one stream and multiple streams both using large block sizes and small.
Andiperf -c 192.168.1.9 -w 1MB -R -P 1 -t 30
Client connecting to 192.168.1.9, TCP port 5001
TCP window size: 1.00 MByte (WARNING: requested 1.00 MByte)
[ 4] 0.0-30.0 sec 1.96 GBytes 562 Mbits/sec
iperf -c 192.168.1.9 -w 1MB -R -P 4 -t 30
[ 7] 0.0-30.0 sec 547 MBytes 153 Mbits/sec
[ 5] 0.0-30.0 sec 568 MBytes 159 Mbits/sec
[ 4] 0.0-30.0 sec 415 MBytes 116 Mbits/sec
[ 6] 0.0-30.0 sec 444 MBytes 124 Mbits/sec
[SUM] 0.0-30.0 sec 1.93 GBytes 552 Mbits/sec
iperf -c 192.168.1.9 -w 1MB -R -P 16 -t 30
[ 4] 0.0-30.0 sec 110 MBytes 30.9 Mbits/sec
[ 6] 0.0-30.0 sec 102 MBytes 28.6 Mbits/sec
[ 5] 0.0-30.0 sec 133 MBytes 37.2 Mbits/sec
[ 8] 0.0-30.0 sec 145 MBytes 40.6 Mbits/sec
[ 9] 0.0-30.0 sec 107 MBytes 29.8 Mbits/sec
[ 10] 0.0-30.0 sec 120 MBytes 33.5 Mbits/sec
[ 7] 0.0-30.0 sec 127 MBytes 35.4 Mbits/sec
[ 13] 0.0-30.0 sec 89.5 MBytes 25.0 Mbits/sec
[ 11] 0.0-30.0 sec 108 MBytes 30.0 Mbits/sec
[ 14] 0.0-30.0 sec 120 MBytes 33.6 Mbits/sec
[ 16] 0.0-30.0 sec 124 MBytes 34.8 Mbits/sec
[ 15] 0.0-30.0 sec 106 MBytes 29.6 Mbits/sec
[ 12] 0.0-30.1 sec 112 MBytes 31.2 Mbits/sec
[ 19] 0.0-30.1 sec 99.8 MBytes 27.8 Mbits/sec
[ 18] 0.0-30.1 sec 146 MBytes 40.7 Mbits/sec
[ 17] 0.0-30.1 sec 130 MBytes 36.1 Mbits/sec
[SUM] 0.0-30.1 sec 1.83 GBytes 524 Mbits/sec
iperf -c 192.168.1.9 -w 64KB -R -P 1 -t 30
TCP window size: 65.0 KByte (WARNING: requested 64.0 KByte)
[ 4] 0.0-30.0 sec 580 MBytes 162 Mbits/sec
iperf -c 192.168.1.9 -w 64KB -R -P 4 -t 30
[ 4] 0.0-30.0 sec 250 MBytes 69.9 Mbits/sec
[ 6] 0.0-30.0 sec 231 MBytes 64.5 Mbits/sec
[ 7] 0.0-30.0 sec 251 MBytes 70.1 Mbits/sec
[ 5] 0.0-30.0 sec 250 MBytes 69.7 Mbits/sec
[SUM] 0.0-30.0 sec 981 MBytes 274 Mbits/sec
iperf -c 192.168.1.9 -w 64KB -R -P 16 -t 30
[ 4] 0.0-30.0 sec 124 MBytes 34.7 Mbits/sec
[ 6] 0.0-30.0 sec 124 MBytes 34.6 Mbits/sec
[ 5] 0.0-30.0 sec 124 MBytes 34.6 Mbits/sec
[ 9] 0.0-30.0 sec 124 MBytes 34.6 Mbits/sec
[ 8] 0.0-30.0 sec 124 MBytes 34.6 Mbits/sec
[ 10] 0.0-30.0 sec 124 MBytes 34.6 Mbits/sec
[ 11] 0.0-30.0 sec 124 MBytes 34.6 Mbits/sec
[ 12] 0.0-30.0 sec 124 MBytes 34.6 Mbits/sec
[ 14] 0.0-30.0 sec 124 MBytes 34.6 Mbits/sec
[ 18] 0.0-30.0 sec 124 MBytes 34.6 Mbits/sec
[ 17] 0.0-30.0 sec 124 MBytes 34.7 Mbits/sec
[ 16] 0.0-30.0 sec 124 MBytes 34.7 Mbits/sec
[ 19] 0.0-30.0 sec 124 MBytes 34.7 Mbits/sec
[ 7] 0.0-30.0 sec 124 MBytes 34.7 Mbits/sec
[ 13] 0.0-30.0 sec 124 MBytes 34.6 Mbits/sec
[ 15] 0.0-30.0 sec 124 MBytes 34.6 Mbits/sec
[SUM] 0.0-30.0 sec 1.94 GBytes 554 Mbits/sec
Did you try to netinstall on eth1 ?Hello,
Please help me.
I have rb952ui-5ac2nD.
A would like test routeros downgrade. But router is brick.
Download mipsbe5.26, and click downgrade.
Router reboot, and not respond.
Situation:
When not responded 30 minutes I reboot. Until reboot power and usr blink no other (1-2-3-4-5 if lan cable pluged, not blink).
I try netinstall 6.35.4, but not work.
I disable Windows7 firewall and setting notebook IP 10.1.1.10 Nm:255.255.255.0.
Netinstall setting: boot server enabled, client ip 10.1.1.5.
And press the router reset button 30second, but not work, netinstall is can not see the router.
Winbox can not see a router.
What is wrong?
Help me!
There is no settings for LAN portsI think you can disable all but power led.
Go to: System/LEDs
# aug/15/2016 17:09:46 by RouterOS 6.36
# software id = QRKI-8CAS
add admin-mac=XX:XX:XX:XX:XX:XX auto-mac=no name=bridgeLocal
/interface wireless
# managed by CAPsMAN
# channel: 2417/20-Ce/gn(20dBm), SSID: XXXXXX, CAPsMAN forwarding
set [ find default-name=wlan1 ] ssid=MikroTik
add authentication-types=wpa2-psk eap-methods="" management-protection=allowed mode=dynamic-keys name=XXX supplicant-identity="" \
wpa2-pre-shared-key=retrofit
/interface wireless
# channel: 5500/20-Ceee/ac(27dBm), SSID: XXX-5Ghz, CAPsMAN forwarding
set [ find default-name=wlan2 ] adaptive-noise-immunity=ap-and-client-mode band=5ghz-onlyac channel-width=20/40/80mhz-Ceee country=\
germany distance=indoors frequency=auto hw-protection-mode=rts-cts hw-retries=15 mode=ap-bridge multicast-helper=full \
security-profile=default ssid=MikroTik wireless-protocol=802.11 wmm-support=enabled wps-mode=disabled
/interface bridge filter
add action=drop chain=input dst-port=68 in-interface=wlan2 ip-protocol=udp mac-protocol=ip
add bridge=bridgeLocal interface=ether2
add bridge=bridgeLocal interface=ether3
add bridge=bridgeLocal interface=ether4
add bridge=bridgeLocal interface=ether5
add bridge=bridgeLocal interface=sfp1
add bridge=bridgeLocal interface=wlan2
add bridge=bridgeLocal interface=ether1
add bridge=bridgeLocal interface=wlan1
/interface wireless cap
set certificate=request discovery-interfaces=ether1 enabled=yes interfaces=wlan1,wlan2 lock-to-caps-man=yes
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=ether1
add dhcp-options=hostname,clientid disabled=no interface=bridgeLocal
/system clock
/system identity
set name=XXXXXXXXX
/system routerboard settings
set cpu-frequency=720MHz protected-routerboot=disabled
/tool romon
set enabled=yes secrets=XXXXXXXXX
Not sure if I'm reading this right, your solution was to replace all HAP ACs with old RB951 and not use the HAP ACs at all?
Update: Without CAPsMAN, wifi speeds are much, much better! I configured the wireless Interfaces on one of the HAP ACs directly without using CAPsMAN and now wifi speeds are up to 70/70Mbps+ for 11n and 280/280Mbps+ for 11ac.We bought 5 new HAP ACs for testing last week and are having huge wifi issues with them.
LAN/Ethernet performance is flawless but WiFi speeds are incredibly bad in for 11n and 11ac.
Even with a 1m distance to the routers, we get 2/10mbits (down/up) on 11n and 8/30mbits on 11ac.
We are using the same CAPsMAN setup we have been using with a lot of other mikrotik devices, including wap ac and hap ac lite. CAPsMAN shows negotiated speeds of 800Mps+ (3 chains) in the registration table for some devices. All 3 we have tested so far are showing the same behaviour. All are upgraded to the newest RouterOS 3.36 and have wireless-rep installed.
Any idea what the issue could be?
Works fine on mine..I have 19 HAP AC's and on none of them it is possible to get the 2.4 ghz working correctly ...
- i did also lower the tx power, still not working
if you use central forwarding with capsman, the router must re-encapsulate all data to be able to send to the controller.Update: Without CAPsMAN, wifi speeds are much, much better! I configured the wireless Interfaces on one of the HAP ACs directly without using CAPsMAN and now wifi speeds are up to 70/70Mbps+ for 11n and 280/280Mbps+ for 11ac.
It seems that CAPsMAN with local forwarding is causing a lot of issues. Maybe CAPsMAN is not configuring HAP ACs correctly?
Are you passing by any firewall filters? Try enabling fasttrack for that connection.Hm, tried to test network performance between windows PC connected by gigabit cable (cat.5e) to hAP AC and MacBook Pro connected by wifi 5ghz (1000-1300Mbit connection). Why transfer speed is so low?
Code: Select alliperf -c 192.168.1.253 -t 30 -i 5 ------------------------------------------------------------ Client connecting to 192.168.1.253, TCP port 5001 TCP window size: 22.5 KByte (default) ------------------------------------------------------------ [ 4] local 192.168.1.10 port 57665 connected with 192.168.1.253 port 5001 [ ID] Interval Transfer Bandwidth [ 4] 0.0- 5.0 sec 194 MBytes 325 Mbits/sec [ 4] 5.0-10.0 sec 216 MBytes 363 Mbits/sec [ 4] 10.0-15.0 sec 186 MBytes 313 Mbits/sec [ 4] 15.0-20.0 sec 219 MBytes 367 Mbits/sec [ 4] 20.0-25.0 sec 230 MBytes 387 Mbits/sec [ 4] 25.0-30.0 sec 218 MBytes 366 Mbits/sec [ 4] 0.0-30.0 sec 1.23 GBytes 354 Mbits/sec
Looks like it enabled.Are you passing by any firewall filters? Try enabling fasttrack for that connection.
add action=accept chain=forward comment="defconf: accept established,related" \
add action=accept chain=input connection-state=related
add action=drop chain=input disabled=yes in-interface=Smile
connection-state=new in-interface=wan
add action=drop chain=input connection-state=new dst-port=123 in-interface=\
Smile log-prefix=" " protocol=udp
Smile log-prefix=" " protocol=tcp
add action=drop chain=input connection-state=new dst-port=53 in-interface=\
Usually those RouterBOOT updates are just "additional device support" (to make it work on new hardware revisions etc.).I noticed a new firmware upgrade is out now for the hap ac, 3.34. I've just upgraded, anyone see the changelog?
Just apply black tape on them.Guys, please add a new feature - completely disable all leds (power led can be enabled). It is very difficult to sleep with disco-light on the roof.
+1Guys, please add a new feature - completely disable all leds (power led can be enabled). It is very difficult to sleep with disco-light on the roof.
Yes, the power parts that are required are more in number and higher in price and complexity.Why can't the hAP AC Lite be AF/AT POE instead of passive? Is that a big change? It would make a great dorm room switch for us if it was POE. A in-wall form factor would be the next ask..
Yes, that part should work fine. I'm currently powering my hAP AC and wAP AC using a Ubiquiti 24v passive injector, no issues.Will the ubiquiti instant 802.3af to passive poe adapter work in powering the HAP AC? i.e one side into a netgar GS110tp - the other side into ether1 of the HAP.
/caps-man channel
add band=2ghz-b/g/n extension-channel=disabled frequency=2412 name="channel-2.4-1" width=20
add band=2ghz-b/g/n extension-channel=disabled frequency=2417 name="channel-2.4-2" width=20
add band=2ghz-b/g/n extension-channel=disabled frequency=2422 name="channel-2.4-3" width=20
add band=2ghz-b/g/n extension-channel=disabled frequency=2427 name="channel-2.4-4" width=20
add band=2ghz-b/g/n extension-channel=disabled frequency=2432 name="channel-2.4-5" width=20
add band=2ghz-b/g/n extension-channel=disabled frequency=2437 name="channel-2.4-6" width=20
add band=2ghz-b/g/n extension-channel=disabled frequency=2442 name="channel-2.4-7" width=20
add band=2ghz-b/g/n extension-channel=disabled frequency=2447 name="channel-2.4-8" width=20
add band=2ghz-b/g/n extension-channel=disabled frequency=2452 name="channel-2.4-9" width=20
add band=2ghz-b/g/n extension-channel=disabled frequency=2457 name="channel-2.4-10" width=20
add band=2ghz-b/g/n extension-channel=disabled frequency=2462 name="channel-2.4-11" width=20
add band=2ghz-b/g/n extension-channel=disabled frequency=2467 name="channel-2.4-12" width=20
add band=2ghz-b/g/n extension-channel=disabled frequency=2472 name="channel-2.4-13" width=20
add band=2ghz-b/g/n extension-channel=eC frequency=2412 name="channel-2.4-1-eC" width=20
add band=2ghz-b/g/n extension-channel=eC frequency=2417 name="channel-2.4-2-eC" width=20
add band=2ghz-b/g/n extension-channel=eC frequency=2422 name="channel-2.4-3-eC" width=20
add band=2ghz-b/g/n extension-channel=eC frequency=2427 name="channel-2.4-4-eC" width=20
add band=2ghz-b/g/n extension-channel=eC frequency=2432 name="channel-2.4-5-eC" width=20
add band=2ghz-b/g/n extension-channel=eC frequency=2437 name="channel-2.4-6-eC" width=20
add band=2ghz-b/g/n extension-channel=eC frequency=2442 name="channel-2.4-7-eC" width=20
add band=2ghz-b/g/n extension-channel=eC frequency=2447 name="channel-2.4-8-eC" width=20
add band=2ghz-b/g/n extension-channel=eC frequency=2452 name="channel-2.4-9-eC" width=20
add band=2ghz-b/g/n extension-channel=eC frequency=2457 name="channel-2.4-10-eC" width=20
add band=2ghz-b/g/n extension-channel=eC frequency=2462 name="channel-2.4-11-eC" width=20
add band=2ghz-b/g/n extension-channel=eC frequency=2467 name="channel-2.4-12-eC" width=20
add band=2ghz-b/g/n extension-channel=eC frequency=2472 name="channel-2.4-13-eC" width=20
add band=2ghz-b/g/n extension-channel=Ce frequency=2412 name="channel-2.4-1-Ce" width=20
add band=2ghz-b/g/n extension-channel=Ce frequency=2417 name="channel-2.4-2-Ce" width=20
add band=2ghz-b/g/n extension-channel=Ce frequency=2422 name="channel-2.4-3-Ce" width=20
add band=2ghz-b/g/n extension-channel=Ce frequency=2427 name="channel-2.4-4-Ce" width=20
add band=2ghz-b/g/n extension-channel=Ce frequency=2432 name="channel-2.4-5-Ce" width=20
add band=2ghz-b/g/n extension-channel=Ce frequency=2437 name="channel-2.4-6-Ce" width=20
add band=2ghz-b/g/n extension-channel=Ce frequency=2442 name="channel-2.4-7-Ce" width=20
add band=2ghz-b/g/n extension-channel=Ce frequency=2447 name="channel-2.4-8-Ce" width=20
add band=2ghz-b/g/n extension-channel=Ce frequency=2452 name="channel-2.4-9-Ce" width=20
add band=2ghz-b/g/n extension-channel=Ce frequency=2457 name="channel-2.4-10-Ce" width=20
add band=2ghz-b/g/n extension-channel=Ce frequency=2462 name="channel-2.4-11-Ce" width=20
add band=2ghz-b/g/n extension-channel=Ce frequency=2467 name="channel-2.4-12-Ce" width=20
add band=2ghz-b/g/n extension-channel=Ce frequency=2472 name="channel-2.4-13-Ce" width=20
/caps-man channel
add name="channel-5-36" frequency=5180 width=20 band=5ghz-a/n/ac extension-channel=disabled
add name="channel-5-40" frequency=5200 width=20 band=5ghz-a/n/ac extension-channel=disabled
add name="channel-5-44" frequency=5220 width=20 band=5ghz-a/n/ac extension-channel=disabled
add name="channel-5-48" frequency=5240 width=20 band=5ghz-a/n/ac extension-channel=disabled
add name="channel-5-52" frequency=5260 width=20 band=5ghz-a/n/ac extension-channel=disabled
add name="channel-5-56" frequency=5270 width=20 band=5ghz-a/n/ac extension-channel=disabled
add name="channel-5-60" frequency=5300 width=20 band=5ghz-a/n/ac extension-channel=disabled
add name="channel-5-64" frequency=5320 width=20 band=5ghz-a/n/ac extension-channel=disabled
add name="channel-5-36-Ce" frequency=5180 width=20 band=5ghz-a/n/ac extension-channel=Ce
add name="channel-5-40-Ce" frequency=5200 width=20 band=5ghz-a/n/ac extension-channel=Ce
add name="channel-5-44-Ce" frequency=5220 width=20 band=5ghz-a/n/ac extension-channel=Ce
add name="channel-5-48-Ce" frequency=5240 width=20 band=5ghz-a/n/ac extension-channel=Ce
add name="channel-5-52-Ce" frequency=5260 width=20 band=5ghz-a/n/ac extension-channel=Ce
add name="channel-5-56-Ce" frequency=5270 width=20 band=5ghz-a/n/ac extension-channel=Ce
add name="channel-5-60-Ce" frequency=5300 width=20 band=5ghz-a/n/ac extension-channel=Ce
add name="channel-5-64-Ce" frequency=5320 width=20 band=5ghz-a/n/ac extension-channel=Ce
add name="channel-5-36-eC" frequency=5180 width=20 band=5ghz-a/n/ac extension-channel=eC
add name="channel-5-40-eC" frequency=5200 width=20 band=5ghz-a/n/ac extension-channel=eC
add name="channel-5-44-eC" frequency=5220 width=20 band=5ghz-a/n/ac extension-channel=eC
add name="channel-5-48-eC" frequency=5240 width=20 band=5ghz-a/n/ac extension-channel=eC
add name="channel-5-52-eC" frequency=5260 width=20 band=5ghz-a/n/ac extension-channel=eC
add name="channel-5-56-eC" frequency=5270 width=20 band=5ghz-a/n/ac extension-channel=eC
add name="channel-5-60-eC" frequency=5300 width=20 band=5ghz-a/n/ac extension-channel=eC
add name="channel-5-64-eC" frequency=5320 width=20 band=5ghz-a/n/ac extension-channel=eC
add name="channel-5-36-Ceee" frequency=5180 width=20 band=5ghz-a/n/ac extension-channel=Ceee
add name="channel-5-40-Ceee" frequency=5200 width=20 band=5ghz-a/n/ac extension-channel=Ceee
add name="channel-5-44-Ceee" frequency=5220 width=20 band=5ghz-a/n/ac extension-channel=Ceee
add name="channel-5-48-Ceee" frequency=5240 width=20 band=5ghz-a/n/ac extension-channel=Ceee
add name="channel-5-52-Ceee" frequency=5260 width=20 band=5ghz-a/n/ac extension-channel=Ceee
add name="channel-5-56-Ceee" frequency=5270 width=20 band=5ghz-a/n/ac extension-channel=Ceee
add name="channel-5-60-Ceee" frequency=5300 width=20 band=5ghz-a/n/ac extension-channel=Ceee
add name="channel-5-64-Ceee" frequency=5320 width=20 band=5ghz-a/n/ac extension-channel=Ceee
add name="channel-5-36-eCee" frequency=5180 width=20 band=5ghz-a/n/ac extension-channel=eCee
add name="channel-5-40-eCee" frequency=5200 width=20 band=5ghz-a/n/ac extension-channel=eCee
add name="channel-5-44-eCee" frequency=5220 width=20 band=5ghz-a/n/ac extension-channel=eCee
add name="channel-5-48-eCee" frequency=5240 width=20 band=5ghz-a/n/ac extension-channel=eCee
add name="channel-5-52-eCee" frequency=5260 width=20 band=5ghz-a/n/ac extension-channel=eCee
add name="channel-5-56-eCee" frequency=5270 width=20 band=5ghz-a/n/ac extension-channel=eCee
add name="channel-5-60-eCee" frequency=5300 width=20 band=5ghz-a/n/ac extension-channel=eCee
add name="channel-5-64-eCee" frequency=5320 width=20 band=5ghz-a/n/ac extension-channel=eCee
add name="channel-5-36-eeCe" frequency=5180 width=20 band=5ghz-a/n/ac extension-channel=eeCe
add name="channel-5-40-eeCe" frequency=5200 width=20 band=5ghz-a/n/ac extension-channel=eeCe
add name="channel-5-44-eeCe" frequency=5220 width=20 band=5ghz-a/n/ac extension-channel=eeCe
add name="channel-5-48-eeCe" frequency=5240 width=20 band=5ghz-a/n/ac extension-channel=eeCe
add name="channel-5-52-eeCe" frequency=5260 width=20 band=5ghz-a/n/ac extension-channel=eeCe
add name="channel-5-56-eeCe" frequency=5270 width=20 band=5ghz-a/n/ac extension-channel=eeCe
add name="channel-5-60-eeCe" frequency=5300 width=20 band=5ghz-a/n/ac extension-channel=eeCe
add name="channel-5-64-eeCe" frequency=5320 width=20 band=5ghz-a/n/ac extension-channel=eeCe
add name="channel-5-36-eeeC" frequency=5180 width=20 band=5ghz-a/n/ac extension-channel=eeeC
add name="channel-5-40-eeeC" frequency=5200 width=20 band=5ghz-a/n/ac extension-channel=eeeC
add name="channel-5-44-eeeC" frequency=5220 width=20 band=5ghz-a/n/ac extension-channel=eeeC
add name="channel-5-48-eeeC" frequency=5240 width=20 band=5ghz-a/n/ac extension-channel=eeeC
add name="channel-5-52-eeeC" frequency=5260 width=20 band=5ghz-a/n/ac extension-channel=eeeC
add name="channel-5-56-eeeC" frequency=5270 width=20 band=5ghz-a/n/ac extension-channel=eeeC
add name="channel-5-60-eeeC" frequency=5300 width=20 band=5ghz-a/n/ac extension-channel=eeeC
add name="channel-5-64-eeeC" frequency=5320 width=20 band=5ghz-a/n/ac extension-channel=eeeC
Same here, and during high throughput transfers on 5Ghz it goes up to 70, and i get wifi disconnects than after 10-15mins..My hAP AC idles at 59 degrees Celsius in a room that is around 21. Is this normal?
How about device it self?What temperatures are safe as i said i saw mine going to 70c(Room temperature below 25C) and than im getting wireless disconnects..None of these temperatures should pose any risks to the device. It works fine even up to 65C ambient temperature.
55C is completely normal for the CPU, and can get higher. Disconnects should not be related, must be a coincidence. What do the Wireless Debug logs say about them? Which frequency are the clients using when they disconnect ?How about device it self?What temperatures are safe as i said i saw mine going to 70c(Room temperature below 25C) and than im getting wireless disconnects..None of these temperatures should pose any risks to the device. It works fine even up to 65C ambient temperature.
5GHz interface, disconnected extensive data loost is only thing in logs, than im unable connect back for about 2minutes back.I also tested this on stock rested HAP AC with default configuration without entering any settings.It also kicks ALL clients connected to interface not just one.55C is completely normal for the CPU, and can get higher. Disconnects should not be related, must be a coincidence. What do the Wireless Debug logs say about them? Which frequency are the clients using when they disconnect ?How about device it self?What temperatures are safe as i said i saw mine going to 70c(Room temperature below 25C) and than im getting wireless disconnects..None of these temperatures should pose any risks to the device. It works fine even up to 65C ambient temperature.
Your answer makes no sense, how would i achieve 400mbit per sec(up to 50MB per sec) transfer in low signal?The error indicates poor signal.
You can make a new logging topic to file (hAP ac has the space for this)
Like this:
Hello everyone,
i used Mikrotik devices over the last couple years and they have been very stable for me.
My last configuration was my RB2011 as gateway and capsman in combination with a hAP Accesspoint.
This configuration was stable but my neighbors seems to get a new wlan ap or printer every day so there are 10+ wlans in 2.4GHz segment which results in poor performance.
So i decided to get a hAP AC and only use the 5GHz frequency. Everything worked perfect for 2 days but then the wireless startet flapping.
The SSID was sometimes not visible, then came back but the devices were unable to connect and then it disappeared again.
A reboot of the hAP AC resolves the problem for a short time and then it starts again. Unfortunately there were no entrys in the logs.
The Problem happens with and without capsman and only in 5GHz frequency. The 2.4 configuration is actually running stable.
It seems that there is a bug in ROS or a hardware fault...
I'm a network engineer and work mostly which Cisco or Brocade devices so i know what i'm doing.
I also send a supout to support but i don't think about getting a response before next year.
Configuration:
Frequency: 5500 Ceee
With: 20/40/80MHz
Country: Germany
ROS: 6.37.3
Thanks in advance!
Not yet but i will start a debug log today in the evening.Did you check the wireless debug logs?
Thanks for this information. I start the debug log today and then try to downgrade to this version.I had the same problem since it was introduced DFS automatic mode.
I returned to version 6.36.4 and everything seems ok.
Dec/19/2016 19:01:02 wireless,debug wlan2: 78:F8:82:D0:7E:50 attempts to associate
Dec/19/2016 19:01:02 wireless,debug wlan2: 78:F8:82:D0:7E:50 not in local ACL, by default accept
Dec/19/2016 19:01:55 wireless,debug wlan2: 78:F8:82:D0:7E:50 attempts to associate
Dec/19/2016 19:01:55 wireless,debug wlan2: 78:F8:82:D0:7E:50 not in local ACL, by default accept
Dec/19/2016 19:04:03 wireless,debug wlan2: E0:63:E5:D3:D9:2E attempts to associate
Dec/19/2016 19:04:03 wireless,debug wlan2: E0:63:E5:D3:D9:2E not in local ACL, by default accept
Dec/19/2016 19:32:26 wireless,debug wlan2: 78:F8:82:D0:7E:50 attempts to associate
Dec/19/2016 19:32:26 wireless,debug wlan2: 78:F8:82:D0:7E:50 not in local ACL, by default accept
Dec/19/2016 19:33:36 wireless,debug wlan2: 78:F8:82:D0:7E:50 attempts to associate
Dec/19/2016 19:33:36 wireless,debug wlan2: 78:F8:82:D0:7E:50 not in local ACL, by default accept
I tried to use sfp port with this copper SFP GLC-T-A:
Do i have a chance with hap ac and this copper module (i tried any possible variations with auto-negotiation on/off and manual defining speed/duplex on a both sides).
Or just stop doing wrong and buy S-RJ01?
There is a problem in the transition from the WAN (L2TP) local area networkIs this device faulty fixed, or still have issues with WAN to LAN speeds? Anyone with newer production batch to tell me?
The same. HAP AC, 6.40.4 Tried several different copper SFP without success. Here are two of them:I tried to use sfp port with this copper SFP GLC-T-A:
# monitor sfp1
sfp-connector-type: LC
sfp-link-length-copper: 100m
sfp-vendor-name: CISCO-FINISAR
sfp-vendor-part-number: SFP-T
sfp-vendor-revision: 11.0
sfp-vendor-serial: MTC100810350
sfp-manufacturing-date: 10-10-18
eeprom-checksum: good
{skip}
without certain success. In general, this transceiver didn't work with hap ac for me but one time i had successful link (1G) to my book Acer V5-573G (RTL8411). Not sure what happens in this case, seems link up immediately after hard reboot of device, but it can't reproduce it again. I suspect that it's looks like auto-negotiation issue.
When i insert this modue into CRS210 (into sfp-sfpplus1 port) - all works fine.
status: no-link
auto-negotiation: done
advertising:
link-partner-advertising:
sfp-module-present: yes
sfp-rx-loss: no
sfp-type: SFP-or-SFP+
sfp-vendor-name: FINISAR CORP.
sfp-vendor-part-number: FCLF-8521-3
sfp-vendor-revision: A
sfp-vendor-serial: PL53JUK
sfp-manufacturing-date: 11-07-29
eeprom: 0000: 03 04 00 00 00 00 08 00 00 00 00 01 0c 00 00 00 ........ ........
0010: 00 00 64 00 46 49 4e 49 53 41 52 20 43 4f 52 50 ..d.FINI SAR CORP
0020: 2e 20 20 20 00 00 90 65 46 43 4c 46 2d 38 35 32 . ...e FCLF-852
0030: 31 2d 33 20 20 20 20 20 41 20 20 20 00 00 00 1c 1-3 A ....
0040: 00 10 00 00 50 4c 35 33 4a 55 4b 20 20 20 20 20 ....PL53 JUK
0050: 20 20 20 20 31 31 30 37 32 39 20 20 00 00 00 92 1107 29 ....
0060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
0070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
0080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
0090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
00a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
00b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
00c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
00d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
00e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
00f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
status: no-link
advertising:
sfp-rx-loss: no
sfp-vendor-name: FOUNDRY NETWORKS
sfp-vendor-part-number: ABCU-5700RZ-FD
sfp-vendor-serial: AN09337041
sfp-manufacturing-date: 09-08-16
eeprom: 0000: 03 04 00 00 00 00 08 00 00 00 00 01 0d 00 00 00 ........ ........
0010: 00 00 64 00 46 4f 55 4e 44 52 59 20 4e 45 54 57 ..d.FOUN DRY NETW
0020: 4f 52 4b 53 00 00 17 6a 41 42 43 55 2d 35 37 30 ORKS...j ABCU-570
0030: 30 52 5a 2d 46 44 20 20 20 20 20 20 00 00 00 fd 0RZ-FD ....
0040: 00 12 00 00 41 4e 30 39 33 33 37 30 34 31 20 20 ....AN09 337041
0050: 20 20 20 20 30 39 30 38 31 36 20 20 00 00 00 74 0908 16 ...t
0060: 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20
0070: 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20
