sstyle
Re: HAP AC
Sun Oct 09, 2016 1:22 pm
Did it, but what should I do with ventilation holes?
Siona
Re: HAP AC
Sun Oct 09, 2016 1:29 pm
Black pvc tape works as a charm! [GRINNING FACE WITH SMILING EYES]
sstyle
Re: HAP AC
Sun Oct 09, 2016 1:35 pm
And get overheating as result?!
benoga
Re: HAP AC
Fri Oct 21, 2016 8:13 pm
Guys, please add a new feature - completely disable all leds (power led can be enabled). It is very difficult to sleep with disco-light on the roof.
+1
mleonidov
Re: HAP AC
Sat Oct 22, 2016 4:37 am
benoga
Re: HAP AC
Sun Oct 23, 2016 10:18 am
@mleonidov
the Power LED can't be disabled on the HAP AC. We want to disable all LED, incl. Power.
mjbop1
Re: HAP AC
Wed Oct 26, 2016 12:57 am
Why can't the hAP AC Lite be AF/AT POE instead of passive? Is that a big change? It would make a great dorm room switch for us if it was POE. A in-wall form factor would be the next ask..:)
normis
Re: HAP AC
Wed Oct 26, 2016 8:43 am
Yes, the power parts that are required are more in number and higher in price and complexity.
paulct
Re: HAP AC
Fri Oct 28, 2016 10:02 am
Will the ubiquiti instant 802.3af to passive poe adapter work in powering the HAP AC? i.e one side into a netgar GS110tp - the other side into ether1 of the HAP.
Quindor
Re: HAP AC
Fri Oct 28, 2016 8:45 pm
Yes, that part should work fine. I'm currently powering my hAP AC and wAP AC using a Ubiquiti 24v passive injector, no issues.
Hammer
Re: HAP AC
Tue Nov 15, 2016 11:42 am
I had problems with the channel configuration (best performance 5GHz AC) and found this CAPsMAN Channels list.
Very helpful for the configuration
2.4 GHz Channels
/caps-man channel
add band=2ghz-b/g/n extension-channel=disabled frequency=2412 name="channel-2.4-1" width=20
add band=2ghz-b/g/n extension-channel=disabled frequency=2417 name="channel-2.4-2" width=20
add band=2ghz-b/g/n extension-channel=disabled frequency=2422 name="channel-2.4-3" width=20
add band=2ghz-b/g/n extension-channel=disabled frequency=2427 name="channel-2.4-4" width=20
add band=2ghz-b/g/n extension-channel=disabled frequency=2432 name="channel-2.4-5" width=20
add band=2ghz-b/g/n extension-channel=disabled frequency=2437 name="channel-2.4-6" width=20
add band=2ghz-b/g/n extension-channel=disabled frequency=2442 name="channel-2.4-7" width=20
add band=2ghz-b/g/n extension-channel=disabled frequency=2447 name="channel-2.4-8" width=20
add band=2ghz-b/g/n extension-channel=disabled frequency=2452 name="channel-2.4-9" width=20
add band=2ghz-b/g/n extension-channel=disabled frequency=2457 name="channel-2.4-10" width=20
add band=2ghz-b/g/n extension-channel=disabled frequency=2462 name="channel-2.4-11" width=20
add band=2ghz-b/g/n extension-channel=disabled frequency=2467 name="channel-2.4-12" width=20
add band=2ghz-b/g/n extension-channel=disabled frequency=2472 name="channel-2.4-13" width=20
add band=2ghz-b/g/n extension-channel=eC frequency=2412 name="channel-2.4-1-eC" width=20
add band=2ghz-b/g/n extension-channel=eC frequency=2417 name="channel-2.4-2-eC" width=20
add band=2ghz-b/g/n extension-channel=eC frequency=2422 name="channel-2.4-3-eC" width=20
add band=2ghz-b/g/n extension-channel=eC frequency=2427 name="channel-2.4-4-eC" width=20
add band=2ghz-b/g/n extension-channel=eC frequency=2432 name="channel-2.4-5-eC" width=20
add band=2ghz-b/g/n extension-channel=eC frequency=2437 name="channel-2.4-6-eC" width=20
add band=2ghz-b/g/n extension-channel=eC frequency=2442 name="channel-2.4-7-eC" width=20
add band=2ghz-b/g/n extension-channel=eC frequency=2447 name="channel-2.4-8-eC" width=20
add band=2ghz-b/g/n extension-channel=eC frequency=2452 name="channel-2.4-9-eC" width=20
add band=2ghz-b/g/n extension-channel=eC frequency=2457 name="channel-2.4-10-eC" width=20
add band=2ghz-b/g/n extension-channel=eC frequency=2462 name="channel-2.4-11-eC" width=20
add band=2ghz-b/g/n extension-channel=eC frequency=2467 name="channel-2.4-12-eC" width=20
add band=2ghz-b/g/n extension-channel=eC frequency=2472 name="channel-2.4-13-eC" width=20
add band=2ghz-b/g/n extension-channel=Ce frequency=2412 name="channel-2.4-1-Ce" width=20
add band=2ghz-b/g/n extension-channel=Ce frequency=2417 name="channel-2.4-2-Ce" width=20
add band=2ghz-b/g/n extension-channel=Ce frequency=2422 name="channel-2.4-3-Ce" width=20
add band=2ghz-b/g/n extension-channel=Ce frequency=2427 name="channel-2.4-4-Ce" width=20
add band=2ghz-b/g/n extension-channel=Ce frequency=2432 name="channel-2.4-5-Ce" width=20
add band=2ghz-b/g/n extension-channel=Ce frequency=2437 name="channel-2.4-6-Ce" width=20
add band=2ghz-b/g/n extension-channel=Ce frequency=2442 name="channel-2.4-7-Ce" width=20
add band=2ghz-b/g/n extension-channel=Ce frequency=2447 name="channel-2.4-8-Ce" width=20
add band=2ghz-b/g/n extension-channel=Ce frequency=2452 name="channel-2.4-9-Ce" width=20
add band=2ghz-b/g/n extension-channel=Ce frequency=2457 name="channel-2.4-10-Ce" width=20
add band=2ghz-b/g/n extension-channel=Ce frequency=2462 name="channel-2.4-11-Ce" width=20
add band=2ghz-b/g/n extension-channel=Ce frequency=2467 name="channel-2.4-12-Ce" width=20
add band=2ghz-b/g/n extension-channel=Ce frequency=2472 name="channel-2.4-13-Ce" width=20
5 GHz Channels
/caps-man channel
add name="channel-5-36" frequency=5180 width=20 band=5ghz-a/n/ac extension-channel=disabled
add name="channel-5-40" frequency=5200 width=20 band=5ghz-a/n/ac extension-channel=disabled
add name="channel-5-44" frequency=5220 width=20 band=5ghz-a/n/ac extension-channel=disabled
add name="channel-5-48" frequency=5240 width=20 band=5ghz-a/n/ac extension-channel=disabled
add name="channel-5-52" frequency=5260 width=20 band=5ghz-a/n/ac extension-channel=disabled
add name="channel-5-56" frequency=5270 width=20 band=5ghz-a/n/ac extension-channel=disabled
add name="channel-5-60" frequency=5300 width=20 band=5ghz-a/n/ac extension-channel=disabled
add name="channel-5-64" frequency=5320 width=20 band=5ghz-a/n/ac extension-channel=disabled
add name="channel-5-36-Ce" frequency=5180 width=20 band=5ghz-a/n/ac extension-channel=Ce
add name="channel-5-40-Ce" frequency=5200 width=20 band=5ghz-a/n/ac extension-channel=Ce
add name="channel-5-44-Ce" frequency=5220 width=20 band=5ghz-a/n/ac extension-channel=Ce
add name="channel-5-48-Ce" frequency=5240 width=20 band=5ghz-a/n/ac extension-channel=Ce
add name="channel-5-52-Ce" frequency=5260 width=20 band=5ghz-a/n/ac extension-channel=Ce
add name="channel-5-56-Ce" frequency=5270 width=20 band=5ghz-a/n/ac extension-channel=Ce
add name="channel-5-60-Ce" frequency=5300 width=20 band=5ghz-a/n/ac extension-channel=Ce
add name="channel-5-64-Ce" frequency=5320 width=20 band=5ghz-a/n/ac extension-channel=Ce
add name="channel-5-36-eC" frequency=5180 width=20 band=5ghz-a/n/ac extension-channel=eC
add name="channel-5-40-eC" frequency=5200 width=20 band=5ghz-a/n/ac extension-channel=eC
add name="channel-5-44-eC" frequency=5220 width=20 band=5ghz-a/n/ac extension-channel=eC
add name="channel-5-48-eC" frequency=5240 width=20 band=5ghz-a/n/ac extension-channel=eC
add name="channel-5-52-eC" frequency=5260 width=20 band=5ghz-a/n/ac extension-channel=eC
add name="channel-5-56-eC" frequency=5270 width=20 band=5ghz-a/n/ac extension-channel=eC
add name="channel-5-60-eC" frequency=5300 width=20 band=5ghz-a/n/ac extension-channel=eC
add name="channel-5-64-eC" frequency=5320 width=20 band=5ghz-a/n/ac extension-channel=eC
add name="channel-5-36-Ceee" frequency=5180 width=20 band=5ghz-a/n/ac extension-channel=Ceee
add name="channel-5-40-Ceee" frequency=5200 width=20 band=5ghz-a/n/ac extension-channel=Ceee
add name="channel-5-44-Ceee" frequency=5220 width=20 band=5ghz-a/n/ac extension-channel=Ceee
add name="channel-5-48-Ceee" frequency=5240 width=20 band=5ghz-a/n/ac extension-channel=Ceee
add name="channel-5-52-Ceee" frequency=5260 width=20 band=5ghz-a/n/ac extension-channel=Ceee
add name="channel-5-56-Ceee" frequency=5270 width=20 band=5ghz-a/n/ac extension-channel=Ceee
add name="channel-5-60-Ceee" frequency=5300 width=20 band=5ghz-a/n/ac extension-channel=Ceee
add name="channel-5-64-Ceee" frequency=5320 width=20 band=5ghz-a/n/ac extension-channel=Ceee
add name="channel-5-36-eCee" frequency=5180 width=20 band=5ghz-a/n/ac extension-channel=eCee
add name="channel-5-40-eCee" frequency=5200 width=20 band=5ghz-a/n/ac extension-channel=eCee
add name="channel-5-44-eCee" frequency=5220 width=20 band=5ghz-a/n/ac extension-channel=eCee
add name="channel-5-48-eCee" frequency=5240 width=20 band=5ghz-a/n/ac extension-channel=eCee
add name="channel-5-52-eCee" frequency=5260 width=20 band=5ghz-a/n/ac extension-channel=eCee
add name="channel-5-56-eCee" frequency=5270 width=20 band=5ghz-a/n/ac extension-channel=eCee
add name="channel-5-60-eCee" frequency=5300 width=20 band=5ghz-a/n/ac extension-channel=eCee
add name="channel-5-64-eCee" frequency=5320 width=20 band=5ghz-a/n/ac extension-channel=eCee
add name="channel-5-36-eeCe" frequency=5180 width=20 band=5ghz-a/n/ac extension-channel=eeCe
add name="channel-5-40-eeCe" frequency=5200 width=20 band=5ghz-a/n/ac extension-channel=eeCe
add name="channel-5-44-eeCe" frequency=5220 width=20 band=5ghz-a/n/ac extension-channel=eeCe
add name="channel-5-48-eeCe" frequency=5240 width=20 band=5ghz-a/n/ac extension-channel=eeCe
add name="channel-5-52-eeCe" frequency=5260 width=20 band=5ghz-a/n/ac extension-channel=eeCe
add name="channel-5-56-eeCe" frequency=5270 width=20 band=5ghz-a/n/ac extension-channel=eeCe
add name="channel-5-60-eeCe" frequency=5300 width=20 band=5ghz-a/n/ac extension-channel=eeCe
add name="channel-5-64-eeCe" frequency=5320 width=20 band=5ghz-a/n/ac extension-channel=eeCe
add name="channel-5-36-eeeC" frequency=5180 width=20 band=5ghz-a/n/ac extension-channel=eeeC
add name="channel-5-40-eeeC" frequency=5200 width=20 band=5ghz-a/n/ac extension-channel=eeeC
add name="channel-5-44-eeeC" frequency=5220 width=20 band=5ghz-a/n/ac extension-channel=eeeC
add name="channel-5-48-eeeC" frequency=5240 width=20 band=5ghz-a/n/ac extension-channel=eeeC
add name="channel-5-52-eeeC" frequency=5260 width=20 band=5ghz-a/n/ac extension-channel=eeeC
add name="channel-5-56-eeeC" frequency=5270 width=20 band=5ghz-a/n/ac extension-channel=eeeC
add name="channel-5-60-eeeC" frequency=5300 width=20 band=5ghz-a/n/ac extension-channel=eeeC
add name="channel-5-64-eeeC" frequency=5320 width=20 band=5ghz-a/n/ac extension-channel=eeeC
thebigcow
Re: HAP AC
Tue Dec 13, 2016 6:33 pm
My hAP AC idles at 59 degrees Celsius in a room that is around 21. Is this normal?
ivicask
Re: HAP AC
Wed Dec 14, 2016 9:34 am
Same here, and during high throughput transfers on 5Ghz it goes up to 70, and i get wifi disconnects than after 10-15mins..
athurdent
Re: HAP AC
Wed Dec 14, 2016 10:34 am
Too bad, cannot post images in this board.
My hAP AC (located in Germany, room temperature, wall mounted) is at an average of 38°C over the last 3 month, about 6 clients connected, mostly idle.
My wAP AC (also Germany, room temperature, lying on a shelf) has an average of 54°C also over the last 3 month, about 0-2 clients conneted, mostly idle.
normis
Re: HAP AC
Wed Dec 14, 2016 10:35 am
None of these temperatures should pose any risks to the device. It works fine even up to 65C ambient temperature.
ivicask
Re: HAP AC
Wed Dec 14, 2016 10:48 am
How about device it self?What temperatures are safe as i said i saw mine going to 70c(Room temperature below 25C) and than im getting wireless disconnects..
normis
Re: HAP AC
Wed Dec 14, 2016 10:50 am
55C is completely normal for the CPU, and can get higher. Disconnects should not be related, must be a coincidence. What do the Wireless Debug logs say about them? Which frequency are the clients using when they disconnect ?
ivicask
Re: HAP AC
Wed Dec 14, 2016 11:15 am
5GHz interface, disconnected extensive data loost is only thing in logs, than im unable connect back for about 2minutes back.I also tested this on stock rested HAP AC with default configuration without entering any settings.It also kicks ALL clients connected to interface not just one.
It happens when i transfer large files over network share(about 30gb of pst files), to a connected laptop equipped with dual chain AC, speeds go up to 400mbit/s during transfer and CPU usage is around 50% and it doesnt not go even near 100%, and i have NO other 5ghz networks in range.This doesnt happen on 2ghz interface, or when i connect slower 5ghz clients or single chain clients.
Also not sure how to capture logs when its random 10-30 mins of copy, and Supout runs for few sec only, is there a way to monitor entire process until it breaks?
normis
Re: HAP AC
Wed Dec 14, 2016 11:26 am
The error indicates poor signal.
You can make a new logging topic to file (hAP ac has the space for this)
Like this:
ivicask
Re: HAP AC
Wed Dec 14, 2016 11:28 am
Like this:
Your answer makes no sense, how would i achieve 400mbit per sec(up to 50MB per sec) transfer in low signal?
Im 3-4m form router, CCQ is near 100%, signal and everything is in perfect conditions.
I will try capture the logs as you described above and ill submit ticket
Thanks.
normis
Re: HAP AC
Wed Dec 14, 2016 11:29 am
Interference can cause noise and disturb the signal. You don't have disconnects all the time. It could be many things
gandlz
Re: HAP AC
Thu Dec 15, 2016 11:47 pm
just touching my new hAP ac and have a question on 5G-wireless:
I see it does not support tx power mode “card rates” or “manual”. I can only choose “all rates fixed”. As this is not recommended to use, how can I safely increase tx power to 200 or 500mW (23 or 27dBm). This is allowed where I live, depending on the frequency.
Edit: I just found out, that it seems handle transmit power according to regulatory-domain and frequency but I would say this is wrong:
5150-5250 - allowed: 200mW, hAP ac: 100mW
5250-5350 - allowed: 100mW (200mW only with TPC), hAP ac: 200mW
5470-5725 - allowed: 500mW (1000mW only with TPC), hAP ac: 500mW
So only the third range is correct. The first and second seem to be exchanged. Am I misinformed?
Also, “current tx power” shows an empty table at 5G-interface. On 2G-interface it is working.
Thanks a lot!
Gandlz
Valexus
Re: HAP AC
Mon Dec 19, 2016 11:19 am
Hello everyone,
i used Mikrotik devices over the last couple years and they have been very stable for me.
My last configuration was my RB2011 as gateway and capsman in combination with a hAP Accesspoint.
This configuration was stable but my neighbors seems to get a new wlan ap or printer every day so there are 10+ wlans in 2.4GHz segment which results in poor performance.
So i decided to get a hAP AC and only use the 5GHz frequency. Everything worked perfect for 2 days but then the wireless startet flapping.
The SSID was sometimes not visible, then came back but the devices were unable to connect and then it disappeared again.
A reboot of the hAP AC resolves the problem for a short time and then it starts again. Unfortunately there were no entrys in the logs.
The Problem happens with and without capsman and only in 5GHz frequency. The 2.4 configuration is actually running stable.
It seems that there is a bug in ROS or a hardware fault...
I'm a network engineer and work mostly which Cisco or Brocade devices so i know what i'm doing.
I also send a supout to support but i don't think about getting a response before next year.
Configuration:
Frequency: 5500 Ceee
With: 20/40/80MHz
Country: Germany
ROS: 6.37.3
Thanks in advance!
normis
Re: HAP AC
Mon Dec 19, 2016 1:47 pm
Did you check the wireless debug logs?
grusu
Re: HAP AC
Mon Dec 19, 2016 2:05 pm
Hello everyone,
Configuration:
With: 20/40/80MHz
Country: Germany
ROS: 6.37.3
Thanks in advance!
I had the same problem since it was introduced DFS automatic mode.
I returned to version 6.36.4 and everything seems ok.
Valexus
Re: HAP AC
Mon Dec 19, 2016 2:12 pm
Not yet but i will start a debug log today in the evening.
Thanks for this information. I start the debug log today and then try to downgrade to this version.
Valexus
Re: HAP AC
Mon Dec 19, 2016 8:45 pm
After starting the logging and activating 5GHz again with frequency "auto" it choosed 5500MHz and startet to act strange like before.
The wireless Debug log wasn't very helpful
Dec/19/2016 19:01:02 wireless,debug wlan2: 78:F8:82:D0:7E:50 attempts to associate
Dec/19/2016 19:01:02 wireless,debug wlan2: 78:F8:82:D0:7E:50 not in local ACL, by default accept
Dec/19/2016 19:01:55 wireless,debug wlan2: 78:F8:82:D0:7E:50 attempts to associate
Dec/19/2016 19:01:55 wireless,debug wlan2: 78:F8:82:D0:7E:50 not in local ACL, by default accept
Dec/19/2016 19:04:03 wireless,debug wlan2: E0:63:E5:D3:D9:2E attempts to associate
Dec/19/2016 19:04:03 wireless,debug wlan2: E0:63:E5:D3:D9:2E not in local ACL, by default accept
Dec/19/2016 19:32:26 wireless,debug wlan2: 78:F8:82:D0:7E:50 attempts to associate
Dec/19/2016 19:32:26 wireless,debug wlan2: 78:F8:82:D0:7E:50 not in local ACL, by default accept
Dec/19/2016 19:33:36 wireless,debug wlan2: 78:F8:82:D0:7E:50 attempts to associate
Dec/19/2016 19:33:36 wireless,debug wlan2: 78:F8:82:D0:7E:50 not in local ACL, by default accept
I've set frequency to 5260 and now i'm testing again.
zhup
Re: HAP AC
Thu Dec 22, 2016 2:30 pm
Are you going to release the HAP AC v2 with the more powerful hardware (CPU, more ram etc.)?
freshmeat123
Re: HAP AC
Wed Feb 01, 2017 12:34 am
I tried to use sfp port with this copper SFP GLC-T-A:
# monitor sfp1
sfp-connector-type: LC
sfp-link-length-copper: 100m
sfp-vendor-name: CISCO-FINISAR
sfp-vendor-part-number: SFP-T
sfp-vendor-revision: 11.0
sfp-vendor-serial: MTC100810350
sfp-manufacturing-date: 10-10-18
eeprom-checksum: good
{skip}
without certain success. In general, this transceiver didn't work with hap ac for me but one time i had successful link (1G) to my book Acer V5-573G (RTL8411). Not sure what happens in this case, seems link up immediately after hard reboot of device, but it can't reproduce it again. I suspect that it's looks like auto-negotiation issue.
When i insert this modue into CRS210 (into sfp-sfpplus1 port) - all works fine.
Do i have a chance with hap ac and this copper module (i tried any possible variations with auto-negotiation on/off and manual defining speed/duplex on a both sides).
Or just stop doing wrong and buy S-RJ01?
Igor
freshmeat123
Re: HAP AC
Tue Feb 21, 2017 11:58 pm
I've got S-RJ01 for testing. Native copper module works fine with hap ac.
OKNET
Re: HAP AC
Mon Mar 13, 2017 6:58 pm
Once HapAC is placed in CAPs mode, it is no more seen on /ip neighbor table
Turned back in stand-alone mode it is seen again
Is it a normal behaviour ?
shafiqrahman
Re: HAP AC
Sun Apr 23, 2017 1:05 pm
There is a device (Amazon Fire) which disconnects and connects continuously, is there a way to make it stable? Another, thing is that , I use a broadband connection which prone to disconnection , with my previous router whenever something happens with the internet connection there is "Yellow triangle" appears on the system tray of my windows computer. So, I could know that there is nothing wrong with my end, so I can call the ISP to fix the issue. But, since upgrading to hAP AC, its always connected, whether there is internet connection or not. So, How can I make that yellow triangle appear when there is no internet connection.
deanMKD1
Re: HAP AC
Thu Sep 21, 2017 8:59 pm
Is this device faulty fixed, or still have issues with WAN to LAN speeds? Anyone with newer production batch to tell me?
wolfktl
Re: HAP AC
Wed Oct 11, 2017 8:04 pm
There is a problem in the transition from the WAN (L2TP) local area network
Download speed 40 Mbps maximum outbound 90 Mbps.
When channel 100 Mbps
But best from the device shows 90/90
flicker
Re: HAP AC
Wed Oct 11, 2017 9:09 pm
# monitor sfp1
{skip}
The same. HAP AC, 6.40.4 Tried several different copper SFP without success. Here are two of them:
                    status: no-link
          auto-negotiation: done
               advertising:
  link-partner-advertising:
        sfp-module-present: yes
               sfp-rx-loss: no
                  sfp-type: SFP-or-SFP+
           sfp-vendor-name: FINISAR CORP.
    sfp-vendor-part-number: FCLF-8521-3
       sfp-vendor-revision: A
         sfp-vendor-serial: PL53JUK
    sfp-manufacturing-date: 11-07-29
                    eeprom: 0000: 03 04 00 00 00 00 08 00  00 00 00 01 0c 00 00 00  ........ ........
                            0010: 00 00 64 00 46 49 4e 49  53 41 52 20 43 4f 52 50  ..d.FINI SAR CORP
                            0020: 2e 20 20 20 00 00 90 65  46 43 4c 46 2d 38 35 32  .   ...e FCLF-852
                            0030: 31 2d 33 20 20 20 20 20  41 20 20 20 00 00 00 1c  1-3      A   ....
                            0040: 00 10 00 00 50 4c 35 33  4a 55 4b 20 20 20 20 20  ....PL53 JUK
                            0050: 20 20 20 20 31 31 30 37  32 39 20 20 00 00 00 92      1107 29  ....
                            0060: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
                            0070: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
                            0080: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
                            0090: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
                            00a0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
                            00b0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
                            00c0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
                            00d0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
                            00e0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
                            00f0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
                    status: no-link
               advertising:
               sfp-rx-loss: no
           sfp-vendor-name: FOUNDRY NETWORKS
    sfp-vendor-part-number: ABCU-5700RZ-FD
         sfp-vendor-serial: AN09337041
    sfp-manufacturing-date: 09-08-16
                    eeprom: 0000: 03 04 00 00 00 00 08 00  00 00 00 01 0d 00 00 00  ........ ........
                            0010: 00 00 64 00 46 4f 55 4e  44 52 59 20 4e 45 54 57  ..d.FOUN DRY NETW
                            0020: 4f 52 4b 53 00 00 17 6a  41 42 43 55 2d 35 37 30  ORKS...j ABCU-570
                            0030: 30 52 5a 2d 46 44 20 20  20 20 20 20 00 00 00 fd  0RZ-FD       ....
                            0040: 00 12 00 00 41 4e 30 39  33 33 37 30 34 31 20 20  ....AN09 337041
                            0050: 20 20 20 20 30 39 30 38  31 36 20 20 00 00 00 74      0908 16  ...t
                            0060: 20 20 20 20 20 20 20 20  20 20 20 20 20 20 20 20
                            0070: 20 20 20 20 20 20 20 20  20 20 20 20 20 20 20 20
First model (FCLF-8521-3) is listed at:
https://wiki.mikrotik.com/wiki/Manual:Peripherals
Update: this is a autonegotiation problem, indeed. I was able to get link when I had pulled off the sfp, switched autonegotiation: off, speed: 1G, full duplex: yes, and then inserted the sfp again.
Thanks to the guy who described this procedure somewhere in russian forum.
deanMKD1
Re: HAP AC
Sat Dec 23, 2017 5:51 pm
Working temperature on my HAP AC is not going under 29 Celsius.
So for so good for me.
666blade666
Re: HAP AC
Tue May 29, 2018 10:18 am
Hi. Help me please. I have HAP AC and iPhone 5s. iPhone 5s support 5Ghz, but I can`t connect my iPhone 5s to 5Ghz, to have maximum wifi speed. Here is my wifi settings:
[mikrotik@user] > /interface wireless security-profiles print where name=profile1
Flags: * - default
0 name="profile1" mode=dynamic-keys authentication-types=wpa2-psk unicast-ciphers=aes-ccm group-ciphers=aes-ccm wpa-pre-shared-key="" wpa2-pre-shared-key="p123456789" supplicant-identity="mikrotik" eap-methods=passthrough
tls-mode=no-certificates tls-certificate=none mschapv2-username="" mschapv2-password="" static-algo-0=none static-key-0="" static-algo-1=none static-key-1="" static-algo-2=none static-key-2="" static-algo-3=none static-key-3=""
static-transmit-key=key-0 static-sta-private-algo=none static-sta-private-key="" radius-mac-authentication=no radius-mac-accounting=no radius-eap-accounting=no interim-update=0s radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-use
radius-mac-caching=disabled group-key-update=5m management-protection=disabled management-protection-key=""
[mikrotik@user] > /interface wireless print where name=wlan2
0 R name="wlan2" mtu=1500 l2mtu=1600 mac-address=E4:8D:8C:53:82:0E arp=enabled interface-type=Atheros AR9888 mode=ap-bridge ssid="5Ghz" frequency=auto band=5ghz-onlyac channel-width=20/40/80mhz-Ceee secondary-channel="" scan-list=default
wireless-protocol=any vlan-mode=no-tag vlan-id=1 wds-mode=disabled wds-default-bridge=none wds-ignore-ssid=no bridge-mode=enabled default-authentication=yes default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=yes
security-profile=profile1 compression=no
I connect my iPhone 5s to airCubeAC (Ubiquiti) on 5Ghz and I got speed 88\76. Please tell me the best 5Ghz wifi settings for maximus speed on iPhone 5s.
If I'm not mistaken iPhone 5s have Broadcom BCM4334. On 2.4 Ghz WiFi works fine (I mean DHCP and other services works pretty well).
normis
Re: HAP AC
Tue May 29, 2018 11:31 am
No. The iPhone 5s supports only 802.11a/b/g/n and has no MIMO technology.
You enabled "only-ac" which the iPhone 5s does not support. It would work at 80Mbit in 802.11n mode.
666blade666
Re: HAP AC
Tue May 29, 2018 12:53 pm
Like this?
[mikrotik@user] > /interface wireless set [find default-name=wlan2] band=5ghz-n/ac country=ukraine default-authentication=\
yes default-forwarding=yes frequency=auto mode=ap-bridge security-profile=profile1 ssid=5Ghz bridge-mode=enabled wireless-protocol=\
any scan-list=default wps-mode=push-button vlan-mode=no-tag vlan-id=1 hide-ssid=yes channel-width=20/40/80mhz-Ceee
/interface wireless enable wlan2
And what about: channel-width=20/40/80mhz-Ceee - correct option?
Users browsing this forum: No registered users and 96 guests
