Hi
can I use CCR1072-1G-8S+ for BGP instead of Cisco ASR 1000?
The Mix technical suggests me Cisco but can we compare it with new ccr mikrotik?
thanks
You would think the software in Cisco's most expensive data center core switches or large service provider routers would be so rock solid that catastrophic bugs couldn't take down an entire data center or service provider core, sadly this isn't the case. The reality is that all network vendors have bugs that must be worked through and there is a definite process you must follow as a network engineer in code selection and testing in your environment if you want to be successful.hardware/software issues relating to random reboots, or locking up
I've been up in the middle of the night to go deal with catastrophic outages due to Cisco bugs twice as often as I do with MikroTik. Take a look at the resolved caveats in the code below to see just how many bugs there really are in code developed by a large network vendor like Cisco.CSCum01502
Symptoms: A Cisco Nexus 7000 Series switch running Cisco NX-OS Release 6.1(1) reboots due to a netstack HAP reset.
Conditions: This symptom has no known triggers.
You're welcome....and certainly 100% uptime is a goal we should all work towards even if it is extremely difficult to achieve.Thanks IPANetEngineer for the comprehensive and reassuring response.
It's nice to see someone with so much experience responding to questions like mine, it's much appreciated.
I've read through a lot of the articles on http://www.stubarea51.net - very awesome site I must say!
I agree with you about 100% uptime, it's not realistic, but it's a goal we set ourselves.
As for features, we have a simple network of BGP & OSPF and use the philosophy of "Simple solutions have simple problems, complex solutions have complex problems".
I been trying to find some documentation on connecting SFP+ uplink to a switch that has a SFP uplink.
So CCR1072-1G-8S+ with SFP+ transceiver -------------- Fiber --------------- HP Switch with SFP transceiver.
In my mind it should be possible the same as it works with ethernet, but would you perhaps be able to confirm this?
No I mean if I have an SFP+ transceiver in the Mikrotik and a normal 1G SFP transceiver in the HP switch, will the link work at 1G? I ask because I would rather populate this unit with the 10G SFP+ modules and when we get around to upgrading some of our older switches, I can order 10G switches.
If you're wanting to connect the CCR1072 via a 10 Gig SFP+ module to an HP switch at 10 gig, then yes it is definitely supported.
I think we were actually using Antaira SFP modules, but any SFP module will work in the CCR series.I assume this was the http://routerboard.com/S-85DLC05D module?
On a side note, I don't suppose you know if the CCR1036 uses ECC ram or not, I know the CCR1072 does?
Hi Normis,CCR1036 uses regular laptop type SODIMM modules. CCR1072 uses soldered-on ECC RAM.
The device itself also must be made to support ECC, so just using ECC modules will not improve anything (except maybe that ECC modules will be higher quality in general).Hi Normis,CCR1036 uses regular laptop type SODIMM modules. CCR1072 uses soldered-on ECC RAM.
Thanks for confirming that. Do you know if the CCR1036 does support ECC ram (if we had to swop the modules out).
Also, I understand the purpose of ECC ram in a server environment, but does ECC ram matter in a network router like the CCR's?
Is there a risk of a CCR1036 catching a wobbly because of a bit-flip because it is not using ECC, or isn't this something we should be concerned about?
-Dave
So would you still recommend the CCR1036's in a data center environment doing bgp/ospf/etc, even though it does not use ECC ram?The device itself also must be made to support ECC, so just using ECC modules will not improve anything (except maybe that ECC modules will be higher quality in general).
Out of curiosity, have you moved on with CCR1072?We are considering buying 2 of these CCR1072-1G-8S+ for our co-location BGP and replace our old servers running vyatta.
I've read through the BGP tests on http://www.stubarea51.net and it looks impressive, my only concern is regarding the reliability and stability of this unit. A number of people have told us to stay away from the CCR's because of hardware/software issues relating to random reboots, or locking up. We need a 100% uptime solution and will run 2 of these, but my questions are:
- How reliable are the CCR units in a co-location environment doing BGP?
- How stable is the RouterOS running on the CCR's?
- How reliable are the Mikrotik SFP modules?
- How are these units as far as uptime goes? Our existing vyatta routers have never crashed in 5 years.
I guess my question is, if we are going to be investing in two CCR1072-1G-8S+ units, am I going to be buying a white elephant that I am going to regret in 6 months to a year's time?
Yes we have, and they working like a boss.Out of curiosity, have you moved on with CCR1072?We are considering buying 2 of these CCR1072-1G-8S+ for our co-location BGP and replace our old servers running vyatta.
