RouterOS 6.33.5 does show the switch menu in Webfig, but I don't see it in the CLI or Winbox. The LCD menu is available in all three interfaces.Hello,
LCD and Switch menu missing... Anyone else have that problem?
Thank you!
p.s. oh, I just saw *) winbox - added LCD menu for RB3011; will be added Switch menu too?
Moreover, there is no MASTER-PORT and BANDWIDTH (RX/TX) drop-down controls in "interfaces" settings (Winbox).Any news about the "Switch" menu in Winbox?
Did not even appear in the latest 6.34rc version.
It is a good hardware, but the external small power adapter, it's a shame.WHY WHY WHY???
No internal PSU???
Thank you MT for WinBox 3.1Hello,
Thank you!
Hello, I didn't be able to repartition my RB3011 with ROS 6.33.5, could you help me? Is this supported function for arm processor? Thank you.Just received two RB3011 and struggling to repartition them to have two partitions.
It accepts the commands either via terminal or winbox, reboots fine but after a reboot there is still only one partition.
Anyone else tried repartitioning?
Download WinBox 3.1The new 6.35 release still hasn't addressed the lack of repartitioning functionality on the RB3011; switch menu is visible in Webfig but not in Winbox, and the master port field is still missing for Ethernet interfaces when using Winbox.
I bet it will require RouterBOOT update and I think it's not high-priority task since almost noone shutdowns routers2. My RB3011 reboots within 30 seconds after trying to shutdown it from Winbox. Anyone who has RB3011, please report do you have such issue or not.
Yes, all RouterBOARDs will do this, it is not a bug per-se, it is more something like unsupported feature. Device needs to be disconnected from power to turn off completely. If you don't unplug it, it will start again. Shutdown command is not required, it is quite safe to just unplug it.My RB3011 reboots within 30 seconds after trying to shutdown it from Winbox
Isn't a shutdown command only useful while running with external storage for e.g. proxy? Cutting power may damage filesystem on it since it's r/w.Shutdown command is not required, it is quite safe to just unplug it.
Before today I always thought that I should and I must shutdown Mikrotik router before unplug power supply (PS).I bet it will require RouterBOOT update and I think it's not high-priority task since almost noone shutdowns routers2. My RB3011 reboots within 30 seconds after trying to shutdown it from Winbox. Anyone who has RB3011, please report do you have such issue or not.
I'm truly interested in your use-case for that.
Hi, if safe why the log complains about impropper shutdown? Maybe the message needs to be changed.Yes, all RouterBOARDs will do this, it is not a bug per-se, it is more something like unsupported feature. Device needs to be disconnected from power to turn off completely. If you don't unplug it, it will start again. Shutdown command is not required, it is quite safe to just unplug it.My RB3011 reboots within 30 seconds after trying to shutdown it from Winbox
Thank you very much for extended explanations. Now I understand.but sudden reboot may be sign for something bad).
So in summary these log entries are to inform about sudden reboots.
Thanks your answer!It has some problems with mysterious false-positive loop detection, but other than that it's good.
Thank you I read this topic. I think even I'm waiting a few months to purchase... This is a new architecture. The Mikrotik still have to work on it.There's a separate topic about that issue: http://forum.mikrotik.com/viewtopic.php?t=104716
I can confirm. I tried with several USB device and does not work on 6.36rc28. All works fine in 6.35.4With the latest software update 6.36rc28 my RB3011 doesn't see any usb devices. With current version it works fine.
I only had an USB2 HDD, got 30mb/s on SMB.Hi,
have anybody tested RB3011UiAS-RM with shared drive connected on USB 3.0 port for SMB or Widows share performance ?
Which speed are you getting ?
No this requires a kernel newer than the 3.3 that RouterOS v6 uses.did the encryption hw acceleration ever get turned on for this model?
We are working on it, yes.But HW acceleration will be supported in the near future?IPsec accelerator support for RB3011 is still being worked on, the HW acceleration is not yet supported for this model. The CPU is much faster than RB2011 even without HW accelerator.
I have RB3011UiAS-RM with CPU Frequency is empty. It's bug or something wrong with my RB?RB3011RESOURCES.jpghow many nand have your rb3011??
After one year what about HW encryption acceleration?IPsec accelerator (HW acceleration) RB3011UiAS-RM ???
Когда, сколько ждать?
When, how long to wait?
