Hi ... I have a SXT LTE and in a certain mobile operator here in Brazil, the equipment does not connect. We already made sure that it operates LTE in band 7, so the equipment is compatible. However, for the internet to work, it is necessary that the connection is roaming and I can not find a way to activate roaming.
Could someone give some hint or solution?
PS: We have tested chips from other operators and the equipment works perfectly.
