Only 1 wAP at the moment for testing purposes. This one is positioned on the jetty in the harbour. I've three other mounting points on the jetty. The setup was originally running 4 Unifi Ubiquiti AP Outdoor https://www.ubnt.com/unifi/unifi-ap-outdoor/ antenna's but the performance is not so good. That is why I replaced one of them with a wAP to build up experience. Those Unifi Ubiquiti are about 450 euro compared to 90 euro for a wAP. And I want to add three to four AP's. This will safe a lot of money. But is the wAP as good as the Unifi UbiquitiHow many wAPs have you deployed? What's the distance between them and the boats? hundreds of meters is not suitable for wAPs, nor is it Omni antennas either.
wAPs are conceived to deploy in high density, tuning down power to provide coverage to nearby customers, without interferring with other nearby wAPs in the same channel; remember there's only 3 non overlapping channels in 2.4GHz spectrum.Why do the AP's need to be a maximum of 50 meters from each other? There are not wireless communicating with each other. All the AP's in the harbour are connected via ethernet cables.
A harbor is a tricky scenario to provide WiFi coverage... you'll had to deploy one wAP, start playing with lowering Tx Power and test actual throughput with an average smartphone in terms of wireless performance (Apple devices aren't) for its effective coverage area (don't rely on the phone's signal levels), then extrapolate for the needed number of wAPs.Would this be a good solution to have a good WIFI coverage? 7 wAP's in the harbour?
Fine, Thank you/system reset-configuration no-defaults=yes
to get no config.
Thanks for your feedback, that is really appreciated.
The area I need to cover is a harbour of about 120 x 260 meters. In the harbour their are a lot of boats (obviously) with masts (sailboats) as wel as metal boats. The requirement is that there is good WIFI reception inside the boat. Cabling is not really an issue, I can relatively simple get cabling at all the different locations in the harbour. Do you have any suggestion on how to approach this challenge?
Regarding the pole construction, I'm aware of picture in the brochure, also I've a wAP under test at the moment. The wAP is connected against the metal pole and I'm afraid that that disturbs the WIFI signal strength. Therefore I was wondering if there is a different construction available, that you can buy, to connect the wAP on a pole without this losing signal problem.
You can create a .rsc file, and select it to be loaded after reset-configuration, e.g (for a dual band wAP ac):Fine, Thank you/system reset-configuration no-defaults=yes
to get no config.
Is there a "system reset-configuration" argument to get the CAP mode ??
/interface wireless cap
set discovery-interfaces=ether1 enabled=yes interfaces=wlan1,wlan2
Yes. You can configure both radios independently.Hi,
can wap ac be used in 5Ghz for client and 2,4 ghz for AP mode ?
Check this wiki page out.I'm looking for a switch POE Gigabit 8/16/24 Port compatible with Wap AC (8 AP).
Thank you!Check this wiki page out.I'm looking for a switch POE Gigabit 8/16/24 Port compatible with Wap AC (8 AP).
Could you update this page accordingly?:af/at/passive are all supported
http://i.mt.lv/routerboard/files/wAP_ac ... 143210.pdf
