I bought a hAP AC on 28th April. On first boot, I failed to login using winbox and ethernet cable (ether1). It shows "downloading plugins..." then it stops right there. I logged in using wireless interface without any issue. I thought it might be a software bug or a problem with the default config. I updated the firmware to the latest, and I updated the RoS to v6.35 and reset with no default config. Still I got the same issue in wired ethernet ports, and now I've no wireless! Because there's no default config now. So, now I've no access to the router anymore!
Then I "netinstall" the router os, and installed RoS v6.35.1 with default config. Then I logged in through wireless interface again. I configured the router by editing default settings without reset. Still I got issues with winbox login through ethernet ports. I use the latest winbox (v.3.4) and I've many other routerboard devices. I can login to those devices without any issue. I got a hAP lite for free in MUM, I've no issues like this with that device too. I tried using different computers.
I decided to try 6.32.4 (Bugfix only) and found that there's not enough space in flash to store that file for ROS upgrade. Is this 16MB a kind of joke? I've netinstall 6.32.4 (Bugfix only), and found nothing changed.
* I found the problem is not only with the ethernet, problem is with the wireless interface too. It often disconnects, I found nothing in router log for the cause of this disconnection.
* I keep backups of my configurations in its' "spacious" 16MB flash, but after every disconnection, I found the backup files are lost!
I suspect the problem is either with the ethernet chip, or for the low storage space. Please help.
