Tonda
CCR-1016-12S-1S+ power supply replacement
Tue May 03, 2016 1:32 pm
Has anybody exchanged failed power supply in CCR-1016-12S-1S+ router? Is it possible to buy this power supply independently?
nz_monkey
Re: CCR-1016-12S-1S+ power supply replacement
Tue May 03, 2016 2:19 pm
We have.
Contact your distributor. They should be able to source a new PSU from Mikrotik.
Tonda
Thu May 12, 2016 10:45 am
Our distributor told me that they have no power sources and do not know whether it is sold separately. So Mikrotik what is supported way of power supply replacement of CCR-1016-12S-1S+? It was very glad to have redundant power supplies but this advantage is immediately lost if I am not able to easily replace faulty power source... I will send info to Mikrotik support.
nz_monkey
Thu May 12, 2016 2:09 pm
Get your distributor to ask Mikrotik directly.
It might not be on the price list but they can get them.
comintech
Thu Oct 27, 2016 10:53 pm
Hi!
Did you find where to buy this power supply from?
Similar situation here, but for CCR-1036-8G-2S+, can not find any replacement. Google found a site in Germany selling same (apparently) module, but I am in USA in a rush for this CCR to be repaired.
Thanks a lot.
savage
Fri Oct 28, 2016 8:11 am
Hi!
Thanks a lot.
Ditto. My distributor does not carry "spares" :shock:
nz_monkey
Fri Oct 28, 2016 11:55 am
We have managed to get replacement PSU's for CCR1016/1036 and for CCR1072 from our Mikrotik distributor.
So they can get them...
savage
Fri Oct 28, 2016 11:57 am
Yes, I'm not disputing that they CAN get them. The point is they WONT get them. Fundamental difference between the two
Murmaider
Sat Oct 29, 2016 6:20 am
Does Miro honestly not stock them? What about Scoop, they sell Mikrotik hardware.
savage
Sat Oct 29, 2016 9:54 am
No, and No.
Scoop pretty much says "Oh it's an internal PSU - we can't do anything" ...
Murmaider
Sun Oct 30, 2016 12:09 am
I wonder if Miro holds the CCR-1072 PSU's since they hotswap?
I guess the only real option is to find an online spares supplier and ship a couple spares to keep on hand.
EDIT : here is one place - http://shop.meconet.de/MikroTik-Router- ... anguage=en
savage
Sun Oct 30, 2016 12:10 am
Ah, but isn't that the distributors job? Then I may just as well stop supporting the distributors and import everything myself...
Murmaider
Sun Oct 30, 2016 12:14 am
Of course it's there job, but now days expecting people to do their job is asking to much.
Users browsing this forum: mstanciu, satman1w, sid5632 and 34 guests
