So here it goes:
I both a 433ah routerboard used, and there was one blown condensator on it, changed it (original values 560uF 6.3v, replaced with 560uF 12v).
When I connect my link everything works fine, after some random time the link is not working (time outing) but the link is still connected, after I disable/enable the interface the link continues to work as it worked before.
Is there somebody with similar issue? Or is there someone who knows how to fix this?
I fixed this temporary with a net watch...but that's not ideal.
My net watch script:
Code: Select all
/interface disable wlan1-link;
:delay 2;
/interface enable wlan1-link;
:log error "===============> WLAN1-link INTERFACE DISABLE-ENABLE <===============";
