ignatius
upgrading
Tue Aug 23, 2016 8:44 pm
Hi, Guy,
i have two rbs (1000&532a) with the version 3.13 and 2.29 , kindly help me upgrade to the most recent version .i dont have NTP Client and NTP Server on one and i download but it not working.
ignatius
Re: upgrading
Tue Aug 23, 2016 8:54 pm
i have download RO 6 but yet when i drag and drop on the packages it show (could not change the key, invalid key) kindly help me upgrade my RO.
thanks
mmv
Trainer
Trainer
Re: upgrading
Tue Aug 23, 2016 9:07 pm
I not sure, allowed upgrade to ROS 6 for such old routers, if not License level reset to 0 (24 hours of uptime demo). Write to support@microtik.com to check or prepare old version npk for downgrade.
In old ROS (before 4.x, may be before 5.x), You need to Drop *.npk to open Files window.
Check, files uploaded in root of Files (not in subfolder if any exists).
mmv
Trainer
Trainer
Re: upgrading
Tue Aug 23, 2016 9:14 pm
Almost miss it. For versions before 3.28 You have 7 signs Siftware-ID.
So You need after upgrade make Update License Key
http://wiki.mikrotik.com/wiki/Manual:Li ... .282009.29
System - License - Update License Key
pe1chl
Re: upgrading
Tue Aug 23, 2016 9:25 pm
Is the version number you mention the firmware version or the RouterOS version?
ignatius
Re: upgrading
Wed Aug 24, 2016 2:39 pm
software ID :9Q5S-PTT
UPGRADE ABLE TO:V4.X
Level :6.
when i fill the software key upgrade:
user:admin
password:no password
server:192.168.2.1
license N level:4
pay method:prepaid keys.
it give me connection failed .
kindly help me out. Thanks
pe1chl
Re: upgrading
Wed Aug 24, 2016 2:57 pm
You need to contact support@mikrotik.com
mmv
Trainer
Trainer
Re: upgrading
Thu Aug 25, 2016 6:12 pm
ROS version of course.
"Update License Key", not "Upgrade|Get New Key..."
and You need Internet connection on PC, because it online action.
According to Your license information, Your router can be upgraded to latest ROS v4.
As I mention before. Contact support@mikrotik.com with supout.rif to better help.
novelty22
Re: upgrading
Thu Aug 25, 2016 8:00 pm
thanks
On older router OS versions (4.x and below), make sure you actually drag the .npk file into the "Files" dialog box, or you will get this message
ignatius
Re: upgrading
Thu Aug 25, 2016 8:05 pm
how to install RbOs using netinstall , how can I installed a v6 into my Rb1000.
Users browsing this forum: No registered users and 24 guests
