Hello folks!
What HW should I buy for covering my needs? Can't decide between RB or CRS series. I will have 300/300 from my ISP. NOT PPoE. Static IP.
Currently I am using some shitty TPLINK 4 port router and simple switch. I need to hook up my current devices (10) by wire connection. And up to 8 by wireless. Area to cover by wireless is about 180 M2.
I want to try wap AC. I plan to use only AC, not N standard. I think I will need 2 of these devices to cover my needs. But can't decide what should be my primary (main) board. Should it be something like RB3011 or CRS125-24G. By reading this forum and device specification I understand that CRS is just LEVEL 3 switch with routing capabilities, while RB series is pure router boards. Is it so?
Some of my wire devices will not be connected to Internet. For example two NAS stations. I need to achive maximum throughput between them.
What is best solution for home use from your point of view?
Thanks, Dmitrijs
