Gerard
Trainer
Trainer
RB600 Released
Wed Nov 28, 2007 4:48 pm
Mikrotik announced the RB600 to distributors this morning.
CPU MPC8343E 266/400MHz network processor
Memory 64MB DDR SDRAM onboard memory
Boot loader RouterBOOT, 1Mbit Flash chip
Data storage 64MB onboard NAND memory chip
Ethernet Three 10/100/1000 Mbit/s Gigabit Ethernet with Auto-MDI/X
miniPCI Four MiniPCI Type IIIA/IIIB slots
Expansion Daughterboard support, including RB500 daughterboards
Compact Flash Two independent CompactFlash slots (TrueIDE Microdrive supported)
Serial port One DB9 RS232C asynchronous serial port
Speaker Mini PC-Speaker
Power options IEEE802.3af PoE: 38..56V DC including over datalines.
Power jack: 10..56V DC
Fan control Two 5V DC fan power output headers with rotation sensor and automatic
fan switching (maximum output current - 300mA total)
Dimensions 14 cm x 20 cm (5.51 in x 7.87 in), 227 g (8 oz)
Power consumption ~9W without extension cards, maximum – 35+ W
Operating System MikroTik RouterOS v3, Level4 license
Brochure: http://www.quicklinkwireless.com/rb600.pdf
Pre-Order: https://www.quicklinkwireless.com/default.asp?pid=1185
We would also like to inform you that the manufacturing of RB532 (32MB RAM) has been discontinued and this model of RouterBOARD is not available anymore.
-Gerard
Edit: Only the RB532(with 32MB RAM) has been discontinued. The RB532A(with 64MB RAM) will continue to be manufactured.
roadrunner
Re: RB600 Released
Thu Nov 29, 2007 3:41 am
So 802.3af is supported again after the rb192,rb133/c & rb333 not supporting more than 28v. :shock:
And it doesn't support less than 38V on POE? I'm not going to be able to standardize on one power supply ever again :?
Hopefully the Gigabit ports are more stable than the ones on the rb44G.
doush
Long time Member
Long time Member
Re: RB600 Released
Thu Nov 29, 2007 1:17 pm
impressive..
It would be good for them to support 2.9x instead of only 3.0 .. im scared to give the new ros 3.0 a try after the bugs i read on the forum..
Nevertheless, 4mpci and 400mhz rocks...
ghmorris
Re: RB600 Released
Thu Nov 29, 2007 2:31 pm
PowerPC architecture so will never be supported under 2.9.
I'm very pleased to see full 802.3af support, now we should be able to pull power from an 802.3af switch. Well done MT!!
George
ste
Re: RB600 Released
Thu Nov 29, 2007 3:09 pm
I'm wondering wether 4 cards on one board in one housing can
work without interfering each other.
RB600 would give the possibility to handle one uplink and
3 120degree sectors in one box.
Does this make sense using 5GHz?
Stefan
miahac
Long time Member
Long time Member
Re: RB600 Released
Thu Nov 29, 2007 5:03 pm
The IEEE 802.3af standard supports delivery of Power over Ethernet up to 15.4W per port that may be used to deliver power to a variety of devices (figure 1.) The IEEE 802.3af standard also defines the concept of power classes including a reserved class that may be extended to support increased power delivery to PDs in the future. As an example, this class may be expanded to support the power requirements of a laptop PC that typically draws much more than the 15.4W currently allowed for within IEEE 802.3af.
So your POE switch may not be able to power this device.
BurstNET
Re: RB600 Released
Sun Dec 02, 2007 4:19 am
Not happy they are discontinuing RB532 because of this.
Atleast give us 6 months of a known working product before such is done.
Right now we don't have a replacement for RB532 that is 100% tried and true in the field :-(
RB333 and RB600 are NOT at that point yet.
SMA
Gerard
Trainer
Trainer
Re: RB600 Released
Sun Dec 02, 2007 6:06 am
They only discontinued the RB532 and not the RB532A.
-Gerard
BurstNET
Re: RB600 Released
Sun Dec 02, 2007 3:39 pm
<< They only discontinued the RB532 and not the RB532A. >>
Oh...good...whew... :-)
Thanx...
SMA
phendry
Re: RB600 Released
Mon Dec 03, 2007 10:12 pm
Even so it would still make sense that as these new boards are V3 only that they didn't discontinue products that work in favour of ones that are still at an RC stage.
Hellbound
Long time Member
Long time Member
Re: RB600 Released
Tue Dec 04, 2007 5:05 am
shame,
look what froogle brings for rb600
http://www.google.com/products?q=rb600
danletkeman
Re: RB600 Released
Tue Dec 18, 2007 6:54 am
What happened to the 600-666mhz cpu? Will using this board for a wireless bridge actually be better than a 532?
normis
Re: RB600 Released
Tue Dec 18, 2007 9:57 am
of course it will be. compare throughput:
http://www.routerboard.com/pdf/tests_dec_2007.pdf
kapusta_kiszona
Re: RB600 Released
Wed Dec 19, 2007 1:00 am
Well. I'll tomorrow install my first RB600 in a important location, where was 532 before. Wish me luck. :-)
Hammy
Forum Veteran
Forum Veteran
Re: RB600 Released
Sat Dec 22, 2007 5:45 pm
What do those numbers indicate? pps? mbit/s?
Hellbound
Long time Member
Long time Member
Re: RB600 Released
Sat Dec 22, 2007 6:26 pm
that is pps , u have to calculate mbit... I wonder why!
janisk
Re: RB600 Released
Fri Dec 28, 2007 4:36 pm
because of test method, we get test resaults in pps, so we post them as is.
Giepie
Re: RB600 Released
Fri Jan 25, 2008 3:35 am
Hi all
This is perhaps off topic, but I decided to ask anyway due to the fact that the RB600 specs are being discussed over here.
What I need to know, is wheter you can install MT on a CF using the RB600. I have tried this with an RB532A, it didn't work, I contacted MT support and they said it won't, as the board was designed in such a way that MTROS can only be run from the NAND.
What I ideally would like to do, is to install MTv3.1 level6 on a CF, and use the second CF slot for Usermanager data. The main and most important reason for this is in order to run the UM off a 12VDC battery backup.
Our South African power provider ran into magor problems and apparently we'll have to live with these problems for years to come. Some days we have power outages for 2 to 4 hours in one go, usually at the peak hours for business. Our entire system is on battery backup, highsites, core routers, switches, PSTN routers etc, only UM is not.
Any help on this will be appreciated.
Regards, Giepie
normis
Re: RB600 Released
Fri Jan 25, 2008 9:06 am
no, RouterOS can only be installed on a NAND
changeip
Re: RB600 Released
Fri Jan 25, 2008 9:09 am
NAND and CF take about the same amount of power I am guessing... and neither of those take power directly, it's the routerboard itself. Whats the goal ?
Giepie
Re: RB600 Released
Fri Jan 25, 2008 10:17 am
Hi changeip
The point is not what uses less power, I just mentioned my reason for wanting to run UM off a RB and not on a PC.
1) I need to have UM running off a RB600 - (for power backup reasons. RB run off 12VDC, Desktop PC does not)
2) I need to have MT/UM running off a CF - (NAND does not have enough space for user DB and logs)
So my question is, WILL MT RUN OFF A CF ON A RB600?
Like I said, with RB532/A it does NOT work.
Thanks for the help!
G
normis
Re: RB600 Released
Fri Jan 25, 2008 10:52 am
we will make it possible to store UM DB and other data on the CF. booting from it will not be possible
Giepie
Re: RB600 Released
Fri Jan 25, 2008 10:57 am
Hi Normis
Thanks for the info.
I was really hoping it might work with the new ROS.
Could you perhaps tell me by which version it would be possible to save UM DB to CF?
heiko_s
Re: RB600 Released
Fri Jun 20, 2008 11:16 pm
i'm also looking foreward of storing the UM database on a CF card.
Is it already possible?
Or, if not, when will it be?
Thanks in advance
Heiko
Giepie
Re: RB600 Released
Fri Jun 20, 2008 11:28 pm
Hi Heiko
You should perhaps follow this thread too:
http://forum.mikrotik.com/viewtopic.php ... 59#p118659
Apparently the new UM would have many new features, but it sounds like it has more to do with the GUI.
Mikrotik really like keeping us in despense! :) At least they never dissapoint us!
heiko_s
Re: RB600 Released
Sat Jun 21, 2008 12:08 am
Hi Giepie,
Thanks for the tip ;o)
the only thing i really suffer from is the small harddisk-space and the missing feature to store the database and the logs on a CF card.
Good night 8)
Giepie
Re: RB600 Released
Sat Jun 21, 2008 2:23 am
Aparently one of the new features of the new UM is to save your DB to another drive. I honestly can't wait!
G
heiko_s
Re: RB600 Released
Sat Jun 21, 2008 10:15 am
Hi "G" ;o)
...but you either don't know in which decade the new version will be released, don't you?
I too a look on the RadMan. apart from their strict licensing and the encrypted php code, it has not alle the features UM has. Not forget the great advantage to run UM from a powersaving RouterBoard.. 8)
All we can do is "sit'n'wait" 8)
Have a nice time!
Regards
"H"
:D
Users browsing this forum: timotei and 31 guests
