hi,
we got a RB600 for testing and have some problems which seem to be temperature related. the RB works fine on the bench without much load and only configuring via winbox or terminal. as soon as i put it in an operation environment and use 3 radios and 1 ethernet port with a total throughput of about 15-20 mbit/s i get sudden reboots every 5 minutes. after trying different power supply's and different voltages and also trying POE rather than power jack i have reduced the cpu to 266MHz. i got an uptime of about 10 minutes and then sudden reboot. next step was then to open the original RB600 indoor case and putting a fan beside it. i now got uptimes of about 30 minutes before it would just reboot. i have tried ROS 3.1, 3.2 and 3.3. the version makes no difference.
does anybody have similar experience with the RB600 ? how the hell can it be made stable ?
radios in use are 4 R52 if which one is disabled. case as mentioned before the original RB600 indoor case.
regards
Jan
