helmyaja
Reset RB-411 OS Level 4
Tue May 06, 2008 6:55 am
can anybody help me??i can't use reset button on rb-411... :cry: :cry:
normis
Re: Reset RB-411 OS Level 4
Tue May 06, 2008 9:15 am
the reset button is for backup loader (something like a BIOS). if you need to reload the OS config, you have to use the jumper hole.
LZiX
Mon Jun 29, 2009 8:56 am
How time need use this contacts ? I press before poweron and unpress after loading but board not reset.
normis
Mon Jun 29, 2009 9:10 am
you need to hold until hear beep, or software starts. if not reset, you might be doing something incorrectly. make sure you are using a metal object
LZiX
Mon Jun 29, 2009 10:11 am
Thank you, I try again and reset unit done.
saeedagha
Fri Dec 10, 2010 10:03 am
I have tried this many times, but it doesn't work! what the problem is? should it be connected to network or not? what about connecting and disconnecting the power during the reset process?
saeedagha
Fri Dec 10, 2010 10:11 am
Does it reset the IP address too? because I can't access to my Routerboard neither via winbox nor the telnet. what should I do?
normis
Fri Dec 10, 2010 10:13 am
use the Winbox loader to connect with MAC address, see this page:
http://wiki.mikrotik.com/wiki/Manual:First_time_startup
janisk
Fri Dec 10, 2010 11:12 am
without any parameters /system reset-configuration will save current config in backup file, remove everything, and if present, set up defaults (can be changed using netinstall whilst reinstalling RouterOS)
So, if router does not have that default - it is completely blank and only possible way to connect to router is: mac access using winbox, mac-telnet
riaanp
Mon Dec 07, 2015 3:59 pm
Hi there,
I'm stuggling with the same problem. I cannot reset an RB411AH.
I am using a metal screwdriver
It does touch both contacts
I have tried several things in the bridging of the 2 connections:
1) Power on, bridged, until the 1st beep
2) Power on, bridged, until the 2nd double beep
3) Power on, bridged, half way between the 2 sets of beeps
4) Power on, bridged, for a minute
System does not reset.
Please assist
hnoor0077
Sat Apr 30, 2016 1:44 pm
I have tried this many times, but it doesn't work! what the problem is?????
Users browsing this forum: No registered users and 95 guests
